AiP74HC164SA14.TR
AiP74HC164SA14.TR
    I-CORE(中微爱芯)
    SOP-14
    8位串行输入、并行输出移位寄存器
AiP74HC164SA14.TR 数据手册
Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN e Tab: 835-12 or AiP74HC/HCT164 8-bit Serial-in, Parallel-out Shift Register Specification i-c Product Specification Revision History: Version Date 2019-05-A1 2019-05 2021-12-A2 2021-12 2022-01-A3 2022-01 Description New Modify Ordering Information Modify ambient temperature to -40℃~+105℃ and add electrical characteristics of -40℃~+105℃ Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 1、General Description The AiP74HC/HCT164 is an 8-bit serial-in/parallel-out shift register. The device features two serial data inputs (DSA and DSB), eight parallel data outputs (Q0 to Q7). Data is entered serially through DSA or DSB and either input can be used as an active HIGH enable for data entry through the other input. Data is shifted on the LOW-to-HIGH transitions of the clock (CP) input. A LOW on the master reset input (MR) clears the register and forces all outputs LOW, independently of other inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. i-c or e Features:  Input levels: For AiP74HC164: CMOS level For AiP74HCT164: TTL level  Gated serial data inputs  Asynchronous master reset  Specified from -40℃ to +105℃  Packaging information: DIP14/SOP14/TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN Ordering Information: Tube packing specifications: Part number Packaging form Marking code Tube quantity Boxed tube quantity Boxed quantity DIP14 74HC164 25 PCS/tube 40 tube/box 1000 PCS/box AiP74HCT164DA14.TB DIP14 74HCT164 25 PCS/tube 40 tube/box 1000 PCS/box AiP74HC164SA14.TB SOP14 Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: e AiP74HC164DA14.TB Notes 50 PCS/tube 200 tube/box 10000 PCS/box or 74HC164 SOP14 74HCT164 50 PCS/tube 200 tube/box 10000 PCS/box AiP74HC164TA14.TB TSSOP14(1) 74HC164 92 PCS/tube 100 tube/box 9200 PCS/box i-c AiP74HCT164SA14.TB AiP74HCT164TA14.TB TSSOP14(1) 74HCT164 92 PCS/tube 100 tube/box 9200 PCS/box AiP74HC164TA14.TB TSSOP14(2) 74HC164 94 PCS/tube 200 tube/box 18800 PCS/box AiP74HCT164TA14.TB TSSOP14(2) 74HCT164 94 PCS/tube 200 tube/box 18800 PCS/box AiP74HC164TA14.TB TSSOP14(3) 74HC164 96 PCS/tube 140 tube/box 13440 PCS/box AiP74HCT164TA14.TB TSSOP14(3) 74HCT164 96 PCS/tube 140 tube/box 13440 PCS/box Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 0.65mm TSSOP14(4) 74HC164 70 PCS/tube 140 tube/box 9800 PCS/box AiP74HCT164TA14.TB TSSOP14(4) 74HCT164 70 PCS/tube 140 tube/box 9800 PCS/box Reel packing specifications: Part number SOP14 Marking code 74HC164 Reel quantity Boxed reel quantity 4000 PCS/reel 8000 PCS/box Notes Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm or AiP74HC164SA14.TR Packaging form e AiP74HC164TA14.TB Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm SOP14 74HCT164 4000 PCS/reel 8000 PCS/box AiP74HC164TA14.TR TSSOP14 74HC164 4000 PCS/reel 8000 PCS/box i-c AiP74HCT164SA14.TR AiP74HCT164TA14.TR TSSOP14 74HCT164 4000 PCS/reel 8000 PCS/box Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 2、Block Diagram And Pin Description e 2.1、Block Diagram i-c or Figure 1. Logic symbol Figure 2. IEC logic symbol Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 5/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN or e Figure 3. Logic diagram Figure 4. Functional diagram i-c 2.2、Pin Configurations Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 6/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 2.3、Pin Description Pin No. 1 2 3 4 5 6 7 8 Pin Name DSA DSB Q0 Q1 Q2 Q3 GND CP Description data input data input output output output output ground (0V) clock input (LOW-to-HIGH, edge-triggered) 9 MR master reset input (active LOW) 10 11 12 13 14 Q4 Q5 Q6 Q7 VCC output output output output supply voltage or e — 2.4、Function Table Operating modes Reset (clear) Output MR CP DSA DSB Q0 Q1 to Q7 L H H H H X ↑ ↑ ↑ ↑ X l l h h X l h l h L L L L H L to L q0 to q6 q0 to q6 q0 to q6 q0 to q6 i-c Shift Input — Note: H=HIGH voltage level; L=LOW voltage level; ↑=LOW-to-HIGH clock transition; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; q=lower case letters indicate the state of the referenced input one set-up time prior to the LOW-to-HIGH clock transition. