SRT20L150SCT-FCT-DC-CS
Trench MOS Barrier Schottky Rectifier
Reverse Voltage - 150 V
Forward Current - 20 A
Features
Very low forward voltage
High current capability
High forward surge capability
Low power losses High efficiency
Guarding for over voltage protection
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: TO-220AB/CT TO-220F/FCT TO-263/DC,TO-252/CS
Solder bath temperature275℃maximum,10s per JESD22-106
Primary Characteristic
Io
20A
VRRM
150V
IFSM
220A
VF
0.63V
TJ Max
150°C
Maximum Ratings (Per Leg) at Ta=25°C unless otherwise specified
Parameter
Symbols
Value
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
150
V
Maximum RMS voltage
VRMS
150
V
Maximum DC Blocking Voltage
VDC
150
V
Io
A
Maximum Average Forward Rectified Current
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
IFSM
220
A
Operating Temperature Range
TJ
-50 ~ +150
°C
TSTG
-50 ~ +150
°C
RθJA/ RθJC
2/4
°C/W
Storage Temperature Range
Typical Thermal Resistance
(Note1)
Note1: Thermal resistance from Junction to case per leg mounted on heatsink.
Electrical Characteristics (Per Leg) unless otherwise specified
Characteristics
Symbols
at IF=3A
at IF=5A
at IF=10A
Maximum Reverse Current at VR=150V
Units
Max
TA=25°C
0.62
0.65
TA=125°C
0.51
0.69
TA=25°C
VF
V
TA=125°C
0.56
TA=25°C
0.77
0.84
TA=125°C
0.63
TA=25°C
2
10
uA
1.5
mA
TA=125°C
Note2:Pulse test: 300 μs pulse width, 1 % duty cycle
www.yfwdiode.com
Value
Typ
Forward Voltage Drop(Note2)
IR
1/4
GuangDong YFW Electronics Co, Ltd.
Ratings and Characteristic Curves
TA=125℃
TA=25℃
Marking On The Body
Ordering Information
Part Number
Package
Unit Weight
Base Quantity
Delivery mode
SRT20L150SCT
TO-220AB
0.07oz(1.96g)
50 pcs / tube
1000pcs/box 5000pcs/carton
SRT20L150SFCT
TO-220F
0.06oz(1.74g)
50 pcs / tube
SRT20L150SDC
TO-263
0.04oz(1.16g)
50 pcs / tube
SRT20L150SDC-R
TO-263
0.04oz(1.16g)
800 pcs / reel
800pcs/box4000pcs/carton
SRT20L150SCS
TO-252
0.011oz(0.32g)
2500 pcs / reel
2500pcs/box12500pcs/carton
Note: For Halogen Free molding compound, add "H" suffix to part number above.
www.yfwdiode.com
2/4
Package Outline Dimensions Millimeters
www.yfwdiode.com
3/4
www.yfwdiode.com
4/4
很抱歉,暂时无法提供与“SRT20L150SCS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.05162
- 50+1.46129
- 500+1.14199
- 1000+0.91827
- 国内价格
- 1+2.40689
- 10+1.93720
- 30+1.73589
- 100+1.48468
- 500+1.37279
- 1000+1.11845
