13 82 8 T BKA
13 82 8 T BKA
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 有齿 7.87"(200.0mm)
13 82 8 T BKA 数据手册
Installation Pliers 13 >> multifunctional pliers for electrical installation with 6 functions; to grip flat and round material, for bending, deburring, cutting cable, stripping and crimping ferrules (end sleeves) >> smooth surfaces near the tips grip single conductors without damaging them; serrated gripping surfaces and pipe grip for gripping flat and round material >> clear-cut outside edge on the jaw for working on flush-mounted junction boxes and deburring feed-through holes >> stripping holes for 12 and 14 AWG (0.75 – 1.5 mm² and 2.5 mm²) >> crimp die for ferrules (end sleeves) 12 – 20 AWG (0.5 – 2.5 mm²) >> cable shears with induction hardened precision cutting edges for copper and aluminum cables up to 19/32" dia. (5 x 2.5 mm² / dia. 5 mm) >> slim dimensions for easy access in confined areas >> bolted joint: precise, zero-backlash operation of pliers >> high-grade special tool steel; forged, multi stage oil-hardened 13 81 8 13 82 8 13 82 8 T BKA* Pliers with integrated tether attachment point for tool drop protection system 13 82 8 T BKA 13 88 8 US ASTM Cutting capacities Inch Product Number Packaging mm 13 81 8 X 8 200 13 82 8 X 8 200 Pliers 13 82 8 T BKA X 8 200   13 88 8 US 8 200 ASTM X *Learn more about our tethered tool system on pages 207-211 Head Handles black polished atramentized non-slip plastic coated black polished atramentized multi-component grips black polished atramentized insulated, multi-component grips, ASTM-tested Ø Inch Stripping capacities Crimping for cross-sections capacities AWG AWG AWG lbs 9/16 0 12 and 14 12 - 20 0.52 9/16 0 12 and 14 12 - 20 0.59 9/16 0 12 and 14 12 - 20 0.60 9/16 0 12 and 14 12 - 20 0.60 45
13 82 8 T BKA 价格&库存
很抱歉,暂时无法提供与“13 82 8 T BKA”相匹配的价格&库存,您可以联系我们找货
