74 21 200
74 21 200
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 凹槽 8.00"(203.2mm)
74 21 200 数据手册
High Leverage Diagonal Cutters DIN ISO 5749 74 >> forged-on axle for heavy-duty work >> for very tough, continuous use >> high cutting performance with minimum effort due to optimum 74 01 200 coordination of the cutting edge angle and transmission ratio >> precision cutting edges induction hardened (approx. 64 HRC) cut several types of wire including piano wire >> chrome vanadium heavy-duty steel; forged, multi stage oil-hardened Style 1 With opening spring; can be activated if required Style 2 Angled head offers clearance for gripping 74 02 250 10" Length (250 mm) Suitable for copper conductors up to 16 mm² and aluminum conductors up to 35 mm² 74 02 200 T BKA / 74 02 250 T BKA / 74 22 200 T BKA / 74 22 250 T BKA* Pliers with integrated tether attachment point for tool drop protection system 20% less effort required compared to conventional diagonal cutters of the same length. With forged-on joint axle. 74 02 250 T BKA 74 08 200 US ASTM 74 12: Opening spring in deactivated position 74 12: Activated opening spring by pressing down with your thumb 74 12 180 2 3/4" 74 21 200 12°   100 With integrated forged joint axle for very tough, continuous use Cutting capacities Product Number Packaging 74 01 140 Inch mm Pliers Head Handles Style 5 1/2 140 - 74 01 160 X 6 1/4 160 74 01 180 X 7 1/4 180 74 01 200 X 8 200 - 74 01 250 X 10 250 - 74 02 140 5 1/2 140 - 74 02 160 6 1/4 160 X 8 200 74 02 200 T BKA X 8 200 74 02 250 X 10 250 74 02 250 T BKA X 10 250 74 08 200 US 8 200 74 08 250 US X X 10 250 74 12 180 7 1/4 180 74 21 180 7 1/4 180 plastic coated - polished multi-component grips -   ASTM 74 21 250 X 10 250 74 22 200 X 8 200 12° 74 22 200 T BKA X 8 200 12° 74 22 250 X 10 250 12° 74 22 250 T BKA X 10 250 12°     0.53 0.58 0.90 0.35 0.49 0.60 0.66 1/8 3.0 3/32 2.5 0.67 black atramentized polished multi-component grips - 3/16 4.6 9/64 3.5 1/8 3.0 1.00 black atramentized polished multi-component grips, integrated tether attachment point - 3/16 4.6 9/64 3.5 1/8 3.0 1.01 polished insulated, multi-component handles, ASTM-tested 11/64 4.2 3/16 4.6 9/64 3.4 5/32 3.8 5/32 3.8 11/64 4.2 3/16 4.6 11/64 4.2 1/8 3.0 9/64 3.5 3/32 2.5 7/64 2.7 7/64 2.7 1/8 3.0 9/64 3.5 1/8 3.0 3/32 2.5 1/8 3.0 5/64 2.0 3/32 2.2 3/32 2.2 3/32 2.5 1/8 3.0 3/32 2.5 - polished multi-component grips black atramentized polished plastic coated 2 2   0.42 11/64 4.2 2 12° 0.29 - 1 8 200 lbs multi-component grips, integrated tether attachment point 1 X Ø Inch Ø mm 1/16 1.5 5/64 2.0 3/32 2.2 3/32 2.5 1/8 3.0 1/16 1.5 5/64 2.0 3/32 2.2 3/32 2.5 polished black atramentized 74 21 200 Ø Inch Ø mm 5/64 2.0 3/32 2.5 7/64 2.7 1/8 3.0 9/64 3.5 5/64 2.0 3/32 2.5 7/64 2.7 1/8 3.0 black atramentized black atramentized 6 1/4 160 74 12 160 polished black atramentized   7 1/4 180 74 02 180 74 02 200 black atramentized Ø Inch Ø mm 1/8 3.1 9/64 3.4 5/32 3.8 11/64 4.2 3/16 4.6 1/8 3.1 9/64 3.4 5/32 3.8 11/64 4.2 0.68 1.04 0.48 0.60 0.52 0.59 0.89 black atramentized polished multi-component grips 2 black atramentized polished multi-component grips, integrated tether attachment point 2 11/64 4.2 1/8 3.0 3/32 2.5 0.68 black atramentized polished multi-component grips 2 3/16 4.6 9/64 3.5 1/8 3.0 1.00 black atramentized polished multi-component grips, integrated tether attachment point 2 3/16 4.6 9/64 3.5 1/8 3.0 1.01 *Learn more about our tethered tool system on pages 207-211 0.67 101
74 21 200 价格&库存
很抱歉,暂时无法提供与“74 21 200”相匹配的价格&库存,您可以联系我们找货
