77 02 135 H
77 02 135 H
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 5.25"(133.4mm)
77 02 135 H 数据手册
Product information 77 02 135 H Electronics Diagonal Cutter with carbide cutting edges DIN ISO 9654 ● sturdy, zero-backlash box joint ● for extreme demands on cutting pliers caused by hard or tough materials, e.g. piano, nickel, tungsten and diode wire, such as those used more frequently in the electronics and aerospace industries ● always the right cutting tool, even with the hardest material ● precision carbide metal cutting edges soldered into forged blanks ● hardness of the carbide cutting edges 80 – 83 HRC ● pliers with carbide metal cutting edges have a substantially longer service life than such with conventional cutting edges ● constantly reliable cutting results due to the avoidance of cutter deformations ● high cost saving due to longer service life of the pliers Allgemein Article No. 77 02 135 H EAN 4003773075806 Head mirror polished Handles with multi-component grips weight 130 g Dimensions 135 x 50 x 20 mm Technische Attribute Cutting capacities medium hard wire (diameter) Ø 1.6 Cutting capacities hard wire (diameter) Ø 1.2 Cutting capacities soft wire (diameter) Ø 2.2 mm 18 mm 9.5 mm Head width 15 mm Klassifikation eCl@ss 5.1.4 21040302 ETIM 5.0 EC000165 ETIM 6.0 EC000165 proficl@ss 6.0 AAA949c004 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 26.03.2019 | page 1 1
77 02 135 H 价格&库存
很抱歉,暂时无法提供与“77 02 135 H”相匹配的价格&库存,您可以联系我们找货
