MBR2045CT-FCT-DC-CS
SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 45 V
Forward Current - 20 A
FEATURES
Low forward voltage
High current capability
High forward surge capability
Low power losses,High efficiency
Guarding for over voltage protection
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: TO-220AB/CT TO-220F/FCT TO-263/DC TO-252/CS
Solder bath temperature275℃maximum,10s per JESD22-106
Primary Characteristic
Io
2*10A
VRRM
45V
IFSM
260A
VF
0.49V
TJ Max
150°C
Maximum Ratings (Per Leg) at Ta=25°C unless otherwise specified
Symbols
Value
Units
Maximum Repetitive Peak Reverse Voltage
Parameter
VRRM
45
V
Maximum RMS voltage
VRMS
45
V
Maximum DC Blocking Voltage
VDC
45
V
Per Leg
Maximum Average Forward Rectified Current
Total
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
IFSM
Operating Temperature Range
Storage Temperature Range
Typical Thermal Resistance (Note1)
TO-220AB,TO-263 TO-220F TO252
10
Io
A
A
TJ
-55 ~ +150
°C
TSTG
-55 ~ +150
°C
RθJA/ RθJC
2/4
°C/W
Value
Units
Note1: Thermal resistance from Junction to case per leg mounted on heatsink.
Electrical Characteristics (Per Leg) unless otherwise specified
Characteristics
Symbols
Forward Voltage Drop(Note2)
at IF=3A
at IF=5A
at IF=10A
Maximum Reverse Current at VR=45V
TA=25°C
TA=125°C
TA=25°C
VF
Typ
Max
0.42
0.34
0.46
V
TA=125°C
0.41
TA=25°C
0.56
0.60
TA=125°C
0.49
TA=25°C
40
100
uA
12
mA
TA=125°C
IR
Note2:Pulse test: 300 μs pulse width, 1 % duty cycle
www.yfwdiode.com
1/4
Dongguan YFW Electronics Co, Ltd.
MBR2045CT-FCT-DC-CS
RATINGS AND CHARACTERISTIC CURVES
8.3ms Single Half Sine Wave
JEDEC Method
TA=125℃
TA=125℃
TA=25℃
TA=25℃
Marking on the body
Ordering information
Part Number
Package
Unit Weight
Base Quantity
Delivery mode
MBR2045CT
TO-220AB
0.07oz(1.96g)
50 pcs / tube
1000pcs/box 5000pcs/carton
MBR2045FCT
TO-220F
0.06oz(1.74g)
50 pcs / tube
MBR2045DC
TO-263
0.04oz(1.16g)
50 pcs / tube
MBR2045DC -R
O-263
0.04oz(1.16g)
800 pcs / reel
800pcs/box4000pcs/carton
MBR2045CS
TO-252
0.011oz(0.32g)
2500 pcs / reel
2500pcs/box 12500pcs/carton
Note: For Halogen Free molding compound, add "H" suffix to part number above.
www.yfwdiode.com
2/4
MBR2045CT-FCT-DC-CS
Package Outline Dimensions millimeters
www.yfwdiode.com
3/4
MBR2045CT-FCT-DC-CS
www.yfwdiode.com
4/4
很抱歉,暂时无法提供与“MBR2045CS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.35616
- 50+1.05732
- 150+0.92924
- 500+0.76950
- 2500+0.69628
- 5000+0.65351
- 国内价格
- 1+1.13300
- 100+0.87560
- 1250+0.74030
- 2500+0.68640
- 国内价格
- 5+1.40372
- 50+1.09003
- 500+0.78784
- 1000+0.77602
- 2500+0.71088
