NHV0505
NHV0505
    HVMTECHNOLOGY
    SMD5 模块
    高电压 - 非隔离模块 直流转换器 1 输出 500V 200µA 4.5V - 5.5V 输入
NHV0505 数据手册
nHV Series Micro-Sized Precision Regulated HV DC to DC Converter Ultra-Miniature Case Size (.45”L X .35”W X .37”H) Surface Mountable Package 100mW Output Power Capability Extremely Tight Output Regulation and Stability High Impedance Programming Input (>100kΩ) Low Quiescent Current No External Components Required Extremely Low Ripple and EMI/RFI Wide Operating Temp Range (-55°C to +70°C) Mechanical Characteristics     Size: .45”L X .35”W X .37”H Packaging: Encapsulated in high performance epoxy Case Material: Thermoset plastic (Diallyl Phthalate) Mounting: Surface Mountable Package Description The nHV Series is a family of micro sized singleoutput DC to DC converters supplying up to 1.2kV in a (.45”L X .35”W X .37”H) case size. These ultracompact converters are ideal for applications requiring small size, high performance, and ease of use. A high impedance programming input makes it very easy to use, eliminating the need for a low impedance adjustable power source voltage. HVM’s proprietary resonant converter design minimizes quiescent current and operating noise while delivering maximum performance and reliability. Its low power and extremely small size make it ideal for battery powered applications. The devices operate directly from 5VDC ± 0.5VDC input. Output voltage is independent of input power voltage and is proportional to the programming voltage (0 to 5V produces 0 to full scale output) and features excellent linearity. The output power rating is 0.1W. The nHV Series is very stable over a wide operating temperature range. Environmental Characteristics   Operating Temp Range: -55°C to +70°C Storage Temp Range: -55°C to +85°C Note: This component is not compatible with oven reflow soldering. Only hand soldering is recommended. HVM TECHNOLOGY 360 McKenna Ave, New Braunfels TX, 78130 Tel: (830) 626-5552/ www.hvmtech.com/ email: sales@hvmtech.com Rev G Last Updated 8/1/18 APPLICATION SCHEMATIC DIMENSIONS 0.050 0.350 TOP VIEW 1 0.050 TYP Input Power Voltage (V+): 5V ± 0.5Vdc Programming Voltage: 0 to 5 Volts programming input results in 0 to full rated output voltage Programming Input Impedance: 100kΩ Input-Output Isolation: This device is not Isolated, HVRTN internally connected to IN- 0.300 2 0.150 ELECTRICAL CHARACTERISTICS 5 3 4 SIDE VIEW 0.370 BOTTOM VIEW 0.350 0.400 0.450 < 0.2% typical from no load to Load Regulation: full load Output Tolerance at No Load: ± 5% Output Ripple: < 0.2% typical at full load Oscillator Frequency: 45 kHz – 80 kHz Pad # 1 2 3 4 5 FUNCTION IN+ Program IN HVRTN HVOUT HVM TECHNOLOGY 360 McKenna Ave, New Braunfels TX, 78130 Tel: (830) 626-5552/ www.hvmtech.com/ email: sales@hvmtech.com Rev G Last Updated 8/1/18 Model Selection Guide Typical Input Current No Load Input Voltage Output Voltage MAX Output Current nHV0501 5V 0 to +100V 1mA
NHV0505 价格&库存
很抱歉,暂时无法提供与“NHV0505”相匹配的价格&库存,您可以联系我们找货
