V11
EC4A-E SERIES
5-6 WATT 2:1 INPUT RANGE
DC-DC CONVERTERS
FEATURES
* 5-6W Isolated Output
* 24-Pin DIP Package
* Efficiency to 87%
* 2:1 Input Range
* Regulated Outputs
* Pi Input Filter
* Continuous Short Circuit Protection
* Meet EMI EN55032 Class A
* No Tantalum Capacitor inside
* Wide Operating Temperature Range
* UL60950-1 Approval
* Safety Meets IEC/EN/UL 62368-1
MODEL
NUMBER(1)
INPUT
VOLTAGE(2)
OUTPUT
VOLTAGE
OUTPUT
CURRENT
EC4A01□-E
EC4A02□-E
EC4A03□-E
EC4A04□-E
EC4A05□-E
EC4A06□-E
EC4A07□-E
EC4A11□-E
EC4A12□-E
EC4A13□-E
EC4A14□-E
EC4A15□-E
EC4A16□-E
EC4A17□-E
EC4A21□-E
EC4A22□-E
EC4A23□-E
EC4A24□-E
EC4A25□-E
EC4A26□-E
EC4A27□-E
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
5 VDC
12 VDC
15 VDC
±12 VDC
±15 VDC
±5 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±12 VDC
±15 VDC
±5 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±12 VDC
±15 VDC
±5 VDC
3.3 VDC
1000 mA
500 mA
400 mA
±250 mA
±200 mA
±500 mA
1200 mA
1000 mA
500 mA
400 mA
±250 mA
±200 mA
±500 mA
1200 mA
1000 mA
500 mA
400 mA
±250 mA
±200 mA
±500 mA
1200 mA
NOTE:
1. □ can be none, M, H, HM, S, MS, HS or HMS.
2. Nominal Input Voltage is 12, 24 or 48 VDC.
3. Typical Value at Nominal Input Voltage and Full Load.
1
INPUT CURRENT
% EFF.(3)
NO LOAD FULL LOAD
7.5 mA
514 mA
81
10 mA
595 mA
84
15 mA
588 mA
85
12 mA
588 mA
85
18 mA
588 mA
85
12 mA
514 mA
81
7.5 mA
429 mA
77
5 mA
251 mA
83
8 mA
291 mA
86
8 mA
287 mA
87
8 mA
291 mA
86
10 mA
287 mA
87
8 mA
254 mA
82
5 mA
209 mA
79
3 mA
126 mA
83
6 mA
144 mA
87
6 mA
144 mA
87
6 mA
144 mA
87
6 mA
144 mA
87
5 mA
126 mA
83
2 mA
104 mA
79
CAPACITOR
LOAD MAX.
4700uF
4700uF
4700uF
2200uF
2200uF
2200uF
4700uF
4700uF
4700uF
4700uF
2200uF
2200uF
2200uF
4700uF
4700uF
4700uF
4700uF
2200uF
2200uF
2200uF
4700uF
V11
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....…………..........….... 12V ................................ 9-18V
24V ............................ 18-36V
48V ............................ 36-72V
Input Surge Voltage (100ms max.) ………… 12V ….….….......... 25Vdc max.
24V ....................... 50Vdc max.
48V ..................... 100Vdc max.
Under Voltage Lockout …………… 12V power up .…..……......... 8.8Vdc
12V power down …………...... 8Vdc
24V power Up ….…………........ 17Vdc
24V power down …………….... 16Vdc
48V power up ….………........... 34Vdc
48V power down ………........... 31Vdc
Efficiency ................................................................................. See Table
Isolation Voltage:
500 VDC min. ………….…………………………… Standard Models
3K VDC min. ... (Non-Conductive Black Plastic Only) …… Suffix “H” Models
1.5K VDC min. ………….………………………… Suffix “HM” Models
Isolation Resistance .....................................................…… 109 ohm min.
Isolation Capacitance ……………………..………….………… 250pF typ.
Switching Frequency ........................................................... 100KHz min.
Operating Ambient Temperature Range .......................... -40℃ to +85℃
De-rating, Above 80℃ ………………… Linearly to Zero Power at 100℃
Case Temperature …………………………………………….. 100℃ max.
