EC3AE24M
EC3AE24M
    CINCON
    DIP12 模块
    隔离模块 直流转换器 2 输出 12V -12V 125mA,125mA 21.6V - 26.4V 输入
EC3AE24M 数据手册
V12 EC3AE SERIES ︳ 3 WATT DC-DC CONVERTERS FEATURES * 3W Isolated Output * DIP-24/SMD Package * Efficiency to 61% * Regulated Outputs * LC Input Filter * Low Ripple and Noise INPUT CURRENT MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE OUTPUT CURRENT NO LOAD EC3AE01M EC3AE02M EC3AE03M EC3AE04M EC3AE05M EC3AE11M EC3AE12M EC3AE13M EC3AE14M EC3AE15M EC3AE21M EC3AE22M EC3AE23M EC3AE24M EC3AE25M EC3AE31M EC3AE32M EC3AE33M EC3AE34M EC3AE35M EC3AE41M EC3AE42M EC3AE43M EC3AE44M EC3AE45M 5 VDC 5 VDC 5 VDC 5 VDC 5 VDC 12 VDC 12 VDC 12 VDC 12 VDC 12 VDC 24 VDC 24 VDC 24 VDC 24 VDC 24 VDC 28 VDC 28 VDC 28 VDC 28 VDC 28 VDC 48 VDC 48 VDC 48 VDC 48 VDC 48 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 600 mA 250 mA 200 mA ±125 mA ±100 mA 600 mA 250 mA 200 mA ±125 mA ±100 mA 600 mA 250 mA 200 mA ±125 mA ±100 mA 600 mA 250 mA 200 mA ±125 mA ±100 mA 600 mA 250 mA 200 mA ±125 mA ±100 mA 120 mA 120 mA 120 mA 120 mA 120 mA 60 mA 60 mA 60 mA 60 mA 60 mA 40 mA 40 mA 40 mA 40 mA 40 mA 35 mA 35 mA 35 mA 35 mA 35 mA 20 mA 20 mA 20 mA 20 mA 20 mA 1 % CASE EFF. FULL LOAD 984 mA 984 mA 984 mA 984 mA 984 mA 410 mA 410 mA 410 mA 410 mA 410 mA 205 mA 205 mA 205 mA 205 mA 205 mA 176 mA 176 mA 176 mA 176 mA 176 mA 102 mA 102 mA 102 mA 102 mA 102 mA 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 V12 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: ISOLATION VOLTAGE: Input Voltage Range ....……………..........…........................................... ±10% 500 VDC min. …………………………………………… Standard Models Input Filter ………………………………………………….…………..... LC Type CASE MATERIAL: OUTPUT SPECIFICATIONS: Standard Models …… Black Coated Copper with Non-conductive Base Voltage Accuracy ……………....................................….….......... ±3.0% max. NOTE: Temperature Coefficient …………………………………………… ±0.02%/℃ Ripple & Noise, 20MHz BW …………..………………...……. 50mV pk-pk max. Short Circuit Protection ……………………………… Indefinite & Current Limit Line Regulation (note 1) …….…………………...........................…±0.3% max. Load Regulation (note 2) Single ……….…….…….......…...... ±0.5% max. Dual ……….………………………… ±1.0% max. 1. Measured from high line to low line. 2. Measured from full load to 10% load. 3. Suffix “S” to the model number with SMD packages. 4. Maximum case temperature under any operating condition should not be exceeded 100℃. GENERAL SPECIFICATIONS: Typical Derating curve for Natural Convection 120% 71 -25 100% LOAD(%) Efficiency .......................................................................................... See Table Isolation Capacitance ..................................................................... 150pF typ. 9 Isolation Resistance .....................................................…..… 10 ohm min. Switching Frequency ........................................................... 80KHz typ. Operating Ambient Temperature Range .................................. -25℃ to +71℃ De-rating, Above 71℃ …………………… Linearly to Zero power at 100℃ Case Temperature (note 4) ........................................................ 100℃ max. Cooling ……………………………………………….. Natural Convection Storage Temperature Range ………....….......……........ -40℃ to +100℃ Dimensions …… DIP ….….… 1.25x0.80x0.40 inches(31.8x20.3x10.2 mm) SMD ………… 1.25x0.80x0.45 inches(31.8x20.3x11.4 mm) Weight …………………………………………………………………... 17.2g 80% 60% Natural Convection 40% 20% 100 0% -25 Case A Dimensions: 0 25 50 75 Ambient Temperature(oC) NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm) DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 CASE AS PIN CONNECTION 500 VDC Pin SEE NOTE TOP VIEW BOTTOM VIEW Single Output DIP SMD Dual Output DIP 1,24 +V Input SMD +V Input 2,23 NC -V Output 3,22 NC Common 4,5 NP NC NP NC 9 NP NC NP NC 10,15 -V Output Common 11,14 +V Output +V Output 12,13 -V Input -V Input 16 NP NC NP NC 20,21 NP NC NP NC * NC-NO CONNECTION WITH PIN * NP-No PIN 2 100
EC3AE24M 价格&库存
很抱歉,暂时无法提供与“EC3AE24M”相匹配的价格&库存,您可以联系我们找货
