PKE5210PI
PKE5210PI
    FLEX(伟创力)
    DIP6 模块
    隔离模块 直流转换器 1 输出 3.3V 4.5A 18V - 75V 输入
PKE5210PI 数据手册
PUBLIC PUBLIC TABLE OF SPECIFICATION CONTENTS PRODUCT Prepared Prepared(Subject (Subjectresp) resp) jidgezou GeorgeZou Zou jidgezou George Approved Approved(Document (Documentresp) resp) No. No. Checked Checked PKE5000 series DC-DC Converters jidgezou George Zou jidgezou George Zou Input 18 - 75 V, Output up to 7 A / 30 W 11(2) (4) 00152-BMR7105000 Technical 1/1301-BMR 710 5000 Uen Specification Date Date 3/21/2023 3/21/2023 Rev Rev 28701BMR7105000 Rev. L BJ © Flex D March 2023 Key Features • Industry standard case dimensions 25.4 x 25.4 x 11.4 mm (1.00 x 1.00 x 0.45 inch) • High efficiency, typ. 92% at 24 Vin, 12 Vout / 30W • 1500 Vdc input to output isolation • Compliant with IEC/UL 62368 standard General Characteristics • • • • • • • • Input under voltage shutdown Output over voltage protection Output short-circuit protection Output voltage adjust function Over temperature protection Monotonic start-up Remote control ISO 9001/14001 certified supplier Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 4 Electrical Specification 3.3 V, 4.5 A / 15 W 5 V, 3 A / 15 W 12 V, 1.25 A / 15 W 15 V, 1 A / 15 W 3.3 V, 7 A / 23.1 W 5 V, 6 A / 30 W 12 V, 2.5 A / 30 W 15 V, 2 A / 30 W 24 V, 1.25 A / 30 W 48 V, 0.625 A / 30 W 54 V, 0.463 A / 25 W PKE5210PI(P) ...................................... 5 PKE5211PI(P) ...................................... 8 PKE5213PI(P) .................................... 11 PKE5215PI(P) .................................... 14 PKE5310PI(P) .................................... 17 PKE5311PI(P) .................................... 20 PKE5313PI(P) .................................... 23 PKE5315PI(P) .................................... 26 PKE5316ZPI(P) .................................. 29 PKE5316JPI(P) .................................. 32 PKE5316HPI(P) .................................. 35 EMC Specification Operating Information Thermal Consideration Connections Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 38 ........................................................... 40 ........................................................... 41 ........................................................... 42 ........................................................... 43 ........................................................... 44 ........................................................... 44 ......................................................... 45S PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. 2 2 (4) Technical 1/1301-BMR 710 5000 Uen Specification jidgezou George Zou Approved (Document resp) Checked Date Rev 28701BMR7105000 Rev. L PKE5000 series DC-DC Converters jidgezou George Zou Input 18 - 75 V, Output up to 7 A / 30 W 3/21/2023 Ordering Information Compatibility with RoHS requirements Product program PKE5210PI PKE5211PI PKE5213PI PKE5215PI PKE5310PI PKE5311PI PKE5313PI PKE5315PI PKE5316ZPI PKE5316JPI PKE5316HPI Output 3.3 V, 4.5 A / 15 W 5.0 V, 3 A / 15 W 12 V, 1.25 A / 15 W 15 V, 1 A / 15 W 3.3 V, 7 A / 23.1 W 5 V, 6 A / 30 W 12 V, 2.5 A / 30 W 15 V, 2 A / 30 W 24 V, 1.25 A / 30 W 48 V, 0.625 A / 30 W 54 V, 0.463 A / 25 W Product number and Packaging PKE5XXXXn1n2 Options n1 ο Mounting Remote Control logic n2 ο Options Description n1 PI Through hole n2 P Negative * Positive Example positive logic product with tray packaging would be PKE5213PIP. * Standard variant (i.e. no option selected). General Information Reliability The failure rate (λ) and mean time between failures (MTBF= 1/λ) is calculated at max output power and an operating ambient temperature (TA) of +25°C. Flex uses Telcordia SR-332 Issue 3 Method 1 to calculate the mean steady-state failure rate and standard deviation (σ). Telcordia SR-332 Issue 3 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Mean steady-state failure rate, λ Std. deviation, σ 202.797 nFailures/h (PKE52XX) 119.56 nFailures/h 219.767 nFailures/h (PKE53XXX) 89.664 nFailures/h MTBF (mean value) for the PKE52XX = 4.93 Mh. MTBF at 90% confidence level = 2.75 Mh MTBF (mean value) for the PKE53XXX = 4.55 Mh. MTBF at 90% confidence level = 2.94 Mh J March 2023 © Flex The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Warranty Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2023 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. Checked PKE5000 series DC-DC Converters jidgezou George Zou Input 18 - 75 V, Output up to 7 A / 30 W Safety Specification General information PKE products are designed in accordance with the safety standards IEC 62368-1 and UL 62368-1, Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • 3 (4) Technical 1/1301-BMR 710 5000 Uen Specification jidgezou George Zou Approved (Document resp) 3 Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/UL 62368-1 or IEC/UL 623681. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/UL 62368-1 with regards to safety. Flex DC/DC converters are UL 62368-1 or UL 62368-1 recognized. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Isolated DC/DC converters The product provides functional insulation between input and output according to IEC/UL 62368-1. For functional insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the following conditions is met: • The input source provides double or reinforced insulation from the AC mains according to IEC/UL 62368-1. Date 3/21/2023 Rev 28701BMR7105000 Rev. L J March 2023 © Flex • The input source provides basic or supplementary insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/UL 62368-1. • The input source is reliably connected to protective earth and provides basic or supplementary insulation according to IEC/UL 62368-1 and the maximum input source voltage is 60 Vdc. It is recommended to use a slow blow fuse at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating 4 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 1 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Absolute Maximum Ratings Characteristics TP1 Operating Temperature (see Thermal Consideration section) min typ max PKE52XX variants -40 +110 PKE53XXX variants -40 +115 Unit °C TS Storage temperature -55 +125 VI Input voltage 18 75 °C V Viso Isolation voltage (input to output) 1500 Vdc Vtr Input voltage transient (tp 100ms) Vadj Adjust pin voltage (see Operating Information section) VRC Remote Control pin voltage (see Operating Information section) 100 V 0 Vo V Positive logic option 0 6 V Negative logic option 0 6 V Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only, functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Fundamental Circuit Diagram 5 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 2 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Electrical Specification 3.3 V, 4.5 A / 15 W PKE5210PI(P) TP1 = -40 to +90ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 48 V max IO, unless otherwise specified under Conditions. Additional Cout = 22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ Unit VI Input voltage range 75 V VIoff