92 09 05 ESD
92 09 05 ESD
    KNIPEX(凯尼派克)
    镊子 抗磁,防静电 扁平 钝头 4.50"(114.3mm)
92 09 05 ESD 数据手册
Product information 92 09 05 ESD ● Available in reusable ESD or disposable versions ● ESD tweezers are made of 30% carbon fibre reinforced plastic, are electrically and thermally highly conductive and are characterised by high resistance to abrasion and scratching ● ESD versions only: with a surface resistance between 10^2 and 10^3 ohms to compensate in a controlled manner the differences in potential between the operator and the electronic components ● ESD plastic tweezers are temperature-stable up to 130° C, short-term use is possible at up to 190° C ● The carbon fibre reinforced plastic of the ESD variants is extremely flexible, fatigue-resistant, vibration-reducing and water-repellent, with good chemical resistance to most oils, greases, fuels and nonpolar solvents ● ESD plastic tweezers are ideal for maximum surface protection when handling sensitive electronic components, micro-mechanical parts, as well as glass and ceramic components ● ESD plastic tweezers: also available as a set (92 00 05 ESD) ● Carbon fibre reinforced plastic Plastic Tweezers ESD DIN EN 61340 -5-1 General Article No. 92 09 05 ESD EAN 4003773087014 Material carbon fibre reinforced plastic Gripping surfaces smooth gripping surfaces Weight 4.5 g Dimensions 115 x 11.5 x 15 mm Standard DIN EN 61340 -5-1 Reach-konform no RohS-konform no Technical details Surface matt finish Finish straight Tips width (A) 0.12 mm Tips width (B) 7.7 mm Tips width (C) 11.3 mm Tweezers tip version blunt Corrosion-resistant yes Acid resistance very good ESD-tested yes VDE tested no Sectors electronics Magnetic non-magnetisable (100%) Behaviour electrically dissipative KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 1 2 Technical details Classification eCl@ss 5.1.4 21040500 ETIM 5.0 EC000182 ETIM 6.0 EC000182 proficl@ss 6.0 EAB696c019 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 2 2
92 09 05 ESD 价格&库存
很抱歉,暂时无法提供与“92 09 05 ESD”相匹配的价格&库存,您可以联系我们找货
