ECLB60W SERIES
60 WATT 4:1 INPUT
ISOLATED DC-DC CONVERTER
Features
Efficiency Up to 92%
Fixed Switching Frequency
Regulated Outputs
Remote On/Off
Low No Load Power Consumption
Fully protected (OTP/OCP/OVP/UVLO)
1500Vdc I/O Isolation
Operating Case Temperature -40 to +105℃
2.05’’x1.2”x0.4’’ Six-Sided Shield Metal Case
Standard 2”X1” Pin Out Compatible
Safety Meets IEC/EN/UL 62368-1
Full Load Operation up to 60℃ with Heat Sink
LBT127 (M-C655) Natural Convection
-55℃ Operating Available (Suffix “-M2”)
OUTPUT CURRENT
INPUT CURRENT
% EFF.
CAPACITOR
FULL LOAD
(3)
(2)
LOAD MAX.
10 mA
10 mA
10 mA
10 mA
2279 mA
2717 mA
2717 mA
2717 mA
90.5
92
92.5
92
90
92
92
91
15000uF
12000uF
5000μF
4000μF
12 mA
12 mA
8 mA
8 mA
8 mA
8 mA
8 mA
8 mA
2747 mA
2747 mA
1140 mA
1359 mA
1359 mA
1359 mA
1374 mA
1374 mA
91
92
90.5
92
92.5
92
91
92
91
91
90
92
92
91
91
91
2500uF
2000uF
15000uF
12000uF
5000μF
4000μF
2500uF
2000uF
MODEL
INPUT
OUTPUT
NUMBER
VOLTAGE
VOLTAGE
MIN.
MAX.
NO LOAD
ECLB60W-24S33
ECLB60W-24S05
ECLB60W-24S12
ECLB60W-24S15
9-36 VDC
9-36 VDC
9-36 VDC
9-36 VDC
3.3 VDC
5.0 VDC
12 VDC
15 VDC
0 mA
0 mA
0 mA
0 mA
15 A
12 A
5A
4A
ECLB60W-24D12
ECLB60W-24D15
ECLB60W-48S33
ECLB60W-48S05
ECLB60W-48S12
ECLB60W-48S15
ECLB60W-48D12
ECLB60W-48D15
9-36 VDC
9-36 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
±12 VDC
±15 VDC
3.3 VDC
5.0 VDC
12 VDC
15 VDC
±12 VDC
±15 VDC
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
±2.5 A
±2.0 A
15 A
12 A
5A
4A
±2.5 A
±2.0 A
NOTE:
1. Nominal Input Voltage 24 or 48VDC.
2. Measured at Nominal Input Voltage.
3. Measured at 12VDC for 24Vin, 24VDC for 48Vin.
4. -55℃ Start-up Screen per MIL-STD105E S1 Sampling Procedure for “-M2” Version.
PART NUMBER
Series
ECLB60W-
Nominal Input
Voltage
II
Number of
Outputs
O
Nominal Output
Voltage
XX
33:3.3VDC
Remote On/Off
Logic
L
24:24 VDC
48:48 VDC
S:Single
D:Dual
-Y (Option)
None:M2.5x0.45
Mounting Inserts
05:5.0VDC
ECLB60W
Mounting Inserts
12:12VDC
None:Positive
N:Negative
15:15VDC
12:±12VDC
-C:Clear Mounting
Insert (2.65mm
DIA.)
Operating Case
Temp. Range
-Z (Option)
None:-40~105℃
-M2:-55~105℃
15:±15VDC
Part Number Example:
ECLB60W-24S12N-M2: LB Case, 60W, 4:1 18-75Vdc Input, Single 12Vdc Output, Negative Logic, -55~105℃ Operating Case Temp. Range
www.cincon.com
1
REVISION: V18
ECLB60W
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Input Voltage
Continuous
Input Surge Voltage
100ms max.
Operating Ambient Temperature
At the center part of case plate (with derating)
Suffix “-M2” (with Derating)
Device
Min.
Typ.
Max.
