PKE8413API
PKE8413API
    FLEX(伟创力)
    DIP6 模块
    隔离模块 直流转换器 1 输出 12V 3.3A 9V - 75V 输入
PKE8413API 数据手册
PUBLIC PRODUCT TABLE OF CONTENTS SPECIFICATION Prepared (Subject resp) 1/1301-BMR7128400 00152-BMR7128400 Technical Specification jidgezou George Zou Approved (Document resp) 1 (1) (4) No. Checked PKE8000A series jidgezou George ZouDC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Date Rev 2/27/2023 28701- BMR7128400 Rev. G G E © Flex Z D October 2023 Key Features • Industry standard case dimensions 50.8 x 25.4 x 11.9 mm (2 x 1 x 0.47 in) • High Efficiency up to 91% • 2250 Vdc input to output isolation • Meets functional insulation and safety requirements according to IEC/UL 62368 • Complies with EN 45545-2 standard General Characteristics • • • • • • Input under voltage shutdown Remote control Output over voltage protection Over temperature protection Output short-circuit protection Output voltage adjust function Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 4 Electrical Specification 3.3 V, 10 A / 33 W 5 V, 8 A / 40 W 12 V, 3.33 A / 40 W 15 V, 2.67 A / 40 W 24 V, 1.67 A / 40 W 48 V, 0.83 A / 40 W 54 V, 0.74 A / 40 W PKE8410API......................................... 6 PKE8411API....................................... 10 PKE8413API....................................... 14 PKE8415API....................................... 18 PKE8416ZAPI .................................... 22 PKE8416JAPI ..................................... 26 PKE8416HAPI .................................... 30 EMC Specification Operating Information Connections Thermal Consideration Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 34 ........................................................... 35 ........................................................... 36 ........................................................... 37 ........................................................... 38 ........................................................... 39 ........................................................... 39 ........................................................... 41 2 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 1/1301-BMR7128400 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE8000A series jidgezou George ZouDC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Product program PKE8410API PKE8411API PKE8413API PKE8415API PKE8416ZAPI PKE8416JAPI PKE8416HAPI Output 3.3 V, 10 A / 33 W 5 V, 8 A / 40 W 12 V, 3.33 A / 40 W 15 V, 2.67 A / 40 W 24 V, 1.67 A / 40 W 48 V, 0.83 A / 40 W 54 V, 0.74 A / 40 W Product number and Packaging PKE84XXXAPIn1 Options Remote Control logic n1  Description n1 P Date 2/27/2023 Rev 28701- BMR7128400 Rev. G G © Flex Z October 2023 Compatibility with RoHS requirements Ordering Information Options 2 (4) No. Negative* Positive Example: a product with positive logic, tray packaging would be PKE84XXXAPIP. * Standard variant (i.e. no option selected). General Information Reliability The failure rate () and mean time between failures (MTBF= 1/) is calculated at max output power and an operating ambient temperature (TA) of +40°C. Flex uses Telcordia SR-332 Issue 3 Method 1 to calculate the mean steady-state failure rate and standard deviation (). Telcordia SR-332 Issue 3 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Mean steady-state failure rate,  Std. deviation,  258.016nFailures/h 103.291nFailures/h MTBF (mean value) for the PKE841XA series = 3.87Mh. MTBF at 90% confidence level = 2.52Mh The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Warranty Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2023 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. 3 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 1/1301-BMR7128400 Technical Specification jidgezou George Zou Approved (Document resp) Checked PKE8000A series jidgezou George ZouDC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Safety Specification General information Flex Power DC/DC converters and DC/DC regulators are designed in accordance with the safety standards IEC 62368-1, EN 62368-1 and UL 62368-1 Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/EN/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • 3 (4) No. Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters, Power interface modules and DC/DC regulators are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/EN/UL 62368-1. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 62368-1 with regards to safety. Flex Power DC/DC converters, Power interface modules and DC/DC regulators are UL 62368-1 recognized and certified in accordance with EN 62368-1. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Isolated DC/DC converters & Power interface modules The product may provide basic or functional insulation between input and output according to IEC/EN/UL 62368-1 (see Safety Certificate), different conditions shall be met if the output of a basic or a functional insulated product shall be considered as ES1 energy source. For basic insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the Date 2/27/2023 Rev 28701- BMR7128400 Rev. G G © Flex Z October 2023 following conditions is met: • The input source provides supplementary or double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides functional or basic insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. For functional insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the following conditions is met: • The input source provides double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides basic or supplementary insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. • The input source is reliably connected to protective earth and provides