PKE3316HPI
PKE3316HPI
    FLEX(伟创力)
    DIP6 模块
    隔离模块 直流转换器 1 输出 54V 463mA 9V - 36V 输入
PKE3316HPI 数据手册
PUBLIC PUBLIC PRODUCT TABLE OFSPECIFICATION CONTENTS Prepared Prepared (Subject (Subject resp) resp) jidgezou jidgezouGeorge GeorgeZou Zou Approved (Document (Document resp) resp) Approved jidgezou George Zou PKE3000 series DC-DC jidgezou George Zou No. No. Checked Checked Converters Input 9 - 36 V, Output up to 7 A / 30 W (4) 11 (2) 1/1301-BMR7103000 00152-BMR7103000 Date Date Technical Specification 3/20/2023 3/21/2023 Rev Rev 28701BMR7103000 Rev. L J B © Flex D March 2022 Key Features • Industry standard case dimensions 25.4 * 25.4 * 11.4 mm (1.0 * 1.0 * 0.45 in) • High efficiency, typ. 92% at 24 Vin, 12 Vout / 30W • 1500 Vdc input to output isolation • Compliant with IEC/UL 62368 standard General Characteristics • • • • • • • • Input under voltage shutdown Output over voltage protection Output short-circuit protection Output voltage adjust function Over temperature protection Monotonic start-up Remote control ISO 9001/14001 certified supplier Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 4 Electrical Specification 3.3 V, 4.5 A / 15 W 5 V, 3 A / 15 W 12 V, 1.25 A / 15 W 15 V, 1 A / 15 W 3.3 V, 7 A / 23.1 W 5 V, 6 A / 30 W 12 V, 2.5 A / 30 W 15 V, 2 A / 30 W 24 V, 1.25 A / 30 W 48 V, 0.625 A / 30 W 54 V, 0.463 A / 25 W PKE3210PI(P) ...................................... 5 PKE3211PI(P) ...................................... 8 PKE3213PI(P) .................................... 11 PKE3215PI(P) .................................... 14 PKE3310PI(P) .................................... 17 PKE3311PI(P) .................................... 20 PKE3313PI(P) .................................... 23 PKE3315PI(P) .................................... 26 PKE3316ZPI(P) .................................. 29 PKE3316JPI(P) .................................. 32 PKE3316HPI(P).................................. 35 EMC Specification Operating Information Thermal Consideration Connections Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 38 ........................................................... 40 ........................................................... 41 ........................................................... 43 ........................................................... 44 ........................................................... 45 ........................................................... 45 ........................................................... 46 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 1/1301-BMR7103000 Approved (Document resp) Checked jidgezou George ZouDC-DC PKE3000 series Date Converters Input 9 - 36 V, Output up to 7 A / 30 W 3/20/2023 2 2 (4) Technical Specification Rev 28701BMR7103000 Rev. L J March 2022 © Flex Compatibility with RoHS requirements Ordering Information Product program PKE3210PI PKE3211PI PKE3213PI PKE3215PI PKE3310PI PKE3311PI PKE3313PI PKE3315PI PKE3316ZPI PKE3316JPI PKE3316HPI Output 3.3 V, 4.5 A / 15 W 5.0 V, 3 A / 15 W 12 V, 1.25 A / 15 W 15 V, 1 A / 15 W 3.3 V, 7 A / 23.1 W 5 V, 6 A / 30 W 12 V, 2.5 A / 30 W 15 V, 2 A / 30 W 24 V, 1.25 A / 30 W 48 V, 0.625 A / 30 W 54 V, 0.463 A / 25 W Product number and Packaging PKE3XXXXn1n2 Options n1 ο Mounting Remote Control logic n2 ο Options Description n1 PI Through hole n2 P Negative * Positive The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Example positive logic product with tray packing would be PKE3213PIP. Warranty * Standard variant (i.e. no option selected) Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. General Information Limitation of Liability Reliability The failure rate (λ) and mean time between failures (MTBF= 1/λ) is calculated at max output power and an operating ambient temperature (TA) of +25°C. Flex uses Telcordia SR-332 Issue 3 Method 1 to calculate the mean steady-state failure rate and standard deviation (σ). Telcordia SR-332 Issue 3 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Mean steady-state failure rate, λ Std.deviation, σ 195.215 nFailures/h (PKE32XX) 114.01 nFailures/h 219.644 nFailures/h (PKE33XXX) 88.962 nFailures/h MTBF (mean value) for the PKE32XX = 5.12 Mh MTBF at 90% confidence level = 2.87 Mh MTBF (mean value) for the PKE33XXX = 4.55 Mh. MTBF at 90% confidence level = 2.94 Mh Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2023 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 1/1301-BMR7103000 Approved (Document resp) jidgezou George ZouDC-DC PKE3000 series Checked Converters Input 9 - 36 V, Output up to 7 A / 30 W Safety Specification General information PKE products are designed in accordance with the safety standards IEC 62368-1 and UL 62368-1, Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/UL 62368-1 or IEC/UL 623681. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/UL 62368-1 with regards to safety. Flex DC/DC converters are UL 62368-1 or UL 62368-1 recognized. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Isolated DC/DC converters The product provides functional insulation between input and output according to IEC/UL 62368-1. For functional insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the following conditions is met: • The input source provides double or reinforced insulation from the AC mains according to IEC/UL 62368-1. Date 3 3 (4) Technical Specification 3/20/2023 Rev 28701BMR7103000 Rev. L J March 2022 © Flex • The input source provides basic or supplementary insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/UL 62368-1. • The input source is reliably connected to protective earth and provides basic or supplementary insulation according to IEC/UL 62368-1 and the maximum input source voltage is 60 Vdc. It is recommended to use a slow blow fuse at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating 4 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 1 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L F © Flex Absolute Maximum Ratings Characteristics TP1 Operating Temperature (see Thermal Consideration section) TS Storage temperature VI Input voltage Viso Isolation voltage (input to output test voltage) Vtr Input voltage transient (tp 100ms) VRC Remote Control pin voltage (see Operating Information section) Vadj Adjust pin voltage (see Operating Information section) max Unit PKE32XX variants min -40 +110 °C PKE33XXX variants -40 +115 °C -55 +125 °C 9 typ 36 V 1500 Vdc 50 V Positive logic option 0 6 V Negative logic option 0 6 V 0 Vo V Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only, functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Fundamental Circuit Diagram 5 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 F © Flex Electrical Specification 3.3 V, 4.5 A / 15 W PKE3210PI(P) TP1 = -40 to +90ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cout = 22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 6.5 VIon Turn-on input voltage Increasing input voltage 7.5 CI Internal input capacitance PO Output power max Unit 36 V 7.0 8.0 V 8.1 8.8 9 10 0 15 50% of max IO, VI = 24V 84.6 max IO, VI = 24V 87.4 50% of max IO, VI = 12 V 88.2 max IO, VI = 12 V 86.2 V µF W η Efficiency Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 24 V PRC Input standby power VI = 24 V (turned off with RC) fs Switching frequency 0-100 % of max IO 340 400 460 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 4.5 A 3.26 3.30 3.34 V Output adjust range See operating information 2.97 3.63 V Output voltage tolerance band 10-100% of max IO 3.17 3.43 V Idling voltage IO = 0 A 3.0 3.6 V Line regulation max IO 2 10 mV Load regulation VI = 24 V, 10-100% of max IO 10 33 mV ±273 ±700 mV 210 500 µs 0.1 0.86 5 ms 1 6 30 ms VO Vtr Load transient voltage deviation ttr Load transient recovery time tr ts tf tRC Start-up time 5.0 0.866 W W 0.240 VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs Ramp-up time (from 10−90% of VOi) 2.2 % W 10-100% of max IO (from VI connection to 90% of VOi) max IO IO = 0A 0.34 1.6 ms (from VI off to 10% of VO) RC start-up time max IO 5.6 ms RC shut-down fall time max IO 0.1 ms (from RC off to 10% of VO) IO = 0A 1.7 s VI shut-down fall time IO Output current Ilim Current limit threshold VI = 24 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, VI = 24 V, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 17 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 3.9 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V RC 0.45 s 4.8 8.0 4.5 A 11.2 A 2.6 0 Note 1: Output current (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A 5000 µF 34 mVp-p V 6 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 3 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 F © Flex Typical Characteristics 3.3 V, 4.5 A / 15 W PKE3210PI(P) Efficiency Power Dissipation [%] 95 [W] 3.6 90 3.0 85 09VDC 80 12VDC 75 24VDC 70 36VDC 09VDC 2.4 12VDC 1.8 24VDC 1.2 36VDC 0.6 65 60 0.0 0.0 0.5 0.9 1.4 1.8 2.3 2.7 3.2 3.6 4.1 4.5 0.0 0.5 0.9 1.4 1.8 2.3 2.7 3.2 3.6 4.1 4.5 [A] [A] Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics Current Limit Characteristics [V] 3.334 [V] 5 4 3.317 09VDC 12VDC 24VDC 36VDC 3.300 3.284 09VDC 12VDC 24VDC 36VDC 3 2 1 0 3.267 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 [A] Output voltage vs. load current at TP1 = +25°C. 1.5 3 4.5 6 7.5 9 [A] Output voltage vs. load current at IO > max IO, TP1 = +25°C. Output Current Derating Thermal Resistance [A] [W/°C] 30 5.0 4.5 25 4.0 20 3.5 3.0 15 2.5 Nat. conv. 2.0 1.0 m/s(200lfm) 10 1.5 2.0 m/s(400lfm) 5 1.0 3.0 m/s(600lfm) 0.5 0 0 0.0 0 10 20 30 40 50 60 70 80 90 0.5 1 1.5 2 2.5 3 [m/s] 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 7 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G PKE3210PI(P) Start-up Shut-down Top trace: output voltage (2 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 4.5 A electronic load March 2022 © Flex Typical Characteristics 3.3 V, 4.5 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 4.5 A electronic load. 4 (35) No. Output disabled by removing VI at: TP1 = +25°C, VI = 24 V, IO = 4.5 A electronic load. Top trace: output voltage (2 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.) 20 MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (1.125-3.375-1.125 A) at: Bottom trace: load current (2 A/div.). Time scale: (0.5 ms/div.). TP1 =+25°C, VI = 24 V, di/dt = 1A/μs Co = 22 µF ceramic capacitor Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 5.6 × (1.1406Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 6.3875 × (1.1585Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 8 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 5 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 G © Flex Electrical Specification 5 V, 3 A / 15 W PKE3211PI(P) TP1 = -40 to +90ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cout =22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 6.5 VIon Turn-on input voltage Increasing input voltage 7.5 CI Internal input capacitance PO Output power max Unit 36 V 7.0 8.0 V 8.1 8.8 9 10 0 15 50% of max IO, VI = 24V 88.0 max IO, VI = 24V 89.1 50% of max IO, VI = 12 V 89.9 max IO, VI = 12 V 87.4 V µF W η Efficiency Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 24 V PRC Input standby power VI = 24 V (turned off with RC) fs Switching frequency 0-100 % of max IO 340 400 460 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 3 A 4.94 5.00 5.06 V Output adjust range See operating information 4.50 5.50 V Output voltage tolerance band 10-100% of max IO 4.8 5.2 V Idling voltage IO = 0 A 4.6 5.4 V Line regulation max IO 2 10 mV Load regulation VI = 24 V, 10-100% of max IO 10 50 mV Vtr Load transient voltage deviation VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs ±175 ±500 mV ttr Load transient recovery time 150 500 µs tr Ramp-up time 0.1 0.8 5 ms 1 5.8 30 ms VO ts tf tRC (from 10−90% of VOi) Start-up time 1.9 % 5.0 0.782 W W 0.240 W 10-100% of max IO (from VI connection to 90% of VOi) max IO IO = 0A 0.37 0.95 ms (from VI off to 10% of VO) RC start-up time max IO 6.2 ms RC shut-down fall time max IO 0.22 ms (from RC off to 10% of VO) IO = 0A VI shut-down fall time s 1 Output current Ilim Current limit threshold VI = 24 V,TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, VI = 24 V, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 17 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 6.2 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V RC 0.3 s IO 3.2 5.0 3 A 6.8 A 2.9 0 Note 1: Output current (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A 3000 µF 34 mVp-p V 9 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 6 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 G © Flex Typical Characteristics 5 V, 3 A / 15 W PKE3211PI(P) Efficiency Power Dissipation [W] 3.0 [%] 95 90 2.4 85 09VDC 80 12VDC 75 24VDC 36VDC 70 09VDC 1.8 12VDC 24VDC 1.2 36VDC 0.6 65 60 0.0 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3 [A] 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3 [A] Efficiency vs. load current and input voltage at TP1 = +25C. Dissipated power vs. load current and input voltage at TP1 = +25°C. Output Characteristics Current Limit Characteristics [V] 5.050 [V] 6 5 5.025 09VDC 09VDC 12VDC 24VDC 36VDC 4 12VDC 5.000 24VDC 36VDC 4.975 3 2 1 4.950 0 0. 0. 0. 1. 1. 1. 2. 2. 2. 3 6 9 2 5 8 1 4 7 0 3 0 0.6 1.2 1.8 2.4 3 3.6 4.2 4.8 5.4 6 [A] [A] Output voltage vs. load current at TP1 = +25°C. Output voltage vs. load current at IO > max IO , TP1 = +25°C. Output Current Derating Thermal Resistance [W/°C] [A] 3.5 25 3.0 20 2.5 Nat. conv. 15 2.0 1.0 m/s(200lfm) 10 1.5 2.0 m/s(400lfm) 1.0 3.0 m/s(600lfm) 5 0.5 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 10 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G PKE3211PI(P) Start-up Shut-down Top trace: output voltage (2 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 3 A electronic load. March 2022 © Flex Typical Characteristics 5 V, 3 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 3 A electronic load. 7 (35) No. Output disabled by removing VI at: TP1 = +25°C, VI = 24 V, IO = 3 A electronic load. Top trace: output voltage (2 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20 MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (0.75-2.25-0.75 A) at: Bottom trace: load current (1 A/div.). Time scale: (0.5 ms/div.). TP1 =+25°C, VI = 24 V, di/dt = 1A/μs Co = 22 µF ceramic capacitor Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 3.3 × (1.1515Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 3.8 × (1.1316Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 11 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 8 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev G © Flex Electrical Specification 12 V, 1.25 A / 15 W PKE3213PI(P) TP1 = -40 to +90ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cout =22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 6.5 VIon Turn-on input voltage Increasing input voltage 7.5 CI Internal input capacitance PO Output power V 8.8 89.0 50% of max IO, VI = 12 V 88.2 max IO, VI = 12 V 87.4 Input idling power IO = 0 A, VI = 24 V PRC Input standby power VI = 24 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 1.25 A Output adjust range See operating information Output voltage tolerance band 10-100% of max IO Idling voltage IO = 0 A 11.30 Line regulation max IO Load regulation VI = 24 V, 10-100% of max IO Vtr Load transient voltage deviation VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs ttr Load transient recovery time tr Ramp-up time 1.9 V µF 15 max IO, VI = 24V Pli tRC 8.0 8.1 86.5 max IO tf 7.0 0 Power Dissipation Start-up time V 50% of max IO, VI = 24V Pd ts Unit 36 10 Efficiency (from 10−90% of VOi) max 9 η VO March 2022 28701- BMR7103000 Rev. L 3/20/2023 W % 5.0 0.760 W W 0.240 W 340 400 460 kHz 11.85 12.00 12.15 V 10.8 13.2 V 11.52 12.48 V 12.7 V 2 24 mV 5 120 mV ±250 ±700 mV 200 500 µs 0.1 1.2 5 ms 1 5.8 30 ms 10-100% of max IO (from VI connection to 90% of VOi) max IO IO = 0A 0.57 0.15 ms (from VI off to 10% of VO) RC start-up time max IO 5.1 ms RC shut-down fall time max IO 0.28 ms (from RC off to 10% of VO) IO = 0A VI shut-down fall time s 0.16 Output current Ilim Current limit threshold VI = 24 V,TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, VI = 24 V, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 20 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 15 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V RC 0.125 s IO 1.35 2.25 1.25 A 3.15 A 1.4 0 Note 1: Output current (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A 470 µF 40 mVp-p V 12 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 9 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 G © Flex Typical Characteristics 12 V, 1.25 A / 15 W PKE3213PI(P) Efficiency Power Dissipation [W] 3.0 [%] 95 90 2.4 85 09VDC 80 12VDC 09VDC 1.8 12VDC 24VDC 75 36VDC 24VDC 1.2 36VDC 70 0.6 65 60 0.0 0 0.25 0.5 0.75 1 1.25[A] 0 0.25 0.5 0.75 1 1.25[A] Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics Current Limit Characteristics [V] 12.12 [V] 15 12 12.06 09VDC 12VDC 24VDC 36VDC 12.00 11.94 9 09VDC 12VDC 24VDC 36VDC 6 3 0 11.88 0 0.25 0.5 0.75 0 1.25[A] 1 Output voltage vs. load current at TP1 = +25°C. 0.5 1 1.5 2.5 [A] 2 Output voltage vs. load current at IO > max IO , TP1 = +25°C. Output Current Derating Thermal Resistance [A] [W/°C] 25 1.6 1.4 20 1.2 1.0 15 0.8 Nat. conv. 0.6 1.0 m/s(200lfm) 2.0 m/s(400lfm) 0.4 10 5 3.0 m/s(600lfm) 0.2 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 13 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G PKE3213PI(P) Start-up Shut-down Top trace: output voltage (5 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 1.25 A electronic load. March 2022 © Flex Typical Characteristics 12 V, 1.25 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 1.25 A electronic load. 10 (35) No. Output disabled by removing VI at: TP1 = +25°C, VI = 24 V, IO = 1.25 A electronic load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20 MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (0.312-0.937-0.312 A) at: Bottom trace: load current (0.5 A/div.). Time scale: (0.5 ms/div.). TP1 =+25°C, VI = 24 V, di/dt = 1A/μs Co = 22 µF ceramic capacitor Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 22 × (1.1633Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 25.5924 × (1.1390Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 14 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 11 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 G © Flex Electrical Specification 15 V, 1 A / 15 W PKE3215PI(P) TP1 = -40 to +90ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cout =22 µF ceramic capacitor. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 6.5 VIon Turn-on input voltage Increasing input voltage 7.5 CI Internal input capacitance PO Output power max Unit 36 V 7.0 8.0 V 8.1 8.8 9 10 0 15 50% of max IO, VI = 24V 85.8 max IO, VI = 24V 88.8 50% of max IO, VI = 12 V 88.1 max IO, VI = 12 V 87.5 η Efficiency Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 24 V PRC Input standby power VI = 24 V (turned off with RC) fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy 1.9 V µF W % 5.0 0.460 W W 0.240 W 340 400 460 kHz TP1 = +25°C, VI = 24 V, IO = 1 A 14.82 15.00 15.18 V Output adjust range See operating information 13.50 16.50 V Output voltage tolerance band 10-100% of max IO 14.4 15.6 V Idling voltage IO = 0 A 14 16 V Line regulation max IO 2 30 mV Load regulation VI = 24 V, 10-100% of max IO 4 150 mV Vtr Load transient voltage deviation VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs ±230 ±700 mV ttr Load transient recovery time 200 500 µs tr Ramp-up time 0.1 1.08 5 ms 1 7.7 30 ms VO ts tf tRC (from 10−90% of VOi) Start-up time 10-100% of max IO (from VI connection to 90% of VOi) max IO IO = 0A 0.77 0.58 ms (from VI off to 10% of VO) RC start-up time max IO 6.8 ms RC shut-down fall time max IO 0.57 ms (from RC off to 10% of VO) IO = 0A VI shut-down fall time s 0.56 Output current Ilim Current limit threshold VI = 24 V,TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, VI = 24 V, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi 22 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 18 Sink current, see Note 3 See operating information 10 mA Trigger level See operating information 2.5 V RC 0.1 s IO 1.1 1.8 1.0 A 2.5 A 1.5 0 Note 1: Output current (RMS), hiccup mode Note 2: Test condition: Electrolytic Capacitor with 10% - full load Note 3: Sink current drawn by external device connected to the RC pin. Minimum sink current required to guarantee activated RC function. A 470 µF 44 mVp-p V 15 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 12 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 G © Flex Typical Characteristics 15 V, 1 A / 15 W PKE3215PI(P) Efficiency Power Dissipation [W] 3.0 [%] 95 90 2.4 85 09VDC 80 12VDC 09VDC 1.8 12VDC 24VDC 75 36VDC 24VDC 1.2 36VDC 70 0.6 65 0.0 60 0 0.2 0.4 0.6 0.8 0 1 [A] 0.4 0.6 1 [A] 0.8 Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25C. Output Characteristics 0.2 Current Limit Characteristics [V] 15.15 [V] 18 15 15.08 09VDC 12VDC 24VDC 36VDC 15.00 14.93 12 09VDC 12VDC 24VDC 36VDC 9 6 3 14.85 0 0 0.2 0.4 0.6 0.8 1 [A] 0 Output voltage vs. load current at TP1 = +25°C. 0.5 2 2.5 [A] Thermal Resistance [A] 1.2 [W/°C] 25 1.0 20 0.8 Nat. conv. 1.0 m/s(200lfm) 0.4 1.5 Output voltage vs. load current at IO > max IO , TP1 = +25°C. Output Current Derating 0.6 1 15 10 2.0 m/s(400lfm) 3.0 m/s(600lfm) 0.2 5 0 0.0 0 10 20 30 40 50 60 70 80 90 100 [℃] Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. 0 0.5 1 1.5 2 2.5 3 [m/s] Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. 