86 03 300
86 03 300
    KNIPEX(凯尼派克)
    可调(水泵) 钳子 平头 平滑 11.81"(300.0mm)
86 03 300 数据手册
86 03 300 Pliers Wrench pliers and a wrench in a single tool ● ● ● ● ● ● ● ● ● ● ● Replaces the need for sets of metric and imperial spanners Smooth jaws for damage free installation of plated fittings - working directly on chrome! Adjustable tightening tool Also excellent for gripping, holding, pressing and bending workpieces Push the button for adjustment on the workpiece Zero backlash jaw pressure prevents damage to edges of sensitive components Parallel jaws give a more solid grip; its design allows flexible adjustment of all widths up to the specified maximum size Reliable catching of the hinge bolt: no unintentional shifting The ratchet type principle allows quick and easy tightening and release of all bolted connections Lever transmission greater than 10 : 1 for strong gripping power Chrome vanadium electric steel, forged, oil-hardened The smooth jaws grip all parallel surfaces in the capacity range with a high degree of pressure if necessary and open up almost unlimited application possibilities for the pliers wrench: e.g. for tightening locknuts, exerting pressure to activate the adhesive power of contact adhesives, edge breaking in tile work, snapping cable ties, utilisation as a small vice. Article No. 86 03 300 EAN 4003773041429 Pliers chrome plated Handles plastic coated B2 mm 9,5 B3 mm 15,0 B1 mm 9,5 Adjustment positions 22 Capacities for nuts Inch 2 3/8 Pliers wrench: zero backlash contact pressure, no damage to edges Conventional open end wrench: edge pressure causes surface damage Working on plated fittings without damage of the surface Ideal for bending operations Capacities for nuts mm 60 Length mm 300 Net weight g 729 technical change and errors excepted Fast adjustment at the touch of a button replaces the need for sets of metric and imperial spanners Spare Parts Article No. EAN KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 87 09 01 4003773074724 Assortment of spare parts for adjustment for 86/87 250/300 (without 87 2) KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
86 03 300 价格&库存
很抱歉,暂时无法提供与“86 03 300”相匹配的价格&库存,您可以联系我们找货
