BLC05-12W25
BLC05-12W25
    BELLNIX
    SMD7 模块
    隔离模块 直流转换器 2 输出 12V -12V 250mA,250mA 4.5V - 9V 输入
BLC05-12W25 数据手册
Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b ■ Overview The BLC series isolated-type DC-DC converters feature a small package (23.2x21.1x9.7mm) and light weight (5.4g) capable of 6W output. As ultralow noise and extremely high efficiency are made possible by a new circuit, it is ideal for an analog circuit as well as an analog and digital hybrid circuit. ■Model/Rating ■ Features - Ultra low noise - Adjustable Output Voltage - ON/OFF Control - Dual power supply usable as single power supply - Withstand voltage AC500V - Over Current Protection Circuit - No tantalum capacitor or electrolytic capacitor used - Covered with a metal shield - Surface Mount Package - No heat sink needed - Operating Temp Range -40°C to +85°C (Temperature derating required) - RoHS Compliant Table 1 Models BLC Series Input V Vdc BLC05-05S100 Output V Vdc Output I mA 5 0 to 1000 Ripple Line Reg. Load Reg. Efficiency Noise mV(max.) mV(max.) %(typ.) mVpp(typ.) 20 40 8 77 4.5 to 9 BLC05-12S50 12(15) 0 to 500(400) 40 100 8 80 BLC05-12W25 ±12(±15) 0 to 250(200) 80 600 8 80 Note 1: Output voltage in parentheses is when Vadj and –Vout are short-circuited. Note 2: Output current in parentheses is at the maximum output voltage. Note 3: Ripple noise and efficiency are at 5V input voltage and load rating. Note 4: Ripple noise is measured at 20MHz bandwidth, with a multi layered ceramic capacitor with 10μF at input and 0.47μF at output ■ Specifications Input voltage range Table 2 Refer to Table 1 Rated output voltage 5.0V±3%, 12V±3% , ±12V±5% (When Vadj terminal is open) Adjustable output voltage range 4.75 to 6.0V (5.0V model), 11.4 to 15V (12V model), ±11.4 to ±15V (±12V model) Line regulation Refer to Table 1 (Rated output, Input voltage varying in the range of Table 1) Load regulation Refer to Table 1 (Rated input/output, Load varying from 0 to 100%, ±output loaded evenly) Temperature regulation 40mV typ.(5.0V model), 100mV typ. (12V model), 150mV typ. (±12V model) (Rated input/output, for within ambient temperature range with 100% load at temperature derating) Ripple noise Refer to Table 1 (Rated input/output, common temp, measurement frequency bandwidth 20MHz) Efficiency 77% to 80% typ. (Rated input/output, Common temp., Refer to Table 1) Over current protection Operate at 105% or above of rated load current. Auto restart type. Over voltage protection None Under Voltage Lock Out Yes Input over current protection None Remote ON/OFF control Between 2Pin (-Vin) and 3Pin (ON/OFF): Output is ON when open, output is OFF when short. Standby current 4mA max. Withstand voltage Between input and output, input and case, output and case: AC500V/per minute. Insulation resistance Between input and output, input and case, output and case: 50MΩ or more (at DC500V) Capacitance between P and S Approx. 40 to 90pF (depending on the model) Operating temp range Operating temperatures −40°C to +85°C (Refer to temp derating in the datasheet) Storage temp range Storage temperatures -40°C to +85°C Humidity range 20 to 95%R.H. (Max. wet bulb temp 35°C with no condensation) Storage conditions Below 30°C/60% R.H. before mounting the converter Cooling conditions Natural cooling (install in a well-ventilated place) Vibration 10 to 55Hz Total amplitude 1.52mmp-p (2H for each of three directions) Sweep time 15 min Impact Acceleration 100G (3 times for each of three directions, total 18 times) Duration 6ms Weight 5.4g typ. Outer dimensions W=23.2 L=21.1 H=9.7 typ.(mm)(For dimensional details, refer to the shape and dimensions in the datasheet) *The above specifications are provided with rated input/output and ambient temperature 25°C±5°C, unless otherwise specified. *The contents provided in this datasheet may be changed at any time without prior notice. 