EC2SBW-24S12
EC2SBW-24S12
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 12V 835mA 9V - 36V 输入
EC2SBW-24S12 数据手册
V15 EC2SBW SERIES 10 WATT 4:1 INPUT DC-DC CONVERTERS ︳ FEATURES * 10W Isolated Output * 1”×1”×0.4” Shielded Metal Case * Efficiency to 86% * 4:1 Input Range * Regulated Outputs * Input Under Voltage Protection * Remote On/Off * Continuous Short Circuit Protection * Without Tantalum Capacitors Inside * Safety Meets IEC/EN/UL 62368-1 MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE OUTPUT INPUT CURRENT CURRENT MIN. MAX. 3.3 VDC 0 mA 2500 mA EC2SBW-24S33 9-36 VDC EC2SBW-24S05 9-36 VDC 5 VDC 0 mA EC2SBW-24S12 9-36 VDC 12 VDC 0 mA EC2SBW-24S15 9-36 VDC 15 VDC EC2SBW-24D05 9-36 VDC EC2SBW-24D12 NO LOAD % CAPACITOR EFF. LOAD MAX. FULL LOAD 5 mA 425 mA 81 3300uF 2000 mA 5 mA 496 mA 84 2200uF 835 mA 10 mA 486 mA 86 1000uF 0 mA 666 mA 10 mA 486 mA 86 680uF ± 5 VDC 0 mA ±1000 mA 10 mA 496 mA 84 1200uF 9-36 VDC ± 12 VDC 0 mA ±416 mA 10 mA 486 mA 86 470uF EC2SBW-24D15 9-36 VDC ± 15 VDC 0 mA ±333 mA 10 mA 486 mA 86 330uF EC2SBW-48S33 18-75 VDC 3.3 VDC 0 mA 2500 mA 5 mA 210 mA 82 3300uF EC2SBW-48S05 18-75 VDC 5 VDC 0 mA 2000 mA 5 mA 248 mA 84 2200uF EC2SBW-48S12 18-75 VDC 12 VDC 0 mA 835 mA 5 mA 243 mA 86 1000uF EC2SBW-48S15 18-75 VDC 15 VDC 0 mA 666 mA 5 mA 243 mA 86 680uF EC2SBW-48D05 18-75 VDC ± 5 VDC 0 mA ±1000 mA 5 mA 248 mA 84 1200uF EC2SBW-48D12 18-75 VDC ± 12 VDC 0 mA ±416 mA 8 mA 243 mA 86 470uF EC2SBW-48D15 18-75 VDC ± 15 VDC 0 mA ±333 mA 8 mA 243 mA 86 330uF NOTE: 1. Nominal Input Voltage 24 or 48 VDC 1 V15 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....……………..................…. 24V ....................... 9 – 36V 48V ….…..….... 18 – 75V Input Surge Voltage (100ms max.) ……….……24V ……...... 50Vdc max. 48V .............. 100Vdc max. Efficiency ...........................................………..………............ See Table Isolation Voltage .................................……..………......... 1500 VDC min. Isolation Resistance .....................…….……………..……… 109 ohm min. Isolation Capacitance …………………..……………….…… 1000pF typ. Switching Frequency ............................……...................... 100KHz min. Under Voltage Lockout ………..….. 24Vin power up ….…...………. 8.8V typ. 24Vin power down …..…....…. 8.0V typ. 48Vin power up …………...….. 17V typ. 48Vin power down .……..……. 16V typ. Input Filter ………………………………..……….……………. LC Type Positive Logic Remote on/off Control (note3): Logic Compatibility ……… CMOS or Open Collector TTL, Ref. to -Vin Module On …………………………. >+3.5V to 36VDC or Open Circuit Module Off ……………………………….……………. 0 to
EC2SBW-24S12 价格&库存
很抱歉,暂时无法提供与“EC2SBW-24S12”相匹配的价格&库存,您可以联系我们找货