basic or supplementary insulation according to IEC/EN/UL 62368-1 and the maximum input source voltage is 60 Vdc. Galvanic isolation between input and output is verified in an electric strength test and the isolation voltage (Viso) meets the voltage strength requirement for basic insulation according to IEC/EN/UL 62368-1. It is recommended to use a slow blow fuse at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating 4 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 1 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex Absolute Maximum Ratings Characteristics min max Unit TP1 Operating Temperature (see Thermal Consideration section) -40 +105 °C TS Storage temperature -55 +125 °C VI Input voltage 9 75 V Viso Isolation voltage (input to output) 3000 Viso Isolation voltage (input to case) 2000 Vdc Vdc Viso Isolation voltage (output to case) 1500 Vdc Vtr Input voltage transient (withstand for 1s) +100 V VRC Remote Control pin voltage +10 V -0.3 typ Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Fundamental Circuit Diagram for PKE8410API(P), PKE8411API(P), PKE8413API(P), PKE8415API(P) DRIVER CIRCUIT +Vin +Vo -Vo RC -Vin I/P UVP OTP PWM CONTROLLER ISOLATED CONTROL AND FEED BACK SUPERVISION Vadj 5 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) jidgezou George Zou Checked PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 2 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex Fundamental Circuit Diagram for PKE8416ZAPI(P), PKE8416JAPI(P), PKE8416HAPI(P) October 2023 6 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 3 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8410API(P) Electrical Specification 3.3 V, 10 A / 33 W Typical values given at: TP1 = +25°C, VI = 48 V, max IO, unless otherwise specified under Conditions. At least 330 μF E-Cap be added in the input terminal for stabilize input voltage source. (680 µF E-Cap be added in the output terminal for stabilize) Characteristics Conditions min typ max Unit VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 12 µF PO Output power η Efficiency 9 Note2 75 0 33 50% of max IO, VI = 12 V 89 max IO, VI = 12 V 85 50% of max IO, VI = 24 V 89 max IO, VI = 24 V 87 50% of max IO, VI = 48 V 87 max IO, VI = 48 V 87 V W % Pd Power Dissipation max IO 8.3 W Pli Input idling power IO = 0 A, VI = 48 V 0.42 W PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO, VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 10 A Output adjust range VO 242 kHz 3.267 3.3 3.333 V 2.97 3.63 V 0-100 % of max IO 3.201 3.399 V Idling voltage IO = 0 A 3.201 3.399 V Line regulation max IO -33 33 mV Load regulation VI = 48 V, 0-100 % of max IO -33 33 mV Vtr ttr Load transient recovery time tr Ramp-up time tf W 220 Output voltage tolerance band Load transient voltage deviation ts 0.2 198 (from 10−90% of VOi) Start-up time ±200 mV 500 µs 20 ms 24 ms max IO 200 µs max IO 12 ms VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time (from VI off to 10% of VO) tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 12.5 Isc Short circuit current TP1 = 25ºC 0.32 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 20 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 4.3 680 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum(or EE) Cap. cross to output. 10 A 20 A A 5000 µF 40 mVp-p V 7 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) jidgezou George Zou Checked PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8410APIP Power Derating Curve (Output Power VS Input Voltage) 4 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 8 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating (Vin=48V) Available load current vs. ambient air temperature and airflow at VI=48 V. See Thermal Consideration section. Output Current Derating (Vin=9V) Available load current vs. ambient air temperature and airflow at VI = 9 V. See Thermal Consideration section. October 2023 © Flex PKE8410API(P) Typical Characteristics 3.3 V, 10 A / 33 W Efficiency 5 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at I O > max IO at +25°C. Output Current Derating (Vin=48V) with heat sink Available load current vs. ambient air temperature and airflow at V I = 48 V. See Thermal Consideration section. 9 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 6 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex PKE8410API(P) Typical Characteristics 3.3 V, 10 A / 33 W Start-up October 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div.). IO = 10 A resistive load. Time scale: (50 ms/div.). IO = 10 A resistive load. Time scale: (50 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (5.0-7.5-5.0 A) at: Bottom trace: load current (1 A/div.). TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) IO = 10 A resistive load. Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 3.3 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 3.3V model by 8% to 3.56V the required external resistor is: Output Voltage Adjust, Increase:  1.9528  12   12.41 k R ADJ _UP    0.08   1.9528   12  k R ADJ _UP      Example: Output Voltage Adjust, Decrease: To trim down the 3V3 model by 7% to 3.07V the required external resistor is: RADJ _ DOWN  1.8627   15.815  k     1.8627  RADJ _ DOWN    15.815   10.79 k  0.07  10 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 7 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8411API(P) Electrical Specification 5 V, 8 A / 40 W Typical values given at: TP1 = +25°C, VI = 48 V, max IO, unless otherwise specified under Conditions. At least 330 µF E-Cap be added in the input terminal for stabilize input voltage source. Characteristics Conditions min typ Unit 75 V Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 12 