ECLB60W-48D15
ECLB60W-48D15
    CINCON
    DIP6 模块
    隔离模块 直流转换器 2 输出 15V -15V 2A,2A 18V - 75V 输入
ECLB60W-48D15 数据手册
ECLB60W SERIES 60 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 92%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully protected (OTP/OCP/OVP/UVLO)  1500Vdc I/O Isolation  Operating Case Temperature -40 to +105℃  2.05’’x1.2”x0.4’’ Six-Sided Shield Metal Case Standard 2”X1” Pin Out Compatible  Safety Meets IEC/EN/UL 62368-1  Full Load Operation up to 60℃ with Heat Sink LBT127 (M-C655) Natural Convection  -55℃ Operating Available (Suffix “-M2”) OUTPUT CURRENT INPUT CURRENT % EFF. CAPACITOR FULL LOAD (3) (2) LOAD MAX. 10 mA 10 mA 10 mA 10 mA 2279 mA 2717 mA 2717 mA 2717 mA 90.5 92 92.5 92 90 92 92 91 15000uF 12000uF 5000μF 4000μF 12 mA 12 mA 8 mA 8 mA 8 mA 8 mA 8 mA 8 mA 2747 mA 2747 mA 1140 mA 1359 mA 1359 mA 1359 mA 1374 mA 1374 mA 91 92 90.5 92 92.5 92 91 92 91 91 90 92 92 91 91 91 2500uF 2000uF 15000uF 12000uF 5000μF 4000μF 2500uF 2000uF MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD ECLB60W-24S33 ECLB60W-24S05 ECLB60W-24S12 ECLB60W-24S15 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 3.3 VDC 5.0 VDC 12 VDC 15 VDC 0 mA 0 mA 0 mA 0 mA 15 A 12 A 5A 4A ECLB60W-24D12 ECLB60W-24D15 ECLB60W-48S33 ECLB60W-48S05 ECLB60W-48S12 ECLB60W-48S15 ECLB60W-48D12 ECLB60W-48D15 9-36 VDC 9-36 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC ±12 VDC ±15 VDC 3.3 VDC 5.0 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA ±2.5 A ±2.0 A 15 A 12 A 5A 4A ±2.5 A ±2.0 A NOTE: 1. Nominal Input Voltage 24 or 48VDC. 2. Measured at Nominal Input Voltage. 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin. 4. -55℃ Start-up Screen per MIL-STD105E S1 Sampling Procedure for “-M2” Version. PART NUMBER Series ECLB60W- Nominal Input Voltage II Number of Outputs O Nominal Output Voltage XX 33:3.3VDC Remote On/Off Logic L 24:24 VDC 48:48 VDC S:Single D:Dual -Y (Option) None:M2.5x0.45 Mounting Inserts 05:5.0VDC ECLB60W Mounting Inserts 12:12VDC None:Positive N:Negative 15:15VDC 12:±12VDC -C:Clear Mounting Insert (2.65mm DIA.) Operating Case Temp. Range -Z (Option) None:-40~105℃ -M2:-55~105℃ 15:±15VDC Part Number Example: ECLB60W-24S12N-M2: LB Case, 60W, 4:1 18-75Vdc Input, Single 12Vdc Output, Negative Logic, -55~105℃ Operating Case Temp. Range www.cincon.com 1 REVISION: V18 ECLB60W Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Continuous Input Surge Voltage 100ms max. Operating Ambient Temperature At the center part of case plate (with derating) Suffix “-M2” (with Derating) Device Min. Typ. Max. 24Vin -0.3 36 48Vin -0.3 75 24Vin 50 48Vin 100 All -40 105 -M2 -55 105 Maximum Case Temperature All Storage Temperature All -55 Device Min. Units Vdc Vdc ℃ 105 ℃ 125 ℃ Max. Units INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Typ. 24Vin 9 24 36 48Vin 18 48 75 24Vin 8 8.5 8.8 48Vin 16.5 17 17.5 Vdc Input Under Voltage Lockout Turn-On Voltage Threshold Turn-Off Voltage Threshold Lockout Hysteresis Voltage Maximum Input Current No-Load Input Current 24Vin 7.7 8 8.3 48Vin 15.5 16 16.5 24Vin 0.5 48Vin 1 Vin=9V, Full load. 24Vin 7.5 Vin=18V, Full load. 48Vin 3.8 Vin=24, 48V, Io=0A Pi filter All Inrush Current (I2t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All Vdc Vdc A See Model Number Table Input Filter Vdc mA 0.1 30 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Voltage Set Point Accuracy Vin=24, 48V, Full load, Tc=25℃ All Output Voltage Balance Vin=24, 48V, Full load, Tc=25℃ Dual Min. Typ. Max. Units -1.5 +1.5 % -1.0 +1.0 % ±0.5 % Output Voltage Regulation Load Regulation Full Load to no load All Line Regulation Vin=High line to low line, full load All ±0.2 % Cross Regulation Load cross variation 10%/100% Dual ±5.0 % Temperature Coefficient Tc=-40℃ to 105℃ All ±0.02 %/℃ 3.3Vo 100 5Vo 100 Others 150 Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 1uF ceramic capacitors Output Current Range Vin= 9 to 36V, 18 to 75V See Model Number Table Over Current Protection Hiccup mode. Auto recovery Short Circuit Protection 110 All External Load Capacitance Full load (resistive) Output Voltage Trim Range Po≦max rated power, Io ≦ Io_max www.cincon.com All 130 A 170 2 % Continuous, auto recovery. See Model Number Table All mV -10 uF +10 % REVISION: V18 ECLB60W PARAMETER Over Voltage Protection NOTES and CONDITIONS Zener or TVS clamp Device Min. Typ. 3.3Vo 3.9 5Vo 6.2 12Vo 15 15Vo 18 ±12Vo ±15 ±15Vo ±18 Series Max. Units Vdc EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=24V, 48V Device Min. Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % 250 us Von/off to 10%Vo_set, Remote On All 15 ms Vin_min to 10%Vo_set, Power Up All 15 ms 10%Vo_set to 90%Vo_set All 15 ms ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Isolation Voltage (100% Factory Hi-Pot Tested @2sec.) 1 Minute; input to output Device Min. Typ. 1 Minute; input to case Isolation Resistance Input to output All Input to output All Isolation Capacitance Input to case All 1000 Output to case All 1000 Max. Units 1500 All 1000 1 Minute; output to case Vdc 1000 1000 MΩ 1500 pF FEATURE CHARACTERISTICS PARAMETER Switching Frequency NOTES and CONDITIONS Pulse width modulation (PWM), Fixed Device Min. Typ. Max. Single 210 245 265 Dual 270 300 330 Units KHz On/Off Control, Positive Remote On/Off Logic, Refer to –Vin Pin. Logic Low (Module Off) Von/off at Ion/off=1.0mA Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On -M2 0 1.0 Others 0 1.2 All 3.5 75 V V V On/Off Control, Negative Remote On/Off Logic, Refer to –Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery www.cincon.com Von/off at Ion/off=0.0uA, Pin open=Off Von/off at Ion/off=1.0mA All 3.5 75 -M2 0 1.0 Others 0 1.2 Ion/off at Von/off=0V All Logic high, Von/off=15V All Shutdown input idle current All Temperature at the center part of case, nonlatching All 3 0.3 4 V 1 mA 30 uA 10 mA 110 ℃ 100 ℃ REVISION: V18 ECLB60W Series GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Device Min. Typ. 3.3Vo 1116 5Vo 872 Io=100% of Io_max; 12Vo 930 MIL-HDBK - 217F_Notice 1, GB, 25℃ 15Vo 1230 ±12Vo 859 ±15Vo 1063 All 39 Weight Max. Units K hours grams Case Material Aluminum, UL 94V-0 Base Plate Material FR4 Potting Material Shock/Vibration UL 94V-0 Base: Copper Plating: Matte Tin MIL-STD-810F Compliant Humidity 95% RH max. Non Condensing Altitude 5000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI Meets EN55032 Compliant (with External Filter) ESD Meets EN61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated Immunity Meets EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient Meets EN61000-4-4 Level 3: On power input port, ±2kV, external input capacitor required Perf. Criteria A Surge Meets EN61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2kV Perf. Criteria A Conducted Immunity Meets EN61000-4-6 Level 3: 0.15~80MHz, 10V Pin Material Application Note Link Perf. Criteria A ECLB60W Series App Notes Packaging Information Link www.cincon.com Class A Packaging Information 4 REVISION: V18 ECLB60W ECLB60W-24S12 Eff Vs Io @25 Deg. C ECLB60W-24S12 Pd Vs Po @25 