PKE7315API
PKE7315API
    FLEX(伟创力)
    DIP6 模块
    隔离模块 直流转换器 1 输出 15V 2A 43V - 160V 输入
PKE7315API 数据手册
PUBLIC PUBLIC PRODUCT TABLE OFSPECIFICATION CONTENTS Prepared Prepared (Subject (Subject resp) resp) jidgezou jidgezouGeorge GeorgeZou Zou Approved (Document Approved (Document resp) resp) jiddaxie David Xie ZouDC-DC PKE7000A series jidgezou George (4) 21 (3) No. No. Checked Checked Converters Input 43 - 160 V, Output up to 6 A / 30 W 1/1301-BMR7127300 00152-BMR7127300 Date Date 3/2/2023 3/3/2023 Technical Specification Rev Rev 28701BMR 7127300 Rev. F D F © Flex D March 2023 Key Features • Industry standard case dimensions 50.8 x 25.4 x 11.9 mm (2 x 1 x 0.47 in) • High Efficiency up to 91% • 2250 Vdc input to output isolation • Meets safety requirements according to IEC/EN/UL 62368-1 • Compliant to EN 50155 General Characteristics • • • • • • • • Input under voltage shutdown Monotonic start-up Remote control Output over voltage protection Over temperature protection Output short-circuit protection Output voltage adjust function ISO 9001/14001 certified supplier Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 4 Electrical Specification 5 V, 6 A / 30 W 12 V, 2.5 A / 30 W 15 V, 2 A / 30 W 24 V, 1.25 A / 30 W 48 V, 0.625 A / 30 W 54 V, 0.555 A / 30 W PKE7311API......................................... 5 PKE7313API......................................... 8 PKE7315API....................................... 11 PKE7316ZAPI .................................... 14 PKE7316JAPI ..................................... 17 PKE7316HAPI .................................... 20 EMC Specification Operating Information Thermal Consideration Connections Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 23 ........................................................... 24 ........................................................... 25 ........................................................... 26 ........................................................... 27 ........................................................... 28 ........................................................... 28 ........................................................... 30 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 1/1301-BMR7127300 Approved (Document resp) Checked jiddaxie David series Xie PKE7000A DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Ordering Information Product program PKE7311API PKE7313API PKE7315API PKE7316ZAPI PKE7316JAPI PKE7316HAPI Output 5V, 6A / 30 W 12V, 2.5A / 30 W 15V, 2A / 30 W 24V, 1.25A / 30 W 48V, 0.625A / 30 W 54V, 0.555A / 30 W Product number and Packaging PKE73XXXAPI n1 Options n1 ο Remote control logic Options n1 3/2/2023 Technical Specification Rev 28701BMR 7127300 Rev. F D 2 (4) March 2023 © Flex chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Warranty Description P Date 2 Warranty period and conditions are defined in Flex Power Modules General Terms and Conditions of Sale. Negative* Positive Example: A positive logic product would be PKE7311APIP. The products are delivered in trays. * Standard variant (i.e. no option selected). General Information Reliability The failure rate (λ) and mean time between failures (MTBF= 1/λ) is calculated at max output power and an operating ambient temperature (TA) of +25°C. Flex uses Telcordia SR-332 Issue 3 Method 1 to calculate the mean steady-state failure rate and standard deviation (σ). Telcordia SR-332 Issue 3 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Mean steady-state failure rate, λ Std.deviation, σ 206.936 nFailures/h 512.45 nFailures/h MTBF (mean value) for the PKE73XXXA series = 4.83 Mh. MTBF at 90% confidence level = 1.6 Mh Compatibility with RoHS requirements The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2023 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou 1/1301-BMR7127300 Approved (Document resp) jiddaxie David series Xie PKE7000A Checked DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Safety Specification General information Flex converters and DC/DC regulators are designed in accordance with the safety standards IEC 62368-1, EN 62368-1 and UL 62368-1 Audio/video, information and communication technology equipment - Part 1: Safety requirements IEC/EN/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters, Power interface modules and DC/DC regulators are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/EN/UL 62368-1. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 60950-1 with regards to safety. Flex Power DC/DC converters, Power interface modules and DC/DC regulators are UL 62368-1 recognized and certified in accordance with EN 62368-1. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Isolated DC/DC converters & Power interface modules The product may provide basic or functional insulation between input and output according to IEC/EN/UL 62368-1 (see Safety Certificate), different conditions shall be met if the output of a basic or a functional insulated product shall be considered as ES1 energy source. For basic insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the Date 3/2/2023 Technical Specification Rev 28701BMR 7127300 Rev. F D 3 3 (4) March 2023 © Flex following conditions is met: • The input source provides supplementary or double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides functional or basic insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. For functional insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the following conditions is met: • The input source provides double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides basic or supplementary insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. • The