µF PO Output power η Efficiency 9 max VI Note2 0 40 50% of max IO, VI = 12 V 87 max IO, VI = 12 V 85 50% of max IO, VI = 24 V 89 max IO, VI = 24 V 89 50% of max IO, VI = 48 V 86 max IO, VI = 48 V 88 W % Pd Power Dissipation max IO 11.1 W Pli Input idling power IO = 0 A, VI = 48 V 0.38 W PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO, 198 220 242 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 8 A 4.95 5 5.05 V 4.5 5.5 V Output adjust range VO 0-100 % of max IO 4.85 5.15 V Idling voltage IO = 0 A 4.85 5.15 V Line regulation max IO -50 50 mV Load regulation VI = 48 V, 0-100 % of max IO -50 50 mV Vtr ttr Load transient recovery time tr Ramp-up time tf W Output voltage tolerance band Load transient voltage deviation ts 0.2 (from 10−90% of VOi) Start-up time ±200 mV 500 µs 20 ms 24 ms max IO 200 µs max IO 12 ms VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time (from VI off to 10% of VO) tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 14.5 Isc Short circuit current TP1 = 25ºC 0.32 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 20 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 6.2 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 8 A 17 A A 3000 µF 40 mVp-p V 11 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) jidgezou George Zou Checked PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8411APIP Power Derating Curve (Output Power VS Input Voltage) 8 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 12 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating (Vin=48V) Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. Output Current Derating (Vin=9V) Available load current vs. ambient air temperature and airflow at VI = 9 V. See Thermal Consideration section. October 2023 © Flex PKE8411API(P) Typical Characteristics 5 V, 8 A / 40 W Efficiency 9 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at I O > max IO at +25°C. Output Current Derating (Vin=48V) with heat sink Available load current vs. ambient air temperature and airflow at V I = 48 V. See Thermal Consideration section. 13 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 10 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex PKE8411API(P) Typical Characteristics 5 V, 8 A / 40 W Start-up October 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div). IO = 8 A resistive load. Time scale: (100 ms/div.). IO = 8 A resistive load. Time scale: (100 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (4.0-6.0-4.0 A) at: Bottom trace: load current (1 A/div.). TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) IO = 8 A resistive load. Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 5.0 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 5.0V model by 8% to 5.4V the required external resistor is: Output Voltage Adjust, Increase:  1.5   10   8.75 k R ADJ _UP    0.08   1.5  R ADJ _UP    10  k    Example: Output Voltage Adjust, Decrease: To trim down the 5.0V model by 7% to 4.65V the required external resistor is: RADJ _ DOWN  1.5    13  k     1.5  RADJ _ DOWN    13   8.43 k  0.07  14 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 11 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8413API(P) Electrical Specification 12 V, 3.33 A / 40 W Typical values given at: TP1 = +25°C, VI= 48 V, max IO, unless otherwise specified under Conditions. At least 220 µF E-Cap be added in the input terminal for stabilize input voltage source. Characteristics Conditions min typ Unit 75 V Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 12 µF PO Output power η Efficiency 9 max VI Note2 max IO, VI = 12 V 88 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 90 50% of max IO, VI = 48 V 89 max IO, VI = 48 V 91 Power Dissipation max IO Pli Input idling power IO = 0 A, VI = 48 V PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO, VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 3.33 A Output adjust range % 4 W 0.5 W 0.2 W 198 220 242 kHz 11.88 12 12.12 V 10.8 13.2 V 0-100 % of max IO 11.856 12.144 V Idling voltage IO = 0 A 11.856 12.144 V Line regulation max IO -120 120 mV Load regulation VI = 48 V, 0-100 % of max IO -120 120 mV Vtr ttr Load transient recovery time tr Ramp-up time tf W Output voltage tolerance band Load transient voltage deviation ts 40 91 Pd VO 0 50% of max IO, VI = 12 V (from 10−90% of VOi) Start-up time ±200 mV 500 µs 20 ms 24 ms max IO 200 µs max IO 12 ms VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time (from VI off to 10% of VO) tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 20 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 15 4 3.33 A 6.66 A 0.32 0 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. A 1500 µF 40 mVp-p V 15 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) jidgezou George Zou Checked PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8413APIP Power Derating Curve (Output Power VS Input Voltage) 12 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 16 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating (Vin = 48 V) Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. Output Current Derating (Vin = 9 V) Available load current vs. ambient air temperature and airflow at VI = 9 V. See Thermal Consideration section. October 2023 © Flex PKE8413API(P) Typical Characteristics 12 V, 3.33 A / 40 W Efficiency 13 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. Output Current Derating (Vin = 24 V) Available load current vs. ambient air temperature and airflow at VI = 24 V. See Thermal Consideration section. 