EC7BW SERIES
20 WATT 4:1 INPUT
ISOLATED DC-DC CONVERTER
Features
Efficiency up to 90%
Fixed Switching Frequency
Regulated Outputs
Remote On/Off
Fully Protected (OTP/OCP/OVP/UVLO)
1500Vdc I/O Isolation
Operating Case Temperature -40 to +105℃
2”x1”x0.4” Size Meet Industrial Standard
EN 50155 Compliant with External Circuits
Shock & Vibration EN 50155 (EN 61373) Compliant
Fire & Smoke EN 45545-2 Compliant
3000m Operating Altitude
Safety Meets IEC/EN/UL 62368-1
OUTPUT CURRENT
MODEL
INPUT
OUTPUT
NUMBER
VOLTAGE
VOLTAGE
MIN.
EC7BW-24S33
9-36 VDC
3.3 VDC
0 mA
EC7BW-24S05
9-36 VDC
5 VDC
EC7BW-24S12
9-36 VDC
EC7BW-24S15
9-36 VDC
EC7BW-24D05
EC7BW-24D12
INPUT CURRENT
% EFF. CAPACITOR
NO LOAD
FULL LOAD
(1)
LOAD MAX.
5500 mA
55 mA
869 mA
87
5500uF
0 mA
4000 mA
55 mA
926 mA
90
4000uF
12 VDC
0 mA
1670 mA
55 mA
928 mA
90
1800uF
15 VDC
0 mA
1330 mA
55 mA
924 mA
90
1500uF
9-36 VDC
±5 VDC
0 mA
±2000 mA
70 mA
937 mA
89
2000μF
9-36 VDC
±12 VDC
0 mA
±835 mA
35 mA
947 mA
88
1000μF
EC7BW-24D15
9-36 VDC
±15 VDC
0 mA
±666 mA
35 mA
947 mA
88
800μF
EC7BW-48S33
18-75 VDC
3.3 VDC
0 mA
5500 mA
25 mA
430 mA
88
5500uF
EC7BW-48S05
18-75 VDC
5 VDC
0 mA
4000 mA
25 mA
463 mA
90
4000uF
EC7BW-48S12
18-75 VDC
12 VDC
0 mA
1670 mA
25 mA
464 mA
90
1800uF
MAX.
EC7BW-48S15
18-75 VDC
15 VDC
0 mA
1330 mA
25 mA
462 mA
90
1500uF
EC7BW-48D05
18-75 VDC
±5 VDC
0 mA
±2000 mA
35 mA
468 mA
89
2000μF
EC7BW-48D12
18-75 VDC
±12 VDC
0 mA
±835 mA
25 mA
474 mA
88
1000μF
EC7BW-48D15
18-75 VDC
±15 VDC
0 mA
±666 mA
25 mA
474 mA
88
800μF
NOTE:
1. Nominal Input Voltage 24, 48 VDC
www.cincon.com
1
REVISION: V18
EC7BW
Series
PART NUMBER
Series
EC7BW-
Nominal Input
Voltage
II
Number of Outputs
Nominal Output Voltage
O
XX
Remote On/Off
Logic
L
PIN Configuration
-Y
33:3.3VDC
05:5VDC
EC7BW
24:24 VDC
48:48 VDC
S:Single
D:Dual
12:12VDC
15:15VDC
05:±5VDC
12:±12VDC
None:Positive
N:Negative
None:Standard
S:Alternative Pin
Configuration,
Single output
models only
15:±15VDC
Part Number Example:
EC7BW-24S12N: 2”x1”, 20W, 4:1 9-36Vdc Input, Single 12Vdc Output, Negative Logic
www.cincon.com
2
REVISION: V18
EC7BW
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Input Voltage
Continuous
Input Surge Voltage
Operating Ambient Temperature
100ms max.
At the center part of case plate (with derating)
Device
Min.
Typ.
Max.
24Vin
-0.3
36
48Vin
-0.3
75
24Vin
50
48Vin
100
All
-40
Units
Vdc
Vdc
85
105
125
Units
Maximum Case Temperature
All
Storage Temperature
All
-55
Device
Min.
Typ.
Max.