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 7/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Max. +7 Unit V ±20 mA ±20 mA ±25 50 - mA mA mA 500 mW e Parameter Symbol Conditions Min. supply voltage VCC -0.5 input clamping IIK VI < -0.5V or VI > VCC+0.5V current output clamping IOK VO < -0.5V or VO > VCC+0.5V current output current IO -0.5V < VO < VCC+0.5V supply current ICC ground current IGND -50 total power Ptot dissipation storage Tstg -65 temperature DIP 245 Soldering TL 10s temperature SOP 250 Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. ℃ or +150 ℃ 3.2、Recommended Operating Conditions Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V i-c Parameter supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO - AiP74HCT164 - Min. Typ. Max. Unit 2.0 0 0 - 5.0 1.67 - 6.0 VCC VCC 625 139 83 V V V ns/V ns/V ns/V -40 - +105 ℃ 4.5 0 0 5.0 - 5.5 VCC VCC V V V Δt/ΔV VCC=4.5V - 1.67 139 ns/V Tamb - -40 - +105 ℃ Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI = VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V VI = VIH or VIL IO=20uA; VCC=6.0V IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V VI= VCC or GND; VCC=6.0V VI= VCC or GND; IO=0A; VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.98 5.48 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V - - ±0.1 uA - - 8 uA - - 3.5 - pF e Symbol or Parameter LOW-level output voltage VOL input leakage current II supply current ICC input capacitance CI i-c AiP74HCT164 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V IO=-20uA; VCC=4.5V IO=-4.0mA; VCC=4.5V IO=20uA; VCC=4.5V VI = VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; VI=VCC-2.1V; IO=0A; other inputs at VCC or GND; VCC=4.5V to 5.5V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V - - ±0.1 uA - - 8 uA - 100 360 uA - - 3.5 - pF VOH VOL II supply current ICC additional supply current ΔICC input capacitance CI VI = VIH or VIL Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 9/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.3.2、DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol VIH LOW-level input voltage VIL HIGH-level output voltage VOH LOW-level output voltage VOL input leakage current II supply current ICC Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.84 5.34 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V V V V V V - - ±1 uA - - 80 uA VCC=4.5V to 5.5V 2.0 - - V VCC=4.5V to 5.5V - - 0.8 V IO=-20uA; VCC=4.5V IO=-4.0mA; VCC=4.5V IO=20uA; VCC=4.5V VI = VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; VI=VCC-2.1V; IO=0A; other inputs at VCC or GND; VCC=4.5V to 5.5V 4.4 3.84 - - 0.1 0.33 V V V V - - ±1 uA - - 80 uA - - 450 uA or HIGH-level input voltage Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI = VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V VI = VIH or VIL IO=20uA; VCC=6.0V IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=6.0V VI=VCC or GND; IO=0A; VCC=6.0V AiP74HCT164 e Parameter VIH i-c HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current VIL VOH VOL II supply current ICC additional supply current ΔICC VI = VIH or VIL Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 10/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.3.3、DC Characteristics 3 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol VIH LOW-level input voltage VIL HIGH-level output voltage VOH LOW-level output voltage VOL input leakage current II supply current