SMHV0580
SMHV0580
    HVMTECHNOLOGY
    DIP9 模块
    高电压 - 非隔离模块 直流转换器 1 输出 8000V 125µA 4.5V - 5.5V 输入
SMHV0580 数据手册
SMHV Series High-Precision Regulated HV DC to DC Converter Models up to 10kV@1W Sub-Miniature Case Size (.85”x.85”x.6”) Adjustable, 0 to full output Low Ripple, High Impedance, Operating Temp (-55⁰C to +70⁰C) DC/DC Converters Description The SMHV Series is a family of sub-miniature singleoutput, fully regulated DC to DC converters supplying up to 10kV @1W in 0.434 cubic inches (0.85” x 0.85” x 0.6”). These ultra-compact converters are ideal for applications requiring small size, high performance, and ease of use. HVM’s proprietary, ultra-compact resonant converter design minimizes quiescent current and operating noise while delivering maximum performance and reliability. The devices operate directly from 5VDC ± 0.5VDC input. Output voltage is independent of input power voltage and is proportional to the programming voltage (0 to 5V produces 0 to full scale output) and features excellent linearity. Voltage and current monitor outputs provide the user with operational information for maximum control. Mechanical Characteristics    Weight: 15 grams typical Packaging: Encapsulated in high performance epoxy Case Materials: Thermoset Plastic (Diallyl Phthalate) –Optional Metal shield Case Available The SMHV Series has additional features such as voltage and current monitor outputs, and current limit control input. The SMHV Series is very stable over a wide operating temperature range. Available with alternate output voltages, consult sales for additional information. Environmental Characteristics   Operating Temp Range: -55⁰C to +70⁰C Storage Temp Range: -55⁰C to +85⁰C HVM TECHNOLOGY 360 McKenna Ave, New Braunfels TX, 78130 Tel: (830) 626-5552/ www.hvmtech.com/ email: rsaldana@hvmtech.com Rev I Last Updated 4/12/17 APPLICATION SCHEMATIC IN+ (5VDC) www.hvmtech.com 1 0 - 5V IN NOT USED 0 - 1V OUT 0 - 1V OUT 0 - 1V IN DIMENSIONS 8 PROGRAM HVOUT 4 NOT USED 5 LOAD Vmon 6 Imon 7 Ilimit HVRTN 9 GND 2 NOTE: HVRTN INTERNALLY CONNECTED TO GND 3 TOP VIEW 0.850 0.850 SIDE VIEW ELECTRICAL CHARACTERISTICS Input Power Voltage (IN+): 5V ± 10% Programming Voltage: 0 to 5VDC results in 0 to rated output Programming Input Impedance: 10kΩ Input Current Limit: 0 to 1VDC input results in a current load limit to 0 to 100% of rated current; input impedance: 10kΩ Note: To disable current limit, connect Ilimit pin to 5V. Output Tolerance at No Load: Output Voltage Monitor: Output Current Monitor: 0.600 0.20±0.020 0.650 PIN DIAMETER: .025" BOTTOM VIEW 7 6 5 4 3 2 1 ± 5% 0 to 1VDC output, corresponding to 0 to 100% of rated output; output impedance: 1kΩ 0 to 1VDC output, corresponding to 0 to 100% of rated current; output impedance: 1kΩ Input-Output Isolation: Not isolated, HVRTN internally connected to GND Load Regulation: 0.2% (over entire load range) Line Regulation: 0.01% Output Ripple:
SMHV0580 价格&库存
很抱歉,暂时无法提供与“SMHV0580”相匹配的价格&库存,您可以联系我们找货