24Vin
9
24
36
48Vin
18
48
75
24Vin
8
8.5
8.8
48Vin
16.5
17
17.5
INPUT CHARACTERISTICS
PARAMETER
Operating Input Voltage
Vdc
Input Under Voltage Lockout
Turn-On Voltage Threshold
Turn-Off Voltage Threshold
7.7
8
8.3
48Vin
15.5
16
16.5
24Vin
0.6
48Vin
0.9
Vin=9V, Full load
24Vin
2.61
Vin=18V, Full Load
48Vin
1.305
Lockout Hysteresis Voltage
Maximum Input Current
24Vin
No-Load Input Current
Vin=24, 48V, Io=0A
Input Filter
Pi filter.
All
Inrush Current (I2t)
As per ETS300 132-2
All
Input Reflected Ripple Current
P-P thru 12uH inductor, 5Hz to 20MHz.
All
Vdc
Vdc
Vdc
A
mA
See Model Number Table
0.1
A2 s
mA
30
OUTPUT CHARACTERISTICS
PARAMETER
Device
Min.
Voltage Set Point Accuracy
Vin=24, 48V, Full load, Tc=25℃
All
Output Voltage Balance
Dual
Typ.
Max.
Units
-1.5
+1.5
-1.0
+1.0
Output Voltage Regulation
Load Regulation
Line Regulation
Full load to no load
Vin=High line to low line, full load
Cross Regulation
Load cross variation 25%/100%
Temperature Coefficient
Tc=-40℃ to 85℃
All
±1.0
Single
±0.2
Dual
±0.5
Dual
±5.0
All
±0.03
All
75
mV
Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth)
Peak-to-Peak
Full load, 0.1uF ceramic capacitors.
Output Current Range
Vin= 24, 48V
Over Current Protection
Hiccup Mode. Auto recovery
All
Short Circuit Protection
110
Full load (resistive)
Output Voltage Trim Range
Po≦max. rated power, Io ≦ Io_max.
125
150
uF
3
Single
Continuous, Auto Recovery
All
External Load Capacitance
www.cincon.com
A
-10
+10
REVISION: V18
EC7BW
PARAMETER
Over Voltage Protection
Zener Clamp
Device
Min.
Typ.
3.3Vo
3.9
5Vo
6.2
12Vo
15
15Vo
18
±05Vo
±6.2
±12Vo
±15
±15Vo
±18
Series
Max.
Units
Vdc
EFFICIENCY
PARAMETER
100% Load
Vin=24, 48V
Device
Min.
Typ.
Max.
Units
DYNAMIC CHARACTERISTICS
PARAMETER
Device
Min.
Typ.
Max.
Units
Output Voltage Current Transient
Error Band
Recovery Time
Turn-On Delay and Rise Time
Turn-On Delay Time, From On/Off
Control
Turn-On Delay Time, From Input
Output Voltage Rise Time
75% to 100% of Io_max. step load change
di/dt=0.1A/us
(within 1% Vout nominal)
Full load (constant resistive load)
All
±5
All
500
us
Von/off to 10%Vo_set, Remote on
All
1.5
Vin_min. to 10%Vo_set, Power up
All
2.5
ms
10%Vo_set to 90%Vo_set
All
6
ms
ms
ISOLATION CHARACTERISTICS
PARAMETER
Isolation Voltage
(100% factory Hi-Pot tested
@2sec.)
Isolation Resistance
Isolation Capacitance
1 Minute; Input to output
Device
Min.
Typ.
All
Input to output
All
Input to output (10KHz, 0.25V)
All
Max.
Units
1500
Vdc
MΩ
100
pF
1000
FEATURE CHARACTERISTICS
PARAMETER
Switching Frequency
Output ripple frequency
Device
Min.
Typ.
Single
350
Dual
400
Max.
Units
KHz
On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin
Logic Low (Module Off)
Von/off at Ion/off=1.0mA
All
V
Logic High (Module On)
Von/off at Ion/off=0.0uA, Pin open=On
All
5.5 or
Open
Circuit
75
V
Von/off at Ion/off=0.0uA, Pin open=Off
All
5.5 or
Open
Circuit
75
V
All
V
Ion/off at Von/off=0V
All
1
mA
Logic high, Von/off=15V
All
30
uA
Shutdown input idle current
All
10
mA
On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin
Logic High (Module Off)
Logic Low (Module On)
On/Off Current (for both remote
on/off logic)
Leakage Current (for both remote
on/off logic)
Off Converter Input Current
www.cincon.com
4
0.3
4
REVISION: V18
EC7BW
Series
GENERAL SPECIFICATIONS
PARAMETER
MTBF
Device
MIL-HDBK - 217F_Notice 1, GB, 25℃
Weight
Typ.
