TPA1864-SR
TPA1864-SR
    3PEAK(思瑞浦)
TPA1864-SR 数据手册
TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Features Description • • • The TPA186x series of amplifiers are the newest highsupply voltage amplifiers with 30-μV low offset, low noise, and stable high-frequency response. They incorporate 3PEAK’s proprietary and patented design techniques to achieve excellent AC performance with 6-MHz bandwidth, 5-V/μs slew rate, and low distortion while drawing only 1.4-mA quiescent current per amplifier. The input commonmode voltage range extends to V−, and the outputs swing rail-to-rail. • • • • • • • • Supply Voltage: 4.5 V to 40 V or ±2.25 V to ±20 v Offset Voltage: ±30 μV Maximum Differential Input Voltage Range to Supply Rail, can Work as Comparator Input Rail to −VS, Rail-to-Rail Output Drive Any Capacitive Load Bandwidth: 6 MHz, Slew Rate: 5 V/μs Excellent EMI Suppress Performance: 85 dB at 1 GHz The TPA186x has an over-temperature protection feature to guarantee chip safety. The output of the TPA186x will enter high impendence when the die temperature reaches around 170°C and will recover the function when the die temperature is down to around 150°C. The product has a very small power temperature coefficient, which is helpful to temperature-sensitive applications. Over-Temperature Protection Low Noise: 8 nV/√Hz at 1 kHz 2-kV HBM, 1-kV CDM, 500 mA Latch Up −40°C to 125°C Operation Temperature Range Applications Instrumentation Active Filters, ASIC Input or Output Amplifier Sensor Interface Iq(mA) • • • • • Motor Control Industrial Control 3.0 2.8 2.6 2.4 2.2 2.0 1.8 1.6 1.4 1.2 1.0 -50 0 50 100 Temperature(℃) 150 Typical Application Circuit www.3peak.com 1 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Table of Contents Features................................................................................................................................................................1 Applications......................................................................................................................................................... 1 Description........................................................................................................................................................... 1 Typical Application Circuit..................................................................................................................................1 Revision History...................................................................................................................................................3 Pin Configuration and Functions....................................................................................................................... 4 Specifications.......................................................................................................................................................7 Absolute Maximum Ratings (1) .......................................................................................................................7 ESD, Electrostatic Discharge Protection........................................................................................................ 7 Recommended Operating Conditions............................................................................................................ 7 Thermal Information........................................................................................................................................8 Electrical Characteristics................................................................................................................................ 9 Typical Performance Characteristics............................................................................................................ 11 Detailed Description.......................................................................................................................................... 