ICC Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.7 5.2 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.4 0.4 V V V V V V V V V V V V V V V V - - ±1 uA - - 160 uA VCC=4.5V to 5.5V 2.0 - - V VCC=4.5V to 5.5V - - 0.8 V IO=-20uA; VCC=4.5V IO=-4.0mA; VCC=4.5V IO=20uA; VCC=4.5V VI = VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; VI=VCC-2.1V; IO=0A; other inputs at VCC or GND; VCC=4.5V to 5.5V 4.4 3.7 - - 0.1 0.4 V V V V - - ±1 uA - - 160 uA - - 490 uA or HIGH-level input voltage Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI = VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V VI = VIH or VIL IO=20uA; VCC=6.0V IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=6.0V VI=VCC or GND; IO=0A; VCC=6.0V AiP74HCT164 e Parameter VIH i-c HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current VIL VOH VOL II supply current ICC additional supply current ΔICC VI = VIH or VIL Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.3.4、AC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter CP to Qn propagation delay Symbol tpd see Figure 6 MR to Qn propagation delay tPHL see Figure 7 transition time tt see Figure 6 CP pulse width tW see Figure 6 Typ. Max. Unit 80 16 14 60 12 10 60 12 10 60 12 10 +4 +4 +4 6 30 35 41 15 12 12 39 14 11 11 19 7 6 14 5 4 17 6 5 17 6 5 8 3 2 -6 -2 -2 23 71 78 85 170 34 29 140 28 24 75 15 13 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz MHz - 40 - pF VCC=4.5V - 17 36 ns VCC=5.0V;CL=15pF - 14 - ns VCC=4.5V - 19 38 ns VCC=5.0V;CL=15pF - 16 - ns VCC=4.5V VCC=4.5V 18 7 7 15 - ns ns or — MR pulse width tW see Figure 7 MR to CP recovery time trec see Figure 7 DSA and DSB to CP set-up time tsu see Figure 8 DSA and DSB to CP hold time th see Figure 8 CP maximum frequency fmax see Figure 6 power dissipation capacitance CPD i-c — Min. e — Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V per package; VI= GND to VCC AiP74HCT164 CP to Qn propagation delay tpd see Figure 6 tPHL see Figure 7 tt tW see Figure 6 see Figure 6 — MR to Qn propagation delay transition time CP Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN pulse width — MR pulse width tW see Figure 7 VCC=4.5V 18 10 - ns 16 7 - ns 12 6 - ns +4 -2 - ns 27 55 - MHz - 61 - MHz — e MR to CP trec see Figure 7 VCC=4.5V recovery time DSA and DSB to CP tsu see Figure 7 VCC=4.5V set-up time DSA and DSB to CP th see Figure 8 VCC=4.5V hold time CP VCC=4.5V maximum fmax see Figure 8 VCC=5.0V;CL=15pF frequency power per package; dissipation CPD VI= GND to VCC-1.5V capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. 40 - pF i-c or - Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.3.5、AC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter CP to Qn propagation delay Symbol Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V AiP74HCT164 Min. Typ. Max. Unit 100 20 17 75 15 13 75 15 13 75 15 13 4 4 4 5 24 28 - 215 43 37 175 35 30 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz tpd see Figure 6 MR to Qn propagation delay tPHL see Figure 7 transition time tt see Figure 6 CP pulse width tW see Figure 6 tW see Figure 7 MR to CP recovery time trec see Figure 7 DSA and DSB to CP set-up time tsu see Figure 8 DSA and DSB to CP hold time th see Figure 8 CP maximum frequency fmax see Figure 6 CP to Qn propagation delay tpd see Figure 6 VCC=4.5V - - 45 ns tPHL see Figure 7 VCC=4.5V - - 48 ns tt see Figure 6 VCC=4.5V - - 19 ns tW see Figure 6 VCC=4.5V 23 - - ns tW see Figure 7 VCC=4.5V 23 - - ns trec see Figure 7 VCC=4.5V 20 - - ns tsu see Figure 8 VCC=4.5V 15 - - ns — i-c — or MR pulse width e — — MR to Qn propagation delay transition time CP pulse width — MR pulse width — MR to CP recovery time DSA and DSB Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 14/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 to CP set-up time DSA and DSB to CP; th see Figure 8 hold time CP maximum fmax see