Max.
Units
All
720
K
hours
All
35
grams
Case Material
Black Coated Copper
Base plate Material
FR4
Potting Material
Shock/Vibration
UL 94V-0
Base: Copper
Plating: Nickel with Matte Tin
MIL-STD-810F/EN 61373 Compliant
Humidity
95% RH max. Non Condensing
Altitude
3000m Operating Altitude, 12000m Transport Altitude
Thermal Shock
MIL-STD-810F
Fire & Smoke
Pin Material
Min.
Io=100% of Io_max.;
EMC SPECIFICATIONS (External components required, please refer to application note.)
EMI
EN 55032 & EN50155 Compliant (with external filter)
ESD
EN 61000-4-2
Level 3: Air ±8kV, Contact ±6kV
Perf. Criteria A
Class A
Radiated Immunity
EN 61000-4-3
EN 61000-4-4
Perf. Criteria A
Conducted Immunity
EN 61000-4-6
Level 3: 80~1000MHz, 20V/m
Level 3: On power input port, ±2kV, external components
required (EN 50155)
Level 3: Line to earth, ±2kV, Line to line, ±1kV (EN 50155),
external components required
Level 3: 0.15~80MHz, 10V
Interruptions of Voltage Supply
EN 50155
Class S3: 20ms interruptions
Perf. Criteria A
Supply Change Over
EN 50155
Class C2: During a supply break of 30ms
Perf. Criteria A
Fast Transient
Surge
EN 61000-4-5
Application Note Link
Perf. Criteria A
Perf. Criteria A
EC7BW Series App Notes
Packaging Information Link
www.cincon.com
Perf. Criteria A
5
REVISION: V18
EC7BW
Series
Immunity to Environmental Conditions
Phenomenon
EN50155; 2017
Reference Clause(s)
Reference Standard
Low Temperature
Start-up test
13.4.4
EN 60068-2-1
Dry Heat Test
13.4.5
EN 60068-2-2
Low Temperature
Storage Test
13.4.6
EN 60068-2-1
Temperature: -40℃
Duration: 16 hrs
Pass
Cyclic Damp Heat Test
13.4.7
EN 60068-2-30
Temperature: 25℃ - 55℃
Humidity: 90% RH
Duration: 48 hrs
Pass
EN 61373
Temperature: 25℃ +/- 10℃
Humidity: 50% +/-25% RH
Frequency range: 5 ~ 150 Hz
Vertical: 0.98 ⁄
Transverse: 0.44 ⁄
Longitudinal: 0.69 ⁄
Duration: 10 min / axis
Pass
EN 61373
Temperature: 25℃ +/-10℃
Vertical: 5.72 ⁄
Transverse: 2.5 m⁄s
Longitudinal: 3.96 ⁄
Duration: 5 hrs / axis
Pass
EN 61373
+/-Vertical: 30 m⁄s
+/-Transverse: 30 ⁄
+/-Longitudinal: 50 ⁄
Duration: 30ms x18 (Each axis 3
shocks)
Pass
Random Vibration Test
Simulated Long Life Test at
Increased Random Vibration
Levels
Shock Test
13.4.11
13.4.11
13.4.11
Test Conditions
Result
Class OT4
Temperature: -40℃
Duration: 2 hrs
Class OT4 & Cycle B
Temperature: 70℃
Duration: 6 hrs
Extended temperature: 85℃
Extended Duration: 10min
Pass
Pass
EN45545-2 Fire & Smoke Test Conditions
Item
Standard
EN 45545-2: 2013
EN ISO 4589-2: 2006
EN 45545-2: 2013
EN ISO 5659-2: 2013
EN 45545-2: 2013
NF X70-100: 2006
EN 45545-2: 2013
EN ISO 4589-2: 2006
EN 45545-2: 2013
EN ISO 5659-2: 2013
EN 45545-2: 2013
NF X70-100: 2006
EN45545-2: 2013
EN ISO 4589-2
EN 45545-2:2013
EN 60695-2-11:2001
EN 45545-2: 2013
EN 60695-11-10: 2013
Oxygen Index Test
R22
Smoke Density Test
Smoke Toxicity Test
Oxygen Index Test
R23
Smoke Density Test
Smoke Toxicity Test
R24
Oxygen Index Test
R25
Glow - Wire Test
R26
Vertical Flame Test
www.cincon.com
6
Hazard Level
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
REVISION: V18
EC7BW
Series
CHARACTERISTIC CURVE
Power Derating Curve
120%
71
-40