input source is reliably connected to protective earth and provides basic or supplementary insulation according to IEC/EN/UL 62368-1 and the maximum input source voltage is 60 Vdc. Galvanic isolation between input and output is verified in an electric strength test and the isolation voltage (Viso) meets the voltage strength requirement for basic insulation according to IEC/EN/UL 62368-1. It is recommended to use a slow blow fuse at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating 4 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 1 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D 28701- BMR 7127300 Rev. F March 2023 © Flex Absolute Maximum Ratings Characteristics min max Unit TP1 Operating Temperature (see Thermal Consideration section) -40 typ +110 °C TS Storage temperature -55 +125 °C VI Input voltage 43 160 V Viso Isolation voltage (input to output) 3000 Vdc Viso Isolation voltage (input to case) 1500 Vdc Viso Isolation voltage (output to case) 1000 Vdc Vtr Input voltage transient (Tp 100ms) +200 V Vadj Adjust pin voltage (see Operating Information section) VRC Remote Control pin voltage (see Operating Information section) 0 Vo V Positive logic option 0 6 V Negative logic option 0 6 V Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Fundamental Circuit Diagram +Vin +Vo -Vo RC -Vin I/P UVP OTP PWM CONTROLLER ISOLATED CONTROL AND FEED BACK SUPERVISION Vadj 5 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D 28701- BMR 7127300 Rev. F March 2023 © Flex Electrical Specification PKE7311API(P) 5 V, 6 A / 30 W Tp1 = -40 to +110ºC, Vi = 43 to 160 V, {sense pins connected to output pins} unless otherwise specified under Conditions. Typical values given at: Tp1 = +25°C, Vi = 110 V, max Io, unless otherwise specified under Conditions. Additional Cin = 220 µF. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max Unit VI Input voltage range 160 V VIoff Turn-off input voltage Decreasing input voltage 39 40 41 V VIon Turn-on input voltage Increasing input voltage 41 42 43 V CI Internal input capacitance PO Output power 43 0 30 50% of max IO, VI = 43 V 91 max IO, VI = 43 V 89 50% of max IO, VI = 110 V 88 η Efficiency max IO, VI = 110 V 90 Pd Power Dissipation max IO 2.0 Pli Input idling power IO = 0 A, VI = 110 V 1.8 PRC Input standby power VI = 110 V (turned off with RC) fs Switching frequency 0-100 % of max IO 238 VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 110 V, IO = 6 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO Idling voltage IO = 0 A Line regulation max IO Load regulation VI = 110 V, 0-100% of max IO VO Vtr ttr Load transient voltage deviation Load transient recovery time (from 10−90% of VOi) Start-up time ts RC RC start-up time (from VRC connection to 90% of VOi) % 3.5 W W 0.1 W 322 4.95 5 5.05 V 4.5 5 5.5 V 4.85 5.15 V 4.85 5.15 V 15 25 mV 15 25 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 VI = 110 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs kHz 10-100% of max IO (from VI connection to 90% of VOi) tRC W 280 Ramp-up time tr μF 33 max IO Sink current see Note 1 See operating information Trigger level Decreasing / Increasing RC-voltage 10 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 110 V,TP1 < max TP1 11.4 Isc Short circuit current TP1 = 25ºC, see Note 2 2.56 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 3 20 OVP Over voltage protection TP1 = +25°C, VI = 110 V, 0-100% of max IO 6.8 Note 1: Sink current drawn by external device connected to the RC pin. Note 2: Hiccup mode, RMS value, see Operating Information section. Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum Cap. cross to output. ms mA V 6 0 12 A A A 6000 µF 40 mVp-p V 6 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 3 (19) No. 2/1301-BMR7127300 Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D 28701- BMR 7127300 Rev. F © Flex PKE7311API(P) Typical Characteristics 5 V, 6 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=110 V. See Thermal Consideration section. March 2023 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 7 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 4 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7311API(P) Typical Characteristics 5 V, 6 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (2 V/div.). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div}). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div.). IO = 6 A resistive load. Time scale: (200 ms/div.). IO = 6 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (100 mV/div.). TP1 = +25°C, VI = 110 V, Time scale: (5 µs/div.). change (3.0-4.5-3.0 A) at: Bottom trace: load current (2 A/div.). IO = 6 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 110 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 5.0 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 5.0V model by 8% to 5.4V the required external resistor is: Output Voltage Adjust, Increase:  1.5   10   8.75 k R ADJ _UP    0.08   1.5  R ADJ _UP    10  k    Example: Output Voltage Adjust, Decrease: To trim down the 5.0V model by 7% to 4.65V the required external resistor is:  1.5  RADJ _ DOWN    13  k     1.5  RADJ _ DOWN    13   8.43 k  0.07  8 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 5 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F March 2023 © Flex Electrical Specification PKE7313API(P) 12 V, 2.5 A / 30 W Tp1 = -40 to +110ºC, Vi = 43 to 160 V, {sense pins connected to output pins} unless otherwise specified under Conditions. Typical values given at: Tp1 = +25°C, Vi = 110 V, max Io, unless otherwise specified under Conditions. Additional Cin = 220 µF. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max Unit VI Input voltage range 160 V VIoff Turn-off input voltage Decreasing input voltage 39 40 41 V VIon Turn-on input voltage Increasing input voltage 41 42 43 V CI Internal input capacitance PO Output power 43 μF 33 0 30 50% of max IO, VI = 43 V 90 max IO, VI = 43 V 89 50% of max IO, VI = 110 V 87 W η Efficiency max IO, VI = 110 V 88 Pd Power Dissipation max IO 2.5 Pli Input idling power IO = 0 A, VI = 110 V 2.2 W PRC Input standby power VI = 110 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO 297.5 VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 110 V, IO = 2.5 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO 11.64 12.36 V Idling voltage IO = 0 A 11.64 12.36 V VO Vtr ttr tr ts tRC RC % 4 W 350 402.5 kHz 11.88 12 12.12 V 10.8 12 13.2 V Line regulation max IO 30 60 mV Load regulation VI = 110 V, 0-100% of max IO 30 60 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 Load transient voltage deviation Load transient recovery time VI = 110 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs Ramp-up time (from 10−90% of VOi) Start-up time 10-100% of max IO (from VI connection to 90% of VOi) RC start-up time (from VRC connection to 90% of VOi) max IO Sink current see Note 1 See operating information Trigger level Decreasing / Increasing RC-voltage 10 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 110 V,TP1 < max TP1 4.75 Isc Short circuit current TP1 = 25ºC, see Note 2 1.41 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 3 15 OVP Over voltage protection TP1 = +25°C, VI = 110 V, 0-100% of max IO 15 Note 1: Sink current drawn by external device connected to the RC pin. Note 2: Hiccup mode, RMS value, see Operating Information section. Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum Cap. cross to output. ms mA V 2.5 0 5.0 A A A 2000 µF 30 mVp-p V 9 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 6 (19) No. 2/1301-BMR7127300 Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7313API(P) Typical Characteristics 12 V, 2.5 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=110 V. See Thermal Consideration section. March 2023 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 10 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 7 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7313API(P) Typical Characteristics 12 V, 2.5 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (5 V/div.). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div}). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div.). IO = 2.5 A resistive load. Time scale: (200 ms/div.). IO = 2.5 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (10 mV/div.). Output voltage response to load current step- Top trace: output voltage (200 mV/div.). TP1 = +25°C, VI = 110 V, Time scale: (5 µs/div.). change (1.25-1.875-1.25 A) at: Bottom trace: load current (1 A/div.). IO = 2.5 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 110 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 12 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 12V model by 8% to 12.96V the required external resistor is: Output Voltage Adjust, Increase:  3.5998   24   21 k R ADJ _ UP    0.08   3.5998  R ADJ _UP    24  k    Example: Output Voltage Adjust, Decrease: To trim down the 12V model by 7% to 11.16V the required external resistor is:  3.5796  RADJ _ DOWN    31.179  k     3.5796  RADJ _ DOWN    31.179   19.96 k  0.07  11 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 8 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F March 2023 © Flex Electrical Specification PKE7315API(P) 15 V, 2 A / 30 W Tp1 = -40 to +110ºC, Vi = 43 to 160 V, {sense pins connected to output pins} unless otherwise specified under Conditions. Typical values given at: Tp1 = +25°C, Vi = 110 V, max Io, unless otherwise specified under Conditions. Additional Cin = 220 µF. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max VI Input voltage range 160 V VIoff Turn-off input voltage Decreasing input voltage 39 40 41 V VIon Turn-on input voltage Increasing input voltage 41 42 43 CI Internal input capacitance PO Output power 43 0 30 90 max IO, VI = 43 V 87 50% of max IO, VI = 110 V 91 V μF 33 50% of max IO, VI = 43 V Unit W η Efficiency max IO, VI = 110 V 90 Pd Power Dissipation max IO 1.5 Pli Input idling power IO = 0 A, VI = 110 V 0.8 PRC Input standby power VI = 110 V (turned off with RC) fs Switching frequency 0-100 % of max IO 297.5 VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 110 V, IO = 2 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO 14.55 15.45 V Idling voltage IO = 0 A 14.55 15.45 V VO Vtr ttr 0.1 kHz 14.85 15 15.15 V 13.5 15 16.5 V max IO 50 75 mV VI = 110 V, 0-100% of max IO 50 75 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 Load transient voltage deviation (from 10−90% of VOi) VI = 110 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs 10-100% of max IO (from VI connection to 90% of VOi) RC W 402.5 Load regulation Start-up time tRC W W Line regulation Load transient recovery time ts 3.0 350 Ramp-up time tr % RC start-up time (from VRC connection to 90% of VOi) max IO Sink current see Note 1 See operating information Trigger level Decreasing / Increasing RC-voltage 10 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 110 V,TP1 < max TP1 3.25 Isc Short circuit current TP1 = 25ºC, see Note 2 1.52 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 3 20 OVP Over voltage protection TP1 = +25°C, VI = 110 V, 0-100% of max IO 18 Note 1: Sink current drawn by external device connected to the RC pin. Note 2: Hiccup mode, RMS value, see Operating Information section. Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum Cap. cross to output. ms mA V 2 0 4 A A A 1500 µF 40 mVp-p V 12 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 9 (19) No. 2/1301-BMR7127300 Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7315API(P) Typical Characteristics 15 V, 2 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=110 V. See Thermal Consideration section. March 2023 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 13 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 10 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7315API(P) Typical Characteristics 15 V, 2 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div}). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div.). IO = 2 A resistive load. Time scale: (200 ms/div.). IO = 2 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 110 V, Time scale: (5 µs/div.). change (1.0-1.5-1.0 A) at: Bottom trace: load current (1 A/div.). IO = 2 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 110 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 15 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 15V model by 8% to 16.2V the required external resistor is: Output Voltage Adjust, Increase:  4.4993   30   26.24 k R ADJ _UP    0.08   4.4993  R ADJ _UP    30  k    Example: Output Voltage Adjust, Decrease: To trim down the 15V model by 7% to 13.95V the required external resistor is:  4.6  RADJ _ DOWN    39.099  k     4.6  RADJ _ DOWN    39.099   26.62 k  0.07  14 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 11 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F March 2023 © Flex Electrical Specification PKE7316ZAPI(P) 24 V, 1.25 A / 30 W Tp1 = -40 to +110ºC, Vi = 43 to 160 V, {sense pins connected to output pins} unless otherwise specified under Conditions. Typical values given at: Tp1 = +25°C, Vi = 110 V, max Io, unless otherwise specified under Conditions. Additional Cin = 220 µF. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max Unit VI Input voltage range 160 V VIoff Turn-off input voltage Decreasing input voltage 39 40 41 V VIon Turn-on input voltage Increasing input voltage 41 42 43 V CI Internal input capacitance PO Output power 43 μF 33 0 30 50% of max IO, VI = 43 V 89 max IO, VI = 43 V 90 50% of max IO, VI = 110 V 87 W η Efficiency max IO, VI = 110 V 88 Pd Power Dissipation max IO 2.5 Pli Input idling power IO = 0 A, VI = 110 V 0.8 W PRC Input standby power VI = 110 V (turned off with RC) 0.1 W fs Switching frequency 0-100 % of max IO 297.5 VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 110 V, IO = 1.25 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO 23.28 24.72 V Idling voltage IO = 0 A 23.28 24.72 V VO Vtr ttr 402.5 23.76 24 24.24 V 21.6 24 26.4 V max IO 60 120 mV VI = 110 V, 0-100% of max IO 60 120 mV ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 Load transient voltage deviation (from 10−90% of VOi) VI = 110 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs 10-100% of max IO (from VI connection to 90% of VOi) RC kHz Load regulation Start-up time tRC W Line regulation Load transient recovery time ts 4 350 Ramp-up time tr % RC start-up time (from VRC connection to 90% of VOi) max IO Sink current see Note 1 See operating information Trigger level Decreasing / Increasing RC-voltage 10 0.8/2.5 IO Output current 0 Ilim Current limit threshold VI = 110 V,TP1 < max TP1 2.22 Isc Short circuit current TP1 = 25ºC, see Note 2 0.96 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 3 25 OVP Over voltage protection TP1 = +25°C, VI = 110 V, 0-100% of max IO 30 Note 1: Sink current drawn by external device connected to the RC pin. Note 2: Hiccup mode, RMS value, see Operating Information section. Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum Cap. cross to output. ms mA V 1.25 0 2.5 A A A 1000 µF 50 mVp-p V 15 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 12 (19) No. 2/1301-BMR7127300 Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7316ZAPI(P) Typical Characteristics 24 V, 1.25 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=110 V. See Thermal Consideration section. March 2023 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 16 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 13 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7316ZAPI(P) Typical Characteristics 24 V, 1.25 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (10 V/div.). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div}). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div.). IO = 1.25 A resistive load. Time scale: (200 ms/div.). IO = 1.25 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (200 mV/div.). TP1 = +25°C, VI = 110 V, Time scale: (5 µs/div.). change (0.625-0.937-0.625 A) at: Bottom trace: load current (500 mA/div.). IO = 1.25 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 110 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 24 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 24V model by 8% to 25.92V the required external resistor is: Output Voltage Adjust, Increase:  7.1319   56  k R ADJ _ UP      Output Voltage Adjust, Decrease: RADJ _ DOWN  8.6681    71.8  k     7.1319   56   33.15 k R ADJ _ UP    0.08  Example: To trim down the 24V model by 7% to 22.32V the required external resistor is:  8.6681  RADJ _ DOWN    71.8   52.03 k  0.07  17 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 14 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F March 2023 © Flex Electrical Specification PKE7316JAPI(P) 48 V, 0.625 A / 30 W Tp1 = -40 to +110ºC, Vi = 43 to 160 V, {sense pins connected to output pins} unless otherwise specified under Conditions. Typical values given at: Tp1 = +25°C, Vi = 110 V, max Io, unless otherwise specified under Conditions. Additional Cin = 220 µF. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max Unit VI Input voltage range 160 V VIoff Turn-off input voltage Decreasing input voltage 39 40 41 V VIon Turn-on input voltage Increasing input voltage 41 42 43 V CI Internal input capacitance PO Output power 43 μF 33 0 30 50% of max IO, VI = 43 V 90 max IO, VI = 43 V 88 50% of max IO, VI = 110 V 91 W η Efficiency max IO, VI = 110 V 90 Pd Power Dissipation max IO 1.5 Pli Input idling power IO = 0 A, VI = 110 V 0.8 PRC Input standby power VI = 110 V (turned off with RC) fs Switching frequency 0-100 % of max IO 297.5 VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 110 V, IO = 0.625 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO 46.56 49.44 V Idling voltage IO = 0 A 46.56 49.44 V VO Vtr ttr 0.1 kHz 47.52 48 48.48 V 43.2 48 52.8 V max IO 120 240 mV VI = 110 V, 0-100% of max IO 120 240 mV VI = 110 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 Load transient voltage deviation (from 10−90% of VOi) 10-100% of max IO (from VI connection to 90% of VOi) RC W 402.5 Load regulation Start-up time tRC W W Line regulation Load transient recovery time ts 3.2 350 Ramp-up time tr % RC start-up time (from VRC connection to 90% of VOi) max IO Sink current see Note 1 See operating information Trigger level Decreasing / Increasing RC-voltage IO Output current Ilim Current limit threshold 10 0.8/2.5 0 VI = 110 V,TP1 < max TP1 1.05 Isc Short circuit current TP1 = 25ºC, see Note 2 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 3 80 OVP Over voltage protection TP1 = +25°C, VI = 110 V, 0-100% of max IO 58 Note 1: Sink current drawn by external device connected to the RC pin. Note 2: Hiccup mode, RMS value, see Operating Information section. Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum Cap. cross to output. ms mA V 0.625 A 1.25 A 500 µF 150 mVp-p 0.48 0 A V 18 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 15 (19) No. 2/1301-BMR7127300 Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7316JAPI(P) Typical Characteristics 48 V, 0.625 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=110 V. See Thermal Consideration section. March 2023 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 19 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 16 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE7316JAPI(P) Typical Characteristics 48 V, 0.625 A / 30 W Start-up March 2023 Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div}). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div.). IO = 0.625 A resistive load. Time scale: (200 ms/div.). IO = 0.625 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (20 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 110 V, Time scale: (5 µs/div.). change (0.312-0.468-0.312 A) at: Bottom trace: load current (200 mA/div.). IO = 0.625 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 110 V. Time scale: (2 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 48 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 48V model by 8% to 51.84V the required external resistor is: Output Voltage Adjust, Increase:  14.3215  R ADJ _UP    100   79.02 k  0.08   14.3215   100  k R ADJ _UP      Example: Output Voltage Adjust, Decrease: To trim down the 48V model by 7% to 44.64V the required external resistor is:  13.8785  RADJ _ DOWN    128.2  k     13.8785  RADJ _ DOWN   128.2   70.06 k  0.07  20 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 17 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F March 2023 © Flex Electrical Specification PKE7316HAPI(P) 54 V, 0.555 A / 30 W Tp1 = -40 to +110ºC, Vi = 43 to 160 V, {sense pins connected to output pins} unless otherwise specified under Conditions. Typical values given at: Tp1 = +25°C, Vi = 110 V, max Io, unless otherwise specified under Conditions. Additional Cin = 220 µF. See Operating Information section for selection of capacitor types. Characteristics Conditions min typ max Unit VI Input voltage range 160 V VIoff Turn-off input voltage Decreasing input voltage 39 40 41 V VIon Turn-on input voltage Increasing input voltage 41 42 43 V CI Internal input capacitance PO Output power 43 μF 33 0 30 50% of max IO, VI = 43 V 87 max IO, VI = 43 V 85 50% of max IO, VI = 110 V 87 W η Efficiency max IO, VI = 110 V 88 Pd Power Dissipation max IO 2.5 Pli Input idling power IO = 0 A, VI = 110 V 0.8 PRC Input standby power VI = 110 V (turned off with RC) fs Switching frequency 0-100 % of max IO 297.5 VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 110 V, IO = 0.625 A Output adjust range See operating information Output voltage tolerance band 0-100% of max IO 52.38 55.62 V Idling voltage IO = 0 A 52.38 55.62 V VO Vtr ttr 0.1 kHz 53.46 54 54.54 V 48.6 54 59.4 V max IO 150 270 mV VI = 110 V, 0-100% of max IO 150 270 mV VI = 110 V, Load step 50-75-50% of max IO, di/dt = 100mA/μs ±275 ±500 mV 250 500 µs 5 10 ms 8 15 ms 2 5 Load transient voltage deviation (from 10−90% of VOi) 10-100% of max IO (from VI connection to 90% of VOi) RC W 402.5 Load regulation Start-up time tRC W W Line regulation Load transient recovery time ts 5.6 350 Ramp-up time tr % RC start-up time (from VRC connection to 90% of VOi) max IO Sink current see Note 1 See operating information Trigger level Decreasing / Increasing RC-voltage IO Output current Ilim Current limit threshold 10 0.8/2.5 0 VI = 110 V,TP1 < max TP1 0.825 Isc Short circuit current TP1 = 25ºC, see Note 2 Cout Recommended Capacitive Load TP1 = 25ºC VOac Output ripple & noise See ripple & noise