1 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 1. Scope These specifications shall apply to DC input, isolated type DC-DC converter BLC05 series. 2. Model/Rating Model name Rated input voltage Rated output Shape Remarks BLC05-05S100 BLC05-12S50 BLC05-12W25 5.0V, 1000mA 12.0V, 500mA DC5.0V SMD ±12V, each 250mA Unless otherwise mentioned in these specifications, input shall be rated input, output shall be rated output, and ambient temperature shall be 25°C±5°C. 3. Environmental conditions 3-1 Temperature range In operation In storage 3-2 Humidity range In operation In storage −40°C to +85°C (Derating required) −40°C to +85°C 20 to 95%R.H. (However, max. wet bulb temperature 35°C, no condensation) 20 to 95%R.H. (However, max. wet bulb temperature 35°C, no condensation) Note) Store in a place below 30°C and 60% R.H. before mounting. 2 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 4. Specifications & Standards This product complies with RoHS Directive and Bellnix Environmental Management Regulations. 4-1 Input conditions and output characteristics *1 Output voltage stability*2 Output ripple noise *3 Temp. mVp-p mV typ. typ. / max. Input voltage V Output voltage V Output current mA Input mV max. Load mV max. BLC05-05S100 4.5 to 9.0 5±3% 0 to 1000 20 40 40 BLC05-12S50 4.5 to 9.0 12±3% 0 to 500 40 100 BLC05-12W25 4.5 to 9.0 ±12±5% 0 to 250×2 80 600 Model name Efficiency % typ. 77 100 8/ 20 8/ 20 150 8/ 20 80 80 *1 With the measurement circuit of 4-4. Unless otherwise mentioned, input and output values are rated and ambient temperature shall be 25°C±5°C. *2 Input: Input voltage varying from min. to max. Load: Output current varying from 0 to rated. Temperature: Ambient temperatures varying from -40 to Tamax. Within ambient temperature range with 100% load at temperature derating of 4-3. A two output product is when + output current and – output current are equal. *3 Frequency bandwidth 20MHz measured at both ends of external capacitor (C2, or C4, C5). 4-2 Capacitance of external capacitor This product has a limited capacitance for external output capacitors. Limit a capacitance of the external capacitor as follows: Model name BLC05-05S100 BLC05-12S50 BLC05-12W25 External output capacitor Capacitance Plus output side Minus output side *1 0 to 220μF — *1 0 to 100μF — *2 *3 0 to 100μF 0 to 100μF *1 Total of C2 and C3 in the Standard Connection Circuit of 6-1 *2 Total of C2 and C4 in the Standard Connection Circuit of 6-2 *3 Total of C3 and C5 in the Standard Connection Circuit of 6-2 3 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 4-3 Temperature derating 自然空冷 Natural cooling 100 80 負荷率(%) Load rate (%) 60 40 20 0 -40 -30 -20 -10 0 10 20 40 30 60 50 70 80 Ambient temperature (°C) 周囲温度(℃) Note) at rated output 4-4 Measurement circuit 1 +Vin +Vin C1 +Vout 7 V V -Vout BLC-S Series 6 A 2 NC 3 ON/OFF 5 Vadj SW2 A V V Common BLC-W Series 6 A 2 V -Vin SW1 -Vout 3 ON/OFF Vadj +Vout -Vout Coaxial cable 同軸ケーブル:50Ω 1.5m Rx:51Ω Cx:0.1μF SW1 Output ON Open:出力=ON Load Shrt:出力=OFF Output OFF SW2 Open:Vout=5V Shrt:Vout=5V→6V (Multi-layered ceramic capacitor) C1=10μF(積層セラミック) (Multi-layered ceramic capacitor) C2=0.47μF(積層セラミック) 4 +Vout 7 1 +Vin C3 A -Vin SW1 +Vin C2 5 C4 Load C5 Load A SW1 Output ON Open:出力=ON Output OFF Shrt:出力=OFF SW2 Open:Vout=±12V Shrt:Vout=±12V→±15V (Multi-layered ceramic capacitor) C3=10μF(積層セラミック) (Multi-layered ceramic capacitor) C4,C5=0.47μF(積層セラミック) 4 SW2 OSC Cx Rx オシロスコープ Oscilloscope (Measurement (リップル・ of ripple noise) ノイズの測定) GND 4 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 4-5 Additional functions Item Over current protection circuit Over voltage protection circuit Adjustable output voltage range ON/OFF control Specifications & Standards Operate at 105% or above, auto restart type. None Conditions 