Output Power (%)
Output Power (%)
120%
100%
EC7BW Derating Curve
with Heatsink BC100
without Heatsink
100%
80%
60%
40%
Natural Convection
20%
75
-40
80%
60%
40%
With Heat Sink
20%
105
105
0%
0%
-40
-20
60
80
100
-40
Ambient Temperature (℃)
-20
60
80
100
Performance Data
EC7BW-24S33
Eff Vs Io @25 Deg. C
EC7BW-24S33
Pd Vs Po @25 Deg. C
4
Power Dissipation (W)
100%
Efficiency (%)
90%
80%
70%
9V
60%
24V
50%
36V
40%
10%
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Current Load (%)
Output Power (%)
EC7BW-24S05
EC7BW-24S05
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
9V
60%
24V
36V
50%
10%
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
0%
Output Power (%)
7
REVISION: V18
EC7BW
EC7BW-24S12
EC7BW-24S12
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
9V
24V
60%
36V
50%
10%
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-24S15
EC7BW-24S15
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
9V
60%
24V
36V
50%
10%
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-24D05
EC7BW-24D05
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
9V
60%
24V
36V
50%
10%
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-24D12
EC7BW-24D12
Pd Vs Po @25 Deg. C
4
Efficiency (%)
100%
90%
80%
9V
70%
24V
36V
60%
10%
Series
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
0%
Output Power (%)
8
REVISION: V18
EC7BW
EC7BW-24D15
EC7BW-24D15
Pd Vs Po @25 Deg. C
4
Efficiency (%)
100%
90%
80%
9V
70%
24V
36V
60%
10%
9V
24V
36V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-48S33
EC7BW-48S33
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
18V
60%
48V
50%
75V
40%
10%
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-48S05
EC7BW-48S05
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
18V
60%
48V
50%
75V
40%
10%
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-48S12
EC7BW-48S12
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
18V
48V
60%
75V
50%
10%
Series
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
0%
Output Power (%)
9
REVISION: V18
EC7BW
EC7BW-48S15
EC7BW-48S15
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
18V
48V
60%
75V
50%
10%
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-48D05
EC7BW-48D05
Pd Vs Po @25 Deg. C
4
100%
Efficiency (%)
90%
80%
70%
60%
18V
50%
48V
40%
30%
10%
75V
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-48D12
EC7BW-48D12
Pd Vs Po @25 Deg. C
4
Efficiency (%)
100%
90%
80%
18V
70%
36V
75V
60%
10%
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
EC7BW-48D15
EC7BW-48D15
Pd Vs Po @25 Deg. C
4
Efficiency (%)
100%
90%
80%
18V
70%
36V
75V
60%
10%
Series
18V
48V
75V
3
2
1
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
0%
Output Power (%)
10
REVISION: V18
EC7BW
Series
MECHANICAL SPECIFICATION
All Dimensions In Inches (mm)
Tolerances Inches .XX= ±.04 , .XXX= ±.010
Millimeters .XX= ±1.0 , .XXX= ±0.25
SUFFIX"S"PIN
CONFIGURATION
STANDARD PIN
CONFIGURATION
Pin
BOTTOM
VIEW
1
2
3
4
5
6
BOTTOM VIEW
min
PIN CONNECTION
Single
Dual
+Vin
+Vin
-Vin
-Vin
+Vout
+Vout
Common
Trim
-Vout
-Vout
Remote ON/OFF
min
E-mail: sales@cincon.com.tw
Web: www.cincon.com
11
REVISION: V18