Deg. C 7 Power Dissipation (W) Efficiency (%) 100% 90% 80% 9V 12 V 24 V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 6 5 4 3 9 V 2 1 2 V 1 0 90% 100% 0% Current Load (%) ECLB60W-24S15 Pd Vs Po @25 Deg. C 8 Power Dissipation (W) Efficiency (%) 100% 90% 80% 9V 12 V 24 V 70% 20% 30% 40% 50% 60% 70% 80% 7 6 5 4 3 9 V 2 1 2 V 1 0 90% 100% 0% Current Load (%) ECLB60W-24D12 Pd Vs Po @25 Deg. C 8 Power Dissipation (W) Efficiency (%) 100% 90% 80% 9V 12 V 24 V 70% 20% 30% 40% 50% 60% 70% 80% 7 6 5 4 3 9 V 2 1 2 V 1 0 90% 100% 0% Current Load (%) ECLB60W-24D15 Pd Vs Po @25 Deg. C 7 Power Dissipation (W) 100% Efficiency (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) ECLB60W-24D15 Eff Vs Io @25 Deg. C 90% 80% 9V 12 V 24 V 70% 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) ECLB60W-24D12 Eff Vs Io @25 Deg. C 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) ECLB60W-24S15 Eff Vs Io @25 Deg. C 60% 10% Series 20% 30% 40% 50% 60% 70% 80% 5 4 3 9 V 2 1 2 V 1 0 90% 100% Current Load (%) www.cincon.com 6 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V18 ECLB60W ECLB60W-48S33 Eff Vs Io @25 Deg. C ECLB60W-48S33 Pd Vs Po @25 Deg. C 7 Power Dissipation (W) Efficiency (%) 100% 90% 80% 18 V 24 V 48 V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 6 5 4 3 1 8 V 2 4 V 2 1 0 90% 100% 0% Current Load (%) ECLB60W-48S05 Pd Vs Po @25 Deg. C 7 Power Dissipation (W) Efficiency (%) 100% 90% 80% 18 V 24 V 48 V 70% 20% 30% 40% 50% 60% 70% 80% 6 5 4 3 1 8 V 2 4 V 2 1 0 0% 90% 100% Current Load (%) ECLB60W-48S12 Pd Vs Po @25 Deg. C 9 Power Dissipation (W) Efficiency (%) 100% 90% 80% 18 V 24 V 48 V 70% 20% 30% 40% 50% 60% 70% 80% 8 7 6 5 4 1 8 V 2 4 V 3 2 1 0 90% 100% 0% Current Load (%) ECLB60W-48S15 Pd Vs Po @25 Deg. C 8 Power Dissipation (W) 100% Efficiency (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) ECLB60W-48S15 Eff Vs Io @25 Deg. C 90% 80% 18 V 24 V 48 V 70% 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) ECLB60W-48S12 Eff Vs Io @25 Deg. C 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) ECLB60W-48S05 Eff Vs Io @25 Deg. C 60% 10% Series 20% 30% 40% 50% 60% 70% 80% 6 5 4 3 1 8 V 2 4 V 2 1 0 90% 100% Current Load (%) www.cincon.com 7 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V18 ECLB60W ECLB60W-48D12 Eff Vs Io @25 Deg. C ECLB60W-48D12 Pd Vs Po @25 Deg. C 7 Power Dissipation (W) Efficiency (%) 100% 90% 80% 18 V 24 V 48 V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 6 5 4 3 1 8 V 2 4 V 2 1 0 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) ECLB60W-48D15 Eff Vs Io @25 Deg. C ECLB60W-48D15 Pd Vs Po @25 Deg. C 7 Power Dissipation (W) 100% Efficiency (%) Series 90% 80% 18 V 24 V 48 V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 6 5 4 3 1 8 V 2 4 V 2 1 0 0% 90% 100% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) 2.05 [52.0] 1.800 [45.72] 0.350 [8.89] BOTTOM VIEW 3 1 1.20 [30.5] 0.81 [20.7] Mounting lnserts M2.5*0.45 Through 2pl. 0.400 0.400 [10.16] [10.16] 0.400 [10.16] MECHANICAL SPECIFICATION 2 5 6 0.052 [1.33] 0.04 6pl. [1.0] 0.40 [10.2] 0.22 min [5.6] 1.43 [36.4] NOTE: Pin Size is 0.04±0.004 Inch (1.0±0.1 mm)DIA All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.02 ,x.xxx=±0.010 Millimeters:x.x=±0.5 , x.xx=±0.25 0.39 [10.0] 0.200 [5.08] 4 PIN 1 2 3 4 5 6 PIN CONNECTION Single Output Dual Output +V Input +V Input -V Input -V Input +V Output +V Output -V Output Trim -V Output Common Remote On/Off sales@cincon.com.tw 8 REVISION: V18
ECLB60W-48D15 价格&库存
很抱歉,暂时无法提供与“ECLB60W-48D15”相匹配的价格&库存,您可以联系我们找货
