LWB60-48S12
LWB60-48S12
    POLYTRON
    DIP6
    隔离模块 直流转换器 1 输出 12V 5A 18V - 75V 输入
LWB60-48S12 数据手册
P POLYTRON POWER SUPPLIES - LWB60 Series 60 WATT Single & Dual Output 5HJXODWHG([WUD:LGH,QSXW5DQJH '&'&&RQYHUWHUV SpeciĮcaƟons - All specifications are typical at nominal input, full load and 25϶ C. INPUT FEATURES Voltage Range.............................. ......................................................24VDC nominal input .......................................................9 -36VDC ......................................................48VDC nominal input ....................................................18 -75VDC x Extra Wide Input Voltage Range (4:1) x Single and Dual Output x No Minimum Load required x Input/Output Isolation (1600 Vdc Minimum) x Input Įlter................................................... ................................................................................................................Pi Filter Input Surge Voltage..................................................................... 24VDC input....................................................50VDC 100ms, max. 48VDC input..................................................100VDC 100ms, max. Input ReŇected Ripple Current .................................................. .............................................................................20mAp-p Start up Time. .................................................. ..............Constant resisƟve load....... Startup Voltage........................................................................... 24VDC input.....................................................9VDC, max. 48VDC input...................................................18VDC, max. Shutdown Voltage....................................................................... 24VDC input............ ..................................................8VDC 48VDC input............ ................................................16VDC Six-sided Continuous Metal Remote ON/OFF Shielding x Operating Temperature Range: -40 to +85϶C x x ........Power up...........................60ms ........Remote ON/OFF................60ms Referenced to - INPUT pin PosiƟve logic DC-DC ON ................Open or 3 - 12VDC (Standard) DC-DC OFF ...............Short or 0 - 1.2VDC NegaƟve logic DC-DC ON ...............Short or 0 - 1.2VDC (OpƟon) DC-DC OFF ................Open or 3 - 12VDC Input Current of Remote Control Pin......... ...........................-0.5 - 0.5mA Remote oī state input current............ ........................................3mA Low Profile Package: OUTPUT 1.00" X 2.00" X 0.40" Output Power........................................................................... ......................................................................60 WaƩs max. Voltage Accuracy..................................................................... .................................................................................... ±1.0% ............Single.........................±0.2% Line RegulaƟon........................................... .................LL to HL at Full Load................ ............Dual...........................±0.5% Safety Approved UL60950-1, EN60950-1, IEC60950-1 ..............Single....................... ±0.2% ..............Dual..........................±1.0% Cross RegulaƟon....................... ................Asymmetrical Load 25% / 100% FL.............. ...........Dual........................... ±5.0% 3.3 Vout, 5 Vout, 12 Vout.. .................................................10% Voltage Adjustability................. ..........Single Output........... 15 Vout, 24 Vout............... ......................................-10% - 20% Ripple and Noise...........................................Measured by 20MHz band width ..................................With a 10μF/25V X7R MLCC..................... 3.3Vout, 5Vout... ...........100mVp-p .....................................................................................................12Vout, 15Vout. ............125mVp-p ..................................With a 4.7μF/50V X7R MLCC.................... 24Vout.............. ............200mVp-p ම Temperature Coeĸcient.. .................................................. ......................................................................... ±0.2% / C, max. Transient Response recovery Time ...............25% load step change.................. ..........................................................250μS Load RegulaƟon.......................................... .................No Load to Full Load................ x CE Mark meets 2006/95/EC, 2011/95/EC, and 2004/108/EC x RoHS Compliant to EU Directive 2011/65/EU LWB60 Series ............3.3 Vout.......................................... ...................................3.9VDC ............5Vout.............................................. ...................................6.2VDC Over voltage protecƟon..... .Zener Diode clamp. ..........12Vout.............................................. ....................................15VDC ..........15Vout.............................................. ....................................20VDC ..........24Vout.............................................. ....................................30VDC Overload ProtecƟon............................................ ..........% of Iout rated; Hiccup mode.......... ......................................150% Short Circuit ProtecƟon....................................... ................................................................ConƟnuous, automaƟc recovery Additional specifications on next page. DABURN ELECTRONICS & CABLE 44 Richboynton Road, Dover, New Jersey 0780186$ Tel: (973)328-3200 Fax: (973)328-3130 - Email: daburn@daburn.com - Website: www.daburn.com Ver. 1.0 60 Watt DC/DC Converters /:%6HULHV ___________________________________________________________________________________ GENERAL ENVIRONMENTAL Eĸciency................................................................................................................See table IsolaƟon Voltage ................Input to Output ...........................1600VDC, min. 1 minute IsolaƟon Resistance ............................500VDC 1Gё IsolaƟon Capacitance .............................................................................................2200pF Switching Frequency.. ....................................................................................275kHz Typ. Approvals and Standard ..............................................IEC60950-1, UL60950-1, EN60950-1 Case Material ..........................................................................................................Copper Base Material .........................................................................................................FR4 PCB Poƫng Material ........................................................................................Silicon (UL94-V0) 2.00 x 1.00 x 0.40 inches Dimensions (50.8 x 25.4 x 10.2 mm) Weight ............................................................................................................33g (1.16 oz .) 5 MTBF.. ............................MIL-HDBK-217F Tc70϶C, Full load.........................8.582 x 10 hrs Operating Ambient Temperature ......................................... ...............................-40϶C - +85϶C Maximum Case Temperature...... ......................................... .........................................+105϶C Over Temperature ProtecƟon..... ......................................... .........................................+115϶C Storage Temperature Range.......................... .....................................................-55϶C - +125϶C Without Heat-sink.....10.8϶C/WaƩ (1) Thermal Impedance .......Natural ConvecƟon (20LFM)..... With Heat-sink..........10.3϶C/WaƩ Thermal Shock........... ..........................................................................................MIL-STD-810F VibraƟon.................... ..........................................................................................MIL-STD-810F RelaƟve Humidity...... .........................................................................................5% to 95% RH EMC CHARACTERISTICS EMI (Note 2)........................ ............EN55022............ ....................................................Class A ESD...................................... Air ±8KV Contact ±6KV EN61000-4-2 .......Perf. Criteria A Radiated Immunity............. ........EN61000-4-3........ ....................20 V/m .......Perf. Criteria A Fast Transient (Note 3)....... ........EN61000-4-4........ ........................±2KV .......Perf. Criteria A Surge (Note 3)..................... ........EN61000-4-5........ ........................±2KV .......Perf. Criteria A Conducted Immunity.......... ........EN61000-4-6........ .................10Vr.m.s. .......Perf. Criteria A Input Voltage Nominal (Range) (Vdc) Output Voltage (Vdc) Output Current (mA) Output Ripple & Noise S,NGL( OUTPUT 9OLTAG( 24(9-36) 24(9-36) 24(9-36) 24(9-36) 24(9-36) 48(18-75) 48(18-75) 48(18-75) 48(18-75) 48(18-75) 3.3 5 12 15 24 3.3 5 12 15 24 12000 12000 5000 4000 2500 12000 12000 5000 4000 2500 75m Vp-p 75m Vp-p 100m Vp-p 100m Vp-p 150m Vp-p 75m Vp-p 75m Vp-p 100m Vp-p 100m Vp-p 150m Vp-p DUAL OUTPUT 9OLTAG( S(L(&T,ON GU,D( 24(9-36) 24(9-36) 24(9-36) 48(18-75) 48(18-75) 48(18-75) ±12 ±15 ±24 ±12 ±15 ±24 ±2500 ±2000 ±1250 ±2500 ±2000 ±1250 100m Vp-p 100m Vp-p 150m Vp-p 100m Vp-p 100m Vp-p 150m Vp-p Input Current No load (mA) Efficiency (%) 10 10 10 10 10 10 Model Number* 10 10 10 90 92 92 92 92 90 92 92 92 91 LWB60-24S33 LWB60-24S5 LWB60-24S12 LWB60-24S15 LWB60-24S24 LWB60-48S33 LWB60-48S5 LWB60-48S12 LWB60-48S15 LWB60-48S24 10 10 10 10 10 10 91 91 91 91 91 91 LWB60-24-12 LWB60-24-15 LWB60-24-24 LWB60-48-12 LWB60-48-15 LWB60-48-24 10 Capacitor Load max. 32000—F 30000—F 5850—F 3900—F 2000—F 3200—F 3000—F 5850—F 3900—F 2000—F +/-3900—F +/-2400—F +/-1000—F +/-3900—F +/-2400—F +/-1000—F Notes 7KHKHDWVLQNLVRSWLRQDODQG31*&) 7KH/:%VHULHVVWDQGDUGPRGXOHPHHWV(0,&ODVV$RU&ODVV%ZLWKH[WHUQDOFRPSRQHQWV)RUPRUHGHWDLOHGLQIRUPDWLRQSOHDVHFRQWDFW3RO\WURQ 'HYLFHV,QF $QH[WHUQDOILOWHUFDSDFLWRULVUHTXLUHGLIWKHPRGXOHLVWRPHHW(1(1 7KH/:%UHFRPPHQGHGDQDOXPLQXPHOHFWURO\WLFFDSDFLWRU 1LSSRQFKHQLFRQ.
LWB60-48S12 价格&库存
很抱歉,暂时无法提供与“LWB60-48S12”相匹配的价格&库存,您可以联系我们找货
