EC5BW-48S15
EC5BW-48S15
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 15V 1A 18V - 75V 输入
EC5BW-48S15 数据手册
V12 EC5BW SERIES ︳ 15 WATT 4:1 INPUT DC-DC CONVERTERS FEATURES * 15W Isolated Output * Efficiency to 88% * 2’’x1’’ Six-Sided Shield Metal Case * 4:1 Input Range * Regulated Outputs * Fixed Switching Frequency * Input Under Voltage Protection * Over Current Protection * Remote On/Off (Option) * Continuous Short Circuit Protection * No Tantalum Capacitor Inside * Conductive EMI Meets EN55032 Class A * Safety Meets IEC/EN/UL 62368-1 OUTPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. EC5BW-24S33 EC5BW-24S05 EC5BW-24S12 EC5BW-24S15 EC5BW-24D05 EC5BW-24D12 EC5BW-24D15 EC5BW-48S33 EC5BW-48S05 EC5BW-48S12 EC5BW-48S15 EC5BW-48D05 EC5BW-48D12 EC5BW-48D15 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 4000 mA 3000 mA 1250 mA 1000 mA ±1500 mA ±625 mA ±500 mA 4000 mA 3000 mA 1250 mA 1000 mA ±150 0mA ±625 mA ±500 mA NOTE: 1. Nominal Input Voltage 24, 48VDC 2. Measured at Nominal Input Voltage 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin 1 INPUT CURRENT NO LOAD 60 mA 70 mA 30 mA 30 mA 30 mA 30 mA 30 mA 40 mA 40 mA 20 mA 20 mA 20 mA 20 mA 20 mA % EFF. FULL LOAD (2) 632 mA 718 mA 718 mA 710 mA 735 mA 718 mA 710 mA 313 mA 355 mA 359 mA 359 mA 368 mA 359 mA 359 mA 87 87 87 88 85 87 88 88 88 87 87 85 87 87 CAPACITOR (3) LOAD MAX. 87 87 87 88 85 87 88 88 88 87 87 85 87 87 4000µF 3000µF 1250µF 1000µF 1500µF 625µF 470µF 4000µF 3000µF 1250µF 1000µF 1500µF 625µF 470µF V12 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....………………........……. 24VDC ................ 9 – 36VDC 48VDC ……..... 18 – 75VDC Input Surge Voltage (100ms max.) …….…... 24VDC …....... 50VDC max. 48VDC ….... 100VDC max. Under Voltage Lockout ……….….. 24Vin power up ..…..….……. 8.8VDC typ. 24Vin power down …..……. 8.0VDC typ. 48Vin power up …….......….. 17VDC typ. 48Vin power down ……....... 16VDC typ. Input Filter ………………………………..………………………………. PI Type Efficiency ...........................................………..………............ See Table Isolation Voltage .................................……..………......... 1500 VDC min. Isolation Resistance .....................…….…………………… 109 Ohm min. Isolation Capacitance …………………..……………….…… 1000pF typ. Switching Frequency ............................……...................... 400KHz typ. EMI/RFI ……….………….…. Conductive EMI Meets EN55032 Class A Case Grounding …………. Connect Case to -Vin with Decoupling Y Cap OUTPUT SPECIFICATIONS: Operating Ambient Temperature Range ...…..…...…….... -40℃ to +85℃ De-rating, Above 78℃ ……………..…. Linearly to Zero Power at +105℃ Case Temperature (note3) ………………………………………….. 105℃ Voltage Accuracy ………………....……………….......…………… ±1.5% max. Voltage Balance (Dual) …….………………………………….….…. ±2.0% max. Transient Response: 75% - 100% Step Load Change Error Band ………..… ±5% Vout Nominal, Recovery Time ……... 3.5VDC to 75VDC or open circuit Module off ………………….……………….…….…………. 0 to
EC5BW-48S15 价格&库存
很抱歉,暂时无法提供与“EC5BW-48S15”相匹配的价格&库存,您可以联系我们找货