17 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 14 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex PKE8413API(P) Typical Characteristics 12 V, 3.33 A / 40 W Start-up October 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div). TP1 = +25°C, VI = 48 V, Bottom trace: input voltage (20 V/div.). IO = 3.33 A resistive load. Time scale: (200 ms/div.). IO = 3.33 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (1.66-2.49-1.66 A) at: Bottom trace: load current (1 A/div.). TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) IO = 3.33 A resistive load. Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 12 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 12V model by 8% to 12.96V the required external resistor is: Output Voltage Adjust, Increase:  3.5998  R ADJ _UP    24   21 k  0.08   3.5998   24  k R ADJ _ UP      Example: Output Voltage Adjust, Decrease: To trim down the 12V model by 7% to 11.16V the required external resistor is:  3.5796  RADJ _ DOWN    31.179  k     3.5796  RADJ _ DOWN    31.179   19.96 k  0.07  18 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 15 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8415API(P) Electrical Specification 15 V, 2.67 A / 40 W Typical values given at: TP1 = +25°C, VI = 48 V, max IO, unless otherwise specified under Conditions. At least 330 µF E-Cap be added in the input terminal for stabilize input voltage source. Characteristics Conditions min typ Unit 75 V Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 12 µF PO Output power η Efficiency 9 max VI Note2 0 40 50% of max IO, VI = 12 V 91 max IO, VI = 12 V 89 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 91 50% of max IO, VI = 48 V 89 max IO, VI = 48 V 90 W % Pd Power Dissipation max IO 5.4 W Pli Input idling power IO = 0 A, VI = 48 V 0.48 W PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO, VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 2.67 A Output adjust range VO 161 kHz 14.85 15 15.15 V 13.5 16.5 V 0-100 % of max IO 14.55 15.45 V Idling voltage IO = 0 A 14.55 15.45 V Line regulation max IO -150 150 mV Load regulation VI = 48 V, 0-100 % of max IO -150 150 mV Vtr ttr Load transient recovery time tr Ramp-up time tf W 140 Output voltage tolerance band Load transient voltage deviation ts 0.2 119 (from 10−90% of VOi) Start-up time ±200 mV 500 µs 20 ms 24 ms max IO 200 µs max IO 12 ms VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time (from VI off to 10% of VO) tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 4.2 Isc Short circuit current TP1 = 25ºC 0.32 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 40 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 18 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. 2.67 A 5.34 A A 1000 µF 80 mVp-p V 19 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) jidgezou George Zou Checked PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8415APIP Power Derating Curve (Output Power VS Input Voltage) 16 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 20 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating (Vin = 48 V) Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. Output Current Derating (Vin = 9 V) Available load current vs. ambient air temperature and airflow at VI = 9 V. See Thermal Consideration section. October 2023 © Flex PKE8415API(P) Typical Characteristics 15 V, 2.67 A / 40 W Efficiency 17 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at I O > max IO at +25°C. Output Current Derating (Vin = 48 V) with heat sink Available load current vs. ambient air temperature and airflow at V I = 48 V. See Thermal Consideration section. 21 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 18 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex PKE8415API(P) Typical Characteristics 15 V, 2.67 A / 40 W Start-up October 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div). IO = 2.67 A resistive load. Time scale: (50 ms/div.). IO = 2.67 A resistive load. Time scale: (50 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (50 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (1.33-2.0-1.33 A) at: Bottom trace: load current (1 A/div.). TP1 = +25°C, VI = 48 V. Time scale: (2 ms/div.) IO = 2.67 A resistive load. Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 15 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 15V model by 8% to 16.2V the required external resistor is: Output Voltage Adjust, Increase:  4.4993   30   26.24 k R ADJ _UP    0.08   4.4993   30  k R ADJ _ UP      Example: Output Voltage Adjust, Decrease: To trim down the 15V model by 7% to 13.95V the required external resistor is:  4.6  RADJ _ DOWN    39.099  k     4.6  RADJ _ DOWN    39.099   26.62 k  0.07  22 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 19 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8416ZAPI(P) Electrical Specification 24 V, 1.67 A / 40 W Typical values given at: TP1 = +25°C, VI = 48 V, max IO, unless otherwise specified under Conditions. At least 330 µF E-Cap be added in the input terminal for stabilize input voltage source. Characteristics Conditions min typ Unit 75 V Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 20 µF PO Output power η Efficiency 9 max VI Note2 0 40 50% of max IO, VI = 12 V 89 max IO, VI = 12 V 86 50% of max IO, VI = 24 V 90 max IO, VI = 24 V 89 50% of max IO, VI = 48 V 89 max IO, VI = 48 V 89 W % Pd Power Dissipation max IO, VI = 48 V 4.96 Pli Input idling power IO = 0 A, VI = 48 V 0.4 W PRC Input standby power VI = 48 V (turned off with RC) 0.2 W fs Switching frequency 0-100 % of max IO, VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 1.67 A Output adjust range VO 220 242 kHz 23.76 24 24.24 V 26.4 V 21.6 0-100 % of max IO 23.76 24 24.24 V Idling voltage IO = 0 A 23.76 24 24.24 V Line regulation max IO -240 240 mV Load regulation VI = 48 V, 0-100 % of max IO -240 240 mV Vtr ttr Load transient recovery time tr Ramp-up time tf 198 Output voltage tolerance band Load transient voltage deviation ts W (from 10−90% of VOi) Start-up time ±480 VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 300 (from VI off to 10% of VO) 500 µs 10 ms 12 ms max IO 0.5 ms max IO 10 ms 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time mV tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 2 1.67 A 2.9 A 0.2 200 29.4 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. A 440 µF 400 mVp-p 30.6 V 23 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8416ZAPI(P) Power Derating Curve (Output Power VS Input Voltage) 20 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 24 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating (Vin = 48 V) Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. October 2023 © Flex PKE8416ZAPI(P) Typical Characteristics 24 V, 1.67 A / 40 W Efficiency 21 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 25 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 22 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex PKE8416ZAPI(P) Typical Characteristics 24 V, 1.67 A / 40 W Start-up October 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (5 V/div.). IO = 1.67 A resistive load. Time scale: (50 ms/div.). IO = 1.67 A resistive load. Time scale: (20 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (50 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (0.83-1.253-0.83 A) at: Bottom trace: load current (500 mA/div.). IO = 1.67 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (500 us/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 24 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 24V model by 8% to 25.92V the required external resistor is: Output Voltage Adjust, Increase: R _ = 7.1319 − 56 kΩ Δ Output Voltage Adjust, Decrease: R _ 8.6681 = − 71.8 kΩ Δ R _ = 7.1319 − 56 kΩ 0.08 Example: To trim down the 24V model by 7% to 22.32V the required external resistor is: R _ = 8.6681 − 71.8 kΩ 0.07 26 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 23 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8416JAPI(P) Electrical Specification 48 V, 0.83 A / 40 W Typical values given at: TP1 = +25°C, VI= 48 V, max IO, unless otherwise specified under Conditions. At least 330 µF E-Cap be added in the input terminal for stabilize input voltage source. Characteristics Conditions min typ Unit 75 V Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 20 µF PO Output power η Efficiency 9 max VI Note2 0 40 50% of max IO, VI = 12 V 90 max IO, VI = 12 V 87 50% of max IO, VI = 24 V 91 max IO, VI = 24 V 91 50% of max IO, VI = 48 V 89 max IO, VI = 48 V 89 W % Pd Power Dissipation max IO, VI = 48 V 4.9 W Pli Input idling power IO = 0 A, VI = 48 V 0.47 W PRC Input standby power VI = 48 V (turned off with RC) fs Switching frequency 0-100 % of max IO, VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 0.83 A Output adjust range VO 242 kHz 47.52 48 48.48 V 52.8 V 43.2 0-100 % of max IO 47.5 48 48.48 V Idling voltage IO = 0 A 47.52 48 48.48 V Line regulation max IO -480 480 mV Load regulation VI = 48 V, 0-100 % of max IO -480 480 mV Vtr ttr Load transient recovery time tr Ramp-up time tf W 220 Output voltage tolerance band Load transient voltage deviation ts 0.2 198 (from 10−90% of VOi) Start-up time ±960 VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 300 (from VI off to 10% of VO) 500 µs 10 ms 12 ms max IO 0.5 ms max IO 10 ms 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time mV tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 1 0.83 A 1.45 A 0.12 300 54.88 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. A 220 µF 500 mVp-p 57.12 V 27 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8416JAPI(P) Power Derating Curve (Output Power VS Input Voltage) 24 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 28 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. October 2023 © Flex PKE8416JAPI(P) Typical Characteristics 48 V, 0.83 A / 40 W Efficiency 25 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 29 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 26 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex PKE8416JAPI(P) Typical Characteristics 48 V, 0.83 A / 40 W Start-up October 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (10 V/div). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (10 V/div). IO = 8 A resistive load. Time scale: (100 ms/div.). IO = 0.83 A resistive load. Time scale: (100 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (200 mV/div.). Output voltage response to load current step- Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (0.42-0.63-0.42 A) at: Bottom trace: load current (500 mA/div.). IO = 0.83 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (500 us/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 48 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 48V model by 8% to 51.84V the required external resistor is: Output Voltage Adjust, Increase: R _ = 14.932 − 100 kΩ Δ Output Voltage Adjust, Decrease: R _ 13.802 = − 128.73 kΩ Δ R _ = 14.932 − 100 kΩ 0.08 Example: To trim down the 48V model by 7% to 44.64V the required external resistor is: R _ = 13.802 − 128.73 kΩ 0.07 30 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 27 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8416HAPI(P) Electrical Specification 54 V, 0.74 A / 40 W Typical values given at: TP1 = +25°C, VI = 48 V, max IO, unless otherwise specified under Conditions. At least 330 µF E-Cap be added in the input terminal for stabilize input voltage source. Characteristics Conditions min typ Unit 75 V Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7.5 