Figure 6 frequency Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. Number:AiP74HC/HCT164-AX-LJ-A015EN VCC=4.5V +4 - - ns VCC=4.5V 22 - - MHz 3.3.6、AC Characteristics 3 Parameter — tpd see Figure 6 Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V AiP74HCT164 Min. Typ. Max. Unit 120 24 20 90 18 15 90 18 15 90 18 15 4 4 4 5 20 24 - 255 51 43 210 42 36 110 22 19 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz - - 54 ns or CP to Qn propagation delay Symbol e (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) tPHL see Figure 7 transition time tt see Figure 6 CP pulse width tW see Figure 6 i-c MR to Qn propagation delay — MR pulse width tW see Figure 7 MR to CP recovery time trec see Figure 7 DSA and DSB to CP set-up time tsu see Figure 8 DSA and DSB to CP hold time th see Figure 8 CP maximum frequency fmax see Figure 6 CP to Qn propagation tpd see Figure 6 — VCC=4.5V Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 15/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN delay — MR to Qn propagation delay transition time CP pulse width tPHL see Figure 7 VCC=4.5V - - 57 ns tt see Figure 6 VCC=4.5V - - 22 ns tW see Figure 6 VCC=4.5V 27 - - ns tW see Figure 7 VCC=4.5V 27 - - ns MR to CP trec see Figure 7 recovery time DSA and DSB to CP tsu see Figure 8 set-up time DSA and DSB to CP; th see Figure 8 hold time CP maximum fmax see Figure 6 frequency Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. VCC=4.5V 24 - - ns VCC=4.5V 18 - - ns — MR pulse width e — 4 - - ns VCC=4.5V 18 - - MHz or VCC=4.5V 4、Testing Circuit i-c 4.1、AC Testing Circuit Figure 5. Test circuit for measuring switching times Definitions for test circuit: CL=load capacitance including jig and probe capacitance. RT=termination resistance should be equal to the output impedance Zo of the pulse generator. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 16/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 4.2、AC Testing Waveforms or e Figure 6. Waveforms showing the clock (CP) to output (Qn) propagation delays, the clock pulse width, the output transition times and the maximum clock frequency i-c Figure 7. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation delays and the master reset to clock (CP) removal time Figure 8. Waveforms showing the data set-up and hold times for Dn inputs Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 17/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 4.3、Measurement Points Type AiP74HC164 AiP74HCT164 Input VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V Output VX 0.1×VCC 0.1×VCC VY 0.9×VCC 0.9×VCC 4.4、Test Data Type VI VCC 3.0V Load tr , tf 6.0ns 6.0ns CL 15pF, 50pF 15pF, 50pF Test tPLH, tPHL tPLH, tPHL i-c or e AiP74HC164 AiP74HCT164 Input Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 18/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 5、Package Information i-c or e 5.1、DIP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 19/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN i-c or e 5.2、SOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 20/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN i-c or e 5.3、TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 21/ 22 VER:2022-01-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Lead and lead compou nds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Lead frame ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ Chip ○ ○ ○ The lead ○ ○ ○ Plastic sheet installed ○ ○ ○ Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Polybro minated biphenyl s e Part name Hexaval ent chromiu m compoun ds ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit explanation of the following the SJ/T11363-2006 standard. or ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 22/ 22 VER:2022-01-A3
AiP74HC164SA14.TR 价格&库存
很抱歉,暂时无法提供与“AiP74HC164SA14.TR”相匹配的价格&库存,您可以联系我们找货
