V19
EC2SB SERIES
10 WATT 2:1 INPUT
DC-DC CONVERTERS
FEATURES
* 10W Isolated Output
* Efficiency to 87%
* 2:1 Input Range
* Regulated Outputs
* Fixed Switching Frequency
* Input Under Voltage Protection
* Over Current Protection
* Remote On/Off
* Continuous Short Circuit Protection
* Conductive EMI Meets EN55032 Class A
* Without Tantalum Capacitors Inside
* Safety Meets IEC/EN/UL 62368-1
MODEL
NUMBER
INPUT
VOLTAGE
OUTPUT
VOLTAGE
EC2SB-05S33
EC2SB-05S05
EC2SB-05S12
EC2SB-05S15
EC2SB-05D05
EC2SB-05D12
EC2SB-05D15
EC2SB-12S33
EC2SB-12S05
EC2SB-12S12
EC2SB-12S15
EC2SB-12D05
EC2SB-12D12
EC2SB-12D15
EC2SB-24S33
EC2SB-24S05
EC2SB-24S12
EC2SB-24S15
EC2SB-24D05
EC2SB-24D12
EC2SB-24D15
EC2SB-48S33
EC2SB-48S05
EC2SB-48S12
EC2SB-48S15
EC2SB-48D05
EC2SB-48D12
EC2SB-48D15
4.7-9 VDC
4.7-9 VDC
4.7-9 VDC
4.7-9 VDC
4.7-9 VDC
4.7-9 VDC
4.7-9 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
36-75 VDC
36-75 VDC
36-75 VDC
36-75 VDC
36-75 VDC
36-75 VDC
36-75 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
OUTPUT CURRENT
MIN.
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
MAX.
2500 mA
2000 mA
833 mA
666 mA
±1000 mA
±416 mA
±333 mA
2500 mA
2000 mA
833 mA
666 mA
±1000 mA
±416 mA
±333 mA
2500 mA
2000 mA
833 mA
666 mA
±1000 mA
±416 mA
±333 mA
2500 mA
2000 mA
833 mA
666 mA
±1000 mA
±416 mA
±333 mA
NOTE: 1. Nominal Input Voltage 5, 12, 24 or 48 VDC
1
INPUT CURRENT
NO LOAD
120 mA
120 mA
50 mA
50 mA
50 mA
50 mA
50 mA
30 mA
30 mA
35 mA
35 mA
45 mA
45 mA
45 mA
25 mA
25 mA
25 mA
25 mA
25 mA
25 mA
25 mA
20 mA
20 mA
20 mA
20 mA
20 mA
20 mA
20 mA
% CAPACITOR
EFF.
LOAD MAX.
FULL LOAD
1897 mA
87
2470uF
2299 mA
87
2000uF
2298 mA
87
940uF
2297 mA
87
690uF
2353 mA
85
1000uF
2295 mA
87
440uF
2297 mA
87
330uF
838 mA
82
2470uF
980 mA
85
2000uF
957 mA
87
940uF
956 mA
87
690uF
980 mA
85
1000uF
957 mA
87
440uF
957 mA
87
330uF
419 mA
82
2470uF
490 mA
85
2000uF
478 mA
87
940uF
478 mA
87
690uF
490 mA
85
1000uF
478 mA
87
440uF
478 mA
87
330uF
212 mA
81
2470uF
245 mA
85
2000uF
239 mA
87
940uF
239 mA
87
690uF
245 mA
85
1000uF
239 mA
87
440uF
239 mA
87
330uF
http://www.cincon.com
REVISION: November 09, 2020 V19
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....……………...............………. 5V ..................... 4.7 - 9V
12V .................. 9 - 18V
24V ………..... 18 – 36V
48V …….…..... 36 – 75V
Under Voltage Lockout ..………. 5Vin power up: 4.4V, …... power down: 4.2V
12Vin power up: 8.8V, ...…. power down: 8V
24Vin power up: 17V, …... power down: 16V
Efficiency ...........................................………..………............ See Table
Isolation Voltage .................................……..………......... 1500 VDC min.
Isolation Resistance .....................…….….………….……… 109 ohm min.
Isolation Capacitance …………………..………………..…… 1000pF typ.
Switching Frequency ............................……...................... 350KHz typ.
EMI/RFI ….… (Standard) …. Conductive EMI Meets EN55032 Class A
Operating Ambient Temperature Range .....…...…….... -40℃ to +85℃
48Vin power up: 34V, …... power down: 32V
Derating, Above 71℃ (note7) …..…. Linearly to Zero Power at +105℃
Input Surge Voltage (100mS max.) …... EC2SB-05Sxx/05Dxx …. 12Vdc max.
EC2SB-12Sxx/12Dxx ... 25Vdc max.
EC2SB-24Sxx/24Dxx .... 50Vdc max.
EC2SB-48Sxx/48Dxx .. 100Vdc max.
Input Filter ………………………………..…….…… Standard …………. PI Type
SMD ………….... LC Type
Positive Logic Remote on/off Control:
Case Temperature (note4) …………………………………….. 105℃ max.
Cooling ………………………………………………… Natural Convection
Storage Temperature Range ...…............……....…....... -55℃ to +125℃
Humidity ……………………………..…… 95% RH max. Non Condensing
MTBF …… MIL-HDBK-217-F, GB, 25℃, Full Load ……… 1200Khrs typ.
Dimensions ..... Standard .... 1.00x1.00x0.4 inches (25.4x25.4x10.2 mm)
SMD ……. 1.00x1.00x0.36 inches (25.4x25.4x9.2 mm)
Logic Compatibility ……………………….. CMOS or Open Collector TTL
Module On ……………………….. >+5.5V to 75VDC or Open Circuit
Case Material ……..… Black Coated Copper with Non-Conductive Base
Weight …………………………………………………..………………. 18g
Module Off ……….…….…………………….……………. 0 to
很抱歉,暂时无法提供与“EC2SB-24S15”相匹配的价格&库存,您可以联系我们找货