Turn-off input voltage Decreasing input voltage 14 15 16 V VIon Turn-on input voltage Increasing input voltage 15 16 17 V CI Internal input capacitance PO Output power η Efficiency 18 max 1.14 0 μF 15 50% of max IO 84.1 max IO 87.0 50% of max IO, VI = 24 V 87.8 max IO, VI = 24 V 86.8 % Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V 1.028 PRC Input standby power VI = 48 V (turned off with RC) 0.388 fs Switching frequency 0-100 % of max IO 340 400 460 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 4.5 A 3.26 3.30 3.34 V Output adjust range See operating information 2.97 3.63 V Output voltage tolerance band 0-100% of max IO 3.2 3.4 V Idling voltage IO = 0 A 3.2 3.4 V Line regulation max IO 2 10 mV Load regulation VI = 48 V, 10-100% of max IO 10 33 mV ±195 ±700 mV 193 500 µs 0.65 5 ms 6 30 ms VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tf tRC (from 10−90% of VOi) Start-up time 2.1 W VI = 48 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs 0.1 5.0 W W W 10-100% of max IO 1 (from VI connection to 90% of VOi) VI shut-down fall time 0.23 1.31 ms (from VI off to 10% of VO) max IO IO = 0A RC start-up time max IO 6.0 ms RC shut-down fall time max IO 0.1 ms (from RC off to 10% of VO) IO = 0A 1.52 s IO Output current Ilim Current limit threshold VI = 48 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 21 Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 3.9 Sink current, {see Note 3} See operating information 10 mA Trigger level See operating information 2.5 V OVP RC 0 s 4.8 8.5 4.5 A 12.2 A 5000 µF 40 mVp-p 2.7 0 Note 1: Output current (RMS), hiccup mode Note 2: Test condition: Electrolytic capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A V 6 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 3 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Typical Characteristics 3.3 V, 4.5 A / 15 W PKE5210PI(P) Efficiency Power Dissipation [W] 3.6 [%] 95 90 3.0 85 18VDC 80 24VDC 75 48VDC 70 75VDC 18VDC 2.4 24VDC 1.8 48VDC 1.2 75VDC 0.6 65 60 0.0 0.0 0.5 0.9 1.4 1.8 2.3 2.7 3.2 3.6 4.1 4.5 [A] 0.0 0.5 0.9 1.4 1.8 2.3 2.7 3.2 3.6 4.1 4.5 [A] Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics Current Limit Characteristics [V] 3.334 [V] 5 4 3.317 18VDC 24VDC 48VDC 75VDC 3.300 3.284 18VDC 24VDC 48VDC 75VDC 3 2 1 3.267 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 [A] 0 Output voltage vs. load current at TP1 = +25°C. Output Current Derating 1.5 3 4.5 6 7.5 9 [A] Output voltage vs. load current at IO > max IO, TP1 = +25°C. Thermal Resistance [A] [W/°C] 30 5.0 4.5 25 4.0 3.5 20 3.0 2.5 Nat. conv. 2.0 1.0 m/s(200lfm) 1.5 2.0 m/s(400lfm) 1.0 3.0 m/s(600lfm) 0.5 15 10 5 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 7 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H PKE5210PI(P) Start-up Shut-down Top trace: output voltage (2 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 48 V, IO = 4.5 A electronic load. March 2023 © Flex Typical Characteristics 3.3 V, 4.5 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 48 V, IO = 4.5 A electronic load. 4 (34) Output disabled by removing VI at: TP1 = +25°C, VI = 48 V, IO = 4.5 A electronic load. Top trace: output voltage (2 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (1.125-3.375-1.125 A) at: Bottom trace: load current (1 A/div.). TP1 =+25°C, VI = 48 V. Time scale: (0.5 ms/div.). Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 5.6 × (1.1406Voi— Vod) / (Vod — Voi), (KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 6.3875 × (1.1585Vod —Voi) / (Voi — Vod), (KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 8 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 5 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Electrical Specification 5 V, 3 A / 15 W PKE5211PI(P) TP1 = -40 to +90ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 48 VI max IO, unless otherwise specified under Conditions. Additional Cout =22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ Unit VI Input voltage range 75 V VIoff Turn-off input voltage Decreasing input voltage 14 15 16 V VIon Turn-on input voltage Increasing input voltage 15 16 17 V CI Internal input capacitance PO Output power η Efficiency 18 max 1.14 0 μF 15 50% of max IO 84.3 max IO 88.2 50% of max IO, VI = 24 V 88.3 max IO, VI = 24 V 89.0 % Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V 1.409 PRC Input standby power VI = 48 V (turned off with RC) 0.388 fs Switching frequency 0-100 % of max IO 340 400 460 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 3 A 4.94 5.00 5.06 V Output adjust range See operating information 4.50 5.50 V Output voltage tolerance band 0-100% of max IO 4.8 5.2 V Idling voltage IO = 0 A 4.8 5.2 V Line regulation max IO 2 10 mV Load regulation VI = 48 V, 10-100% of max IO 10 50 mV Vtr Load transient voltage deviation VI = 48 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs ±220 ±700 mV ttr Load transient recovery time 250 500 µs tr Ramp-up time 0.58 5 ms 5 30 ms VO ts tf tRC (from 10−90% of VOi) Start-up time 1.9 W 0.1 5.0 W W W 10-100% of max IO 1 (from VI connection to 90% of VOi) VI shut-down fall time 0.36 0.95 ms (from VI off to 10% of VO) max IO IO = 0 A RC start-up time max IO 5.3 ms RC shut-down fall time max IO 0.24 ms (from RC off to 10% of VO) IO = 0 A 0.99 s IO Output current Ilim Current limit threshold VI = 48 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 14 Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 6.2 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V OVP RC 0 s 3.3 6.0 3 A 8.8 A 3000 µF 25 mVp-p 2.6 0 Note 1: Output (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A V 9 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 6 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Typical Characteristics 5 V, 3 A / 15 W PKE5211PI(P) Efficiency Power Dissipation [W] 3.0 [%] 95 90 2.4 85 18VDC 80 24VDC 75 48VDC 18VDC 1.8 24VDC 48VDC 1.2 75VDC 70 75VDC 0.6 65 60 0.0 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3 [A] 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3 [A] Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics Current Limit Characteristics [V] [V] 6 5.050 5 5.025 18VDC 18VDC 24VDC 48VDC 75VDC 4 24VDC 5.000 48VDC 3 75VDC 2 4.975 1 0 4.950 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3 [A] 0 0.6 1.2 1.8 2.4 3 3.6 4.2 4.8 5.4 6 6.6 [A] Output voltage vs. load current at TP1 = +25°C. Output Current Derating Output voltage vs. load current at IO > max IO, TP1 = +25°C. Thermal Resistance [A] 3.5 [W/°C] 25 3.0 20 2.5 Nat. conv. 2.0 15 1.0 m/s(200lfm) 1.5 2.0 m/s(400lfm) 1.0 10 3.0 m/s(600lfm) 5 0.5 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 10 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H PKE5211PI(P) Start-up Shut-down Top trace: output voltage (2 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 48 V, IO = 3 A electronic load. March 2023 © Flex Typical Characteristics 5 V, 3 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 48 V, IO = 3 A electronic load. 7 (34) Output disabled by removing VI at: TP1 = +25°C, VI = 48 V, IO = 3 A electronic load. Top trace: output voltage (2 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (0.75-2.25-0.75 A) at: Bottom trace: load current (1 A/div.). TP1 =+25°C, VI = 48 V. Time scale: (0.5 ms/div.). Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 3.3 × (1.1515Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 3.8 × (1.1316Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 11 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 8 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Electrical Specification 12 V, 1.25 A / 15 W PKE5213PI(P) TP1 = -40 to +90ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 48 V max IO, unless otherwise specified under Conditions. Additional Cout = 22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ Unit VI Input voltage range 75 V VIoff Turn-off input voltage Decreasing input voltage 14 15 16 V VIon Turn-on input voltage Increasing input voltage 15 16 17 V CI Internal input capacitance PO Output power η Efficiency 18 max 1.14 0 μF 15 50% of max IO 86.3 max IO 88.7 50% of max IO, VI = 24 V 87.4 max IO, VI = 24 V 89.6 % Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V 0.760 PRC Input standby power VI = 48 V (turned off with RC) 0.388 fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 1.25 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO Idling voltage IO = 0 A 11.52 12.48 V Line regulation max IO 2 24 mV Load regulation VI = 48 V, 10-100% of max IO 5 120 mV Vtr Load transient voltage deviation VI = 48 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs ±250 ±700 mV ttr Load transient recovery time 200 500 µs tr Ramp-up time 0.91 5 ms 5 30 ms VO ts tf tRC (from 10−90% of VOi) Start-up time 1.9 W 5.0 W W W 340 400 460 kHz 11.85 12.00 12.15 V 10.8 13.2 V 11.52 12.48 V 0.1 10-100% of max IO 1 (from VI connection to 90% of VOi) VI shut-down fall time 0.61 0.25 ms (from VI off to 10% of VO) max IO IO = 0 A RC start-up time max IO 7.0 ms RC shut-down fall time max IO 0.41 ms (from RC off to 10% of VO) IO = 0 A 0.20 s IO Output current Ilim Current limit threshold VI = 48 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 13 Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 15 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V OVP RC 0 s 1.3 2.5 1.25 A 3.7 A 470 µF 25 mVp-p 2.1 0 Note 1: Output current (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A V 12 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 9 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Typical Characteristics 12 V, 1.25 A / 15 W PKE5213PI(P) Efficiency Power Dissipation [W] 3.0 [%] 95 90 2.4 85 18VDC 80 24VDC 18VDC 1.8 24VDC 48VDC 75 75VDC 48VDC 1.2 75VDC 70 0.6 65 60 0.0 0 0.25 0.5 0.75 1.25 [A] 1 0 Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics 0.25 0.5 0.75 1.25 [A] 1 Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics [V] 12.12 12.06 18VDC 24VDC 48VDC 75VDC 12.00 11.94 11.88 0 0.25 0.5 0.75 1.25 [A] 1 Output voltage vs. load current at TP1 = +25°C. Output Current Derating Output voltage vs. load current at IO > max IO, TP1 = +25°C. Thermal Resistance [A] [W/°C] 25 1.6 1.4 20 1.2 1.0 15 0.8 Nat. conv. 0.6 1.0 m/s(200lfm) 2.0 m/s(400lfm) 0.4 10 5 3.0 m/s(600lfm) 0.2 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 13 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H PKE5213PI(P) Start-up Shut-down Top trace: output voltage (5 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 48 V, IO = 1.25 A electronic load. March 2023 © Flex Typical Characteristics 12 V, 1.25 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 48 V, IO = 1.25 A electronic load. 10 (34) Output disabled by removing VI at: TP1 = +25°C, VI = 48 V, IO = 1.25 A electronic load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (0.312-0.937-0.312 A) at: Bottom trace: load current (0.5 A/div.). TP1 =+25°C, VI = 48 V. Time scale: (0.5 ms/div.). Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 22 × (1.1633Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 25.5924 × (1.1390Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 14 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 11 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Electrical Specification 15 V, 1 A / 15 W PKE5215PI(P) TP1 = -40 to +90ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 48 V max IO, unless otherwise specified under Conditions. Additional Cout = 22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ Unit VI Input voltage range 75 V VIoff Turn-off input voltage Decreasing input voltage 14 15 16 V VIon Turn-on input voltage Increasing input voltage 15 16 17 V CI Internal input capacitance PO Output power η Efficiency 18 max 1.14 0 μF 15 50% of max IO 84.4 max IO 88.1 50% of max IO, VI = 24 V 86.9 max IO, VI = 24 V 89.6 Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V 0.460 2.0 PRC Input standby power VI = 48 V (turned off with RC) 0.390 fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy W % 5.0 W W W 340 400 460 kHz TP1 = +25°C, VI = 48 V, IO = 1 A 14.82 15.00 15.18 V Output adjust range See operating information 13.50 16.50 V Output voltage tolerance band 0-100% of max IO 14.4 15.6 V Idling voltage IO = 0 A 14.4 15.6 V Line regulation max IO 2 30 mV Load regulation VI = 48 V, 10-100% of max IO 4 150 mV Vtr Load transient voltage deviation VI = 48 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs ±200 ±700 mV ttr Load transient recovery time 250 500 µs tr Ramp-up time 0.85 5 ms 6 30 ms VO ts tf tRC (from 10−90% of VOi) Start-up time 0.1 10-100% of max IO 1 (from VI connection to 90% of VOi) VI shut-down fall time 0.88 0.57 ms (from VI off to 10% of VO) max IO IO = 0 A RC start-up time max IO 7.1 ms RC shut-down fall time max IO 0.61 ms (from RC off to 10% of VO) IO = 0 A 0.63 s IO Output current Ilim Current limit threshold VI = 48 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 14 Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 18 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V OVP RC 0 s 1.1 2.0 1.0 A 2.9 A 470 µF 25 mVp-p 1.7 0 Note 1: Output (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A V 15 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date Rev 12 (34) Specification 28701BMR7105000 Rev. L H 3/21/2023 March 2023 © Flex Typical Characteristics 15 V, 1 A / 15 W PKE5215PI(P) Efficiency Power Dissipation [W] 3.0 [%] 95 90 2.4 85 18VDC 80 24VDC 18VDC 1.8 24VDC 48VDC 75 75VDC 48VDC 1.2 75VDC 70 0.6 65 60 0.0 0 0.2 0.4 0.6 0.8 1 [A] 0 0.4 0.6 1 [A] 0.8 Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics 0.2 Current Limit Characteristics [V] 15.15 [V] 18 15 15.08 18VDC 24VDC 48VDC 75VDC 15.00 14.93 12 18VDC 24VDC 48VDC 75VDC 9 6 3 0 14.85 0 0.2 0.4 0.6 0.8 1 [A] 0 Output voltage vs. load current at TP1 = +25°C. Output Current Derating 0.5 2.5 [A] 2 Thermal Resistance [W/°C] 25 1.0 20 0.8 Nat. conv. 1.0 m/s(200lfm) 0.4 1.5 Output voltage vs. load current at IO > max IO, TP1 = +25°C. [A] 1.2 0.6 1 15 10 2.0 m/s(400lfm) 3.0 m/s(600lfm) 0.2 5 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 16 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H PKE5215PI(P) Start-up Shut-down Top trace: output voltage (5 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 48 V, IO = 1 A electronic load. March 2023 © Flex Typical Characteristics 15 V, 1 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 48 V, IO = 1 A electronic load. 13 (34) Output disabled by removing VI at: TP1 = +25°C, VI = 48 V, IO = 1 A electronic load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (0.25-0.75-0.25 A) at: Bottom trace: load current (0.5 A/div.). TP1 =+25°C, VI = 48 V. Time scale: (0.5 ms/div.). Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 30 × (1.1499Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 34.497 × (1.1331Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 17 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 14 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5310PI(P) 3.3 V, 7 A / 23.1 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 48 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power Unit 75 V 16.5 17.0 V 17.5 18.0 0 23.1 50% of max IO, VI = 24 V 89 max IO, VI = 24 V 88 50% of max IO, VI = 48 V 89 max IO, VI = 48 V 88 V μF 33 W η Efficiency Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO 238 280 322 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 7 A 3.27 3.30 3.33 V Output adjust range See operating information 2.97 3.30 3.63 V Output voltage tolerance band 0-100% of max IO 3.20 3.40 V Idling voltage IO = 0 A 3.20 3.40 V Line regulation max IO 5.5 6.6 mV Load regulation VI = 48 V, 0-100% of max IO 26 33 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tRC RC (from 10−90% of VOi) Start-up time 3 (from VRC connection to 90% of VOi) 4.3 0.2 VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs W W 0.1 W 100% of max IO (from VI connection to 90% of VOi) RC start-up time % max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 11.2 Isc Short circuit current TP1 = 25ºC, see Note 1 1.89 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 15 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 4.3 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1uF ceramic Cap. and 10uF tantalum(or EE) Cap. cross to output. 0 V 7 A 14 A A 12000 µF 30 mVp-p V 18 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1= +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. March 2023 © Flex PKE5310PI(P) Typical Characteristics 3.3 V, 7 A / 23.1 W Efficiency 15 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1= +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 19 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 16 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5310PI(P) Typical Characteristics 3.3 V, 7 A / 23.1 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Shut-down enabled by disconnecting VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div}). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 7 A resistive load. Time scale: (200 ms/div.). IO = 7 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (10 mV/div.). Output voltage response to load current step- Top trace: output voltage (200 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (3.5-5.25-3.5 A) at: Bottom trace: load current (2 A/div.). IO = 7 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 3.3 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 3.3V model by 8% to 3.56V the required external resistor is: Output Voltage Adjust, Increase:  1.9528  R ADJ _ UP =  − 12  = 12.41 k  0.08   1.9528  R ADJ _ UP =  − 12  k    Example: Output Voltage Adjust, Decrease: To trim down the 3V3 model by 7% to 3.07V the required external resistor is: RADJ _ DOWN  1.8627  = − 15.815  k     1.8627  RADJ _ DOWN =  − 15.815  = 10.79 k  0.07  20 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 17 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5311PI(P) 5 V, 6 A / 30 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 48 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power Unit 75 V 16.5 17.0 V 17.5 18.0 0 30 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 88 50% of max IO, VI = 48 V 89 max IO, VI = 48 V 90 V μF 33 W η Efficiency Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO 238 280 322 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 6 A 4.95 5 5.05 V Output adjust range See operating information 4.5 5 5.5 V Output voltage tolerance band 0-100% of max IO 4.85 5.15 V Idling voltage IO = 0 A 4.85 5.15 V Line regulation max IO 5 10 mV Load regulation VI = 48 V, 0-100% of max IO 30 50 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tRC RC (from 10−90% of VOi) Start-up time 3 (from VRC connection to 90% of VOi) 4.5 0.2 VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs W W 0.1 W 100% of max IO (from VI connection to 90% of VOi) RC start-up time % max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 9.75 Isc Short circuit current TP1 = 25ºC, see Note 1 1.68 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 20 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 6.2 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 6 A 12 A A 8000 µF 40 mVp-p V 21 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. March 2023 © Flex PKE5311PI(P) Typical Characteristics 5 V, 6 A / 30 W Efficiency 18 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 22 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 19 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5311PI(P) Typical Characteristics 5 V, 6 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Shut-down enabled by disconnecting VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div}). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 6 A resistive load. Time scale: (200 ms/div.). IO = 6 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (200 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (3.0-4.5-3.0 A) at: Bottom trace: load current (2 A/div.). IO = 6 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 5.0 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 5.0V model by 8% to 5.4V the required external resistor is: Output Voltage Adjust, Increase:  1.5  R ADJ _ UP =  − 10  = 8.75 k  0.08   1.5  R ADJ _ UP =  − 10  k    Example: Output Voltage Adjust, Decrease: To trim down the 5.0V model by 7% to 4.65V the required external resistor is: RADJ _ DOWN  1.5  = − 13  k     1.5  RADJ _ DOWN =  − 13  = 8.43 k  0.07  23 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 20 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5313PI(P) 12 V, 2.5 A / 30 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 48 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power V 16.5 17.0 V 17.5 18.0 0 30 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 91 50% of max IO, VI = 48 V 90 Efficiency max IO, VI = 48 V 91 Pd Power Dissipation max IO 2.7 Pli Input idling power IO = 0 A, VI = 48 V 0.2 PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 2.5 A Output adjust range Output voltage tolerance band 3.5 W W 0.1 W 322 kHz 11.88 12 12.12 V See operating information 10.8 12 13.2 V 0-100% of max IO 11.64 12.36 V