PHV12-1.0K5000NR
PHV12-1.0K5000NR
    BELLNIX
    DIP7 模块
    高电压 - 非隔离模块 直流转换器 1 输出 -1000V 5mA 10.8V - 16.5V 输入
PHV12-1.0K5000NR 数据手册
Bellnix High Voltage Output, World's Minimum Size, Non-isolated Type DC-DC Converter 3.5 Watt PHV Series High Voltage Output 0-350V High Voltage DC-DC Converter Input: 12V    Output: 350V - Low Ripple Noise Adjustable - 5-Side Metallic Shield Case Input V Input I Output V Output I Line Reg Ripple/ Noise Vdc mA (typ.) mA % (typ.) mVpp(typ.) 10.8-16.5 430 Vdc 0 to +350 0 to -350 0-10 0.01 100 Note: ON/OFF Control is optional. Please add suffix "R" when placing orders. 1 0.5 - Remote ON/OFF Control φ0.8 - Short Circuit, Over-Current 40 Protection 60 40.64 - Non-Isolated Type Between Input and Output  -10°C to +50°C - RoHS Compliance 7 1 2 3 4 5 5.08×4 (Temp Derating Required for 40°C) 2 -Vin Load C2 Vout(com) 6 Vcont ON/OFF Vref 5 (9.68) (12.38) - Operating Temp Range 7 PHV C1 SW1 Open=ON Short=OFF 5 5 20.32 (9.84) 5 5 12V 11.5typ. (optional) - High Reliability, Long-life HVout +Vin 15 - Output Voltage 0%-100% Models 3.5W PHV Series PHV12-350S10P PHV12-350S10N 3 4 C1=47µF C2=4700pF (Open) Pin 1 2 3 4 5 6 7 40 - Minimum Size 1/5-1/6 6 Function +Vin -Vin Vcont Vref On/Off Vout(Com) HVout Output Voltage Control (impress 0V-6V) ON/OFF is optional Weight: 72g typ. Units: mm - Note! This catalogue is an outline of the products. - Note! When designing, be sure to refer to the data sheets. 5 Watt PHV Series Option Pin High Voltage Output 0-2KV High Voltage DC-DC Converter Input: 12V   Output: 500V, 1000V, 2000V - Low Ripple Noise Models Input V Input I Output V Output I Line Reg Ripple/ Noise Vdc mA (typ.) Vdc 0 to +500 0 to -500 0 to +1000 0 to -1000 0 to +2000 0 to -2000 mA % (typ.) mVpp(typ.) - High Reliability, Long-life 5W PHV Series PHV12-0.5K10000P PHV12-0.5K10000N PHV12-1.0K5000P PHV12-1.0K5000N PHV12-2.0K2500P PHV12-2.0K2500N - Short Circuit, Over-Current Note: ON/OFF Control is optional. Please add suffix "R" when placing orders. - Minimum Size 1/7-1/9 - Output Voltage 0%-100% Adjustable - 5-Side Metallic Case - Remote ON/OFF Control (optional) 10.8-16.5 580 0-10 0-5 0.01 1 40 5 5 5 5 60 40.64 (12.38) 5.08×4 7 1 2 3 4 5 6 - Note! This catalogue is an outline of the products. - Note! When designing, be sure to refer to the data sheets. Option Pin +Vin HVout 7 PHV C1 2 SW1 Open=ON Short=OFF (9.68) 1 - RoHS Compliance 20.32 (9.84) -10°C to +50°C (Temp Derating Required for 40°C) -Vin C2 Load Vout(com) 6 Vcont ON/OFF Vref 5 4 3 C1=47µF C2=4700pF (Open) Output Voltage Control (impress 0V-6V) 40 - Operating Temp Range 12V 11.5typ. φ0.8 160 20 0.5 - MTBF 380,000Hrs 80 0-2.5 Protection - Non-Isolated Type Between Input and Output 60 Pin Function 1 +Vin 2 -Vin 3 Vcont 4 Vref 5 On/Off 6 Vout(Com) 7 HV out Units: mm Weight: 94g typ. ON/OFF is optional
PHV12-1.0K5000NR 价格&库存
很抱歉,暂时无法提供与“PHV12-1.0K5000NR”相匹配的价格&库存,您可以联系我们找货