16 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G PKE3215PI(P) Start-up Shut-down Top trace: output voltage (5 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (2 ms/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 1 A electronic load. March 2022 © Flex Typical Characteristics 15 V, 1 A / 15 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 1 A electronic load. 13 (35) No. Output disabled by removing VI at: TP1 = +25°C, VI = 24 V, IO = 1 A electronic load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (10 V/div.). Time scale: (1 ms/div.). Output Load Transient Response Trace: output voltage (20 mV/div.). Time scale: (2 µs/div.). 20 MHz bandwidth Output voltage response to load current step- Top trace: output voltage (200 mV/div.). change (0.25-0.75-0.25 A) at: Bottom trace: load current (0.5 A/div.). Time scale: (0.5 ms/div.). TP1 =+25°C, VI = 24 V, di/dt = 1A/μs Co = 22 µF ceramic capacitor Output Voltage Adjust (see operating information) Passive adjust The resistor value for an adjusted output voltage is calculated by using the following equations: To adjust the output voltage upwards, a resistor is connected between pins 5 and 6. The output voltage increases when the resistance decreases. The resistance value is given by the equation: Rou= 30 × (1.1499Voi— Vod)/(Vod — Voi),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. To adjust the output voltage downwards, a resistor is connected between pins 4 and 5. The output voltage decreases when the resistance decreases. The resistance value is given by the equation: Rod= 34.497 × (1.1331Vod —Voi)/( Voi — Vod),(KOhm); Vod is the desired output voltage and Voi is the initial output voltage. 17 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 14 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L G © Flex Electrical Specification PKE3310PI(P) 3.3 V, 7 A / 23.1 W TP1 = -40 to 115ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 0 23.1 50% of max IO, VI = 12 V 88 max IO, VI = 12 V 87 50% of max IO, VI = 24 V 87 max IO, VI = 24 V 88 W % Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy VO 322 kHz TP1 = +25°C, VI = 24 V, IO = 1.25 A 3.267 3.3 3.333 V Output adjust range See operating information 2.97 3.3 3.63 V Output voltage tolerance band 0-100% of max IO 3.201 3.399 V Idling voltage IO = 0 A 3.201 3.399 V Line regulation max IO 5.5 6.6 mV Load regulation VI = 24 V, 0-100% of max IO 26 33 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms ttr Load transient recovery time tr Ramp-up time RC W 280 Vtr tRC 4.6 238 Load transient voltage deviation ts 3 V μF 33 (from 10−90% of VOi) Start-up time VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V,TP1 < max TP1 11.8 Isc Short circuit current TP1 = 25ºC, see Note 1 1.97 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 12 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 4.3 Note 1: Output current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0 V 7 A 14 A 15000 µF 24 mVp-p A V 18 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 15 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3310PI(P) Typical Characteristics 3.3 V, 7 A / 23.1 W Efficiency Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI= 24 V. See Thermal Consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 19 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 16 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3310PI(P) Typical Characteristics 3.3 V, 7 A / 23.1 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Output disabled by removing VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 7 A resistive load. Time scale: (200 ms/div.). IO = 7 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (10 mV/div.). Output voltage response to load current step- Top trace: output voltage (200 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.) change (3.5-5.25-3.5 A) at: Bottom trace: load current (2 A/div.). IO = 7 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 3.3V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 3.3 V model by 8% to 3.56 V the required external resistor is: Output Voltage Adjust, Increase:  1.9528  R ADJ _ UP =  − 12  = 12.41 k  0.08   1.9528  R ADJ _ UP =  − 12  k    Example: Output Voltage Adjust, Decrease: To trim down the 3.3 V model by 7% to 3.07 V the required external resistor is: RADJ _ DOWN  1.8627  = − 15.815  k     1.8627  RADJ _ DOWN =  − 15.815  = 10.79 k  0.07  20 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 17 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L G © Flex Electrical Specification PKE3311PI(P) 5 V, 6 A / 30 W TP1 = -40 to 115ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 V μF 33 0 30 50% of max IO, VI = 12 V 90 max IO, VI = 12 V 88 50% of max IO, VI = 24 V 89 max IO, VI = 24 V 90 W % Pd Power Dissipation max IO 3.3 Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO 238 280 322 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 7 A 4.95 5 5.05 V Output adjust range See operating information 4.5 5 5.5 V Output voltage tolerance band 0-100% of max IO 4.85 5.15 V Idling voltage IO = 0 A 4.85 5.15 V Line regulation max IO 5 10 mV Load regulation VI = 24 V, 0-100% of max IO 30 50 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms VO Vtr Load transient voltage deviation ttr Load transient recovery time tr ts tRC RC VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs Ramp-up time (from 10−90% of VOi) Start-up time (from VRC connection to 90% of VOi) W 100% of max IO (from VI connection to 90% of VOi) RC start-up time 5.5 max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V,TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, See Note 1 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 22 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 6.2 Note 1: Output current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 9.6 V 6 A 12 A 8000 µF 24 mVp-p 1.57 0 A V 21 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 18 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3311PI(P) Typical Characteristics 5 V, 6 A / 30 W Efficiency Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 22 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 19 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3311PI(P) Typical Characteristics 5 V, 6 A / 30 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Output voltage disabled by removing VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 6 A resistive load. Time scale: (200 ms/div.). IO = 6 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.) change (3.0-4.5-3.0 A) at: Bottom trace: load current (2 A/div.). IO = 6 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 5.0 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 5.0 V model by 8% to 5.4 V the required external resistor is: Output Voltage Adjust, Increase:  1.5  R ADJ _ UP =  − 10  = 8.75 k  0.08   1.5  R ADJ _ UP =  − 10  k    Example: Output Voltage Adjust, Decrease: To trim down the 5.0 V model by 7% to 4.65 V the required external resistor is: RADJ _ DOWN  1.5  = − 13  k     1.5  RADJ _ DOWN =  − 13  = 8.43 k  0.07  23 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 20 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L G © Flex Electrical Specification PKE3313PI(P) 12 V, 2.5 A / 30 W TP1 = -40 to 115ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 V μF 33 0 30 50% of max IO, VI = 12 V 91 max IO, VI = 12 V 90 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 92 W % Pd Power Dissipation max IO 2.5 Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy VO 280 322 kHz TP1 = +25°C, VI = 24 V, IO = 6 A 11.88 12 12.12 V Output adjust range See operating information 10.8 12 13.2 V Output voltage tolerance band 0-100% of max IO 11.64 12.36 V Idling voltage IO = 0 A 11.64 12.36 V Line regulation max IO 12 24 mV Load regulation VI = 24 V, 0-100% of max IO 60 120 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms Load transient voltage deviation ttr Load transient recovery time ts tRC RC W 238 Vtr tr 4 VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs Ramp-up time (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 35 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 15 Note 1: Output current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 4.2 V 2.5 A 5.0 A 3000 µF 70 mVp-p 1.14 0 A V 24 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 21 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3313PI(P) Typical Characteristics 12 V, 2.5 A / 30 W Efficiency Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 25 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 22 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3313PI(P) Typical Characteristics 12 V, 2.5 A / 30 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). Output disabled by removing VI at: Top trace: output voltage (5 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 2.5 A resistive load. Time scale: (200 ms/div.). IO = 2.5 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.). change (1.25-1.875-1.25 A) at: Bottom trace: load current (1 A/div.). IO = 2.5 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 12 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 12 V model by 8% to 12.96V the required external resistor is: Output Voltage Adjust, Increase:  3.5998  R ADJ _ UP =  − 24  = 21 k  0.08   3.5998  R ADJ _ UP =  − 24  k    Example: Output Voltage Adjust, Decrease: To trim down the 12 V model by 7% to 11.16V the required external resistor is: RADJ _ DOWN  3.5796  = − 31.179  k     3.5796  RADJ _ DOWN =  − 31.179  = 19.96 k  0.07  26 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 23 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L G © Flex Electrical Specification PKE3315PI(P) 15 V, 2 A / 30 W TP1 = -40 to 115ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 V μF 33 0 30 50% of max IO, VI = 12 V 91 max IO, VI = 12 V 88 50% of max IO, VI = 24 V 92 max IO, VI = 24 V 91 W % Pd Power Dissipation max IO 2.5 Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy VO 280 322 kHz TP1 = +25°C, VI = 24 V, IO = 2 A 14.85 15 15.15 V Output adjust range See operating information 13.5 15 16.5 V Output voltage tolerance band 0-100% of max IO 14.55 15.45 V Idling voltage IO = 0 A 14.55 15.45 V Line regulation max IO 15 30 mV Load regulation VI = 24 V, 0-100% of max IO 100 150 mV VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms Load transient voltage deviation ttr Load transient recovery time ts tRC RC W 238 Vtr tr 5.2 Ramp-up time (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V,TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 30 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 18 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 3.25 V 2 A 4 A 1200 µF 60 mVp-p 1.02 0 A V 27 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 24 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3315PI(P) Typical Characteristics 15 V, 2 A / 30 W Efficiency Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 28 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 25 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3315PI(P) Typical Characteristics 15 V, 2 A / 30 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Output disabled by removing VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 2 A resistive load. Time scale: (200 ms/div.). IO = 2 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.). change (1.0-1.5-1.0 A) at: Bottom trace: load current (1 A/div.). IO = 2 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 15 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 15 V model by 8% to 16.2V the required external resistor is: Output Voltage Adjust, Increase:  4.4993  R ADJ _ UP =  − 30  = 26.24 k  0.08   4.4993  R ADJ _ UP =  − 30  k    Example: Output Voltage Adjust, Decrease: To trim down the 15 V model by 7% to 13.95V the required external resistor is: RADJ _ DOWN  4.6  = − 39.099  k     4.6  RADJ _ DOWN =  − 39.099  = 26.62 k  0.07  29 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 26 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L G © Flex Electrical Specification PKE3316ZPI(P) 24 V, 1.25 A / 30 W TP1 = -40 to 105ºC, VI = 9 to 36V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 10 µF ceramic Cap. + 22 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 V 33 0 µF 30 50% of max IO, VI = 12 V 89 max IO, VI = 12 V 89 50% of max IO, VI = 24 V 90 max IO, VI = 24 V 90 W % Pd Power Dissipation max IO 3.4 Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy VO 280 322 kHz TP1 = +25°C, VI = 24 V, IO = 1.25 A 23.76 24 24.24 V Output adjust range See operating information 21.6 24 26.4 V Output voltage tolerance band 0-100% of max IO 23.4 24.6 V Idling voltage IO = 0 A 23.4 24.6 V Line regulation max IO 20 48 mV Load regulation VI = 24 V, 25-100% of max IO 20 240 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms Load transient voltage deviation ttr Load transient recovery time ts tRC RC W 238 Vtr tr 4 VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs Ramp-up time (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC, see Note 2 VOac Output ripple & noise See ripple & noise section, VOi, Max IO, see Note 3 60 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 30 Note 1: Output Current (RMS), hiccup mode Note 2: Test condition: Electronic Capacitor and full load Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 1.875 V 1.25 A 2.5 A 470 µF 120 mVp-p 0.95 0 A V 30 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 27 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3316ZPI(P) Typical Characteristics 24 V, 1.25 A / 30 W Efficiency Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 31 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 28 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3316ZPI(P) Typical Characteristics 24 V, 1.25 A / 30 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Output disabled by removing VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 1.25 A resistive load. Time scale: (200 ms/div.). IO = 1.25 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.). change (0.625-0.937-0.625 A) at: Bottom trace: load current (1 A/div.). IO = 1.25 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 24 V, di/dt = 100 mA/ μs Time scale: (10 ms/div.) Cout = 10 µF ceramic Cap. + 22 µF E-Cap. Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 24 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 24V model by 8% to 25.92V the required external resistor is: Output Voltage Adjust, Increase:  7.1319  R ADJ _ UP =  − 56  k    Output Voltage Adjust, Decrease: RADJ _ DOWN  8.6681  = − 71.8  k     7.1319  R ADJ _ UP =  − 56  = 33.15 k  0.08  Example: To trim down the 24V model by 7% to 22.32V the required external resistor is:  8.6681  RADJ _ DOWN =  − 71.8  = 52.03 k  0.07  32 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 29 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L G © Flex Electrical Specification PKE3316JPI(P) 48 V, 0.625 A / 30 W TP1 = -40 to 115ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 V μF 33 0 30 50% of max IO, VI = 12 V 91 max IO, VI = 12 V 89 50% of max IO, VI = 24 V 92 max IO, VI = 24 V 90 W % Pd Power Dissipation max IO 3.2 Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy VO 280 322 kHz TP1 = +25°C, VI = 24 V, IO = 0.625 A 47.52 48 48.48 V Output adjust range See operating information 43.2 48 52.8 V Output voltage tolerance band 0-100% of max IO 47.56 49.44 V Idling voltage IO = 0 A 47.56 49.44 V Line regulation max IO 50 96 mV Load regulation VI = 24 V, 0-100% of max IO 250 480 mV VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms Load transient voltage deviation ttr Load transient recovery time ts tRC RC W 238 Vtr tr 4.5 Ramp-up time (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V,TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 80 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 58 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 1.03 V 0.625 A 1.25 A 150 µF 160 mVp-p 0.48 0 A V 33 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 30 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L G © Flex PKE3316JPI(P) Typical Characteristics 48 V, 0.625 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=24 V. See Thermal Consideration section. THERMAL RESISTANCE (VIN 24 V) Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 34 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 31 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L F © Flex PKE3316JPI(P) Typical Characteristics 48 V, 0.625 A / 30 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Output disabled by removing VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 0.625 A resistive load. Time scale: (200 ms/div.). IO = 0.625 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.). change (0.312-0.468-0.312 A) at: Bottom trace: load current (200 mA/div.). IO = 0.625 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 48 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 48 V model by 8% to 51.84V the required external resistor is: Output Voltage Adjust, Increase:  14.3215  R ADJ _ UP =  − 100  = 79.02 k  0.08   14.3215  R ADJ _ UP =  − 100  k    Example: Output Voltage Adjust, Decrease: To trim down the 48 V model by 7% to 44.64V the required external resistor is: RADJ _ DOWN  13.8785  = − 128.2  k     13.8785  RADJ _ DOWN =  − 128.2  = 70.06 k  0.07  35 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 32 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev March 2022 28701- BMR7103000 Rev. L F © Flex Electrical Specification PKE3316HPI(P) 54 V, 0.463 A / 25 W TP1 = -40 to 115ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI = 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 220 µF, Cout = 0.1 µF ceramic Cap. + 10 µF E-Cap. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.0 VIon Turn-on input voltage Increasing input voltage 8.0 CI Internal input capacitance PO Output power η Efficiency 9 Unit 36 V 7.5 8.0 V 8.5 9.0 V μF 33 0 30 50% of max IO, VI = 12 V 91 max IO, VI = 12 V 88 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 90 % Pd Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO VOi Output voltage initial setting and accuracy VO 322 kHz TP1 = +25°C, VI = 24 V, IO = 0.463 A 53.46 54 54.54 V Output adjust range See operating information 48.6 54 59.4 V Output voltage tolerance band 0-100% of max IO 52.38 55.62 V Idling voltage IO = 0 A 52.38 55.62 V Line regulation max IO 60 108 mV Load regulation VI = 24 V, 0-100% of max IO 300 540 mV VI = 24 V, Load step 50-75-50% of max IO, di/dt = 100 mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 ms ttr Load transient recovery time tRC RC W 280 Load transient voltage deviation ts 3.8 238 Vtr tr 3 W Ramp-up time (from 10−90% of VOi) Start-up time 100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current See operating information Trigger level Decreasing / Increasing RC-voltage 10 mA 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 24 V, TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, see Note 1 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 2 80 OVP Over voltage protection TP1 = +25°C, VI = 24 V, 0-100% of max IO 62 Note 1: Output Current (RMS), hiccup mode Note 2: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 0.75 V 0.463 A 0.926 A 100 µF 160 mVp-p 0.37 0 A V 36 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) 33 (35) No. Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L F © Flex PKE3316HPI(P) Typical Characteristics 54 V, 0.463 A / 25 W Efficiency Efficiency vs. load current and input voltage at TP1 = +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. March 2022 Power Dissipation Dissipated power vs. load current and input voltage at TP1 = +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at TP1 = +25°C. 37 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 34 (35) No. 2/1301-BMR7103000 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE3000 series jiddaxie David Xie DC-DC Converters Input 9 - 36 V, Output up to 7 A / 30 W Date 3/20/2023 Rev 28701- BMR7103000 Rev. L F © Flex PKE3316HPI(P) Typical Characteristics 54 V, 0.463 A / 25 W Start-up March 2022 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Output disabled by connecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div}). TP1 = +25°C, VI = 24 V, Bottom trace: input voltage (10 V/div.). IO = 0.463 A resistive load. Time scale: (200 ms/div.). IO = 0.463 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 24 V, Time scale: (5 µs/div.). change (0.231-0.347-0.231 A) at: Bottom trace: load current (200 mA/div.). IO = 0.463 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 24 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 54 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 54 V model by 8% to 58.32 V the required external resistor is: Output Voltage Adjust, Increase:  16.2  R ADJ _ UP =  − 110  = 92.5 k  0.08   16.2  R ADJ _ UP =  − 110  k    Example: Output Voltage Adjust, Decrease: To trim down the 54 V model by 7% to 50.22V the required external resistor is: RADJ _ DOWN  16.2  = − 142.4  k     16.2  RADJ _ DOWN =  − 142.4  = 89.03 k  0.07  Prepared (Subject resp) No. Technical 3/1301-BMR7103000 jidgezou George Zou Approved (Document resp) 38 PUBLIC PRODUCT SPECIFICATION Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W EMC Specification Conducted EMI measured according to EN55032, CISPR 32 and FCC part 15J (see test set-up). See Design Note 029 for further information. The fundamental switching frequency is 400 kHz for PKE3211PI at VI = 24 V and max IO. Conducted EMI Input terminal value (PKE3211PI typ.) Date 3/20/2023 Rev Specification 28701- BMR7103000 Rev. L E 1 (7) March 2022 © Flex The fundamental switching frequency is 280 kHz for PKE3316ZPI at VI = 24 V and max IO. Conducted EMI Input terminal value (PKE3316ZPI typ.) EMI without filter Optional external filter for class A Suggested external input filter in order to meet class A in EN 55032, CISPR 32 and FCC part 15J. EMI without filter Optional external filter for class B Suggested external input filter in order to meet class B in EN 55032, CISPR 32 and FCC part 15J. Filter components: C1,3 = 1 µF C2,4 = 47 µF C5 = 1 µF CY1,2,3,4,5,6 = 1 nF L1 = 1500 µH EMI with filter Filter components: CY03, CY04: 680 pF (Y CAP.)