Cooling ……………………………………………….. Natural Convection
OUTPUT SPECIFICATIONS:
Storage Temperature Range ………....….......……........ -40℃ to +100℃
Voltage Accuracy .......................................................................... ±1.5% max.
Voltage Balance (Dual) .................................................................. ±1.0% max.
Temperature Coefficient ………………………………………… ±0.05%/℃ max.
Ripple & Noise, 20MHz BW (note5) ……. 3.3V/5V ….…. 100mV pk-pk, max
12V/15V ……….. 1% pk-pk max.
Short Circuit Protection ……………………………………………… Continuous
Line Regulation ……...… Single/Dual (note1) ….……………. ±0.5% max.
Load Regulation …….… Single (note2) ..….…......……….... ±0.5% max.
Dual (note3) ……….………………… ±1.0% max.
Start up Time …………………………………….………………..…... 5 ms max.
EMI …………………………….. Conductive EMI Meet EN55032 Class A
Humidity ................................................. 95% RH max. Non Condensing
MTBF ………. MIL-HDBK-217F ..……..……………………1800Khrs typ.
Dimensions …….. DIP ..… 1.25×0.80x0.40 inches (31.8x20.3×10.2 mm)
MS/HMS Models … 1.25×0.80x0.45 inches (31.8x20.3×11.4 mm)
S/HS Models ……. 1.25×0.80x0.41 inches (31.8x20.3×10.4 mm)
Case Material:
Standard Models ………….…………… Non-Conductive Black Plastic
Suffix “M” Models … Black Coated Copper with Non-Conductive Base
Suffix “S” Models …….……………………..…………… SMD Package
Weight …………………………………………………………………... 12.5g
NOTE:
1. Measured from high line to low line.
2. Measured from full load to 10% load.
3. Measured from full load to 1/4 load.
4. Maximum case temperature under any operating condition should
not exceed 100℃.
5. The output noise is measured with 0.1uF MLCC across for SMD package.
Figure1.Typical Derating curve for Natural Convection
120%
LOAD(%)
80
-40
100%
80%
60%
Natural Convection
40%
20%
100
0%
-40
Case A Dimensions:
-20
60
Ambient Temperature(oC)
80
100
BOTTOM VIEW
0.08
[2.0]
CASE AS
PIN CONNECTION
TOP VIEW
500 VDC
SEE NOTE
Pin
1.25
[31.8]
16
9
15
10
14
11
13
12
0.600
[15.24]
0.80
[20.3]
0.04
[1.0]
0.02
[0.5]
0.15
[3.8]
0.40
[10.2]
0.08
[2.0]
+V Input
2,23
NC
-V Output
2,3
Common
4,5
NC
1.25
[31.8]
*0.41(10.4) for S/HS Models
2
NP
NC
NP
1,24
NC
9
Single Output
SMD
DIP
SMD
NP
NC
NP
NC
-V Input
NP
NC
NC
5
NP
NC
NP
NC
10,15
NC
NP
NC
NP
NC
11
NC
10,15
-V Output
Common
12,13
11,14
+V Output
+V Output
14
-V Input
-V Input
16
16
NP
NC
NP
NC
20,21
20,21
NP
NC
NP
NC
22,23
* NP-NO PIN
* NC-NO CONNECTION WITH PIN
Dual Output
DIP
9
12,13
0.100
[2.54]
Pin
DIP
1,24
4
SMD
1.5K & 3K VDC
Dual Output
SMD
+V Input
3,22
0.45*
[11.4]
3
0.43
[10.9]
22
DIP
0.80
[20.3]
23
2
1.00
[25.4]
1
0.100
[2.54]
24
Single Output
NP
NP
NC
Common
NC
-V Output
NC
+V Output
-V Output
NP
-V Input
NC
+V Input
NP
NC
+V Output
Common
NP
NC
+V Input
NOTE:Pin Size is 0.02 ±0.002 Inch (0.5±0.05 mm)DIA
All Dimensions In Inches (mm)
Tolerances
Inches: X.XX= ±0.02 , X.XXX= ±0.010
Millimeters: X.X= ±0.5 , X.XX=±0.25
很抱歉,暂时无法提供与“EC4A16H-E”相匹配的价格&库存,您可以联系我们找货
