12 42 195
12 42 195
    KNIPEX(凯尼派克)
    工具 单层剥除器,自调 用于 8 ~ 32 AWG
12 42 195 数据手册
12 42 195 KNIPEX MultiStrip 10 Automatic Insulation Stripper ● ● ● ● ● ● ● ● ● ● ● ● ● ● Stripping without re-adjustment from 0.03 to 10.0 mm² Universal blade geometry -robust and more durable Ideal grip design with excellent haptics Recessed wire cutter Fully automatic adjustment to all single-, multi- and fine-stranded conductors with standard insulation throughout the entire capacity range from 0.03 to 10.0 mm² No manual fine adjustment necessary No damage to the conductors The clamping jaws made of steel hold the cable in a way that prevents slipping without damaging the remaining insulation With recessed wire cutter for Cu and Al conductors, stranded up to 10 mm² and single wire up to 6 mm² Particularly smooth-running mechanics and very low weight Replaceable blades block and length stop Handle with soft-plastic zone for a steady grip Body: plastic, fibreglass-reinforced Blade: special tool steel, oil-hardened Patented mechanics The incision depth of the stripping blade adjusts fully automatically to the diameter of the wire and accordingly also to the thickness of all standard insulating materials. There is no need for any manual adjustment which is still necessary when other conventional pliers with a wide wire-stripping range are used. Mode of operation of straight cutters An incision is made in the red area only. Not suitable for highly-flexible or armoured insulation materials or for multi-layered insulation. Article No. 12 42 195 EAN 4003773054580 Stripping capacities in square millimetres mm² 0,03 - 10,0 AWG 32 - 7 Length mm 195 Net weight g 136 Wire cutter for multiple Steel clamping jaws stranded wire cables up avoid slipping of the to 10.0 mm² cable Precise stripping from 0.03 to 10 mm² without re-adjustment technical change and errors excepted Spare Parts KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Article No. EAN 12 49 21 4003773057581 Spare blades block for 12 42 195 Automatic Insulation Stripper 12 49 23 4003773057604 Spare length stop for 12 42 195 Automatic Insulation Stripper KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
12 42 195 价格&库存
很抱歉,暂时无法提供与“12 42 195”相匹配的价格&库存,您可以联系我们找货