24Vin
-0.3
36
48Vin
-0.3
75
24Vin
50
48Vin
100
All
-40
105
-M2
-55
105
Maximum Case Temperature
All
Storage Temperature
All
-55
Device
Min.
Units
Vdc
Vdc
105
125
Max.
Units
INPUT CHARACTERISTICS
PARAMETER
Operating Input Voltage
Typ.
24Vin
9
24
36
48Vin
18
48
75
24Vin
8
8.5
8.8
48Vin
16.5
17
17.5
Vdc
Input Under Voltage Lockout
Turn-On Voltage Threshold
Turn-Off Voltage Threshold
Lockout Hysteresis Voltage
Maximum Input Current
No-Load Input Current
24Vin
7.7
8
8.3
48Vin
15.5
16
16.5
24Vin
0.5
48Vin
1
Vin=9V, Full load.
24Vin
7.5
Vin=18V, Full load.
48Vin
3.8
Vin=24, 48V, Io=0A
Pi filter
All
Inrush Current (I2t)
As per ETS300 132-2.
All
Input Reflected Ripple Current
P-P thru 12uH inductor, 5Hz to 20MHz
All
Vdc
Vdc
A
See Model Number Table
Input Filter
Vdc
mA
0.1
30
A2s
mA
OUTPUT CHARACTERISTICS
PARAMETER
Device
Voltage Set Point Accuracy
Vin=24, 48V, Full load, Tc=25℃
All
Output Voltage Balance
Dual
Min.
Typ.
Max.
Units
-1.5
+1.5
-1.0
+1.0
±0.5
Output Voltage Regulation
Load Regulation
Full Load to no load
All
Line Regulation
Vin=High line to low line, full load
All
±0.2
Cross Regulation
Load cross variation 10%/100%
Dual
±5.0
Temperature Coefficient
Tc=-40℃ to 105℃
All
±0.02
3.3Vo
100
5Vo
100
Others
150
Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth)
Peak-to-Peak
Full load, 1uF ceramic capacitors
Output Current Range
Vin= 9 to 36V, 18 to 75V
Over Current Protection
Hiccup mode. Auto recovery
Short Circuit Protection
110
All
External Load Capacitance
Full load (resistive)
Output Voltage Trim Range
Po≦max rated power, Io ≦ Io_max
www.cincon.com
All
130
A
170
2
Continuous, auto recovery.
All
mV
-10
uF
+10
REVISION: V18
ECLB60W
PARAMETER
Over Voltage Protection
Zener or TVS clamp
Device
Min.
Typ.
3.3Vo
3.9
5Vo
6.2
12Vo
15
15Vo
18
±12Vo
±15
±15Vo
±18
Series
Max.
Units
Vdc
EFFICIENCY
PARAMETER
100% Load
Vin=24V, 48V
Device
Min.
Typ.
Max.
Units
DYNAMIC CHARACTERISTICS
PARAMETER
Device
Min.
Typ.
Max.
Units
Output Voltage Current Transient
Error Band
Recovery Time
Turn-On Delay and Rise Time
Turn-On Delay Time, From
On/Off Control
Turn-On Delay Time, From Input
Output Voltage Rise Time
75% to 100% of Io_max step load change
di/dt=0.1A/us
(within 1% Vout nominal)
Full load (Constant resistive load)
All
±5
250
us
Von/off to 10%Vo_set, Remote On
All
15
ms
Vin_min to 10%Vo_set, Power Up
All
15
ms
10%Vo_set to 90%Vo_set
All
15
ms
ISOLATION CHARACTERISTICS
PARAMETER
Isolation Voltage
(100% Factory Hi-Pot Tested
@2sec.)
1 Minute; input to output
Device
Min.
Typ.
1 Minute; input to case
Isolation Resistance
Input to output
All
Input to output
All
Isolation Capacitance
Input to case
All
1000
Output to case
All
1000
Max.
Units
1500
All
1000
1 Minute; output to case
Vdc
1000
1000
MΩ
1500
pF
FEATURE CHARACTERISTICS
PARAMETER
Switching Frequency
Pulse width modulation (PWM), Fixed
Device
Min.
