YLCM1006C-470T
YLCM1006C-470T
    YJYCOIN(益嘉源)
    SMD,10x8.7mm
    800Ω@100MHZ 47UH@100KHZ 3.2A 40MΩ
YLCM1006C-470T 数据手册
Wire Wound Common Mode Choke -YLCM1006C Series ■ Features ● SMD construction,and low profile. ● High Impedance and Excelletn Frequency Characteristic. ● Self Electromagnetic Shielding. ● Low Magnetic Flux Leakage. ■ Applications ● LED Light,TV game,Monitor,etc. ● EMI common-mode noise. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance Value ⑷ :Taping ■ Shapes and Dimensions (Unit:mm) TYPE A B C Max D E F YLCM1006C 10.0±0.5 8.7±0.5 6.5 6.22±0.1 7.62±0.1 1.4 Ref 深圳市益嘉源电子有限公司 http://www.yjycoin.com -1- Wire Wound Common Mode Choke -YLCM1006C Series ■ Circuit Diagram ■ YLCM1006C Series Part Number Inductance L1=L2(uH) @100KHz/0.1V DC Resistance (mΩ)Max. Rated Current (A)Max. Hi-Pot (Vac) 3mA/1S Impedance (Ω)Min. Freq. Range (MHz) YLCM1006C-100T 10±40% 30 4.00 600 100 10~300 YLCM1006C-220T 22±40% 35 3.80 600 300 10~200 YLCM1006C-470T 47±40% 40 3.20 600 800 10~100 YLCM1006C-101T 100±40% 25 3.00 1000 100 10~300 YLCM1006C-121T 120±40% 25 2.50 1000 200 10~200 YLCM1006C-201T 200±40% 15 3.00 1000 300 7~150 YLCM1006C-221T 220±40% 32 2.20 1000 350 7~150 YLCM1006C-251T 250±40% 35 2.00 1000 400 5~100 YLCM1006C-471T 470±40% 65 1.60 1000 900 2~40 YLCM1006C-501T 500±40% 70 1.50 1000 800 2~5 YLCM1006C-102T 1000±40% 180 0.95 1000 1400 1~40 YLCM1006C-202T 2000±40% 270 0.80 300 2000 0.5~15 YLCM1006C-222T 2200±40% 300 0.75 300 3400 1~11 YLCM1006C-302T 3000±40% 330 0.70 300 3000 0.5~10 YLCM1006C-332T 3300±40% 360 0.65 300 4400 0.9~7 YLCM1006C-392T 3900±40% 540 0.52 300 5000 0.7~6 YLCM1006C-402T 4000±40% 600 0.45 300 4000 0.5~5 YLCM1006C-472T 4700±40% 720 0.35 300 6200 0.6~3 YLCM1006C-502T 5000±40% 780 0.30 300 5000 0.5~3 1. Rated Current:Temp.rise 40℃ Typ 2. Operating Temperature:-20℃ up to +125℃ 3.Storage Temperature:-20℃ up to +40℃,75% RH max. 深圳市益嘉源电子有限公司 http://www.yjycoin.com -2- Wire Wound Common Mode Choke -YLCM1006C Series ■ Materlal List NO. ITEM DESCRIPTION 1 CORE FERRITE 2 CASE DAP-WH9100 3 WIRE P180 Grd1 4 SOLDER Sn99.3:Cu0.7 5 ADHESIVE XNR-3614 6 INK WHITE ■ Reliability Testing Operating Temperature - 20 to + 125 ℃ ( Contain Heating coil ) Appearance Inspection No external defects by visual inspection Terminal Strength After soldering , between copper plaet and terminals of coils , push in two directions of X , Y with standing 10N(1.02kg) for10+/-2 sec. Terminal should not peel off. ( Refer to figure at right ) Heat endurance of reflow Refer to figure soldering Insulating resistance Over 100 MΩ at 100V D.C . between wire and core . Dielectric Strength Apply at 0.5KV 3mA for 1 minute between wire and core . Temperature characteristics Inductance coefficient ( 0~2,000 ) × 10 / ℃( - 20 ~ + 125 ℃ ) Humidity characteristics Inductance deviation within ± 10% , after 96 hours in 90~95% relative humidity at 40 ± 2 ℃ and 1 hours drying under normal condition . A test is made under the above mentioned condition , and it is kept for 2 hours in the normal 深圳市益嘉源电子有限公司 http://www.yjycoin.com -3- Wire Wound Common Mode Choke -YLCM1006C Series ■ Recommended soldering temp.Graph IR Reflow profile Temperature and humidity. After that,no mechanical and electrical defect should be found. ■ Taping Dimensions(Unit:mm) TYPE W A B D P K T MPQ YLCM1006C 24.0±0.3 10.6±0.3 11. 5±0.1 11.5±0.1 16±0.1 5.0±0.1 0.40±0.05 800 深圳市益嘉源电子有限公司 http://www.yjycoin.com -4- Wire Wound Common Mode Choke -YLCM1006C Series ■ Reel Dimensions(Unit:mm) TYPE W W1 A B C D YLCM1006C 330±2.0 24.4±1.5 30.4MAX 23.9 Min 13.0±0.50 21.0±0.80 ■ Direction of rolling 深圳市益嘉源电子有限公司 http://www.yjycoin.com -5- Wire Wound Common Mode Choke -YLCM1006C Series ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com -6-
YLCM1006C-470T 价格&库存
很抱歉,暂时无法提供与“YLCM1006C-470T”相匹配的价格&库存,您可以联系我们找货