4.75 to 6.0V (BLC05-05S100) 11.4 to 15V (BLC05-12S50) ±11.4 to ±15V (BLC05-12W25) Output is ON when OPEN Low (0 to 0.5V, 4mA max.) for output OFF By external resistor Refer to 7-3 Refer to 7-1 4-6 Withstand voltage and Insulation resistance 1) Withstand voltage Between input and output, input and case, output and case: AC500V/per min 2) Insulation resistance Between input and output, input and case, output and case: 50MΩ or more (at DC500V) 5. Outer dimensions and description of terminals 5-1 Shape and dimensions 21.1±0.5 1 Pin mark 1ピンマーク 23.2±0.5 Bdllmiw Company logo 会社ロゴ 1 ISOLATED DC-DC CONVERTER 33 BLC-W +Vin -Vin -Vin 製品型名 Model name 3 ON/OFF ON/OFF Lot No. 4 Vadj Vadj 5 NC -Vout 6 -Vout Common 7 +Vout +Vout Top View 0.25 min. 10 max. Function BLC-S +Vin 2 BLC05-05S100 Side View 5.08 3 4 5.08 2 5 5.08 6 5.08 1.8±0.2 CL 10.16 CL 1.5±0.1 Pin Materials of terminals and case Terminal pin------ Material: Copper Plating: Nickel plating followed by Gold plating Case ------ Material: Nickel silver - Unit: mm - Dimensional tolerance (unless specified):±0.3 - Weight: 5.4g typ. - Tolerance on terminals 0.2 mm max. (Max. lifting of the terminal part when placed on a plane) 7 1 20.1 Bottom View 5 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 2.1 5-2 Recommended footprint dimensions 2.6 CL 7 5.08 CL 5.08 6 5 3 4 5.08 2 5.08 10.16 1 20.1 Note) Recommended dimensions are shown above. Use your design standard for your specific design. 5-3 Lot indication 3 1 (Manufactured in January 2013) (2013年 1月製造) (Manufactured in December 2013) 3 D 2 (2013年12月製造) 製造管理密番(無表示の場合もあり。) Production code for manufacturing control (may not be indicated) 製造月(1~9月=1~9、10月=O、11月=N、12月=D) Manufacturing month (Jan to Sep = 1 to 9, Oct = O, Nov = N, Dec = D) 製造年(西暦末尾1桁) Manufacturing year (the last digit of A.D.) 6. Standard connection circuit 6-1 BLC-S series C2 +Vin SW1 Output ON Open:出力=ON Output OFF Short:出力=OFF Load SW2 Open:Vout=5V,12V Short:Vout=5V→6V =12V→15V C1=22μF C2=22μF C3=0.47μF +Vout 7 1 +Vin C3 C1 -Vout 6 BLC-S Series 2 -Vin NC SW1 3 ON/OFF Vadj 5 SW2 4 6-2 BLC-W series 1 +Vin +Vin +Vout 7 C2 C4 C3 C5 C1 Common BLC-W Series 6 2 -Vin -Vout SW1 3 ON/OFF Vadj 5 4 Load Load SW1 Output ON Open:出力=ON Output OFF Short:出力=OFF SW2 Open:Vout=±12V Short:Vout=±12V→±15V C1=22μF C2,C3=22μF C4,C5=0.47μF SW2 6 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 7. Various functions 7-1 ON/OFF control The ON/OFF control function enables users to control ON/OFF of the output voltage without inputting or cutting it off. Between –Vin terminal (No. 2 pin) and ON/OFF terminal (No. 3 pin) Open (6V max.) : Output ON Short (0 to 0.5V, 4mA max.) : Output OFF +Vin ON/OFF 1 3 or -Vin 2 7-2 Output over current protection If output current has reached over current status, the over current protection circuit is activated lowering the output voltage. (Activating point: 105% or above of the rated load current) The converter should automatically return to normal operation as soon as the over current status is resolved, if this does not occur, turn off the power or turn the output OFF with an ON/OFF control and then reactivate. Holding of over current status for over 30 seconds may result in damage, so resolve over current status within 30 seconds. 