95 62 160
95 62 160
    KNIPEX(凯尼派克)
    缆线 切割器 圆形 6.25"(158.8mm)
95 62 160 数据手册
95 62 160 Wire Rope Cutter Also for high-strength wire rope ● ● ● ● ● ● ● ● Article No. 95 62 160 EAN 4003773082354 Compact, light and powerful Up to 30 % less physical effort compared to wire rope cutters of the same length Double-mounted box joint design for high level of stability Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Convenient work thanks to opening spring Secured by locking device during transport Ball bearing steel For wire rope with Ø 4.00 / 1960 Nmm² Head Tool burnished Handles with multi-component grips Cutting capacity copper cable, multiple6,0 stranded (diameter) Ø mm Compact at 160 mm but nevertheless more powerful than many larger wire rope cutters For cutting highstrength wire ropes (1960 N/mm2) with a diameter of up to 4 mm Double-bearing joint Cutting capacities wire 4,0 rope (diameter) Ø mm Length mm 160 Net weight g 170 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 62 160 价格&库存
很抱歉,暂时无法提供与“95 62 160”相匹配的价格&库存,您可以联系我们找货
