SMD Power Inductors
-YSMC2016S Series
■ Features
● Molding Inductor.
● Low Profile,Low Temp.
● Large Current.
● Customize For Different Need.
● Operating temperature:-40℃ ~ +125℃.
■ Applications
● General Electronic.
● Video Device,TV,TFT.
● Power Module for PC.
● NB/Lap Top Computer.
● Server,VGA Card/Module.
■ Product Identification
⑴ :Type
⑵ :Dimensions
⑶ :Inductance value
⑷ :Inductance Tolerance:N=±30%,M=±20%,K=±10%
深圳市益嘉源电子有限公司
http://www.yjycoin.com
Tel:0755-27803896
Mob:(86)13682526134
-1-
SMD Power Inductors
-YSMC2016S Series
■ Shapes and Dimensions (Unit:mm)
TYPE
A
B
C Max.
D
E
F Ref.
G Ref.
H Ref.
YSMC2016S
2.0±0.2
1.6±0.2
1.0
0.8 Typ
0.5 Typ
2.1
1.7
0.5
■ YSMC2016S Series
Part Number
Inductance
DC Resistance
Saturation
Heat Rating
(uH)
(mΩ)
current(A)
current(A)
@100KHz
Typ.
Max.
Typ.
Max.
Typ.
Max.
YSMC2016S-R24□
0.24
9
12
7.8
7.0
5.9
5.4
YSMC2016S-R33□
0.33
16
19
7.6
6.8
5.7
5.2
YSMC2016S-R47□
0.47
18
21
6.0
5.6
5.4
4.8
YSMC2016S-1R0□
1.0
35
42
4.5
4.2
4.6
4.2
YSMC2016S-1R5□
1.5
61
68
3.5
3.0
3.6
3.2
※ Saturation current:indicates the current when the inductance decrease to approximately 70% of initial
value.(at 25℃)
※ The temperature rise current value is the DC current value having temperature increase up to
approximately 40℃. (at 25℃)
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-2-
SMD Power Inductors
-YSMC2016S Series
■ Reliability Test
NO.
ITEMS
1
OPERATION TEMPERATURE
STORAGE TEMPERATURE
2
TEMPERATURE
COEFFICIENT
3
4
5
6
7
FIXING STRENGTH
RESISTANCE TO SOLDERING
HEAT TEST
SOLDERABILITY TEST
HUMIDITY TEST
THERMAL SHOCK TEST
CONDITIONS
-40 ~ +125 ℃
(INCLUDING COIL
TEMPERATURE RISE)
-40 ~ +125 ℃
-30 ~ +105 ℃
0 ~ 2000ppm/℃
SAMPLE IS PUSHED IN THREE
DIRECTIONS O,Y AND Z WITH
FORCE OF 5. ON FOR 10±5
SECONDS.AFTER SOLDERING
BETWEEN COPPER PLATE AND
ELECTRODES.
NO ELECTRODE
DETACHMENT.
REFER TO THE SPEC
“STD-001NP”
NO MECHANICAL
BREAKAGE.DEVIATION
RELATIVE TO INITIAL
VALUE:L:WITHIN ±5.0%
IMMERSE THE ELECTRODE IN
FLUX FOR 5 SECONDS.THEN DIP
THE
ELECTRODE
INTO
A
SOLDERING BATH OF 245±5 ℃
FOR 2±0.5 SECONDS.
OVER 95% OF THE
SURFACE BEING
IMMERSED SHALL BE
COVERED WITH NEW
SOLDER UNIFORMLY.
TEMPERATURE:60℃±2℃
HUMIDITY:90%~95%RH
DURATION:96±4 HOURS.
DEVIATION RELATIVE TO
INITIAL
VALUE:
L:WITHIN ±5.0%
20 CYCLES OF +105℃ FOR 30
MINUTES,-40℃ FOR 30
MINUTES.CHARACTERISTICS
ARE MEASURED AFTER THE
AMBIENT AIR EXPOSURE OF 1
HOUR.
8
HIGH TEMPERATURE
STORAGE TEST
TEMPERATURE:125℃±2℃
DURATION:96±4 HOURS
9
LOW TEMPERATURE
STORAGE TEST
TEMPERATURE:-40℃±3℃
深圳市益嘉源电子有限公司
SPECIFICATION
Tel:0755-27803896
INITIAL VALUE:
L:WITHIN ±5.0%
Mob:(86)13682526134
-3-
SMD Power Inductors
-YSMC2016S Series
■ Reflow profile for SMT components
■ Reflow is referred to standard IPC/JEDEC J-STD-020D
Profile Feature
Lead(Pb) Free solder
Preheat and Soak
Temperature Min.(Tsmin)
150℃
Temperature Max.(Tsmax)
200℃
time(Tsmin to Tsmax)(ts)
60-120 Seconds
Average ramp up rate Tsmax to Tp
3℃/Second Max.
Liquidous temperature(TL)
217℃
Time(TL)maintained above TL
60-150 Seconds
Peak package body temperature(Tp)
Table2
Time(tp)*within 5℃ of the specified classification
30*seconds
Temperature(Tc)
Average Ramp-down rate(Tp to TL)
6℃/second max
Time 25℃ to peak temperature
8 minutes max.
Table2.Pb-Free Process-Classification Temperatures(Tc)
Package Thickness
Volume mm³ <350
Volume mm³ 350~2000
Volume mm³ >2000
<1.6mm
260℃
260℃
260℃
1.6mm – 2.5mm
260℃
250℃
245℃
>2.5mm
250℃
245℃
245℃
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-4-
SMD Power Inductors
-YSMC2016S Series
■ Taping Dimensions(Unit:mm)
TYPE
W
A
B
C
D
E
P
K
Ref
T
MPQ
YSMC2016S
8.0±0.1
2.35±0.05
2.8±0.05
2.75
3.5±0.05
1.35±0.05
4.0±0.1
1.35
0.25±0.05
3000
■ Reel Dimensions(Unit:mm)
TYPE
W
W1
W2
W3
A
B
C
D
YSMC2016S
178±2.0
12.8±1.50
14.4MAX
8.4 Min
13.0±0.50
21.0±0.80
2.0±0.50
100 Min
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-5-
SMD Power Inductors
-YSMC2016S Series
■ Direction of rolling
■ Cover tape peel off condition
Cover tape peel force shall be 0.1N to 1.3N.
Reference peel speed 300±10mm/min.
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-6-
很抱歉,暂时无法提供与“YSMC2016S-R47M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.51930
- 50+0.40972
- 150+0.35498
- 500+0.31392
- 3000+0.28113
- 6000+0.26469
