Product information
92 09 04 ESD
● Available in reusable ESD or disposable versions
● ESD tweezers are made of 30% carbon fibre reinforced plastic, are
electrically and thermally highly conductive and are characterised by
high resistance to abrasion and scratching
● ESD versions only: with a surface resistance between 10^2 and
10^3 ohms to compensate in a controlled manner the differences in
potential between the operator and the electronic components
● ESD plastic tweezers are temperature-stable up to 130° C, short-term
use is possible at up to 190° C
● The carbon fibre reinforced plastic of the ESD variants is extremely
flexible, fatigue-resistant, vibration-reducing and water-repellent, with
good chemical resistance to most oils, greases, fuels and nonpolar
solvents
● ESD plastic tweezers are ideal for maximum surface protection when
handling sensitive electronic components, micro-mechanical parts, as
well as glass and ceramic components
● ESD plastic tweezers: also available as a set (92 00 05 ESD)
● Carbon fibre reinforced plastic
Plastic Tweezers ESD
DIN EN 61340 -5-1
General
Article No.
92 09 04 ESD
EAN
4003773087007
Material
Gripping surfaces
smooth gripping surfaces
Weight
4.5 g
Dimensions
115 x 11.5 x 15 mm
Standard
DIN EN 61340 -5-1
Reach-konform
no
RohS-konform
no
Technical details
Surface
matt finish
Finish
straight
Tips width (A)
0.12 mm
Tips width (B)
3.3 mm
Tips width (C)
11.5 mm
Tweezers tip version
blunt
Corrosion-resistant
yes
Acid resistance
very good
ESD-tested
yes
VDE tested
no
Sectors
electronics
Magnetic
non-magnetisable (100%)
Behaviour
electrically dissipative
KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal
16.09.2021 | page 1 2
Technical details
Classification
eCl@ss 5.1.4
21040500
ETIM 5.0
EC000182
ETIM 6.0
EC000182
proficl@ss 6.0
EAB696c019
technical change and errors excepted
16.09.2021 | page 2 2
很抱歉,暂时无法提供与“92 09 04 ESD”相匹配的价格&库存,您可以联系我们找货