V VIon Turn-on input voltage Increasing input voltage 8.5 V CI Internal input capacitance 20 µF PO Output power η Efficiency 9 max VI Note2 0 40 50% of max IO, VI = 12 V 91 max IO, VI = 12 V 89 50% of max IO, VI = 24 V 90 max IO, VI = 24 V 91 50% of max IO, VI = 48 V 88 max IO, VI = 48 V 89 W % Pd Power Dissipation max IO, VI = 48 V 4.65 Pli Input idling power IO = 0 A, VI = 48 V 0.45 W PRC Input standby power VI = 48 V (turned off with RC) 0.2 W fs Switching frequency 0-100 % of max IO, VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 48 V, IO = 0.74 A Output adjust range VO 220 242 kHz 53.46 54 54.45 V 59.4 V 49.6 0-100 % of max IO 53.46 54 54.54 V Idling voltage IO = 0 A 53.46 54 54.54 V Line regulation max IO -540 540 mV Load regulation VI = 48 V, 0-100 % of max IO -540 540 mV Vtr ttr Load transient recovery time tr Ramp-up time tf 198 Output voltage tolerance band Load transient voltage deviation ts W (from 10−90% of VOi) Start-up time ±1080 VI = 48 V, Load step 50-75-50% of max IO, di/dt = 1 A/μs 300 (from VI off to 10% of VO) 500 µs 10 ms 12 ms max IO 0.5 ms max IO 10 ms 10-100% of max IO, TP1 = 25ºC, VI = 48 V (from VI connection to 90% of VOi) VI shut-down fall time mV tRC RC start-up time IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 1 OVP Over voltage protection TP1 = +25°C, VI = 48 V, 10-100% of max IO 0.88 0.74 A 1.26 A 0.12 300 60.76 Note 1: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum (or EE) Cap. cross to output. A 220 µF 500 mVp-p 63.24 V 31 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Note 2: PKE8416HAPI(P) Power Derating Curve (Output Power VS Input Voltage) 28 (30) Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G © Flex October 2023 32 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI = 48 V. See Thermal Consideration section. October 2023 © Flex PKE8416HAPI(P) Typical Characteristics 54 V, 0.74 A / 40 W Efficiency 29 (30) Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 33 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 2/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Technical Specification Date Rev 10/20/2023 F L 28701- BMR7128400 Rev. G October 2023 © Flex PKE8416HAPI(P) Typical Characteristics 54 V, 0.74 A / 40 W Start-up 30 (30) Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (10 V/div). TP1 = +25°C, VI = 9 V, Bottom trace: input voltage (10 V/div). IO = 0.74 A resistive load. Time scale: (100 ms/div.). IO = 0.74 A resistive load. Time scale: (100 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (100 mV/div.). Output voltage response to load current step- Top trace: output voltage (1 V/div.). TP1 = +25°C, VI = 48 V, Time scale: (5 µs/div.). change (0.37-0.555-0.37 A) at: Bottom trace: load current (500 mA/div.). IO = 0.74 A resistive load. 20 MHz bandwidth TP1 = +25°C, VI = 48 V. Time scale: (500 us/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 54 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 54V model by 8% to 58.3V the required external resistor is: Output Voltage Adjust, Increase: R _ 16.2 − 110 kΩ = Δ Output Voltage Adjust, Decrease: R _ 16.2 = − 142.4 kΩ Δ R _ = . . − 110 kΩ Example: To trim down the 54V model by 7% to 50.22V the required external resistor is: R _ = . . − 142.4 kΩ 34 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 1 (5) No. jidgezou George Zou Approved (Document resp) 3/1301-BMR7128400 Technical Specification Checked Date PKE8000A seriesZou DC-DC Converters jidgezou George Input 9-75 V, Output up to 10 A / 40 W 2/27/2023 Rev 28701BMR7128400 Rev. G E L October 2023 © Flex EMC Specification Conducted EMI measured according to EN55032, CISPR 32 and FCC part 15J (see test set-up). See Design Note 009 for further information. The fundamental switching frequency is 220 kHz for PKE 8416ZA PIP (40W/24V) at V I = 48 V and max IO. Conducted EMI Input terminal value (typ) Test set-up Layout recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. If a ground layer is used, it should be connected to the output of the product and the equipment ground or chassis. EMI without filter Optional external filter for class B Suggested external input filter in order to meet class B in EN 55032, CISPR 32 and FCC part 15J. A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Output ripple and noise Output ripple and noise measured according to figure below. See Design Note 022 for detailed information. CY9 CY1 CY3 L1 CY5 L2 CY15 +VIN 1 C01 C02 C03 C04 C05 C06 2 -VIN CY2 CY4 CY6 CY8 CY13 CY11 CY7 R2 3 +Vi -Vi ON/OFF +Vo -Vo TRIM 4 5 C07 C08 +VO C09 -VO 6 PKE8400 CY10 CY12 CY16 CY14 Filter components: CY5, CY6, CY7, CY8: 2.2nF (Y-CAP.) C03, C04:100 µF (EE-CAP.) C05:330 µF (EE-CAP.) L1:JUMPER, L2:3.6mH (CM CHOKE) NC: CY1-CY4, CY9-CY16, C01-C02, C06-C09, R2 Output ripple and noise test setup EMI with filter 35 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 2 (5) No. Checked PKE8000A seriesZou DC-DC Converters jidgezou George Input 9-75 V, Output up to 10 A / 40 W Operating Information Input Voltage The input voltage range 9 to 75 Vdc , At input voltages exceeding 80 V, the power loss will be higher than at normal input voltage and TP1 must be limited to absolute max +115°C. The absolute maximum continuous input voltage is 80 Vdc. Short duration transient disturbances can occur on the DC distribution and input of the product when a short circuit fault occurs on the equipment side of a protective device (fuse or circuit breaker). The voltage level, duration and energy of the disturbance are dependent on the particular DC distribution network characteristics and can be sufficient to damage the product unless measures are taken to suppress or absorb this energy. The