SS54C
SS54C
    DIOS(迪恩思)
    SMC(DO-214AB)
    肖特基二极管 40V 5A SMC(DO-214AB)
SS54C 数据手册
SS52C THRU SS520C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Reverse Voltage - 20 to 200 Volts Forward Current -5.0 Amperes Features DO-214AB/SMC The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Built-in strain relief,ideal for automated placement Low reverse leakage 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90) High forward surge current capability High temperature soldering guaranteed 0.280(7.11) 0.260(6.60) 250 C/10 seconds at terminals 0.012(0.305) 0.006(0.152) Mechanical Data 0.103(2.62) 0.079(2.06) 0.060(1.52) 0.030(0.76) Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Weight : 0.008 ounce, 0.225 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS SS52C SS54C SS56C SS58C SS510C SS515C SS520C UNITS Maximum repetitive peak reverse voltage VRRM 20 40 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 40 60 80 100 150 200 V Maximum average forward rectified current at TL =100 C I(AV) 5.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 120.0 A Maximum instantaneous forward voltage at 5.0A VF Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C Typical thermal resistance Operating junction temperature range Storage temperature range IR 0.70 0.55 0.85 0.5 50 0.95 0.05 10 V mA RqJA 47.0 C/W TJ -55 to +150 C TSTG -55 to +150 C 1 SS52C THRU SS520C Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 140 Peak Forward Surage Current Amperes 8.0 7.0 6.0 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 5.0 4.0 3.0 2.0 1.0 0.0 0 20 40 60 80 100 120 140 120 100 80 60 f=60Hz 40 20 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 TJ=25 C 1 0.1 SS52C-SS54C SS56C SS58C-SS510C SS515C-SS520C 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, VOLTS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES SS52C-SS56C SS58C-SS520C 10.0 10 TJ=100 C 1 0.1 0.01 0.001 0 TJ=25 C 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 2
SS54C 价格&库存
很抱歉,暂时无法提供与“SS54C”相匹配的价格&库存,您可以联系我们找货
SS54C
  • 20+0.16275
  • 200+0.15225
  • 500+0.14175
  • 1000+0.13125
  • 3000+0.12600
  • 6000+0.11865
库存:3942
SS54C
  • 20+0.55440
  • 100+0.33070
  • 800+0.23150
  • 3000+0.16540
  • 6000+0.15710
  • 30000+0.14550
库存:3611