7-3. Output Voltage[%] Characteristics in the over current mode 100 Note) A drooping characteristic may be seen in the over current protection state as shown on the left figure. Note that output voltage may not go up if connected to a nonlinear load such as a lamp, motor, etc., or a constant current load. 50 0 0 100 Output Current[%] 7 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b Adjustable Output voltage 7-3-1 Short circuiting Vadj and –Vout terminals Output voltage can be set at the maximum as per the following table by short-circuiting Vadj and –Vout terminals. In case of no variable output voltage, open the terminal. Output voltage for the connection of Vadj terminal Between Vadj and –Vout terminals Model name Open Short BLC05-05S100 5.0V 6.0V BLC05-12S50 12.0V 15.0V BLC05-12W25 ±12.0V ±15.0V 7-3-2 Resistor adjustment control The output voltage is adjustable by inserting a resistor between Vadj terminal and +Vout terminal or –Vout terminal To decrease the output voltage 7 +Vout 7 +Vout BLC-S 4 7 Rb Rb Vadj Load Vo BLC-W To increase the output voltage +Vout 4 6 Com 5 -Vout +Vout Load Vadj Load Vo BLC-S 4 Load Vadj Vo BLC-W 6 4 Ra Load 6 7 -Vout 6 -Vout 5 Com Vo Vadj Ra Load -Vout To increase the output voltage Model name To decrease the output voltage Output voltage: Vo[V], Connecting resistor: Rb[kΩ] Output voltage: Vo[V],Connecting resistor: Ra[kΩ] BLC05-05S10 0 Vo=(49.94Rb+1448.94)/(340.56+10Rb) Rb=(340.56Vo-1448.94)/(49.94-10Vo) Variable range: Vo=4.75V min. Vo=(1448.94+49.94Ra)/(10Ra+240) Ra=(1448.94-240Vo)/(10Vo-49.94) Variable range: Vo=6.0V max. BLC05-12S50 Vo=(17.98Rb+105.86)/(15.63+1.5Rb) Rb=(15.63Vo-105.86)/(17.98-1.5Vo) Variable range: Vo=11.4V min. Vo=(105.86+17.98Ra)/(1.5Ra+7.05) Ra=(105.86-7.05Vo)/(1.5Vo-17.98) Variable range: Vo=15.0V max. Vo=(53.04Rb+539.53)/(60.06+2.2Rb) BLC05-12W25 Rb=(60.06Vo-539.53)/(53.04-2.2Vo) Variable range: Vo=22.8V min. (±11.4V min.) Vo=(539.53+53.04Ra)/(2.2Ra+18.04) Ra=(539.53-18.04Vo)/(2.2Vo-53.04) Variable range: Vo=30.0V max. (±15.0V max.) Note) If output voltage is made variable, use at the maximum power or less. If output voltage is made lower, do not connect Rb to resistor which is less than Vo min. setting resistor value. 8 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 7-4 Activation and deactivation voltage This product has an under voltage lock out function to prevent malfunction when there is low input voltage. The activation voltage and deactivation voltage is within the range shown in the table below. Range of activation and 2.8 to 4.4V deactivation voltage 7-5 Input circuit protection function This input circuit has a built-in fuse to protect the secondary circuit against over current that runs for any reason. Rated current and fusing current of the built-in fuse are as shown in the following table. Power supply should have more current capacity than the following fusing current to ensure a fuse blowout in an emergency. Rated current 5.0A Fusing current 10A or more 8. Protection against reverse connection of input power supply (example) This product may be damaged if erroneously connected with reverse input polarity. To cope with a possible reverse connection, add a protection circuit as shown in the following figure. The following is an example using a fuse and a diode. Fuse +Vin D1 +Vin 1 7 BLC-S Series C1 -Vin +Vout C2 2 6 C3 Load -Vout 9. Common mode noise reduction method (example) To reduce common mode noise of this product, connect a capacitor of 1000pF or so (C4) between the primary and secondary terminals as shown in the following figure. In this case, note that using a capacitor of too much capacitance may result in the increase of coupling capacitance between primary and secondary terminals. Also, select a capacitor in consideration of required withstand voltage. (Noise on the primary side may run through to the secondary side through C4 according to conditions, so check in actual use conditions.) Fuse +Vin D1 +Vin 7 1 BLC-S Series C1 -Vin 2 +Vout C2 6 C3 Load -Vout C4 10. Input feedback noise reduction method (example) Input feedback noise from the convertor can be reduced by designing a Pi filter at input side as shown in the following figure. Add as needed. L1 +Vin +Vin C1 1 7 BLC-S Series C2 -Vin 2 6 9 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 11. Serial operation method (example) Serial operation is possible by wiring this product as per the following figure. Limit the output current not to exceed the smaller rated current of the power supplies connected in series to avoid more current than rating to run into the power supply. +Vin 1 7 +Vout BLC-S Series +Vin -Vin 2 D1 6 -Vout Load +Vin 1 7 +Vout BLC-S Series -Vin 2 D2 6 -Vout Note) This product is not suitable for parallel operation. Schottky diodes of low forward voltage are recommended for D1 and D2. 