BST12-0.7S16PCM
BST12-0.7S16PCM
    BELLNIX
    SMD7 模块
    非隔离 PoL 模块 直流转换器 1 输出 0.75 ~ 5V 16A 10V - 14V 输入
BST12-0.7S16PCM 数据手册
Bellnix Tracking Function, Non-Isolated Type POL DC-DC Converter RoHS Tracking Output Preoision Sequencial Simultaneous Ratio-Metric Compliance World Standard Size! ±2% 6A/10A/16A BST Series Low Price, Tracking Function, Step Down DC-DC Converter Input: +2.8 to +5.5V  Output: +0.75V[+0.75 to +3.3V] Input: +10 to 14V  Output: +0.75V[+0.75 to +5.0V] Voltage can be optionally set with external resistors. (Ex.: 1V, 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 5V) - Tracking Function Models Sequencial Operation BST Series BST04-0.7S06PCM BST12-0.7S06PCM BST04-0.7S10PCM BST12-0.7S10PCM BST04-0.7S16PCM BST12-0.7S16PCM Simultaneous Tracking Operation Ratio-Metric Tracking Operation - Remote ON/ OFF Control - Industry's Standard Package - Surface Mount Package (SMD) - Ultra High Efficiency - Adjustable Output Voltage - Over-Current Protection - No Electrolytic Capacitor, No Tantalum Capacitor - Operating Temp Range -40°C to +85°C (Temp Derating Required) - RoHS Compliance - DOSA Compatible Input V Vdc Vdc 2.8-5.5 10-14 2.8-5.5 10-14 2.8-5.5 10-14 0.75-3.3 0.75-5.0 0.75-3.3 0.75-5.0 0.75-3.3 0.75-5.0 (6A series) 2.00 %(typ.) 6 0.3 0.2 %(typ.) 0.4 10 0.3 0.4 16 0.3 0.4 Efficiency mVpp(typ.) %(typ.) 40 30 25 30 25 30 94 91.5 96 94.5 95 93.5 (10/16A series) 33.0 4.83 4.83 4.83 4.83 7.54 2.00 1 1.40 3.8 Bottom View This catalogue is an outline of the products. When in designing, be sure to refer to the data sheets. Pin 1 2 3 4 5 6 30K Function On/Off Vin Seq 13.5 1.2 Model BST04 BST12 Pin no. is not shown on the converter. Gnd Trim Vout Bottom View Weight : BST04-16A : 8.0g typ. Weight : BST04-10A : 9.0g typ. Weight : BST12-10A/16A : 9.0g typ. Units : mm Pin 1 2 3 4 5 6 7 H(Height) 8.3 9.7 Function On/Off Vin Seq Pin no. is not shown on the converter. Gnd Vout Trim Sense BST-10A/16A Series Vin Cout R1 Vin Load Vout BST**-0.7S10PCM BST**-0.7S16PCM 30K Trim Gnd Sense Trim Seq On/Off Cin Gnd Cout R1 Load SW1 SW1 Cin: BST04=47µF Ceramic capacitor//2×100µF Tantalum capacitor Cin: BST04=47µF Ceramic capacitor//2×100µF Tantalum capacitor BST12=2×22µF Ceramic capacitor Cout: 1µF Ceramic capacitor//10µF Tantalum capacitor (Common for BST04 and 12) R1: Vout up Resistor 1.91 1 Vout Seq On/Off 7 2.80 BST **-0.7S06P CM Cin 6 2 0.120 BST-6A Series Vin 5 29.90 Weight : BST-6A : 4.0g typ. Units : mm - Note! 4 0.64 1.50 2 0.120 3 6 8.64 5 4 1.5 3 10.29 2.3 11.4 8.89 1.5 1.40 A H(HEIGHT)max. 4.83 4.06 4.06 4.57 7.1max. Output I Line Reg. Load Reg. Ripple Noise Note 1:When the output voltage is not adjusted, the rated output voltage is Vo=0.75V. Note 2: When adjusting the Vout, the input and output voltage difference must be greater than 0.5V. Vin(V)-Vo(V)≧0.5V Note 3: Ripple noise is measured at 20MHz bandwidth. Note 4: Efficiency is when BST04 series is at: Vin=5V,Vo=3.3V and BST12 series is at: Vin=12V,Vo=5V respectively. Note 5: Depending on the ambient temp conditions, air flow cooling is required. 27.9 Vin Output V (Common for 10A and 16A series) BST12 (10A series)=4×22µF Ceramic capacitor BST12 (16A series)=6×22µF Ceramic capacitor Cout: 1µF Ceramic capacitor//10µF Tantalum capacitor (Common for BST04 and 12) R1:Vout up Resistor
BST12-0.7S16PCM 价格&库存
很抱歉,暂时无法提供与“BST12-0.7S16PCM”相匹配的价格&库存,您可以联系我们找货
