92 81 05
92 81 05
    KNIPEX(凯尼派克)
    镊子 抗磁,防静电 尖头 精细型 5.25"(133.4mm)
92 81 05 数据手册
Product information 92 81 05 Tweezers with exchangeable tips ESD ● For particularly demanding precision work: tough and highly resistant to corrosion ● Maximum surface protection when handling sensitive electronic components, micro-mechanical parts, as well as glass and ceramic components ● For the electronics and precision engineering industries, watchmakers and jewellers ● Handcrafted body: polished edges and an excellent matt, scratch-free and non-reflective surface ● High-quality premium stainless steel body: high temperature resistance and excellent corrosion resistance to most chemicals, salts and acids ● The interchangeable tips are made from 30% carbon fibre reinforced plastic: very good electrical and thermal conductivity, scratch-proof and with high abrasion resistance ● The interchangeable, carbon fibre reinforced plastic tips have a surface resistance between 10^2 and 10^3 ohms to compensate in a controlled manner the differences in potential between the operator and electronic components ● The interchangeable tips are permanently temperature stable up to 130° C, and up to 190° C for short periods ● The carbon fibre reinforced plastic tips are extremely flexible, fatigueresistant, vibration-dampening and water-repellent ● The tips have good chemical resistance to most oils, lubricants, fuels and nonpolar solvents ● The same accuracy and stability as regular tweezers: the plastic tips have a 3-point connection with zero backlash (2 fixed points on the arms, one screw), which guarantee the user perfect attachment to the body with zero backlash ● Potential savings: the tip assortment includes a selection of the most diverse shapes. Depending on the application, only the tips need to be purchased later ● Premium stainless steel General Article No. 92 81 05 EAN 4003773087175 Material premium stainless steel Gripping surfaces smooth gripping surfaces Weight 17 g Dimensions 130 x 10 x 17 mm Reach no RohS no Technical details Tips width (A) 0.7 mm Tips width (B) 0.6 mm Corrosion-resistant yes yes VDE tested no sectors Industry electronics KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.07.2021 | page 1 2 Technical details Classification eCl@ss 5.1.4 21040500 ETIM 5.0 EC000182 ETIM 6.0 EC000182 proficl@ss 6.0 EAB696c019 Spare Parts 92 89 05 Exchangeable ESD tips for 92 81 05, technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.07.2021 | page 2 2
92 81 05 价格&库存
很抱歉,暂时无法提供与“92 81 05”相匹配的价格&库存,您可以联系我们找货
