ESDSRVLC05-4
ESDSRVLC05-4
    YINT(音特电子)
    SOT-23-6
    ESD 5V截止
ESDSRVLC05-4 数据手册
ESD Protection Diode ESDSRVLC05-4 Trustworthy electronic circuit protection expert ESDSRVLC05-4 Description The ESDSRVLC05-4 has ultra low capacitance rail-to-rail diodes with an additional zener diode fabricated in a proprietary silicon avalanche technology to protect each I/O pin providing a high level of protection for electronic equipment that may experience destructive electrostatic discharges (ESD). These robust diodes can safely absorb repetitive ESD strikes at the Functional Diagram maximum level (level 4) specified in the IEC 61000-4-2 international standard without performance degradation. Their very low loading capacitance also makes them ideal for protecting high speed signal pins such as HDMI,DVI,USB2.0, and IEEE 1394. Features ●Case :JEDEC SOT-23-6L package ●Low clamping voltage ●Small packaging options saves board space Rail-to-Rail Protection ●Low capacitance :0.9 pF typical ●Protection for 4 Lines ● Compatible with IEC 61000-4-2(ESD) :Air 18KV , Contact 13KV ●Compatible with IEC 61000-4-5(Surge):5.5A ,8/20 uS - level 2 (line-GND)&Level 3 (Line-Line) Applications ●USB Power and Data Line Protection ●10/100/1000 Ethernet ●Video Graphics Cards Dual USB Port Protection ●SIM Ports ●ATM Interfaces ●Montors and Flat Panel Displays ●Digital Video Interface(DVI) ●IEEE 1394 Fire wire Ports www.yint.com.cn 1 Rev:19.3 ESD Protection Diode ESDSRVLC05-4 Trustworthy electronic circuit protection expert Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Symbol Value Units Peak Current (tp =8/20μs) PPK 150 W Peak Current (tp =8/20μs) IPP 5.5 A IEC61000-4-2 (Contact) VESD ±13 KV IEC61000-4-2 (Air) VESD ±18 KV Lead Soldering Temperature TL 260 (10 sec) °C Operating Temperature TJ -50 to 125 °C Storage Temperature Range TSTG -50 to 150 °C Electrical Characteristics (TA = 25 °C unless otherwise noted) Parameter Symbol Reverse Stand-off Voltage VRWM Reverse Breakdown Voltage VBR Reverse Leakage Current Clamping Voltage IR VC CJ1 Junction Capacitance CJ2 www.yint.com.cn Conditions Min. Typ. Max. Any I/O pin to ground It = 1mA Any I/O pin to ground 5 6 1 μA 8.5 12 V 0.35 0.45 pF 0.9 pF Any I/O pin to ground tP=8/20μs Any I/O pin to ground VR=0V, f = 1MHz Between I/0 pins VR=0V, f = 1MHz Any I/O pin to ground 2 V V VRWM =5.0V, T=25℃ IPP = 1A, Units Rev:19.3 ESD Protection Diode ESDSRVLC05-4 Trustworthy electronic circuit protection expert Characteristics Curves www.yint.com.cn 3 Rev:19.3 ESD Protection Diode ESDSRVLC05-4 Trustworthy electronic circuit protection expert ACKAGE OUTLINE DIMENSIONS in millimeters:SOT23-6L Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. www.yint.com.cn 4 Rev:19.3