14 Overview.......................................................................................................................................................14 Functional Block Diagram.............................................................................................................................14 Application and Implementation...................................................................................................................... 15 Application Information ................................................................................................................................ 15 Tape and Reel Information................................................................................................................................ 16 Package Outline Dimensions........................................................................................................................... 18 SOT23-5....................................................................................................................................................... 18 SOP8............................................................................................................................................................ 19 MSOP8......................................................................................................................................................... 20 DFN3X3-8.....................................................................................................................................................21 SOP14.......................................................................................................................................................... 22 TSSOP14......................................................................................................................................................23 Order Information.............................................................................................................................................. 24 IMPORTANT NOTICE AND DISCLAIMER......................................................................................................... 25 www.3peak.com 2 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Revision History Date Revision Notes 2019-09-10 Rev.0 2019-11-27 Rev.0.01 2020-04-26 Rev.A 2020-08-01 Rev.A.1 Added More Test Figures. 2020-11-06 Rev.A.2 Updated Test Figure: Iq vs. temperature, Vout vs. Iout. 2021-05-04 Rev.A.3 Added Tape and Reel Information. 2021-07-07 Rev.A.4 Initial Version. Removed Part Number: TPA1862-TSR; Added Part Number: TPA1864-SR, TPA1864-TR. Added Test Figure. Updated maximum rating: Input voltage: (−VS) − 0.3 to (+VS) + 0.3 → (−VS) − 0.3 to 40 V Differential Input Voltage: (+VS) (−VS) → (−VS) − (+VS) to (+VS) − (−VS) . Updated to new document format; 2022-08-18 Rev.A.5 Updated the working voltage to 40 V, the absolute rating voltage to 42 V; Added new package: TPA1862-DF7R. 2022-12-28 Rev.A.6 Updated to new document format. www.3peak.com 3 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Pin Configuration and Functions TPA1861 SOT23-5 Package Top View Out 1 TPA1861 SOP8 Package Top View +Vs 5 Part Number NC 11 88 NC −IN 22 77 +Vs +IN 33 66 OUT −Vs 4 55 NC 2 −Vs +In 4 3 −In Table 1. Pin Functions: TPA1861 Pin Name I/O 6 Out Output 2 4 −VS 3 3 +In Input Noninverting input 4 2 −In Input Inverting input 5 7 +VS Positive power supply 1 NC Not connected 5 NC Not connected 8 NC Not connected SOT23-5 SOP8 1 Description Output Negative power supply TPA1862 www.3peak.com TPA1862 4 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps SOP8 Package Top View MSOP8 Package Top View Out A 11 88 +Vs −In A 22 77 Out B +In A 33 66 −In B −Vs 4 55 +In B Out A 1 8 +Vs −In A 2 7 Out B +In A 3 6 −In B −Vs 4 5 +In B TPA1862 DFN3X3-8 Package Top View Out A 1 8 +Vs −In A 2 7 Out B +In A 3 6 −In B −Vs 4 5 +In B Table 2. Pin Functions: TPA1862 Pin SOP8 Name I/O 1 Out A Output 2 −In A Input Inverting input 3 +In A Input Noninverting input 4 −VS 5 +In B Input Noninverting input 6 −In B Input Inverting input 7 Out B Output 8 +VS MSOP8 DFN3X3 Description -8 Output Negative power supply Output