+ bead core*2 (RH type) CY05: 2.2 nF (Y CAP.)+ bead core*2 CY07: 100 pF (Y CAP.) + bead core*2 C01, C02, C03, C04, C05, C06: 100 µF (AL-CAP.) L01: 1.6 mH (CM CHOKE) CY04, CY06, CY08 were not assembled in test EMI with filter Prepared (Subject resp) No. Technical 3/1301-BMR7103000 jidgezou George Zou Approved (Document resp) Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W Test set-up Layout recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Output ripple and noise Output ripple and noise measured according to figure below. See Design Note 022 for detailed information. Output ripple and noise test setup for PKE32XX variant 39 PUBLIC PRODUCT SPECIFICATION Date 3/20/2023 Rev Specification 28701- BMR7103000 Rev. L E 2 (7) March 2022 © Flex Output ripple and noise test setup for PKE33XXX variant PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 3/1301-BMR7103000 jidgezou George Zou Approved (Document resp) Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W Operating Information Date 3/20/2023 40 3 (7) Specification Rev 28701- BMR7103000 Rev. L E March 2022 © Flex the need for control signals or a switch, the RC pin must be wired directly to -In. Input Voltage The input voltage range is 9 to 36 Vdc. At input voltages exceeding 36 V, the power loss will be higher than at normal input voltage and TP1 must be limited to absolute max +110°C for PKE32XX variants’ products and +115°C for PKE33XXX variants’ products. The absolute maximum continuous input voltage is 36 Vdc. Short duration transient disturbances can occur on the DC distribution and input of the product when a short circuit fault occurs on the equipment side of a protective device (fuse or circuit breaker). The voltage level, duration and energy of the disturbance are dependant on the particular DC distribution network characteristics and can be sufficient to damage the product unless measures are taken to suppress or absorb this energy. The transient voltage can be limited by capacitors and other energy absorbing devices like zener diodes connected across the positive and negative input conductors at a number of strategic points in the distribution network. The end-user must secure that the transient voltage will not exceed the value stated in the Absolute maximum ratings. ETSI TR 100 283 examines the parameters of DC distribution networks and provides guidelines for controlling the transient and reduce its harmful effect. Turn-off Input Voltage The products monitor the input voltage and will turn on and turn off at predetermined levels. The minimum hysteresis between turn on and turn off input voltage is about 1 V. Remote Control (RC) The products are fitted with a remote control function referenced to the primary negative input connection -In, with negative and positive logic options available. The RC function allows the product to be turned on/off by an external device like a semiconductor or mechanical switch. The RC pin has an internal pull up resistor to +In. The external device must provide a minimum required sink current to guarantee a voltage not higher than maximum voltage on the RC pin (see Electrical characteristics table). When the RC pin is left open, the voltage generated on the RC pin is 3 – 6 V. The standard product is provided with “negative logic” (Active Low) remote control. When the RC pin is left open, or connected to a voltage higher than 2.5V referenced to -In, the product will be off when the input voltage is applied. To turn on the product the RC pin should be connected to -In. In situations where it is desired to have the product to power up automatically without The second option is “positive logic” (Active High) remote control, which can be ordered by adding the suffix “P” to the end of the part number. In this case, when the RC pin is left open, the product starts up automatically when the input voltage is applied. Turn off is achieved by connecting the RC pin to the -In. The product will restart automatically when this connection is opened. See Design Note 021 for detailed information. Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. The products are designed for stable operation without external capacitors connected to the input or output. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains significant inductance, the addition of a 22 - 100 µF capacitor across the input of the PKE 32XX (15W variant) product or a 220 µF capacitor across the input of the PKE 33XXX (30W variant) product will ensure stable operation. The capacitor is not required when powering the product from an input source with an inductance below 10 µH. The minimum required capacitance value depends on the output power and the input voltage. The higher output power the higher input capacitance is needed. Approximately doubled capacitance value is required for a 24 V input voltage source compared to a 48 V input voltage source. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. It is equally important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors will become part of the product’s control loop. The control loop is optimized for a wide range of external capacitance and the maximum recommended value that could be used without any additional analysis is found in the Electrical specification. The ESR of the capacitors is a very important parameter. Stable operation is guaranteed with a verified ESR value of >5 mΩ across the output connections. For further information please contact your local Flex representative. PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 3/1301-BMR7103000 jidgezou George Zou Approved (Document resp) Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W Output Voltage Adjust The products have an Output Voltage Adjust pin (Trim). This pin can be used to adjust the output voltage above or below Output voltage initial setting. When increasing the output voltage, the voltage at the output pins must be kept below the threshold of the over voltage protection, (OVP) to prevent the product from shutting down. At increased output voltages the maximum power rating of the product remains the same, and the max output current must be decreased correspondingly. To increase the voltage the resistor should be connected between the Trim pin and -Out pin. The resistor value of the Output voltage adjust function is according to information given under the Output section for the respective product. To decrease the output voltage, the resistor should be connected between the Trim pin and +Out pin. Trim Trim Date 3/20/2023 Rev 4 (7) Specification 28701- BMR7103000 Rev. L E 41 March 2022 © Flex Over Current Protection (OCP) The products include current limiting circuitry for protection at continuous overload. The output voltage will decrease towards zero for output currents in excess of max output current (max IO). The product will resume normal operation after removal of the overload. The load distribution should be designed for the maximum output short circuit current specified. Thermal Consideration General The products are designed to operate in different thermal environments and sufficient cooling must be provided to ensure reliable operation. For products mounted on a PWB without a heat sink attached, cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependant on the airflow across the product. Increased airflow enhances the cooling of the product. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity at VI = 24 V. The product is tested on a 107 x 45 mm, 70 µm (2 oz), 1-layer test board in a wind box with 370 x 220 mm. Increase Decrease Over Temperature Protection (OTP) The products are protected from thermal overload by an internal over temperature shutdown circuit. When TP1 as defined in thermal consideration section exceeds 115°C the product will shut down. The product will make continuous attempts to start up (non-latching mode) and resume normal operation automatically when the temperature has dropped >5°C below the temperature threshold. Over Voltage Protection (OVP) The converters have output over voltage protection that will prevent output voltage to exceed the specified value in technical specification. The converter will limit the outputvoltage to the maximum level. Converters will resume normal operation automatically after removal of the over voltage condition. PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 3/1301-BMR7103000 jidgezou George Zou Approved (Document resp) Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W Ambient Temperature Calculation For products with base plate/heatsink the maximum allowed ambient temperature can be calculated By using the thermal resistance. 1. The power loss is calculated by using the formula [(1/η) - 1)] x output power - power losses (Pd). η = efficiency of product. E.g. 89.9% = 0.899 2. Find the thermal resistance (Rth) in the Thermal Resistance graph found in the Output section for each model Calculate the temperature increase (AT). AT = Rth x Pd 3. Max allowed ambient temperature is. Max TP1 - AT. E.g. PKE3316JPI at 2m/s: (Room temperature:25℃) η = 0.879 Rth = 7.64°C/W 1. [(1/0.879) - 1] × 30 W = 4.12 W 2. 4.12 W × 7.64°C/W = 31.4°C 3. 105 °C -31.4°C = max ambient temperature is 73.6°C The actual temperature will be dependent on several factors such as the PB size,number of layers and direction of airflow. Date 3/20/2023 Rev © Flex 5 (7) Specification 28701- BMR7103000 Rev. L E 42 March 2022 Prepared (Subject resp) No. Technical 3/1301-BMR7103000 jidgezou George Zou Approved (Document resp) Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W Definition of product operating temperature The product operating temperatures is used to monitor the temperature of the product, and proper thermal conditions can be verified by measuring the temperature at positions P1. The temperature at this position (TP1) should not exceed the maximum temperatures in the table below. Temperature above maximum TP1, measured at the reference point P1 are not allowed and may cause permanent damage. Position P1 43 PUBLIC PRODUCT SPECIFICATION Description Reference point (PKE32XX variant) Date 6 (7) Specification Rev March 2022 28701- BMR7103000 Rev. L 3/20/2023 E © Flex Connections 1 2 3 Max Temp. 6 5 4 TP1=110º C Top view Input side 1 2 3 P1 Air Flow 6 5 4 Top view Output side Reference point on PKE32XX variant Position P1 Description Reference point (PKE33XXX variant) P1 Reference point on PKE33XXX variant Max Temp. TP1 = 115º C Pin 1 Designation On/Off Control Function Remote control 2 -Input Negative input 3 +Input Positive input 4 +Out Positive output 5 Trim Output voltage adjust 6 -Out Negative output PUBLIC PRODUCT SPEC. MECHANICAL Prepared (Subject resp) 1 (2) No. 4/1301-BMR7105000 Technical Specification jidgezou George Zou Approved (Document resp) 44 Checked PKE3000 series DC-DC Converters jidgezou George Zou Input 9 - 36 V, Output up to 7 A / 30 W Date 8/26/2020 Rev 28701- BMR7103000 Rev. L B March 2022 © Flex Mechanical Information Notes: 1. Weight: typical 16g 2. All dimensions in mm (inches) 3. Tolerance x.x mm =±1.016mm(0.04”) x.xx mm =±0.254mm(0.010”) ll component placements – whether shown as physical components or symbolical outline – are for reference only and are subject to change throughout the product’s life cycle, unless explicitly described and dimensioned in this drawing. 45 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgjian Grace Jiang PKE3000 series DC-DC Converters Approved (Document resp) Checked 5/1301-BMR710 Input 9 - 36 V, Output up to 7 A / Donnie 30 W Li Date 12/4/2018 Technical Specification 1 (3) 28701- BMR7103000 Rev. L March 2022 Rev © Flex PD1 Soldering Information - Hole Mounting The hole mounted product is intended for plated through hole mounting by wave or manual soldering. The pin temperature is specified to maximum to 270°C for maximum 10 seconds. A maximum preheat rate of 4°C/s and maximum preheat temperature of 150°C is suggested. When soldering by hand, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside the product or between the product and the host board. The cleaning residues may affect long time reliability and isolation voltage. Delivery Package Information The products are delivered in antistatic clamshell trays Tray Specifications Material Antistatic PS Surface resistance Bakability Tray thickness Box capacity Tray weight 105 < Ohm/square < 1011 This tray is not bake-able 23.1 mm [0.9094 inch] 250 products (10 full trays/box) 60 g empty, 510 g full tray Sheets Product Carton Box 46 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgjian Grace Jiang PKE3000 series DC-DC Converters Approved (Document resp) Checked 5/1301-BMR710 Input 9 - 36 V, Output up to 7 A / Donnie 30 W Li Date Technical Specification 2 (3) 28701- BMR7103000 Rev. L March 2022 Rev 12/4/2018 © Flex PD1 Product Qualification Specification Characteristics External visual inspection IPC-E-610 Change of temperature (Temperature cycling) IEC 60068-2-14 Na Temperature range Number of cycles Dwell/transfer time -55 to 105°C 20 30 min/3 min Cold (in operation) IEC 60068-2-1 Temperature TA Duration -45°C 72 h Damp heat IEC 60068-2-30 Temperature Humidity Duration 45°C 95 % RH 72 hours Electrostatic discharge susceptibility IEC 61340-3-1, JESD 22-A114 Human body model (HBM) Class 2, 2000 V Mechanical shock IEC 60068-2-27 Ea Peak acceleration Duration 200 g 6 ms Operational life test MIL-STD-202G, method 108A Duration 1000 h Resistance to soldering heat IEC 60068-2-20 Tb, method 1A Solder temperature Duration 270°C 10-13 s Robustness of terminations IEC 60068-2-21 Test Ua1 Through hole mount products All leads Solderability IEC 60068-2-20 test Ta Temperature, SnPb Eutectic Temperature, Pb-free 235°C 245°C Vibration, broad band random IEC 61373 Frequency RMS acceleration Duration 5 to 150 Hz 5 grms 5 hrs in each direction
PKE3316HPI 价格&库存
很抱歉,暂时无法提供与“PKE3316HPI”相匹配的价格&库存,您可以联系我们找货