Typ.
Max.
Single
210
245
265
Dual
270
300
330
Units
KHz
On/Off Control, Positive Remote On/Off Logic, Refer to –Vin Pin.
Logic Low (Module Off)
Von/off at Ion/off=1.0mA
Logic High (Module On)
Von/off at Ion/off=0.0uA, Pin open=On
-M2
Others
All
3.5
75
V
V
V
On/Off Control, Negative Remote On/Off Logic, Refer to –Vin Pin
Logic High (Module Off)
Logic Low (Module On)
On/Off Current (for Both Remote
On/Off Logic)
Leakage Current (for Both Remote
On/Off Logic)
Off Converter Input Current
Over Temperature Shutdown
Over Temperature Recovery
www.cincon.com
Von/off at Ion/off=0.0uA, Pin open=Off
All
3.5
75
-M2
Others
Ion/off at Von/off=0V
All
Logic high, Von/off=15V
All
Shutdown input idle current
All
Temperature at the center part of case, nonlatching
All
3
0.3
4
V
1
mA
30
uA
10
mA
110
100
REVISION: V18
ECLB60W
Series
GENERAL SPECIFICATIONS
PARAMETER
MTBF
Device
Min.
Typ.
3.3Vo
1116
5Vo
872
Io=100% of Io_max;
12Vo
930
MIL-HDBK - 217F_Notice 1, GB, 25℃
15Vo
1230
±12Vo
859
±15Vo
1063
All
39
Weight
Max.
Units
K
hours
grams
Case Material
Aluminum, UL 94V-0
Base Plate Material
FR4
Potting Material
Shock/Vibration
UL 94V-0
Base: Copper
Plating: Matte Tin
MIL-STD-810F Compliant
Humidity
95% RH max. Non Condensing
Altitude
5000m Operating Altitude, 12000m Transport Altitude
Thermal Shock
MIL-STD-810F
Fire & Smoke
EN45545-2 Compliant
EMI
Meets EN55032 Compliant (with External Filter)
ESD
Meets EN61000-4-2
Level 3: Air ±8kV, Contact ±6kV
Perf. Criteria A
Radiated Immunity
Meets EN61000-4-3
Level 3: 80~1000MHz, 20V/m
Perf. Criteria A
Fast Transient
Meets EN61000-4-4
Level 3: On power input port, ±2kV, external input capacitor required
Perf. Criteria A
Surge
Meets EN61000-4-5
Level 4: Line to earth, ±4kV, Line to line, ±2kV
Perf. Criteria A
Conducted Immunity
Meets EN61000-4-6
Level 3: 0.15~80MHz, 10V
Pin Material
Application Note Link
Perf. Criteria A
ECLB60W Series App Notes
Packaging Information Link
www.cincon.com
Class A
4
REVISION: V18
ECLB60W
ECLB60W-24S12
Eff Vs Io @25 Deg. C
ECLB60W-24S12
Pd Vs Po @25 Deg. C
7
Power Dissipation (W)
Efficiency (%)
100%
90%
80%
9V
12
V
24
V
70%
60%
10%
20%
30%
40%
50%
60%
70%
80%
6
5
4
3
9
V
2
1
2
V
1
90% 100%
0%
Current Load (%)
ECLB60W-24S15
Pd Vs Po @25 Deg. C
8
Efficiency (%)
100%
90%
80%
9V
12
V
24
V
70%
20%
30%
40%
50%
60%
70%
80%
7
6
5
4
3
9
V
2
1
2
V
1
90% 100%
0%
Current Load (%)
ECLB60W-24D12
Pd Vs Po @25 Deg. C
8
Efficiency (%)
100%
90%