Positive power supply TPA1864 SOP14 Package Top View www.3peak.com TPA1864 TSSOP14 Package Top View 5 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Out A 1 14 Out D −In A 2 13 −In D +In A +Vs +In B 3 +In D 12 4 −Vs 11 5 +In C 10 −In B 6 9 −In C Out B 7 8 Out C Out A 1 14 Out D −In A 2 13 −In D +In A 3 12 +In D +Vs 4 11 −Vs +In B 5 10 +In C −In B 6 9 −In C Out B 7 8 Out C Table 3. Pin Functions: TPA1864 Pin Name I/O 1 Out A Output 2 −In A Input Inverting input 3 +In A Input Noninverting input 4 +VS 5 +In B Input Noninverting input 6 −In B Input Inverting input 7 Out B Output Output 8 Out C Output Output 9 −In C Input Inverting input 10 +In C Input Noninverting input 11 −VS 12 +In D Input Noninverting input 13 −In D Input Inverting input 14 Out D Output TSSOP1 4 SOP14 www.3peak.com Description Output Positive power supply Negative power supply Output 6 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Specifications Absolute Maximum Ratings (1) All test conditions: Over operating ambient temperature, unless otherwise noted. Parameter Min Max Unit 42 V V (−VS) – 0.3 42 V V (−VS) − (+VS) (+VS) − (−VS) V −10 10 mA (−VS) − 0.3 (+VS) + 0.3 V Supply Voltage, (+VS) − (−VS) Input Voltage Differential Input Voltage Input Current: +IN, −IN (2) Output Voltage Output Short-Circuit Duration (3) Infinite TJ Maximum Operating Junction Temperature TA Operating Temperature Range TSTG Storage Temperature Range TL Lead Temperature (Soldering, 10 sec) 150 °C −40 125 °C −65 150 °C 260 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (2) The inputs are protected by ESD protection diodes to the negative power supply. If the input extends to more than 300 mV beyond the negative power supply, the input current should be limited to less than 10 mA. (3) A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Parameter HBM CDM Condition Human Body Model ESD (1) Charged Device Model ESD (2) Minimum Level Unit ANSI/ESDA/JEDEC JS-001 2 kV ANSI/ESDA/JEDEC JS-002 1 kV (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Recommended Operating Conditions Parameter Min Typ Max Unit VS Supply Voltage, (+VS) − (−VS) 4.5 or ±2.25 40 or ±20 V TA Operating Temperature Range −40 125 °C www.3peak.com 7 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Thermal Information Package Type θJA θJC Unit SOT23-5 250 81 °C/W SOP8 158 43 °C/W MSOP8 210 45 °C/W SOP14 120 36 °C/W TSSOP14 180 35 °C/W www.3peak.com 8 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Electrical Characteristics All test condition is at VS = 30 V, TA = 25°C, RL = 10 kΩ, unless otherwise noted. Parameter Conditions TA Min Typ Max Unit Power Supply VS IQ Supply Voltage Range Quiescent Current per Amplifier     4.5 or ±2.25   40 or ±20 V VS = 40 V     1.6 2 mA     1.4 1.6 mA −40°C to 125°C     1.8 mA     1.2 1.5 mA −40°C to 125°C     1.7 mA   125 140   dB −40°C to 125°C 120     dB   −30   30 μV   −30   30 μV −40°C to 125°C −50   50 μV   −30   30 μV −40°C to 125°C −50   50 μV −40°C to 125°C   0.01 0.2 μV/°C     100   pA −40°C to 125°C   100   pA     100   pA     10 100 μA −40°C to 125°C     120 μA Differential Mode     5   pF Common Mode     2.5   pF   130 140   dB −40°C to 125°C 125     dB   (V−)   (V+) – 1.5 V   125 140   dB −40°C to 125°C 120     dB     10 15 mV −40°C to 125°C     30 mV     75 100 mV VS = 30 V VS = 5 V PSRR Power Supply Rejection Ratio VS= 4.5 V to 36 V Input Characteristics VS = 40 V, VCM = 20 V VOS Input Offset Voltage VS = 30 V, VCM = 15 V VS = 5 V, VCM = 2.5 V VOSTC Input Offset Voltage Drift   IB Input Bias Current   IOS Input Offset Current   IIN Different Input Current VS = 36 V, VID = 36 V CIN Input Capacitance Av Open-loop Voltage Gain RLOAD = 10 kΩ, VOUT = 0.5 V to 29.5 V VCMR Common-mode Input Voltage Range   CMRR Common Mode Rejection Ratio VCM = 0 V to 28.5 V Output Characteristics   Output Swing from Positive Rail www.3peak.com RLOAD = 100 kΩ to VS/2 RLOAD = 10 kΩ to VS/2 9 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Parameter Conditions TA Min Typ Max Unit −40°C to 125°C     180 mV     400 500 mV −40°C to 125°C     750 mV     3 5 