73 71 180
73 71 180
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 7.25"(184.2mm)
73 71 180 数据手册
KNIPEX TwinForce® High Leverage Diagonal Cutter DIN ISO 5749 73 Superior high leverage diagonal cutter with patented double joint >> ideal transmission of force due to double-hinged design 73 71 180 >> reliably cuts all types of wire, including steel tape >> for rough or very fine cutting >> for comfortable cutting, repetitive cutting or extremely hard cutting jobs >> high degree of stability and zero backlash due to precisely milled forged-in axle >> chrome vanadium heavy-duty steel; forged, oil-hardened 73 72 180 NEW for diagonal cutters: The option to reapply the tool. The KNIPEX TwinForce® cuts even 5/32" (4 mm) thick wire without great effort when reapplied two or three times. Conventional high leverage diagonal cutters either cannot cut these diameters or only with very great effort. Extremely easy cutting with little strain: cuts 50% easier than KNIPEX high leverage diagonal cutters of the same size Insert the wires as close to the hinge as possible. In case of cutters with very high transmission, the width of the gap between the cutting edges close to the fulcrum may be less than the thickness of the wire. Wires may slip forward when the cutting starts. Continue cutting in the same location along the wire. Now cutting is much easier because the wire remains in place closer to the fulcrum. First make a notch in the wire using the KNIPEX TwinForce® until the required hand force increases considerably. Now open the pliers and slide the wire backwards towards the joint. You can repeat this process if necessary. TwinForce ® Inch mm Pliers Head Handles X 7 1/4 180 black atramentized polished plastic coated 73 72 180 BK X 7 1/4 180   black atramentized polished multi-component grips Product Number Packaging 73 71 180 Ø Inch Ø mm 7/32 5.5 7/32 5.5 Cutting capacities Ø Inch Ø mm 3/16 4.6 3/16 4.6 Ø Inch Ø mm 1/8 3.2 1/8 3.2 Ø Inch Ø mm 1/8 3.0 1/8 3.0 lbs 0.56 0.62 99
73 71 180 价格&库存
很抱歉,暂时无法提供与“73 71 180”相匹配的价格&库存,您可以联系我们找货
