YSPI1030Y-100M
YSPI1030Y-100M
    YJYCOIN(益嘉源)
    IND-2P_10.5X10.3MM_SM
    10UH ±20% 6A
YSPI1030Y-100M 数据手册
SMD Power Inductors -YSPI1030Y Series ■ Features ● Molding Inductor. ● Low Profile,Low Temp. ● Large Current(Over 15A). ● Customize For Different Need. ● Operating temperature:-40℃ ~ +125℃. ■ Applications ● General Electronic. ● Video Device,TV,TFT. ● Power Module for PC. ● NB/Lap Top Computer. ● Server,VGA Card/Module. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance value ⑷ :Inductance Tolerance:N=±30%,M=±20% ■ Shapes and Dimensions (Unit:mm) TYPE A B C Max. YSPI1030Y 10.5±1.0 10.3±0.3 3.0 深圳市益嘉源电子有限公司 http://www.yjycoin.com D 2.8±0.3 Flatten OR 3.0±0.3 E G Ref. H Ref. I Ref. 2.0±0.5 6.0 4.0 3.5 -1- SMD Power Inductors -YSPI1030Y Series ■ YSPI1030Y Series Inductance Part Number DC Resistance (mΩ) (uH) @100KHz Heat Rating Saturation Typ. Max. Current (A) Current (A) YSPI1030Y-R12M 0.12 0.60 0.78 40.0 62.0 YSPI1030Y-R22M 0.22 0.80 1.05 24.0 40.0 YSPI1030Y-R36M 0.36 1.10 1.40 20.0 35.0 YSPI1030Y-R56M 0.56 2.60 3.30 18.0 30.0 YSPI1030Y-R68M 0.68 2.60 3.30 16.0 20.0 YSPI1030Y-1R0M 1.0 4.50 5.50 9.0 16.0 YSPI1030Y-2R2M 2.2 11.0 13.5 7.0 11.0 YSPI1030Y-3R3M 3.3 13.0 16.0 6.0 10.0 YSPI1030Y-4R7M 4.7 19.0 23.0 5.5 8.0 YSPI1030Y-6R8M 6.8 24.0 28.0 5.0 7.5 YSPI1030Y-8R2M 8.2 44.0 50.0 4.5 7.0 YSPI1030Y-100M 10 58.0 66.0 4.0 6.0 ※ The saturation current value is the DC current value having inductance decrease down to 30%.(at 20℃) ※ The temperature rise current value is the DC current value having temperature increase up to 40℃. (at 20℃) ※ The rated current is the DC current value that satisfies both of current value saturation current value and temperature rise current value. 深圳市益嘉源电子有限公司 http://www.yjycoin.com -2- SMD Power Inductors -YSPI1030Y Series ■ Taping Dimensions(Unit:mm) TYPE W A B C D E P K Ref T MPQ YSPI1030Y 24±0.3 10.6±0.1 11.45±0.1 10.75 11.5±0.1 4.4±0.1 16±0.1 4.2 0.40±0.05 1000 ■ Reel Dimensions(Unit:mm) TYPE W W1 W2 W3 A B C D YSPI1030Y 330±2.0 24.4±1.5 30.4MAX 23.9 Min 13.0±0.50 21.0±0.80 2.0±0.50 100 Min 深圳市益嘉源电子有限公司 http://www.yjycoin.com -3- SMD Power Inductors -YSPI1030Y Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com -4-
YSPI1030Y-100M
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光隔离集成电路,用于红外发射和接收。
3. 引脚分配:共有8个引脚,包括Vcc、Out、GND、Vo、RE、DE、He和OE。
4. 参数特性:工作电压为5V,工作电流为20mA,响应频率为20kHz,隔离电压为2.5kV。
5. 功能详解:EL817通过红外信号实现电信号的隔离传输,具有抗干扰能力强、传输距离远等优点。
6. 应用信息:广泛应用于工业控制、仪器仪表、通信设备等领域。
7. 封装信息:采用DIP-8封装形式。
YSPI1030Y-100M 价格&库存
很抱歉,暂时无法提供与“YSPI1030Y-100M”相匹配的价格&库存,您可以联系我们找货