12. Soldering conditions Observe the following conditions for soldering temperature and time. Flow mounting is not possible for this product. Reflow method Reflow temperature profile In the case of Sn-3Ag-0.5Cu series solder 部品表面温度(℃) Parts surface temperature (°C) A 1.0 ~ 3.0℃/s A' Ty1: Ty2: Ty1 ~ Ty2: B 1.0 ~ 4.0℃/s B' TP: and over 225℃以上: C 1.0 ~ 5.0℃/s TP 225 Ty2 Ty1 A A' B B' 150±10℃ 170±10℃ 40 ~ 100s 245℃max. 20 ~ 40s C Soldering time (s) 半田付け時間(s) Refrain from causing vibration of the product during the reflow. The number of reflows shall be once (no mounting of the reverse side). * Eutectic solder may be used so far as within the above profile condition. 10 DC-DC Converter BDD20170524_A01 Ultra Low Noise, Ultra Compact, Isolated type DC-DC Converter 6Watt BLC05 Series b 13. Vibration and impact tests Vibration 10 to 55Hz Impact Acceleration Impact time 6ms Total amplitude 1.52mmp-p (2H for each of three directions) Sweep time 15 minutes 100G (3 times for each of 3 directions, total 18 times) 14. Cleaning This product is not made for immersible cleaning. Use of no-clean flux is recommended 15. Precautions for use To ensure user’s safety, check specifications before using the product and always observe the following precautions for use. • This product is intended for use in general electronics equipment (office equipment, communication equipment, measurement equipment). Do not use the product for medical equipment, nuclear equipment, trains, etc., whereby human life or property may be directly affected by damaged product. Consult with us for any use other than for such general electronics equipment. • Minor changes and component parts changes that do not affect contents of the specifications will be made due to characteristic improvement of the product and other reasons without prior notice. • This product is not suitable for parallel operation. • Do not use connectors and sockets for mounting the product. Contact resistance may have an adverse effect on the performance. Use the soldering method for mounting on the printed circuit board. • This equipment has a built-in over current protection circuit but avoid a prolonged short circuit which may lead to failure. • This product may be damaged if used under nonstandard electrical conditions or nonstandard environmental conditions including temperature. Ensure use within the standards. • Avoid using this product in a place that generates corrosive gas or is dusty. • This product may be damaged by static electricity. Make sure that the workplace is guarded against static buildup and static electricity on operators by use of proper grounding. • This product has no built-in function for over voltage protection. • This product does not come with a test report. 16. Warranty The warranty term of the product is one year after shipment. Should the product become defective within the warranty period due to our design or workmanship, the product will be repaired free of charge or replaced. However, this warranty does not cover products which have been subjected to unauthorized inner modifications, etc. The scope of our warranty is limited to that of the said product. 17. Contact If you have any further technical questions for this product, please contact us. E-mail: info@bellnix.com URL: http://www.bellnix.com 11 DC-DC Converter BDD20170524_A01
BLC05-12W25 价格&库存
很抱歉,暂时无法提供与“BLC05-12W25”相匹配的价格&库存,您可以联系我们找货