transient voltage can be limited by capacitors and other energy absorbing devices like zener diodes connected across the positive and negative input conductors at a number of strategic points in the distribution network. The end-user must secure that the transient voltage will not exceed the value stated in the Absolute maximum ratings. ETSI TR 100 283 examines the parameters of DC distribution networks and provides guidelines for controlling the transient and reduce its harmful effect. Turn-off Input Voltage The products monitor the input voltage and will turn on and turn off at predetermined levels. The minimum hysteresis between turn on and turn off input voltage is 1.7 V. Remote Control (RC) The products are fitted with a remote control function referenced to the primary negative input connection (-In), with negative and positive logic options available.The RC function allows the product to be turned on/off by an external device like a semiconductor or mechanical switch. The RC pin has an internal pull up resistor to +In. The external device must provide a minimum required sink current to guarantee a voltage not higher than maximum voltage on the RC pin (see Electrical characteristics table). When the RC pin is left open, the voltage generated on the RC pin is 3 - 5 V. The standard product is provided with “negative logic” RC and will be on until the RC pin is connected to the -In. To turn off the product the RC pin should be left open, or connected to a voltage higher than 2.5 V referenced to -In. In situations where it is desired to have the product to power up automatically without the need for control signals or a switch, the RC pin can be wired directly to -In. 3/1301-BMR7128400 Technical Specification Date 2/27/2023 Rev 28701BMR7128400 Rev. G E L October 2023 © Flex The second option is “positive logic” remote control, which can be ordered by adding the suffix “P” to the end of the part number. When the RC pin is left open, the product starts up automatically when the input voltage is applied. Turn off is achieved by connecting the RC pin to the -In. The product will restart automatically when this connection is opened. See Design Note 021 for detailed information. Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. The products are designed for stable operation without external capacitors connected to the input or output. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains significant inductance, the addition of a 220 µF capacitor across the input of the product will ensure stable operation. The capacitor is not required when powering the product from an input source with an inductance below 10 µH. The minimum required capacitance value depends on the output power and the input voltage. The higher output power the higher input capacitance is needed. Approximately doubled capacitance value is required for a 24 V input voltage source compared to a 48 V input voltage source. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. It is equall y important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors will become part of the product’s control loop. The control loop is optimized for a wide range of external capacitance and the maximum recommended value that could be used without any additional analysis is found in the Electrical specification. The ESR of the capacitors is a very important parameter. Stable operation is guaranteed with a verified ESR value of >5 mΩ across the output connections. For further information please contact your local Ericsson Power Modules representative. 36 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 3 (5) No. Checked PKE8000A seriesZou DC-DC Converters jidgezou George Input 9-75 V, Output up to 10 A / 40 W Output Voltage Adjust (Vadj) The products have an Output Voltage Adjust pin (Vadj). This pin can be used to adjust the output voltage above or below Output voltage initial setting. When increasing the output voltage, the voltage at the output pins (including any remote sense compensation ) must be kept below the threshold of the over voltage protection, (OVP) to prevent the product from shutting down. At increased output voltages the maximum power rating of the product remains the same, and the max output current must be decreased correspondingly. To increase the voltage the resistor should be connected between the Vadj pin and -Out pin. The resistor value of the Output voltage adjust function is according to information given under the Output section for the respective product. To decrease the output voltage, the resistor should be connected between the Vadj pin and +Out pin. 3/1301-BMR7128400 Technical Specification Date Rev 28701BMR7128400 Rev. G E L 2/27/2023 October 2023 © Flex Position Description Max Temp. P1 Reference point TP1=105º C P1 (Reference Point) ● TOP VIEW Over Voltage Protection (OVP) The products have output over voltage protection that will shut down the product in over voltage conditions. The product will make continuous attempts to start up (non-latching mode) and resume normal operation automatically after removal of the over voltage condition. Over Temperature Protection (OTP) The products are protected from thermal overload by an internal over temperature shutdown circuit. When TP1 as defined in thermal consideration section exceeds 105°C the product will shut down. The product will make continuous attempts to start up (non-latching mode) and resume normal operation automatically when the temperature has dropped >5°C below the temperature threshold. Definition of product operating temperature The product operating temperatures is used to monitor the temperature of the product, and proper thermal