EC3AB27
EC3AB27
    CINCON
    DIP14 模块
    隔离模块 直流转换器 1 输出 3.3V 600mA 18V - 36V 输入
EC3AB27 数据手册
V16 EC3AB SERIES ︳ 3 WATT 2:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 3W Isolated Output * DIP-24/SMD Package * Efficiency to 80% * Regulated Outputs * Pi Input Filter * Continuous Short Circuit Protection * Meets EN55032 Class B Conducted * Remote On/Off (Option) * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER(1) INPUT VOLTAGE(2) OUTPUT VOLTAGE OUTPUT CURRENT EC3AB11□ EC3AB12□ EC3AB13□ EC3AB14□ EC3AB15□ EC3AB16□ EC3AB17□ EC3AB21□ EC3AB22□ EC3AB23□ EC3AB24□ EC3AB25□ EC3AB26□ EC3AB27□ EC3AB31□ EC3AB32□ EC3AB33□ EC3AB34□ EC3AB35□ EC3AB36□ EC3AB37□ 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 600 mA 250 mA 200 mA ±300 mA ±125 mA ±100 mA 600 mA 600 mA 250 mA 200 mA ±300 mA ±125 mA ±100 mA 600 mA 600 mA 250 mA 200 mA ±300 mA ±125 mA ±100 mA 600 mA NOTE: 1. □ Can be None, M, H, HM, MS, HMS, HT, HMT or HMTS. 2. Nominal Input Voltage 12, 24 or 48 VDC 3. Typical Value at Nominal Input Voltage and Full Load 1 INPUT CURRENT NO LOAD 7.5 mA 7.5 mA 7.5 mA 12 mA 12 mA 12 mA 7.5 mA 5 mA 5 mA 5 mA 7.5 mA 7.5 mA 7.5 mA 5 mA 2 mA 2 mA 2 mA 3 mA 3 mA 3 mA 3 mA FULL LOAD 329 mA 316 mA 321 mA 329 mA 325 mA 329 mA 229 mA 162 mA 156 mA 156 mA 164 mA 156 mA 162 mA 111 mA 81 mA 81 mA 81 mA 80 mA 82 mA 82 mA 58 mA % EFF.(3) CASE 76 79 78 76 77 76 72 77 80 80 76 80 77 74 77 77 77 78 76 76 71 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 V16 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: ISOLATION VOLTAGE: Input Voltage Range ....……………..........….......... 12V ........................ 9-18V 24V ...................... 18-36V 48V ...................... 36-72V 500 VDC min. …………………………………………… Standard Models 3K VDC min. (note4) …………………………………… Suffix “H” Models 1.5K VDC min. ………………………………………… Suffix “HM” Models Positive Logic Remote On/Off (See note6) CASE MATERIAL: Input Filter ………………………………………………….…….……..... Pi Type Standard Models ………………………… Non-Conductive Black Plastic OUTPUT SPECIFICATIONS: Suffix “M” Models ……. Black Coated Copper with Non-Conductive Base Voltage Accuracy .......................................................................... ±2.0% max. NOTE: Voltage Balance (Dual) .................................................................. ±1.0% max. Temperature Coefficient ……….……………………………… ±0.05%/℃ max. Ripple & Noise, 20MHz BW …………….… 3.3V/5V ……. 100mV pk-pk max. 12V/15V ……...… 1% pk-pk max. Short Circuit Protection ……………………………………………… Continuous Line Regulation Single/Dual (note1) …….………………….........…±0.5% max. Load Regulation (note2) Single ………………….......……….... ±0.5% max. Dual (note3) ………………………… ±1.0% max. 1. Measured from high line to low line. 2. Measured from full load to 10% load. 3. Measured from full load to 1/4 load. 4. Non-conductive black plastic only. 5. Suffix “T” to the model number with remote on/off for “H”/”HM” versions only. 6. Logic Compatibility …. CMOS or open collector TTL, ref. to -Vin Module on ………………...……..……… >5.5VDC or open circuit GENERAL SPECIFICATIONS: Module off ….………………..……….……………. 0 to
EC3AB27
物料型号: - 系列名称:EC3AB - 型号示例:EC3AB11, EC3AB12, EC3AB13等,分别对应不同的输入电压和输出电压。
器件简介: - 这些转换器提供3瓦的隔离输出,具有DIP-24或SMD封装。 - 效率高达80%,具有Pi型输入滤波器。 - 具有连续短路保护,符合EN55032 B级传导要求。 - 可选的远程开/关功能,安全标准符合IEC/EN/UL 62368-1。
引脚分配: - 引脚1和24为+V输入,引脚2和23为-V输出,引脚3和22为公共地。 - 引脚11和14为+V输出,引脚10和15为-V输出。 - 引脚16为-V输出,引脚20和21为公共地。
参数特性: - 输入电压范围:9-18VDC, 18-36VDC, 36-72VDC。 - 输出电压:5VDC, 12VDC, 15VDC, ±5VDC, ±12VDC, ±15VDC, 3.3VDC。 - 输出电流:从100mA到600mA不等。 - 效率:在71%到81%之间。 - 隔离电压:标准型号至少500VDC,带“H”后缀的型号至少3KVDC,带“HM”后缀的型号至少1.5KVDC。
功能详解: - 这些转换器具有电压精度±2.0%,电压平衡±1.0%,温度系数±0.05%/℃。 - 纹波和噪声:3.3V/5V最大100mV峰-峰,12V/15V最大1%峰-峰。 - 具有连续短路保护功能。
应用信息: - 适用于需要高效率和隔离保护的DC-DC转换应用。
封装信息: - 提供DIP-24和SMD封装选项,尺寸分别为1.25x0.80x0.50英寸(31.8x20.3×12.7毫米)和1.25x0.80x0.55英寸(31.8x20.3×14.0毫米)。
EC3AB27 价格&库存
很抱歉,暂时无法提供与“EC3AB27”相匹配的价格&库存,您可以联系我们找货
