EC9BW-24S15
EC9BW-24S15
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 15V 2A 9V - 36V 输入
EC9BW-24S15 数据手册
V15 EC9BW SERIES 30 WATT 4:1 INPUT DC-DC CONVERTERS ︳ FEATURES * 30W Isolated Output * Efficiency to 92% * 2’’x1’’ Six-Sided Shield Metal Case * 4:1 Input Range * Regulated Outputs * Fixed Switching Frequency * Input Under Voltage Protection * Over Current Protection * Remote On/Off * Continuous Short Circuit Protection * No Tantalum Capacitor Inside * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT OUTPUT VOLTAGE VOLTAGE OUTPUT CURRENT INPUT CURRENT % EFF. MIN. MAX. NO LOAD FULL LOAD (2) 3.3 VDC 0 mA 7500 mA 100 mA 1172 mA 88 EC9BW-24S33 9-36 VDC EC9BW-24S05 9-36 VDC 5 VDC 0 mA 6000 mA 110 mA EC9BW-24S12 9-36 VDC 12 VDC 0 mA 2500 mA 50 mA 1397 mA 1374 mA EC9BW-24S15 9-36 VDC 15 VDC 0 mA 2000 mA 50 mA EC9BW-24D12 9-36 VDC ±12 VDC 0 mA ±1250 mA EC9BW-24D15 9-36 VDC ±15 VDC 0 mA EC9BW-48S33 18-75 VDC 3.3 VDC EC9BW-48S05 18-75 VDC 5 VDC EC9BW-48S12 18-75 VDC CAPACITOR (3) LOAD MAX. 88.5 7500µF 89.5 89.5 91 90.5 6000µF 2500µF 1374 mA 91 90.5 2000µF 60 mA 1374 mA 91 90.5 1250µF ±1000 mA 60 mA 1359 mA 92 91 1000µF 0 mA 7500 mA 50 mA 593 mA 87 87.5 7500µF 0 mA 6000 mA 50 mA 89.5 90 12 VDC 0 mA 2500 mA 30 mA 694 mA 683 mA 91.5 90 6000µF 2500µF EC9BW-48S15 18-75 VDC 15 VDC 0 mA 2000 mA 30 mA 679 mA 92 91 2000µF EC9BW-48D12 18-75 VDC ±12 VDC 0 mA ±1250m A 40 mA 683 mA 40 mA 679 mA EC9BW-48D15 18-75 VDC ±15 VDC 0 mA ±1000m A NOTE: 1. Nominal Input Voltage 24 or 48 VDC 2. Measured at 12VDC for 24Vin, 24VDC for 48Vin 3. Measured at Nominal Input Voltage 1 91.5 90.5 92 91 1250µF 1000µF V15 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....……………..............…. 24VDC ................ 9 – 36VDC 48VDC ….……. 18 – 75VDC Input Surge Voltage (100ms max.) ………….. 24VDC ..…....... 50VDC max. 48VDC …..... 100VDC max. Under Voltage Lockout …………….. 24Vin Power Up .…….……. 8.8VDC typ. 24Vin Power Down ….……. 8.0VDC typ. 48Vin Power Up …….....….. 17VDC typ. 48Vin Power Down ……....... 16VDC typ. Input Filter …………………………………………..……….……………. PI Type Positive Logic Remote on/off Control (note3&4) Efficiency ............................................…..……..………............ See Table Isolation Voltage ….............................…...…………...... 1500 VDC min. Isolation Resistance …..................…….……………..…… 109 ohm min. Isolation Capacitance …………………..……………….…… 1000pF typ. Switching Frequency ............................……...................... 430KHz typ. EMI/RFI ………………………………….…. Six-Sided Continuous Shield OUTPUT SPECIFICATIONS: Storage Temperature Range ...……..........……....…....... -55℃ to +125℃ Thermal Shutdown, Case Temp. .………….....................……. 110℃ typ. Humidity ................................................. 95% RH max. Non-Condensing Voltage Accuracy ………………....………...……….......…………… ±1% max. Voltage Balance (Dual) …….…..…………..……………………….…. ±1% max. Transient Response: 75% - 100% Step Load Change Error Band ………… ±5% Vout Nominal, Recovery Time ….…... 3.5VDC to 75VDC or open circuit Module off …………………..……………….………. 0 to
EC9BW-24S15 价格&库存
很抱歉,暂时无法提供与“EC9BW-24S15”相匹配的价格&库存,您可以联系我们找货