mV −40°C to 125°C     10 mV     25 35 mV −40°C to 125°C     60 mV     130 150 mV −40°C to 125°C     300 mV   60 95   mA −40°C to 85°C 40     mA −40°C to 125°C 35     mA   130 150   mA −40°C to 85°C 100     mA −40°C to 125°C 85     mA       1   nF     6   MHz   3 5   V/μs −40°C to 125°C 2.2     V/μs     500   ns     7   μs     12   μs RLOAD = 2 kΩ to VS/2 RLOAD = 100 kΩ to VS/2   Output Swing from Negative Rail RLOAD = 10 kΩ to VS/2 RLOAD = 2 kΩ to VS/2 Source ISC Output Short-Circuit Current Sink   Capacitive Load Drive AC Specifications GBW Gain-Bandwidth Product   SR Slew Rate G = 1, 10 V step tOR Overload Recovery   tS Settling Time, 0.1% Settling Time, 0.01% G = 1, 10 V step PM Phase Margin RL = 10 K, CL = 100 pF     70   ° GM Gain Margin RL = 10 K, CL = 100 pF     15   dB f = 0.1 Hz to 10 Hz     0.1   μVPP f = 0.1 Hz     8   nV/√Hz f = 1 kHz     8   nV/√Hz f = 10 kHz     10   nV/√Hz f = 100 kHz     20   nV/√Hz Noise Performance EN eN Input Voltage Noise Input Voltage Noise Density iN Input Current Noise f = 10 kHz     200   fA/√Hz THD+N Total Harmonic Distortion and Noise f = 1 kHz, G =1, RL = 10 kΩ, VOUT = 6 VRMS     0.0005   % www.3peak.com 10 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Typical Performance Characteristics All test condition: VS = ±15 V, VCM = 0 V, RL = 10 kΩ, unless otherwise noted. 3.00 20 15 2.50 10 2.00 IQ(mA) Vos(uV) 5 0 -5 1.50 1.00 -10 0.50 -15 -20 0.00 -15 -10 -5 0 Vcom(V) 5 10 15 0 10 ±VCC(V) 15 20 Figure 2. Iq vs. Supply Voltage 3 3 2.8 2.8 2.6 2.6 2.4 2.4 2.2 2.2 Iq(mA) Iq(mA) Figure 1. Offset Voltage vs. Common-Mode Voltage 5 2 1.8 2 1.8 1.6 1.6 1.4 1.4 1.2 1.2 1 1 -50 0 50 Temperature(℃) 100 -50 150 Figure 3. Iq vs. Temperature, +-2.5 V Supply, TPA1862 0 50 Temperature(℃) 100 150 Figure 4. Iq vs. Temperature, +-15 V Supply, TPA1862 160 140 EMIRR(dB) 120 100 80 60 40 20 0 100M 1000M Frequecy(Hz) Figure 5. EMIRR vs. Frequency www.3peak.com Figure 6. Open Loop Gain and Phase vs. Frequency RL = 10 kΩ, CL = 50 pF 11 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps 120 120 PSRR+ 100 PSRR- 100 80 CMRR(dB) PSRR(dB) 140 80 60 60 40 40 20 20 0 100 1K 10K Frequency(Hz) 100K 0 1000 1M Figure 7. PSRR vs. Frequency 10K 100K Frequency(Hz) Figure 8. CMRR vs. Frequency Time: 2 us/div, Measure Time: 260 ns Time: 2 us/div, Measure Time: 420 ns RL= 2 K, CL= 100 pF, G = 10 RL = 2 K, CL = 100 pF, G = 10 Figure 9. Positive Overload Recovery Figure 10. Negative Overload Recovery Voltage: 50 mV/div, Time: 2 us/div Voltage: 2 V/div, Time: 2 μs/div RL = 2 K, CL = 100 pF, G = 1 RL =2 K, CL =100 pF, G = 1 Figure 11. 100-mV Signal Step Response www.3peak.com 1M Figure 12. 10-V Signal Step Response 12 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 12 0.001 10 0.0008 8 0.0006 6 0.0004 4 0.0002 2 0 10 100 1K Frequency(Hz) 10K 0 100K 0 Figure 13. Voltage Noise Density vs. Frequency 16 -4 14 -6 12 -8 10 -40℃ TPA1862 25℃ TPA1862 85℃ TPA1862 125℃ TPA1862 8 6 5K 10K Frequency(Hz) 15K 20K Figure 14. THD vs. Frequency, G = 1 Vout(V) Vout (V) 3.5Vrms_40KHz Filter 3.5Vrms_A Weighting Filter 6Vrms_40KHz Filter 6Vrms_A Weighting Filter THD+N(%) Equivalent Input Voltage Noise(nV/√Hz) 40-V, 6-MHz, Zero-Drift Op Amps -40℃ TPA1862 25℃ TPA1862 85℃ TPA1862 -10 -12 -14 -16 4 0 20 40 60 Iout (mA) 80 0 100 100 Iout(mA) 150 200 Figure 16. VOUT vs. IOUT, Sink Figure 15. VOUT vs. IOUT, Source www.3peak.com 50 13 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Detailed Description Overview The TPA186x series op amps can operate on a single-supply voltage (4.5 V to 40 V), or a split-supply voltage (±2.25 V to ±20 V), making them highly versatile and easy to use. The power-supply pins should have local bypass ceramic capacitors (typically 0.01 μF to 0.1 μF). Parameters that can exhibit variance with regard to operating voltage or temperature are presented in the Typical Performance Characteristics. Functional Block Diagram Figure 17. Functional Block Diagram www.3peak.com 14 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Application and Implementation Note Information in the following application