Idling voltage IO = 0 A 11.64 12.36 V Line regulation max IO 12 24 mV Load regulation VI = 48 V, 0-100% of max IO 60 120 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms ttr Load transient recovery time tr Ramp-up time RC % 280 Vtr tRC W 238 Load transient voltage deviation ts V μF 33 η VO Unit 75 (from 10−90% of VOi) Start-up time VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 4.45 Isc Short circuit current TP1 = 25ºC, see Note 1 1.25 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 35 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 15 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 2.5 A 5.0 A A 2000 µF 70 mVp-p V 24 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. March 2023 © Flex PKE5313PI(P) Typical Characteristics 12 V, 2.5 A / 30 W Efficiency 21 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 25 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 22 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5313PI(P) Typical Characteristics 12 V, 2.5 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). Shut-down enabled by disconnecting VI at: Top trace: output voltage (5 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div}). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 2.5 A resistive load. Time scale: (200 ms/div.). IO = 2.5 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (1.25-1.875-1.25 A) at: Bottom trace: load current (1 A/div.). IO = 2.5 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 12 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 12V model by 8% to 12.96V the required external resistor is: Output Voltage Adjust, Increase:  3.5998  R ADJ _ UP =  − 24  = 21 k  0.08   3.5998  R ADJ _ UP =  − 24  k    Example: Output Voltage Adjust, Decrease: To trim down the 12V model by 7% to 11.16V the required external resistor is: RADJ _ DOWN  3.5796  = − 31.179  k     3.5796  RADJ _ DOWN =  − 31.179  = 19.96 k  0.07  26 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 23 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5315PI(P) 15 V, 2 A / 30 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 48 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power V 16.5 17.0 V 17.5 18.0 0 30 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 89 50% of max IO, VI = 48 V 90 Efficiency max IO, VI = 48 V 91 Pd Power Dissipation max IO 2.7 Pli Input idling power IO = 0 A, VI = 48 V 0.2 PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 2 A Output adjust range Output voltage tolerance band 4.2 W W 0.1 W 322 kHz 14.85 15 15.15 V See operating information 13.5 15 16.5 V 0-100% of max IO 14.55 15.45 V Idling voltage IO = 0 A 14.55 15.45 V Line regulation max IO 15 30 mV Load regulation VI = 48 V, 0-100% of max IO 100 150 mV VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms ttr Load transient recovery time tr Ramp-up time RC % 280 Vtr tRC W 238 Load transient voltage deviation ts V μF 33 η VO Unit 75 (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 3.3 Isc Short circuit current TP1 = 25ºC, see Note 1 0.96 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 40 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 18 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 2 A 4 A A 1200 µF 80 mVp-p V 27 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. March 2023 © Flex PKE5315PI(P) Typical Characteristics 15 V, 2 A / 30 W Efficiency 24 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 28 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 25 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5315PI(P) Typical Characteristics 15 V, 2 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). Shut-down enabled by disconnecting VI at: Top trace: output voltage (5 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div}). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 2 A resistive load. Time scale: (200 ms/div.). IO = 2 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (1.0-1.5-1.0 A) at: Bottom trace: load current (1 A/div.). IO = 2 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 15 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 15V model by 8% to 16.2V the required external resistor is: Output Voltage Adjust, Increase:  4.4993  R ADJ _ UP =  − 30  = 26.24 k  0.08   4.4993  R ADJ _ UP =  − 30  k    Example: Output Voltage Adjust, Decrease: To trim down the 15V model by 7% to 13.95V the required external resistor is: RADJ _ DOWN  4.6  = − 39.099  k     4.6  RADJ _ DOWN =  − 39.099  = 26.62 k  0.07  29 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 26 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5316ZPI(P) 24 V, 1.25 A / 30 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 24 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power V 16.5 17.0 V 17.5 18.0 0 30 50% of max IO, VI = 24 V 92 max IO, VI = 24 V 91 50% of max IO, VI = 48 V 92 Efficiency max IO, VI = 48 V 91 Pd Power Dissipation max IO 2.7 Pli Input idling power IO = 0 A, VI = 48 V 0.2 PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 1.25 A Output adjust range Output voltage tolerance band 3.5 W W 0.1 W 322 kHz 23.76 24 24.24 V See operating information 21.6 24 26.4 V 0-100% of max IO 23.28 24.72 V Idling voltage IO = 0 A 23.28 24.72 V Line regulation max IO 20 48 mV Load regulation VI = 48 V, 0-100% of max IO 20 240 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms ttr Load transient recovery time tr Ramp-up time RC % 280 Vtr tRC W 238 Load transient voltage deviation ts V μF 33 η VO Unit 75 (from 10−90% of VOi) Start-up time VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 2.05 Isc Short circuit current TP1 = 25ºC, see Note 1 0.94 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 50 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 30 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 1.25 A 2.5 A A 560 µF 100 mVp-p V 30 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. March 2023 © Flex PKE5316ZPI(P) Typical Characteristics 24 V, 1.25 A / 30 W Efficiency 27 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 31 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 28 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5316ZPI(P) Typical Characteristics 24 V, 1.25 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Output disabled by removing VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div}). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 1.25 A resistive load. Time scale: (200 ms/div.). IO = 1.25 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (10 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.). change (0.625-0.937-0.625 A) at: Bottom trace: load current (500 mA/div.). IO = 1.25 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 24 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 24 V model by 8% to 25.92 V the required external resistor is: Output Voltage Adjust, Increase:  7.1319  R ADJ _ UP =  − 56  k    Output Voltage Adjust, Decrease: RADJ _ DOWN  8.6681  = − 71.8  k     7.1319  R ADJ _ UP =  − 56  = 33.15 k  0.08  Example: To trim down the 24V model by 7% to 22.32V the required external resistor is:  8.6681  RADJ _ DOWN =  − 71.8  = 52.03 k  0.07  32 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 29 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5316JPI(P) 48 V, 0.625 A / 30 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 48 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power 88 50% of max IO, VI = 48 V 90 max IO, VI = 48 V 90 Pli Input idling power IO = 0 A, VI = 48 V PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 0.625 A Output adjust range Output voltage tolerance band 3 V μF 30 max IO, VI = 24 V max IO W % 4.2 0.2 W W 0.1 W 238 280 322 kHz 47.52 48 48.48 V See operating information 43.2 48 52.8 V 0-100% of max IO 46.56 49.44 V Idling voltage IO = 0 A 46.56 49.44 V Line regulation max IO 50 96 mV Load regulation VI = 48 V, 0-100% of max IO 250 480 mV VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time RC V 18.0 91 Power Dissipation tRC 17.0 17.5 0 Pd ts 16.5 50% of max IO, VI = 24 V Efficiency VO V 33 η Unit 75 (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 1.08 Isc Short circuit current TP1 = 25ºC, see Note 1 0.48 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 90 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 58 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 0.625 A 1.25 A A 120 µF 180 mVp-p V 33 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating (Vin = 48 V) Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. Output Current Derating (Vin = 24 V) Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. March 2023 © Flex PKE5316JPI(P) Typical Characteristics 48 V, 0.625 A / 30 W Efficiency 30 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. THERMAL RESISTANCE (Vin = 48 V) Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 34 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 31 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5316JPI(P) Typical Characteristics 48 V, 0.625 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Shut-down enabled by disconnecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 0.625 A resistive load. Time scale: (200 ms/div.). IO = 0.625 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (0.312-0.468-0.312 A) at: Bottom trace: load current (500 mA/div.). IO = 0.625 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 48 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 48 V model by 8% to 51.84 V the required external resistor is: Output Voltage Adjust, Increase:  14.3215  R ADJ _ UP =  − 100  = 79.02 k  0.08   14.3215  R ADJ _ UP =  − 100  k    Example: Output Voltage Adjust, Decrease: To trim down the 48V model by 7% to 44.64V the required external resistor is: RADJ _ DOWN  13.8785  = − 128.2  k     13.8785  RADJ _ DOWN =  − 128.2  = 70.06 k  0.07  35 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 32 (34) Specification 28701BMR7105000 Rev. L H March 2023 © Flex Electrical Specification PKE5316HPI(P) 54 V, 0.463 A / 25 W TP1 = -40 to 115ºC, VI = 18 to 75 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 48 V max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 18 VIoff Turn-off input voltage Decreasing input voltage 16.0 VIon Turn-on input voltage Increasing input voltage 17.0 CI Internal input capacitance PO Output power V 16.5 17.0 V 17.5 18.0 0 30 50% of max IO, VI = 24 V 89 max IO, VI = 24 V 90 50% of max IO, VI = 48 V 88 Efficiency max IO, VI = 48 V 88 Pd Power Dissipation max IO 3.5 Pli Input idling power IO = 0 A, VI = 48 V 0.5 PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 0.463 A Output adjust range Output voltage tolerance band 4.4 W W 0.1 W 322 kHz 53.46 54 54.54 V See operating information 48.6 54 59.4 V 0-100% of max IO 52.38 55.62 V Idling voltage IO = 0 A 52.38 55.62 V Line regulation max IO 60 108 mV Load regulation VI = 48 V, 0-100% of max IO 300 540 mV VI = 48 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms ttr Load transient recovery time tr Ramp-up time RC % 280 Vtr tRC W 238 Load transient voltage deviation ts V μF 33 η VO Unit 75 (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current Ilim Current limit threshold VI = 48 V,TP1 < max TP1 0 0.73 Isc Short circuit current TP1 = 25ºC, see Note 1 0.36 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 80 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 0-100% of max IO 62 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 0.463 A 0.926 A A 100 µF 160 mVp-p V 36 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev Specification 28701BMR7105000 Rev. L H Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. March 2023 © Flex PKE5316HPI(P) Typical Characteristics 54 V, 0.463 A / 25 W Efficiency 33 (34) Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 37 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7105000 Technical Approved (Document resp) Checked jidgezou George ZouDC-DC Converters George Zou PKE5000 series Input 18 - 75 V, Output up to 7 A / 30 W Date 3/21/2023 Rev 34 (34) Specification 28701BMR7105000 Rev. L H © Flex PKE5316HPI(P) Typical Characteristics 54 V, 0.463 A / 25 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Shut-down enabled by disconnecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div}). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 0.463 A resistive load. Time scale: (200 ms/div.). IO = 0.463 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (50 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (0.231-0.347-0.231 A) at: Bottom trace: load current (200 mA/div.). IO = 0.463 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 54 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 54 V model by 8% to 58.32 V the required external resistor is: Output Voltage Adjust, Increase:  16.2  R ADJ _ UP =  − 110  = 92.5 k  0.08   16.2  R ADJ _ UP =  − 110  k    Example: Output Voltage Adjust, Decrease: To trim down the 54V model by 7% to 50.22V the required external resistor is: RADJ _ DOWN  16.2  = − 142.4  k     16.2  RADJ _ DOWN =  − 142.4  = 89.03 k  0.07  38 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 1 (6) No. Checked PKE5000 series Zou DC-DC Converters jidgezou George Input 18 - 75 V, Output up to 7 A / 30 W EMC Specification Conducted EMI measured according to EN55032, CISPR 32 and FCC part 15J (see test set-up). See Design Note 029 for further information. 3/1301-BMR7105000 Technical Specification Date Rev 28701BMR7105000 Rev. L E 3/21/2023 March 2023 © Flex The fundamental switching frequency is 280 kHz for PKE5313PI at VI = 48 V and max IO. Conducted EMI Input terminal value (typ.) The fundamental switching frequency is 400 kHz for PKE5211PI at VI = 48 V and max IO. Conducted EMI Input terminal value (typ.) EMI without filter EMI without filter Optional external filter for class B Suggested external input filter in order to meet class B in EN 55032, CISPR 32 and FCC part 15J. Filter components: C1,3 = 1 µF C2,4 = 47 µF C5 = 1 µF CY1,2,3,4,5,6 = 1 nF L1 = 1500 µH Optional external filter for class A Suggested external input filter in order to meet class A in EN 55032, CISPR 32 and FCC part 15J. CY05 CY01 +Vin C01 + C02 + CY07 CY03 L01 C03 + C04 + +Vin MODULE -Vin -Vin CY02 CY04 +Vout -Vout CY06 C05 + C06 +Vo + -Vo CY08 Filter components: CY01:100 pF (Y CAP.)