34 22 130 ESD
34 22 130 ESD
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 5.25"(133.4mm)
34 22 130 ESD 数据手册
34 22 130 ESD Precision Electronics Gripping Pliers ESD ● ● ● ● ● ● ● ● ● For very precise assembly work, e.g. in electronics and fine mechanics For gripping, holding and bending Electrically discharging handles - dissipative Smoothly ground gripping surfaces, edges finely rounded Approx. 20% lighter than conventional electronics pliers Bolted joint and carefully manufactured joint surfaces for even, lowfriction movement throughout the entire opening range Smooth-running double spring for a gentle and even opening Ergonomically optimised multi-component handles Ball bearing chrome steel, forged, multi stage oil-hardened Style:half-round jaws ❍ The subtle difference KNIPEX precision electronics pliers are made of high-quality ball bearing steel and processed with the highest degree of care. Each opening movement is gentle and even without backlash. Each work step proceeds reliably and precisely. This makes work much easier for professionals. ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 34 22 130 ESD EAN 4003773061656 Pliers burnished Head polished Handles with multi-component grips Style 2 B mm 22,7 D mm 6,5 E mm 1,6 F mm 1,6 A mm 11,2 Nominal size 130 mm Length mm 135 Net weight g 65 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
34 22 130 ESD 价格&库存
很抱歉,暂时无法提供与“34 22 130 ESD”相匹配的价格&库存,您可以联系我们找货
