NJM2884ADL3-33-TE1
NJM2884ADL3-33-TE1
    NISSHINBO(日清纺)
    TO-252-6
    PMIC - 稳压器 - 线性 正 固定 1 输出 500mA TO-252-5
NJM2884ADL3-33-TE1 数据手册
NJM2884/A LOW DROPOUT VOLTAGE REGULATOR GENERAL DESCRIPTION The NJM2884/A is a low dropout voltage regulator with ON/OFF control. Advanced Bipolar technology achieves low noise, high ripple rejection and low quiescent current. It delivers up to 5V/500mA output power with the maximum input voltage of 10V. The NJM2884/A is suitable for audio/video and PC related applications. The “U2” suffix product achieves high PD compared with “U1” although the same package outline (SOT-89-5) . PACKAGE OUTLINE NJM2884U1/U2 NJM2884ADL3 NJM2884AKH1(2.0×2.0×0.397mm) FEATURES High Ripple Rejection 75dB typ. (f=1kHz, Vo=3V Version) Low Output Noise Voltage Vno=45µVrms typ. Output capacitor with 2.2µF ceramic capacitor (Vo≥2.7V) Output Current Io(max.)=500mA High Precision Output Vo±1.0% Low Dropout Voltage 0.18V typ. (Io=300mA) ON/OFF Control Function Internal Thermal Overload Protection Internal Short Circuit Current Limit Bipolar Technology Package Outline SOT-89-5(NJM2884U1/U2)/ TO-252-5(NJM2884ADL3)/ ESON6-H1(NJM2884AKH1) PIN CONFIGURATION 5 2 4 1 2 3 3 1. CONTROL 2. GND 3. N.C. 4. VOUT 5. VIN 1. CONTROL 2. VIN 3. GND 4. VOUT 5. N.C. 123 45 NJM2884U1/U2 NJM2884ADL3 1. VOUT 2. NC 3. GND Exposed Pad 4. CONTROL 1 2 3 6 5 4 (connected to GND) 5. NC NJM2884AKH1 6. VIN 6 5 4 1 2 3 EQUIVALENT CIRCUIT VIN VOUT Thermal Protection CONTROL Bandgap Reference GND Ver.2012-07-12 -1- NJM2884/A OUTPUT VOLTAGE RANK LIST The WHITE column shows applicable Voltage Rank(s) Device Name Vout Device Name Vout NJM2884U1/U2-15 NJM2884U1-16 NJM2884U1-17 NJM2884U1/U2-18 NJM2884U1-19 NJM2884U1-02 NJM2884U1-21 NJM2884U1-22 NJM2884U1-23 NJM2884U1-24 NJM2884U1-25 NJM2884U1/U2-255 NJM2884U1-26 NJM2884U1-27 NJM2884U1-28 NJM2884U1-29 NJM2884U1-03 NJM2884U1-31 NJM2884U1-32 NJM2884U1-33 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.55V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V NJM2884U1-34 NJM2884U1-35 NJM2884U1-36 NJM2884U1-37 NJM2884U1-38 NJM2884U1-39 NJM2884U1-04 NJM2884U1-41 NJM2884U1-42 NJM2884U1-43 NJM2884U1-44 NJM2884U1-45 NJM2884U1-46 NJM2884U1-47 NJM2884U1-48 NJM2884U1-49 NJM2884U1/U2-05 3.4V 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V 4.1V 4.2V 4.3V 4.4V 4.5V 4.6V 4.7V 4.8V 4.9V 5.0V Device Name Vout Device Name Vout NJM2884ADL3-15 NJM2884ADL3-16 NJM2884ADL3-17 NJM2884ADL3-18 NJM2884ADL3-19 NJM2884ADL3-02 NJM2884ADL3-21 NJM2884ADL3-22 NJM2884ADL3-23 NJM2884ADL3-24 NJM2884ADL3-25 NJM2884ADL3-26 NJM2884ADL3-27 NJM2884ADL3-28 NJM2884ADL3-29 NJM2884ADL3-03 NJM2884ADL3-31 NJM2884ADL3-32 NJM2884ADL3-33 NJM2884ADL3-34 