High Efficiency, Ultra Small Size, Non-Isolated Type POL DC-DC Converter
BSA03
Achieved high efficiency at a low price !
RoHS
1A/2.2A/6A BSA Series
Compliance
High Efficiency, Low Price Step-Down DC-DC Converter
Input: +3.3V, +5V
Input: +12V, +15V, +24V
Input: +24V
- High Efficiency (82%-91%)
- Ultra Small Size
- Adopted Original MCM
- MTBF 1,000,000Hrs
- Low Price
- Simple Structure
- Over-Heat Protection
- Over-Current Protection
- Easy to Use SIP, DIP Type
- Adjustable Output Voltage
- Non-Isolated Type Converter
- Heat Sink Not Required
- Long Life, High Reliability
- Operating Temp Range
-20°C to +70°C
(Temp Derating Required)
BSA24 series
Output: +1.8V (+1.0V to +3.3V)
Output: +3.3V (+3V to +5V)
Output: +12V (+9V to +12V)
Models
BSA Series
BSA03-1.8S6R0
BSA03-1.8S6R0-D
BSA24-3.3S2R2
BSA24-3.3S2R2-D
BSA24-12S1R0
BSA24-12S1R0-D
BSA24
Input V
Output V
Output I
Vdc
3.3
(3-5.5)
24
(9-36)
24
(18-36)
Vdc
1.8
(1-3.3)
3.3
(3-5)
12
(9-12)
A
Line Reg Load Reg Ripple/Noise Efficiency
%(typ.)
0-6
1
1
30
86
1.5
1
50
82
1.5
1
100
91
0-1.8
(0-2.2)
0-0.75
(0-1)
%(typ.) mVpp(typ.)
%(typ.)
Note 1: For DIP type add a suffix "D".
Note 2: External capacitors are required.
Note 3: The output voltage inside the ( ) indicates the adjustable range.
Note 4: The output current inside the ( ) indicates the value with air flow cooling.
Note 5: The BSA03 has requirements for input/ output voltage differences. Depending on conditions, air flow
Note 5: cooling maybe required.
38(+0.8/-0.5)
Bellnix
BSA03-1.8S6R0-D
212
Function
1
2-4
5-8
9-11
12
13-18
ON/OFF
+Vin
GND
+Vout
V.adj
3.5±1.5
2.54×11=27.94
0.25
Weight: 9g typ.
Units: mm
1
12
t 0.25
pin
12
1
13
6.0max.
212
18
0.5
NC
*13-18pin: For DIP type.
2.54×11=27.94
(BSA24 SIP type)
Weight: 9g typ.
Units: mm
3.5±1.5
Bellnix
BSA03-1.8S6R0
3.5typ.
24 max.
21.5(+1/-0.5)
1.0typ.
22.25 typ.
t1.0
38(+0.8/-0.5)
-30°C to +85°C
(-30°C to -20°C :
Startup guaranteed)
BSA03 series
- RoHS Compliance
(BSA03 DIP type)
5.5typ.
21.5(+1/-0.5)
(BSA03 SIP type)
(BSA24 DIP type)
7.2typ.
t 1.0
Weight: 7g typ.
Units: mm
This catalogue is an outline of the products.
Function
1
2-4
5-8
9-11
12
13-18
ON/OFF
+Vin
GND
+Vout
V.adj
1
12
8.5max.
0.25
pin
0.5
NC
22.25 typ.
A24-3-2D
Bellnix
12
2.54×11=27.94
- Note!
13
29
21.5(+1/-0.5)
1
3.5±1.5
0.5
38(+0.8/-0.5)
18
24 max.
A24-3-2
Bellnix
21.5(+1/-0.5)
29
2.0typ.
2.54×11=27.94
t 0.25
4.2typ.
3.5±1.5
38(+0.8/-0.5)
Weight: 7g typ.
Units: mm
When designing, be sure to refer to the
data sheets.
DC-DC CONVERTERS
BDD2008.12A
很抱歉,暂时无法提供与“BSA03-1.8S6R0-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+270.139931+32.68692
- 10+211.8987610+25.63974
- 50+199.2316550+24.10702
- 100+199.23165100+24.10702
- 500+186.42685500+22.55764
- 1000+169.491471000+20.50846