conditions can be verified by measuring the temperature at positions P1. The temperature at this position (TP1) should not exceed the maximum temperatures in the table below. Temperature above maximum TP1, measured at the reference point P1 are not allowed and may cause permanent damage. Over Current Protection (OCP) The products include current limiting circuitry for protection at continuous overload. The output voltage will decrease towards zero for output currents in excess of max output current (max IO). The product will resume normal operation after removal of the overload. The load distribution should be designed for the maximum output short circuit current specified. Pin 1 Designation On/Off Control Function Remote control 2 -Input Negative input 3 +Input Positive input 4 +Out Positive output 5 6 -Out Trim Negative output Output voltage adjust 37 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) Checked PKE8000A seriesZou DC-DC Converters jidgezou George Input 9-75 V, Output up to 10 A / 40 W Thermal Consideration General The products are designed to operate in different thermal eviorments and sufficient cooling must be provided to ensure reliable operation. For products mounted on a PWB without a heat sink attached, cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependent on the airflow across the product. Increased airflow enhances the cooling of the product. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity at VI = 48 V. The product is tested on a 107 x 45 mm, 70 µm (2 oz), 1-layer test board in a wind box with 370 x 220 mm. Product can be selected with heat-sink version, available to add operating temperature range. For customer different requirement (customer added different size heat-sink), the option is product attached with Thermal glue tape so that customer can attach different size heat-sink by themselves. The heat-sink assembly drawing: 4 (5) No. 3/1301-BMR7128400 Technical Specification Date 2/27/2023 Rev 28701BMR7128400 Rev. G E L © Flex October 2023 Prepared (Subject resp) 1 (3) No. jidgezou George Zou Approved (Document resp) 38 PUBLIC PRODUCT SPECIFICATION Checked PKE8000A series jidgezou George ZouDC-DC Converters Input 9-75 V, Output up to 10 A / 40 W 4/1301-BMR7128400 Technical Specification Date 10/20/2023 Rev 28701- BMR7128400 Rev. G C © Flex Mechanical Information Notes: 1. All dimensions in inches (mm) 2. Tolerance .xx =±0.04” .xxx=±0.020” October 2023 39 PUBLIC PRODUCT SPEC. Prepared (Subject resp) No. jidgezou George Zou 5/1301-BMR7128400 Approved (Document resp) jidgezou George Zou PKE8000A series Checked DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Soldering Information - Hole Mounting The hole mounted product is intended for plated through hole mounting by wave or manual soldering. The pin temperature is specified to maximum to 270°C for maximum 10 seconds. A maximum preheat rate of 4°C/s and maximum preheat temperature of 150°C is suggested. When soldering by hand, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside the product or between the product and the host board. The cleaning residues may affect long time reliability and isolation voltage. Delivery Package Information The products are delivered in antistatic clamshell trays Tray Specifications Material Surface resistance Bakeability Antistatic PS Tray thickness 19.5 mm [0.767 inch] Box capacity 162 products (9 full trays/box) Tray weight 60 g empty, 640 g full tray 103 < Ohm/square < 109 This tray is not bake-able Date 2/27/2023 1 (3) Technical Specification Rev 28701BMR7128400 Rev. G C J © Flex October 2023 40 PUBLIC PRODUCT SPEC. Prepared (Subject resp) No. jidgezou George Zou 5/1301-BMR7128400 Approved (Document resp) jidgezou George Zou PKE8000A series Checked DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Package Date 2/27/2023 2 (3) Technical Specification Rev 28701BMR7128400 Rev. G C J © Flex October 2023 41 PUBLIC PRODUCT SPEC. Prepared (Subject resp) No. jidgezou George Zou 5/1301-BMR7128400 Approved (Document resp) Checked jidgezou George Zou PKE8000A series DC-DC Converters Input 9-75 V, Output up to 10 A / 40 W Date 2/27/2023 3 (3) Technical Specification Rev 28701BMR7128400 Rev. G C J October 2023 © Flex Product Qualification Specification Characteristics External visual inspection IPC-A-610 Change of temperature (Temperature cycling) IEC 60068-2-14 Na Temperature range Number of cycles Dwell/transfer time -55 to 105°C 20 30 min/3 min Cold (in operation) IEC 60068-2-1 Ad Temperature TA Duration -45°C 72 h Damp heat IEC 60068-2-30 Temperature Humidity Duration 45°C 95 % RH 72 hours Dry heat IEC 60068-2-2 Bd Temperature Duration 125°C 1000 h Electrostatic discharge susceptibility IEC 61340-3-1, JESD 22-A114 Human body model (HBM) Class 2, 2000 V Immersion in cleaning solvents IEC 60068-2-45 XA, method 2 Water Glycol ether {Isopropyl alcohol} 55°C 35°C {35°C} Mechanical shock IEC 60068-2-27 Ea Peak acceleration Duration 200 g 6 ms Moisture reflow sensitivity 1 J-STD-020E Level 1 (SnPb-eutectic) Level 3 (Pb Free) 225°C 260°C Operational life test MIL-STD-202G, method 108A Duration 1000 h Resistance to soldering heat IEC 60068-2-20 Tb, method 1A Solder temperature Duration 270°C 10-13 s Robustness of terminations IEC 60068-2-21 Test Ua1 Through hole mount products All leads Solderability IEC 60068-2-20 test Ta 1 Preconditioning Temperature, SnPb Eutectic Temperature, Pb-free 235°C 245°C Vibration, broad band random IEC 61373 Frequency RMS acceleration Duration 5 to 150 Hz 5 grms 5 hrs in each direction Notes 1 Only for products intended for wave soldering (plated through hole products)
PKE8413API 价格&库存
很抱歉,暂时无法提供与“PKE8413API”相匹配的价格&库存,您可以联系我们找货