sections is not part of the 3PEAK’s component specification and 3PEAK does not warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. Application Information Low Side Current Sensing Application Figure 18 shows the device configured in a low-side current sensing application. The low-side current sensing method consists of placing a sense resistor between the load and the circuit ground. The voltage dropping across the resistor is amplified by different amplifier circuits with the device. The VREF can be used to add bias voltage to the output voltage. Particular attention must be paid to the matching and precision of R1, R2, R3, and R4, to maximize the accuracy of the measurement. Figure 18. Low-Side Current Sensing Application Power Supply Recommendations Place 0.1-μF bypass capacitors close to the power supply pins for reducing coupling errors from the noisy or high-impedance power supplies. www.3peak.com 15 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Tape and Reel Information Order Number Package D1 (mm) W1 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) W0 (mm) Pin1 Quadrant TPA1861-TR SOT23-5 180.0 13.1 3.2 3.2 1.4 4.0 8.0 Q3 TPA1861-SR SOP8 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 TPA1862-SR SOP8 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 TPA1862-VR MSOP8 330.0 17.6 5.2 3.3 1.5 8.0 12.0 Q1 TPA1862DF7R DFN3X3-8 330.0 17.6 3.4 3.4 1.1 8.0 12.0 Q2 www.3peak.com 16 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Order Number Package D1 (mm) W1 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) W0 (mm) Pin1 Quadrant TPA1864-SR SOP14 330.0 21.6 6.5 9.0 2.1 8.0 16.0 Q1 TPA1864-TR TSSOP14 330.0 17.6 6.8 5.4 1.2 8.0 12.0 Q1 www.3peak.com 17 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Package Outline Dimensions SOT23-5 www.3peak.com 18 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps SOP8 www.3peak.com 19 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps MSOP8 www.3peak.com 20 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps DFN3X3-8 www.3peak.com 21 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps SOP14 www.3peak.com 22 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps TSSOP14 www.3peak.com 23 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps Order Information Operating Temperature Range Package Marking Information MSL Transport Media, Quantity Eco Plan TPA1861-SR −40 to 125°C SOP8 1861 3 Tape and Reel, 4000 Green TPA1861-TR −40 to 125°C SOT23-5 A86 3 Tape and Reel, 3000 Green TPA1862-SR −40 to 125°C SOP8 1862 3 Tape and Reel, 4000 Green TPA1862-VR −40 to 125°C MSOP8 1862 3 Tape and Reel, 3000 Green TPA1862-DF7R −40 to 125°C DFN3X3-8 A1862 3 Tape and Reel, 4000 Green TPA1864-SR −40 to 125°C SOP14 1864 3 Tape and Reel, 2500 Green TPA1864-TR −40 to 125°C TSSOP14 1864 3 Tape and Reel, 3000 Green Order Number (1) For future products, contact the 3PEAK factory for more information and samples. Green: 3PEAK defines "Green" to mean RoHS compatible and free of halogen substances. www.3peak.com 24 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2023. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any thirdparty’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. www.3peak.com 25 / 26 AA20230101A6 TPA1861/TPA1862/TPA1864 40-V, 6-MHz, Zero-Drift Op Amps This page intentionally left blank www.3peak.com 26 / 26 AA20230101A6
TPA1864-SR 价格&库存
很抱歉,暂时无法提供与“TPA1864-SR”相匹配的价格&库存,您可以联系我们找货
TPA1864-SR
  • 2500+18.798792500+2.43913
库存:2441
TPA1864-SR
  • 1+31.972201+4.14837
  • 10+24.0526410+3.12081
  • 25+22.0785025+2.86467
  • 100+19.90467100+2.58262
  • 250+18.86786250+2.44809
  • 500+18.24322500+2.36705
  • 1000+17.728961000+2.30032
库存:2441
TPA1864-SR
    • 1+14.15120
    • 10+11.50520
    • 30+10.05480
    • 100+8.41820
    库存:100
    TPA1864-SR
      • 1+15.59520
      • 10+12.67920
      • 30+11.08080
      • 100+9.27720
      • 500+8.46720
      • 1000+8.10000
      库存:1732
      TPA1864-SR
      • 1+15.30300
      • 10+12.31020
      • 30+10.74930
      • 100+8.99920
      • 500+8.21330
      • 1000+7.85710
      库存:2335
