LT6911C ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY
LT6911C --- Product Brief
HDMI1.4/DP++ to Dual-port MIPI DSI/CSI/LVDS with Audio
1. Features
1/2 Configurable Port
HDMI1.4 Receiver
Support Maximum Data Rate 1.2Gbps/lane
1 clock lane and 4 configurable data lanes per port
Output Color Depth supports 6-bit and 8-bit
Compliant with the HDMI 1.4 specification with TMDS
Video stream copy mode for each port
data rates up to 3.4Gbps per channel
Side-by-side 3D support
Support HDCP 1.4
Adaptive receiver Equalization for PCB, cable and
Miscellaneous
3.3V/1.2VSupply Power
connector losses
Internal CSC support conversions between YCbCr
Dual-mode DispalyPort Receiver
Compliant
with
DisplayPort
Dual-mode
4:4:4 and RGB, and between YCbCr 4:2:2 and YCbCr
spec
4:4:4
1.1(DP++)with 4K30Hz HDMI support
Support SPDIF and 2-channel IIS audio output
Adaptive receiver equalization to compensate PCB
Support 100KHz I2C slave
and/or connector losses
Integrated Microprocessor
Integrated 50Ω termination resistors for AC coupled
Temperature Range: -40°C ~ +85°C
differential inputs
Low Intra-pair and Inter-pair skews
ESD ±2kV HBM
Support DisplayPort all 4 levels of output
Single/Dual-Port MIPI® DSI/CSI Transmitter
Compliant with DCS1.02, D-PHY1.2& DSI1.02
&CSI-2 1.0
1 Clock Lane, and 1~4 Configurable Data Lanes per
port
The LT6911C is a high performance HDMI1.4/DP++ to
MIPI®DSI/CSI/LVDS chip for VR/Smart phone/Display
application.
For
1/2 configurable port
MIPI®DSI/CSI
output,
LT6911C
features
configurable single-port or dual-port MIPI®DSI/CSI with
80Mbps~1.5Gbps per data lane
Maximum 64pixels overlap for each half
Both non-burst and burst video mode supported
Support RGB666, Loosely
2. General Description
RGB666, RGB888,
RGB565, 16-bit YCbCr4:2:2,20-bit YCbCr4:2:2,24-bit
YCbCr 4:2:2, 12-bit YCbCr4:2:0Video Format
Single/Dual-Port LVDS Transmitter
Compatible with VESA and JEIDA standard
1 high-speed clock lane and 1~4 high-speed data lanes
operating at maximum 1.5Gbps/lane, which can support
a total bandwidth of up to 12Gbps. LT6911C supports
burst mode DSI video data transferring, also supports
flexible video data mapping path. For LVDS output,
LT6911C can be configured as single-port or dual-port.
For 2D video stream, the same video stream can be
mapped to two separated panels, for 3D video format,
left side data can be sent to one panel, and right side
data can be sent to another panel.
Lontium Semiconductor Corporation www.lontiumsemi.com
LT6911C Product Brief – Rev 1.3 1
3. Applications
Mobile system
Display
VR
MIPI P0
HDMI1.4/DP++
MIPI P1
LT6911C
Audio
LVDS P0
HDMI1.4/DP++
LT6911C
LVDS P1
Audio
Figure3.1 Application Diagrams
4. Ordering Information
Table 4.1 Ordering Information
Part Number
Operating
Temperature Range
Package
Packing Method
MPQ
LT6911C
-40℃ to+85℃
QFN64 (7.5*7.5)
Tray
2600pcs
LT6911C Product Brief – Rev 1.3 2
Copyright © 2016-2022 Lontium Semiconductor Corporation, All rights reserved.
Lontium Semiconductor Proprietary & Confidential
This document and the information it contains belong to Lontium Semiconductor. Any
review, use, dissemination, distribution or copying of this document or its information
outside the scope of a signed agreement with Lontium is strictly prohibited.
LONTIUM DISCLAIMS ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING
THOSE OF NONINFRINGEMENT, MERCHANTABILITY, TITLE AND FITNESS FOR A
PARTICULAR PURPOSE. CUSTOMERS EXPRESSLY ASSUME THEIR OWN RISH IN
RELYING ON THIS DOCUMENT.
LONTIUM PRODUCTS ARE NOT DESIGNED OR INTENDED FOR USE IN LIFE
SUPPORT APPLIANCES, DEVICES OR SYSTEMS WHERE A MALFUNCTION OF A
LONTIUM DEVICE COULD RESULT IN A PERSONAL INJURY OR LOSS OF LIFE.
Lontium assumes no responsibility for any errors in this document, and makes no
commitment to update the information contained herein. Lontium reserves the right to
change or discontinue this document and the products it describes at any time, without
notice. Other than as set forth in a separate, signed, written agreement, Lontium grants the
user of this document no right, title or interest in the document, the information it contains or
the intellectual property in embodies.
Trademarks
Lontium™ 龙迅™ and ClearEdge™ is a registered trademark of Lontium Semiconductor. All
other brand names, product names, trademarks, and registered trademarks contained
herein are the property of their respective owners.
Visit our corporate web page at: www.lontiumsemi.com
Technical support: support@lontium.com
Sales: sales@lontium.com
LT6911C Product Brief – Rev 1.3 3
很抱歉,暂时无法提供与“LT6911C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+30.78000
- 10+29.64000
- 100+26.90400
- 500+25.53600