+ bead core*2 (RH type) CY03, CY04: 680 pF (Y CAP.) + bead core*4 (RH type) CY05,CY06,CY07,CY08: 2.2 nF (Y CAP.) + bead core*8 (RH type) C02: 100 µF (AL-CAP.) C03: 330 µF (AL-CAP.) L01: 1.6 mH (CM CHOKE) EMI with filter EMI with filter PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2 (6) No. jidgezou George Zou Approved (Document resp) 39 Checked PKE5000 series Zou DC-DC Converters jidgezou George Input 18 - 75 V, Output up to 7 A / 30 W Test set-up Layout recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. If a ground layer is used, it should be connected to the output of the product and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Output ripple and noise Output ripple and noise measured according to figure below. Output ripple and noise test setup for PKE53XX variants Output ripple and noise test setup for PKE53XXX variants 3/1301-BMR7105000 Technical Specification Date 3/21/2023 Rev 28701BMR7105000 Rev. L E © Flex March 2023 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 40 3 (6) No. jidgezou George Zou Approved (Document resp) Checked PKE5000 series Zou DC-DC Converters jidgezou George Input 18 - 75 V, Output up to 7 A / 30 W Operating Information Input Voltage The input voltage range 18 to 75 Vdc. At input voltages exceeding 75 V, the power loss will be higher than at normal input voltage and TP1 must be limited to absolute max +110°C for PKE52XX variants’ products and +115°C for PKE53XXX variants’ products. The absolute maximum continuous input voltage is 75 Vdc. Short duration transient disturbances can occur on the DC distribution and input of the product when a short circuit fault occurs on the equipment side of a protective device (fuse or circuit breaker). The voltage level, duration and energy of the disturbance are dependant on the particular DC distribution network characteristics and can be sufficient to damage the product unless measures are taken to suppress or absorb this energy. The transient voltage can be limited by capacitors and other energy absorbing devices like zener diodes connected across the positive and negative input conductors at a number of strategic points in the distribution network. The end-user must secure that the transient voltage will not exceed the value stated in the Absolute maximum ratings. ETSI TR 100 283 examines the parameters of DC distribution networks and provides guidelines for controlling the transient and reduce its harmful effect. Turn-off Input Voltage The products monitor the input voltage and will turn on and turn off at predetermined levels. The minimum hysteresis between turn on and turn off input voltage is 1 V. Remote Control (RC) The products are fitted with a remote control function referenced to the primary negative input connection (-In), with negative and positive logic options available.The RC function allows the product to be turned on/off by an external device like a semiconductor or mechanical switch. The RC pin has an internal pull up resistor to +In. The external device must provide a minimum required sink current to guarantee a voltage not higher than maximum voltage on the RC pin (see Electrical characteristics table). When the RC pin is left open, the voltage generated on the RC pin is 3 - 6 V. The standard product is provided with “negative logic” (Active Low) remote control. When the RC pin is left open or connected to a voltage higher than 2.5V referenced to -In, the product will be off when the input voltage is applied. To turn on the product, the RC pin should be connected to -In. In situations where it is desired to have the product to power up 3/1301-BMR7105000 Technical Specification Date 3/21/2023 Rev 28701BMR7105000 Rev. L E March 2023 © Flex automatically without the need for control signals or a switch, the RC pin must be wired directly to -In. The second option is “positive logic” (Active High) remote control, which can be ordered by adding the suffix “P” to the end of the part number. In this case, when the RC pin is left open, the product starts up automatically when the input voltage is applied. Turn off is achieved by connecting the RC pin to the -In. The product will restart automatically when this connection is opened. See Design Note 021 for detailed information. Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. The products are designed for stable operation without external capacitors connected to the input or output. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains significant inductance, the addition of 22 - 100 µF capacitor across the input of the PKE52XX (15W variant) product or a 220 µF capacitor across the input of the PKE53XXX (30W variant) product will ensure stable operation. The capacitor is not required when powering the product from an input source with an inductance below 10 µH. The minimum required capacitance value depends on the output power and the input voltage. The higher output power the higher input capacitance is needed. Approximately doubled capacitance value is required for a 24 V input voltage source compared to a 48 V input voltage source. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. It is equally important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors will become part of the product’s control loop. The control loop is optimized for a wide range of external capacitance and the maximum recommended value that could be used without any additional analysis is found in the Electrical specification. The ESR of the capacitors is a very important parameter. Stable operation is guaranteed with a verified ESR value of >5 mΩ across the output connections. For further information please contact your local Flex representative. 41 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) Checked PKE5000 series Zou DC-DC Converters jidgezou George Input 18 - 75 V, Output up to 7 A / 30 W Output Voltage Adjust (Vadj) The products have an Output Voltage Adjust pin (Trim). This pin can be used to adjust the output voltage above or below Output voltage initial setting. When increasing the output voltage, the voltage at the output pins must be kept below the threshold of the over voltage protection, (OVP) to prevent the product from shutting down. At increased output voltages, the maximum power rating of the product remains the same and the max output current must be decreased correspondingly. To increase the voltage the resistor should be connected between the Trim pin and –Out pin. The resistor value of the Output voltage adjust function is according to information given under the Output section for the respective product. To decrease the output voltage, the resistor should be connected between the Trim pin and +Out pin. Trim Increase 4 (6) No. 3/1301-BMR7105000 Technical Specification Date 3/21/2023 Rev 28701BMR7105000 Rev. L E March 2023 © Flex Thermal Consideration General The products are designed to operate in different thermal eviorments and sufficient cooling must be provided to ensure reliable operation. For products mounted on a PWB without a heat sink attached, cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependent on the airflow across the product. Increased airflow enhances the cooling of the product. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity at VI = 48 V. The product is tested on a 107 x 45 mm, 70 µm (2 oz), 1-layer test board in a wind box with 370 x 220 mm. Trim Decrease Over Temperature Protection (OTP) The products are protected from thermal overload by an internal over temperature shutdown circuit. When TP1 as defined in thermal consideration section exceeds 115°C the product will shut down. The product will make continuous attempts to start up (non-latching mode) and resume normal operation automatically when the temperature has dropped >5°C below the temperature threshold. Over Voltage Protection (OVP) The converters have output over voltage protection that will prevent output voltage to exceed the specified value in technical specification. Definition of product operating temperature The product operating temperatures is used to monitor the temperature of the product, and proper thermal conditions can be verified by measuring the temperature at positions P1. The temperature at this position (TP1) should not exceed the maximum temperatures in the table below. Temperature above maximum TP1, measured at the reference point P1 are not allowed and may cause permanent damage. Position P1 Description Reference point (PKE52XX variant) The converter will limit the outputvoltage to the maximum level. Converters will resume normal operation automatically after removal of the over voltage condition. Over Current Protection (OCP) The products include current limiting circuitry for protection at continuous overload. The output voltage will decrease towards zero for output currents in excess of max output current (max IO). The product will resume normal operation after removal of the overload. The load distribution should be designed for the maximum output short circuit current specified. Reference point on PKE52XX variant Max Temp. TP1 = 110º C 42 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 5 (6) No. jidgezou George Zou Approved (Document resp) Checked PKE5000 series Zou DC-DC Converters jidgezou George Input 18 - 75 V, Output up to 7 A / 30 W Position Description Max Temp. P1 Reference point (PKE53XXX variant) TP1 = 115º C P1 3/1301-BMR7105000 Technical Specification Date Rev 3/21/2023 28701BMR7105000 Rev. L E March 2023 © Flex Ambient Temperature Calculation For products with base plate/heatsink the maximum allowed ambient temperature can be calculated By using the thermal resistance. 1. The power loss is calculated by using the formula [(1/η) - 1)] x output power - power losses (Pd). η = efficiency of product, E.g. 89.9% = 0.899 2. ● Find the thermal resistance (Rth) in the Thermal Resistance graph found in the Output section for each model. Calculate the temperature increase (AT). AT = Rth x Pd 3. Max allowed ambient temperature is. Max TP1 - AT. E.g. PKE5316JPI at 2m/s: (Room temperature:25℃) η = 0.87 Reference point on PKE53XXX variant Rth = 7.85°C/W 1. [(1/0.87) - 1] × 30 W = 4.48 W 2. 4.48W × 7.85°C/W = 35.1°C Connections 1 2 3 6 5 4 Top view Pin 1 Designation On/Off Control Function Remote control 2 -Input Negative input 3 +Input Positive input 4 +Out Positive output 5 Trim Output voltage adjust 6 -Out Negative output 3. 105 °C - 35.1°C = max ambient temperature is 69.9°C The actual temperature will be dependent on several factors such as the PB size,number of layers and direction of airflow. PUBLIC PRODUCT SPEC. MECHANICAL Prepared (Subject resp) 1 (2) No. 4/1301-BMR7105000 Technical Specification jidgezou George Zou Approved (Document resp) 43 Checked PKE5000 series DC-DC Converters jidgezou George Zou Input 18 - 75 V, Output up to 7 A / 30 W Date 8/26/2020 Rev 28701- BMR7105000 Rev. L B March 2023 © Flex Mechanical Information Notes: 1. Weight: typical 16g 2. All dimensions in mm (inches) 3. Tolerance x.x mm =±1.016mm(0.04”) x.xx mm =±0.254mm(0.010”) ll component placements – whether shown as physical components or symbolical outline – are for reference only and are subject to change throughout the product’s life cycle, unless explicitly described and dimensioned in this drawing. 44 INTERNAL USE ONLY PRODUCT SPECIFICATION Technical Specification Prepared (Subject resp) No. jidgjian Grace Jiang PKE5000 series DC-DC Converters Approved (Document resp) Checked 5/1301-BMR710 Input 18 - 75 V, Output up to 7 A Donnie / 30 W Li Date 12/4/2018 28701- BMR7105000 Rev. L Rev © Flex PD1 Soldering Information - Hole Mounting The hole mounted product is intended for plated through hole mounting by wave or manual soldering. The pin temperature is specified to maximum to 270°C for maximum 10 seconds. A maximum preheat rate of 4°C/s and maximum preheat temperature of 150°C is suggested. When soldering by hand, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside the product or between the product and the host board. The cleaning residues may affect long time reliability and isolation voltage. Delivery Package Information The products are delivered in antistatic clamshell trays Tray Specifications Material Antistatic PS Surface resistance Bakability Tray thickness Box capacity Tray weight 105 < Ohm/square < 1011 This tray is not bake-able 23.1 mm [0.9094 inch] 250 products (10 full trays/box) 60 g empty, 510 g full tray Sheets Product Carton Box 1 (3) March 2023 45 INTERNAL USE ONLY PRODUCT SPECIFICATION Technical Specification Prepared (Subject resp) No. jidgjian Grace Jiang PKE5000 series DC-DC Converters Approved (Document resp) Checked 5/1301-BMR710 Input 18 - 75 V, Output up to 7 A Donnie / 30 W Li Date 28701- BMR7105000 Rev. L 2 (3) March 2023 Rev 12/4/2018 © Flex PD1 Product Qualification Specification Characteristics External visual inspection IPC-E-610 Change of temperature (Temperature cycling) IEC 60068-2-14 Na Temperature range Number of cycles Dwell/transfer time -55 to 105°C 20 30 min/3 min Cold (in operation) IEC 60068-2-1 Temperature TA Duration -45°C 72 h Damp heat IEC 60068-2-30 Temperature Humidity Duration 45°C 95 % RH 72 hours Electrostatic discharge susceptibility IEC 61340-3-1, JESD 22-A114 Human body model (HBM) Class 2, 2000 V Mechanical shock IEC 60068-2-27 Ea Peak acceleration Duration 200 g 6 ms Operational life test MIL-STD-202G, method 108A Duration 1000 h Resistance to soldering heat IEC 60068-2-20 Tb, method 1A Solder temperature Duration 270°C 10-13 s Robustness of terminations IEC 60068-2-21 Test Ua1 Through hole mount products All leads Solderability IEC 60068-2-20 test Ta Temperature, SnPb Eutectic Temperature, Pb-free 235°C 245°C Vibration, broad band random IEC 61373 Frequency RMS acceleration Duration 5 to 150 Hz 5 grms 5 hrs in each direction
PKE5210PI 价格&库存
很抱歉,暂时无法提供与“PKE5210PI”相匹配的价格&库存,您可以联系我们找货