section, VOi, max IO, see Note 3 100 OVP Over voltage protection TP1 = +25°C, VI = 110 V, 0-100% of max IO 62 Note 1: Sink current drawn by external device connected to the RC pin. Note 2: Hiccup mode, RMS value, see Operating Information section. Note 3: Measured with 0.1 µF ceramic Cap. and 10 µF tantalum Cap. cross to output. ms mA V 0.555 A 1.11 A 330 µF 200 mVp-p 0.48 0 A V 21 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 18 (19) No. 2/1301-BMR7127300 Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D L 28701- BMR 7127300 Rev. F © Flex PKE 7316HA PI(P) Typical Characteristics 54 V, 0.555 A / 30 W Efficiency Efficiency vs. load current and input voltage at +25C. Output Current Derating Available load current vs. ambient air temperature and airflow at VI=110 V. See Thermal Consideration section. March 2023 Power Dissipation Dissipated power vs. load current and input voltage at +25°C. Current Limit Characteristics Output voltage vs. load current at IO > max IO at +25°C. 22 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 19 (19) No. jidgezou George Zou 2/1301-BMR7127300 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Technical Specification Date Rev 3/3/2023 D March 2023 © Flex PKE7316HAPI(P) Typical Characteristics 54 V, 0.555 A / 30 W Start-up L 28701- BMR 7127300 Rev. F Shut-down Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). Start-up enabled by connecting VI at: Top trace: output voltage (20 V/div.). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div}). TP1 = +25°C, VI = 110 V, Bottom trace: input voltage (50 V/div.). IO = 0.555 A resistive load. Time scale: (200 ms/div.). IO = 0.555 A resistive load. Time scale: (200 ms/div.). Output Ripple & Noise Output Load Transient Response Output voltage ripple at: Trace: output voltage (50 mV/div.). Output voltage response to load current step- Top trace: output voltage (500 mV/div.). TP1 = +25°C, VI = 110 V, Time scale: (5 µs/div.). change (0.278-0.416-0.278 A) at: Bottom trace: load current (200 mA/div.). IO = 0.555 A resistive load. 20MHz bandwidth TP1 = +25°C, VI = 110 V. Time scale: (5 ms/div.) Output Voltage Adjust (TRIM UP/TRIM DOWN) Output Voltage = 54 V The resistor value for an adjusted output voltage is calculated by Example: using the following equations: To trim up the 54V model by 8% to 58.32V the required external resistor is: Output Voltage Adjust, Increase:  16.2  R ADJ _ UP    110   92.5 k  0.08   16.2  R ADJ _ UP    110  k    Example: Output Voltage Adjust, Decrease: To trim down the 54V model by 7% to 50.22V the required external resistor is: RADJ _ DOWN  16.2    142.4  k     16.2  RADJ _ DOWN   142.4   89.03 k  0.07  PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 23 1 (5) No. jidgezou George Zou Approved (Document resp) 3/1301-BMR7127300 Technical Specification Checked Date PKE7000A seriesZou DC-DC Converters jidgezou George Input 43 - 160 V, Output up to 6 A / 30 W 3/2/2023 Rev 28701BMR 7127300 Rev. F D L March 2023 © Flex EMC Specification Conducted EMI measured according to EN55011 (see test set-up). See Design Note 009 for further information. The fundamental switching frequency is 350 kHz for PKE7313APIP at VI = 110 V and max IO. Conducted EMI Input terminal value (typ) Test set-up EMI without filter Optional external filter for class B Suggested external input filter in order to meet class B in EN 55011 CY7 CY1 +Vin C01 + CY3 L1 C02 + CY5 +Vin CY2 +Vo MODULE -Vin -Vin +Vout -Vout CY4 Layout recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. If a ground layer is used, it should be connected to the output of the product and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Output ripple and noise Output ripple and noise measured according to figure below. See Design Note 022 for detailed information. -Vo CY6 CY8 Filter components: L1: 6.0mH (CM CHOKE) C01, C02: 100 µF(EE-CAP.) CY1, CY2: 1nF (Y-CAP.) CY5, CY6, CY8: 0.1 nF (Y-CAP.) NC: CY3, CY4, CY7 Output ripple and noise test setup EMI with filter PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 24 2 (5) No. jidgezou George Zou Approved (Document resp) Checked PKE7000A seriesZou DC-DC Converters jidgezou George Input 43 - 160 V, Output up to 6 A / 30 W Operating Information Input Voltage The input voltage range 43 to 160 Vdc , At input voltages exceeding 160 V, the power loss will be higher than at normal input voltage and TP1 must be limited to absolute max +110°C. The absolute maximum continuous input voltage is 160 Vdc. Short duration transient disturbances can occur on the DC distribution and input of the product when a short circuit fault occurs on the equipment side of a protective device (fuse or circuit breaker). The voltage level, duration and energy of the disturbance are dependant on the particular DC distribution network characteristics and can be sufficient to damage the product unless measures are taken to suppress or absorb this energy. The transient voltage can be limited by capacitors and other energy absorbing devices like zener diodes connected across the positive and negative input conductors at a number of strategic points in the distribution network. The end-user must secure that the transient voltage will not exceed the value stated in the Absolute maximum ratings. ETSI TR 100 283 examines the parameters of DC distribution networks and provides guidelines for controlling the transient and reduce its harmful effect. Turn-off Input Voltage The products monitor the input voltage and will turn on and turn off at predetermined levels. The minimum hysteresis between turn on and turn off input voltage is 1.7 V. Remote Control (RC) The