EC5SAW-48S12N
EC5SAW-48S12N
    CINCON
    SIP6 模块
    隔离模块 直流转换器 1 输出 12V 833mA 18V - 75V 输入
EC5SAW-48S12N 数据手册
V10 ︳ EC5SAW SERIES 10 WATT WIDE INPUT DC-DC CONVERTERS FEATURE * 4:1 Input Range * Regulated Outputs * 3000VDC/2000VAC Isolation * Efficiency Up to 89.5% * Compact SIP8 Package * Remote On/Off Control * 6.6-10W Isolated Output * Fixed Switching Frequency * No Tantalum Capacitor Inside * Input Under-Voltage Protection * Low No Load Power Consumption * Continuous Short Circuit Protection MODEL NUMBER INPUT OUTPUT VOLTAGE(4) VOLTAGE OUTPUT CURRENT MIN. MAX. INPUT CURRENT %EFF. NO LOAD FULL LOAD (3) CAPACITOR (2) LOAD MAX. EC5SAW-24S33N 9-36 VDC 3.3 VDC 0 mA 2000 mA 6 mA 336 mA EC5SAW-24S05N 9-36 VDC 5 VDC 0 mA 2000 mA 6 mA 490 mA EC5SAW-24S12N 9-36 VDC 12 VDC 0 mA 833 mA 6 mA 473 mA EC5SAW-24S15N 9-36 VDC 15 VDC 0 mA 666 mA 6 mA 468 mA EC5SAW-24D05N 9-36 VDC ±5 VDC 0 mA ±1000 mA 6 mA 490 mA EC5SAW-24D12N 9-36 VDC ±12 VDC 0 mA ±417 mA 7 mA EC5SAW-24D15N 9-36 VDC ±15 VDC 0 mA ±333 mA 7 mA EC5SAW-48S33N 18-75 VDC 3.3 VDC 0 mA 2000 mA 6 mA 168 mA 81 81 2000uF EC5SAW-48S05N 18-75 VDC 5 VDC 0 mA 2000 mA 6 mA 245 mA 84 85 2000uF EC5SAW-48S12N 18-75 VDC 12 VDC 0 mA 833 mA 6 mA 237 mA 87.5 88 833uF EC5SAW-48S15N 18-75 VDC 15 VDC 0 mA 666 mA 6 mA 234 mA 87.5 88 666uF EC5SAW-48D05N 18-75 VDC ±5 VDC 0 mA ±1000 mA 6 mA 245 mA 84 85 1000uF EC5SAW-48D12N 18-75 VDC ±12 VDC 0 mA ±417 mA 6 mA 234 mA 88 88 417uF EC5SAW-48D15N 18-75 VDC ±15 VDC 0 mA ±333 mA 6 mA 234 mA 87.5 88 333uF NOTE: 1. Nominal Input Voltage 24 or 48 VDC 2. Measured at Nominal Input Voltage 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin 4. For 3.3Vo, 5Vo & ± 5Vo has Derating by Input is Required Show Fig.1 1 81 81.5 83.5 85 87 89 88.5 89.5 84 2000uF 2000uF 833uF 666uF 85 1000uF 468 mA 88.5 89 417uF 468 mA 88.5 89 333uF V10 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ........……………..................... 24V ..................... 9-36V 48V.................... 18-75V Input Surge Voltage (100 ms max.) …………...…….. 24V ……… 50VDC max. 48V……. 100VDC max. Input Filter ………………………………………………..……..…….... Capacitive Remote On/Off Control: Module On …………………………… Open or High Impedance Efficiency .................................................................…..……... See Table Isolation Voltage ..........….. Input/Output ….…....……..…. 3000VDC min. Input/Output ....................... 2000VAC min. Isolation Resistance .................................…...............……. 109 ohm min. Isolation Capacitance …………………………………………... 50pF max. Switching Frequency ...........................…..................…….... 530KHz typ. Operating Ambient Temperature ……………..…... -40℃ to +85℃ Module Off ………………………………………… 2mA to 4mA De-rating, Above 50℃ ………..………. Linearly to Zero power at 105℃ Module Off (Input Idle Current) …….…………...… 2.5mA max. Case Temperature (note4) ……………………….…………. 105℃ max. OUTPUT SPECIFICATIONS: Cooling ……………………….…………….…………. Natural Convection Voltage Accuracy ............................................………................. 1.0% max. Storage Temperature ………………....….........…........ -55℃ to +125℃ Voltage Balance (Dual) …………………………………………….... 1.0% max Transient Response: 75%~100% Step Load Change Humidity …………………………….……. 95% RH max. Non condensing MTBF …. MIL-HDBK-217F, GB, 25℃, Full Load ……..… 1930Khrs typ. Error Band …… 5% Vout Nominal, Recovery Time …….….. < 250μs Ripple & Noise, 20MHz BW (Note 5) .... 3.3V & 5V & ±5V … 100mV pk-pk max. 12V/15V/±12V/±15V…..... 1%Vo max. Dimensions …..…..............… 0.87x0.37x0.47 inches (22.0x9.5x12.0mm) Case Material ……………………………… Non-Conductive Black Plastic Weight ……………………………………………….…………………... 4.9g Temperature Coefficient ....................……….....…................. 0.02%/C max. NOTE: Short Circuit Protection .........................................................….…. Continuous Line Regulation (note1) .…….………………..….......................…. 0.2% max. Load Regulation (note2) ……..………….......................…............ 1.0% max. Cross Regulation (Dual note3) … Asymmetrical Load 25%/100% .. 5.0% max. Current Limit …………………………………………………………...180% typ. Start up time ……………………………….......................……… 5ms typ. 1. Measured from high line to low line. 2. Measured from full load to no load. 3. For asymmetric loading, both channels must be at 25% load or more. 4. Maximum case temperature under any operating condition should not be exceeded 105℃. 5. Output ripple and noise measured with 1uF ceramic capacitor CASE SA DIMENSIONS: All Dimensions In Inches (mm) Tolerances:Inches Millimeters X.XX=±0.02 X. X=±0.5 Pin ±0.002 ±0.05 0.47 (12.0) 0.16 (4.1) 0.02 (0.5) 0.87 (22.0) 0.10 (2.5) 1 2 3 0.08 (2.1) 6 7 8 0.14 (3.5) 0.37 (9.5) 0.01 (0.3) 0.70 (17.8) Bottom View PIN CONNECTION Pin Single Dual 1 -V Input -V Input +V Input 2 +V Input 3 On/Off On/Off 6 +V Output +V Output 7 -V Output Common 8 NC -V Output Fig1. Input Voltage Derating Curve 0.02 (0.5) Fig2. Typical Derating Curve for Naturel Convection 2
EC5SAW-48S12N 价格&库存
很抱歉,暂时无法提供与“EC5SAW-48S12N”相匹配的价格&库存,您可以联系我们找货
