34 42 130
34 42 130
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 5.25"(133.4mm)
34 42 130 数据手册
Product information 34 42 130 Precision Electronics Gripping Pliers DIN ISO 9655 ● the assortment for highest standard of performance and results ● precision pliers for fine assembly work, e g. in electronics and fine mechanics ● for gripping, holding and bending ● bolted joint: precise, zero backlash operation of pliers ● precisely finished joint surfaces for smooth, low friction movement along the complete opening range ● low-friction double spring for gentle and even opening ● smooth ground gripping surfaces, edges carefully deburred ● non-reflective finish ● low weight ● ergonomically shaped, two-colour dual component handles; blue/grey ● flat, wide jaws ● with precision laser cut cross-shaping ● Ball bearing chrome steel, forged, multi stage oil-hardened Allgemein Article No. 34 42 130 EAN 4003773080282 Pliers burnished Head polished Handles with multi-component grips weight 67 g Dimensions 130 x 51 x 20 mm Technische Attribute Style 4 21.9 6.5 1.4 3.5 Head width 11.2 Klassifikation eCl@ss 5.1.4 21040301 proficl@ss 6.0 EAA840c015 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 26.03.2019 | page 1 1
34 42 130 价格&库存
很抱歉,暂时无法提供与“34 42 130”相匹配的价格&库存,您可以联系我们找货