products are fitted with a remote control function referenced to the primary negative input connection (-In), with negative and positive logic options available.The RC function allows the product to be turned on/off by an external device like a semiconductor or mechanical switch. The RC pin has an internal pull up resistor to +In. The external device must provide a minimum required sink current to guarantee a voltage not higher than maximum voltage on the RC pin (see Electrical characteristics table). When the RC pin is left open, the voltage generated on the RC pin is 3 - 5 V. The standard product is provided with “negative logic” RC and will be on until the RC pin is connected to the -In. To turn off the product the RC pin should be left open, or connected to a voltage higher than 2.5 V referenced to -In. In situations where it is desired to have the product to power up automatically without the need for control signals or a switch, the RC pin can be wired directly to -In. 3/1301-BMR7127300 Technical Specification Date 3/2/2023 Rev 28701BMR 7127300 Rev. F D L March 2023 © Flex The second option is “positive logic” remote control, which can be ordered by adding the suffix “P” to the end of the part number. When the RC pin is left open, the product starts up automatically when the input voltage is applied. Turn off is achieved by connecting the RC pin to the -In. The product will restart automatically when this connection is opened. See Design Note 021 for detailed information. Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. The products are designed for stable operation without external capacitors connected to the input or output. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains significant inductance, the addition of a 22 µF capacitor across the input of the product will ensure stable operation. The capacitor is not required when powering the product from an input source with an inductance below 10 µH. The minimum required capacitance value depends on the output power and the input voltage. The higher output power the higher input capacitance is needed. Approximately doubled capacitance value is required for a 24 V input voltage source compared to a 48 V input voltage source. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. It is equally important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors will become part of the product’s control loop. The control loop is optimized for a wide range of external capacitance and the maximum recommended value that could be used without any additional analysis is found in the Electrical specification. The ESR of the capacitors is a very important parameter. Stable operation is guaranteed with a verified ESR value of >5 mΩ across the output connections. For further information please contact your local Flex representative. 25 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) jidgezou George Zou Approved (Document resp) 3 (5) No. Checked PKE7000A seriesZou DC-DC Converters jidgezou George Input 43 - 160 V, Output up to 6 A / 30 W Output Voltage Adjust (Vadj) The products have an Output Voltage Adjust pin (Vadj). This pin can be used to adjust the output voltage above or below Output voltage initial setting. When increasing the output voltage, the voltage at the output pins (including any remote sense compensation ) must be kept below the threshold of the over voltage protection, (OVP) to prevent the product from shutting down. At increased output voltages the maximum power rating of the product remains the same, and the max output current must be decreased correspondingly. To increase the voltage the resistor should be connected between the Vadj pin and -Out pin. The resistor value of the Output voltage adjust function is according to information given under the Output section for the respective product. To decrease the output voltage, the resistor should be connected between the Vadj pin and +Out pin. Over Temperature Protection (OTP) The products are protected from thermal overload by an internal over temperature shutdown circuit. When TP1 as defined in thermal consideration section exceeds 110°C the product will shut down. The product will make continuous attempts to start up (non-latching mode) and resume normal operation automatically when the temperature has dropped >10°C below the temperature threshold. Over Voltage Protection (OVP) The products have output over voltage protection that will shut down the product in over voltage conditions. The product will make continuous attempts to start up (non-latching mode) and resume normal operation automatically after removal of the over voltage condition. Over Current Protection (OCP) The products include current limiting circuitry for protection at continuous overload. The output voltage will decrease towards zero for output currents in excess of max output current (max IO). The product will resume normal operation after removal of the overload. The load distribution should be designed for the maximum output short circuit current specified. 3/1301-BMR7127300 Technical Specification Date 3/2/2023 Rev 28701BMR 7127300 Rev. F D L March 2023 © Flex Thermal Consideration General The products are designed to operate in different thermal eviorments and sufficient cooling must be provided to ensure reliable operation. For products mounted on a PWB without a heat sink attached, cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependent on the airflow across the product. Increased airflow enhances the cooling of the product. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity at VI = 110 V. The product is tested on a 107 x 45 mm, 70 µm (2 oz), 1-layer test board in a wind box with 370 x 220 mm. Product can be selected with heat-sink version, available to add operating temperature range. For customer different requirement (customer added different size heat-sink), the option is product attached with Thermal glue tape so that customer can attach different size heat-sink by themselves. The heat-sink assembly drawing: PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 26 4 (5) No. jidgezou George Zou Approved (Document resp) Checked PKE7000A seriesZou DC-DC Converters jidgezou George Input 43 - 160 V, Output up to 6 A / 30 W Definition of product operating temperature The product operating temperatures is used to monitor the temperature of the product, and proper thermal conditions can be verified by measuring the temperature at positions P1. The temperature at this position (TP1) should not exceed the maximum temperatures in the table below. Temperature above maximum TP1, measured at the reference point P1 are not allowed and may cause permanent damage. Position Description Max Temp. P1 Reference point TP1 = 110º C P1 (Reference Point) ● TOP VIEW Reference point on PKE73XXA variant Pin 1 Designation On/Off Control Function Remote control 2 -Input Negative input 3 +Input Positive input 4 +Out Positive output 5 6 -Out Trim Negative output Output voltage adjust 3/1301-BMR7127300 Technical Specification Date 3/2/2023 Rev 28701BMR 7127300 Rev. F D L © Flex March 2023 PUBLIC PRODUCT SPEC. MECHANICAL Prepared (Subject resp) 1 (2) No. 4/1301-BMR7127000 Technical Specification jidgezou George Zou Approved (Document resp) 27 Checked PKE7000A series jidgezou George ZouDC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Date Rev 4/9/2020 28701- BMR 7127300 Rev. F B March 2023 © Flex Mechanical Information Notes: 1. All dimensions in inches (mm) 2. Tolerance .xx =±0.04” .xxx=±0.020” All component placements – whether shown as physical components or symbolical outline – are for reference only and are subject to change throughout the product’s life cycle, unless explicitly described and dimensioned in this drawing. PUBLIC PRODUCT SPEC. Prepared (Subject resp) No. jidgezou George Zou 5/1301-BMR7127000 Approved (Document resp) jidgezou George Zou PKE7000A series Checked DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Soldering Information - Hole Mounting The hole mounted product is intended for plated through hole mounting by wave or manual soldering. The pin temperature is specified to maximum to 270°C for maximum 10 seconds. A maximum preheat rate of 4°C/s and maximum preheat temperature of 150°C is suggested. When soldering by hand, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside the product or between the product and the host board. The cleaning residues may affect long time reliability and isolation voltage. Delivery Package Information The products are delivered in antistatic clamshell trays Tray Specifications Material Surface resistance Bakeability Antistatic PS Tray thickness 19.5 mm [0.767 inch] Box capacity 162 products (9 full trays/box) Tray weight 60 g empty, 640 g full tray 103 < Ohm/square < 109 This tray is not bake-able Date 4/9/2020 Technical Specification Rev 28701BMR 7127300 Rev. F B J © Flex 28 1 (3) March 2023 PUBLIC PRODUCT SPEC. Prepared (Subject resp) No. jidgezou George Zou 5/1301-BMR7127000 Approved (Document resp) jidgezou George Zou PKE7000A series Checked DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Package Date 4/9/2020 Technical Specification Rev 28701BMR 7127300 Rev. F B J © Flex 29 2 (3) March 2023 30 PUBLIC PRODUCT SPEC. 3 (3) Prepared (Subject resp) No. jidgezou George Zou 5/1301-BMR7127000 Approved (Document resp) Checked jidgezou George Zou PKE7000A series DC-DC Converters Input 43 - 160 V, Output up to 6 A / 30 W Date 4/9/2020 Technical Specification Rev 28701BMR 7127300 Rev. F B J March 2023 © Flex Product Qualification Specification Characteristics External visual inspection IPC-A-610 Change of temperature (Temperature cycling) IEC 60068-2-14 Na Temperature range Number of cycles Dwell/transfer time -55 to 105°C 20 30 min/3 min Cold (in operation) IEC 60068-2-1 Ad Temperature TA Duration -45°C 72 h Damp heat IEC 60068-2-30 Temperature Humidity Duration 45°C 95 % RH 72 hours Dry heat IEC 60068-2-2 Bd Temperature Duration 125°C 1000 h Electrostatic discharge susceptibility IEC 61340-3-1, JESD 22-A114 Human body model (HBM) Class 2, 2000 V Immersion in cleaning solvents IEC 60068-2-45 XA, method 2 Water Glycol ether {Isopropyl alcohol} 55°C 35°C {35°C} Mechanical shock IEC 60068-2-27 Ea Peak acceleration Duration 200 g 6 ms Moisture reflow sensitivity 1 J-STD-020E Level 1 (SnPb-eutectic) Level 3 (Pb Free) 225°C 260°C Operational life test MIL-STD-202G, method 108A Duration 1000 h Resistance to soldering heat IEC 60068-2-20 Tb, method 1A Solder temperature Duration 270°C 10-13 s Robustness of terminations IEC 60068-2-21 Test Ua1 Through hole mount products All leads Solderability IEC 60068-2-20 test Ta 1 Preconditioning Temperature, SnPb Eutectic Temperature, Pb-free 235°C 245°C Vibration, broad band random IEC 61373 Frequency RMS acceleration Duration 5 to 150 Hz 5 grms 5 hrs in each direction Notes 1 Only for products intended for wave soldering (plated through hole products) EN 50155 Phenomenon EN 50155 Reference Clause(s) Reference Standard Characteristic Test 12.2.1, 12.2.2, 5.1.1.1, 5.1.3, 12.2.9, 12.2.6 - EMC 12.2.7, 12.2.8 EN 50121-3-2 EN 61000-4 EN 55011 Environmental Tests 12.2.3, 12.2.4, 12.2.5,12.2.11 EN 60068-2 EN 61373
PKE7315API 价格&库存
很抱歉,暂时无法提供与“PKE7315API”相匹配的价格&库存,您可以联系我们找货