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V NJM2884ADL3-35 NJM2884ADL3-36 NJM2884ADL3-37 NJM2884ADL3-38 NJM2884ADL3-39 NJM2884ADL3-40 NJM2884ADL3-41 NJM2884ADL3-42 NJM2884ADL3-43 NJM2884ADL3-44 NJM2884ADL3-45 NJM2884ADL3-46 NJM2884ADL3-47 NJM2884ADL3-48 NJM2884ADL3-49 NJM2884ADL3-05 NJM2884AU1-15 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V 4.1V 4.2V 4.3V 4.4V 4.5V 4.6V 4.7V 4.8V 4.9V 5.0V 1.5V -2- Ver.2012-07-12 NJM2884/A Device Name Vout Device Name Vout NJM2884AKH1-15 NJM2884AKH1-16 NJM2884AKH1-17 NJM2884AKH1-18 NJM2884AKH1-19 NJM2884AKH1-02 NJM2884AKH1-21 NJM2884AKH1-22 NJM2884AKH1-23 NJM2884AKH1-24 NJM2884AKH1-25 NJM2884AKH1-26 NJM2884AKH1-27 NJM2884AKH1-28 NJM2884AKH1-29 NJM2884AKH1-03 NJM2884AKH1-31 NJM2884AKH1-32 NJM2884AKH1-33 NJM2884AKH1-34 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V NJM2884AKH1-35 NJM2884AKH1-36 NJM2884AKH1-37 NJM2884AKH1-38 NJM2884AKH1-39 NJM2884AKH1-04 NJM2884AKH1-41 NJM2884AKH1-42 NJM2884AKH1-43 NJM2884AKH1-44 NJM2884AKH1-45 NJM2884AKH1-46 NJM2884AKH1-47 NJM2884AKH1-48 NJM2884AKH1-49 NJM2884AKH1-05 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V 4.1V 4.2V 4.3V 4.4V 4.5V 4.6V 4.7V 4.8V 4.9V 5.0V Ver.2012-07-12 -3- NJM2884/A ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Input Voltage VIN Control Voltage VCONT RATINGS +10 +10 (Ta=25°C) UNIT V V 625(*1) 960(*2) 625(*1) SOT-89-5 (U2) 2400(*2) mW Power Dissipation PD 1190(*1) TO-252-5 3125(*2) 445(*3) ESON6-H1 1135(*4) Operating Temperature Topr - 40 ∼ +85 °C Storage Temperature Tstg - 40 ∼ +150 °C (*1): Mounted on glass epoxy board. (76.2 x114.3 x 1.6mm:based on EIA/JDEC standard size, 2Layers, Cu area 100mm2) (*2): Mounted on glass epoxy board. (76.2 x 114.3 x 1.6mm:based on EIA/JDEC standard, 4Layers) ( 4Layers: Applying 74.2×74.2mm inner Cu area and a thermal via hall to a board based on JEDEC standard JESD51-5) (*3): Mounted on glass epoxy board (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2Layers FR-4, with Exposed Pad) (*4): Mounted on glass epoxy board (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4Layers FR-4, with Exposed Pad) (4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) SOT-89-5 (U1) INPUT VOLTAGE RANGE VIN=+2.3V~9V(In case of Vo
NJM2884ADL3-33-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2884ADL3-33-TE1”相匹配的价格&库存,您可以联系我们找货
NJM2884ADL3-33-TE1
  • 3000+5.341863000+0.69145
  • 6000+5.221626000+0.67589
  • 9000+5.161429000+0.66810
  • 15000+5.0947415000+0.65947
库存:566
NJM2884ADL3-33-TE1
  • 1+11.047221+1.42995
  • 10+8.0311310+1.03955
  • 25+7.2698025+0.94100
  • 100+6.42865100+0.83212
  • 250+6.02785250+0.78025
  • 500+5.78646500+0.74900
  • 1000+5.677611000+0.73491
库存:566