80%
9V
12
V
24
V
70%
20%
30%
40%
50%
60%
70%
80%
7
6
5
4
3
9
V
2
1
2
V
1
90% 100%
0%
Current Load (%)
ECLB60W-24D15
Pd Vs Po @25 Deg. C
7
100%
Efficiency (%)
10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Output Power (%)
ECLB60W-24D15
90%
80%
9V
12
V
24
V
70%
60%
10%
Output Power (%)
ECLB60W-24D12
60%
10%
Output Power (%)
ECLB60W-24S15
60%
10%
Series
20%
30%
40%
50%
60%
70%
80%
5
4
3
9
V
2
1
2
V
1
90% 100%
Current Load (%)
www.cincon.com
6
0%
Output Power (%)
6
REVISION: V18
ECLB60W
ECLB60W-48S33
ECLB60W-48S33
Pd Vs Po @25 Deg. C
7
Efficiency (%)
100%
90%
80%
18
V
24
V
48
V
70%
60%
10%
20%
30%
40%
50%
60%
70%
80%
6
5
4
3
1
8
V
2
4
V
2
1
90% 100%
0%
Current Load (%)
ECLB60W-48S05
Pd Vs Po @25 Deg. C
7
Efficiency (%)
100%
90%
80%
18
V
24
V
48
V
70%
20%
30%
40%
50%
60%
70%
80%
6
5
4
3
1
8
V
2
4
V
2
1
0%
90% 100%
Current Load (%)
ECLB60W-48S12
Pd Vs Po @25 Deg. C
9
Efficiency (%)
100%
90%
80%
18
V
24
V
48
V
70%
20%
30%
40%
50%
60%
70%
80%
8
7
6
5
4
1
8
V
2
4
V
3
2
1
90% 100%
0%
Current Load (%)
ECLB60W-48S15
Pd Vs Po @25 Deg. C
8
100%
Efficiency (%)
Output Power (%)
ECLB60W-48S15
90%
80%
18
V
24
V
48
V
70%
60%
10%
Output Power (%)
ECLB60W-48S12
60%
10%
Output Power (%)
ECLB60W-48S05
60%
10%
Series
20%
30%
40%
50%
60%
70%
80%
6
5
4
3
1
8
V
2
4
V
2
1
90% 100%
Current Load (%)
www.cincon.com
7
0%
Output Power (%)
7
REVISION: V18
ECLB60W
ECLB60W-48D12
ECLB60W-48D12
Pd Vs Po @25 Deg. C
7
Efficiency (%)
100%
90%
80%
18
V
24
V
48
V
70%
60%
10%
20%
30%
40%
50%
60%
70%
80%
6
5
4
3
1
8
V
2
4
V
2
1
90% 100%
0%
Current Load (%)
Output Power (%)
ECLB60W-48D15
ECLB60W-48D15
Pd Vs Po @25 Deg. C
7
100%
Efficiency (%)
Series
90%
80%
18
V
24
V
48
V
70%
60%
10%
20%
30%
40%
50%
60%
70%
80%
6
5
4
3
1
8
V
2
4
V
2
1
0%
90% 100%
Current Load (%)
Output Power (%)
2.05
[52.0]
1.800
[45.72]
0.350
[8.89]
BOTTOM VIEW
3
1
1.20
[30.5]
0.81
[20.7]
Mounting lnserts
M2.5*0.45 Through 2pl.
0.400 0.400
[10.16] [10.16]
0.400
[10.16]
MECHANICAL SPECIFICATION
2
5
6
0.052
[1.33]
0.04 6pl.
[1.0]
0.40
[10.2]
0.22 min
[5.6]
1.43
[36.4]
NOTE: Pin Size is 0.04±0.004 Inch (1.0±0.1 mm)DIA
All Dimensions in Inches[mm]
Tolerance Inches:x.xx=±0.02 ,x.xxx=±0.010
Millimeters:x.x=±0.5 , x.xx=±0.25
0.39
[10.0]
0.200
[5.08]
4
PIN
1
2
3
4
5
6
PIN CONNECTION
Single Output
Dual Output
+V Input
+V Input
-V Input
-V Input
+V Output
+V Output
-V Output
Trim
-V Output
Common
Remote On/Off
sales@cincon.com.tw
8
REVISION: V18
