BSI-5.0S4R0FPA
BSI-5.0S4R0FPA
    BELLNIX
    DIP36_12Pin
    非隔离 PoL 模块 直流转换器 1 输出 5V 4A 6V - 16.5V 输入
BSI-5.0S4R0FPA 数据手册
Bellnix High Efficiency, Ultra Small Size, Non-Isolated Type POL DC-DC Converter RoHS 4A/6A BSI-P Series Compliance Ultra High Efficiency (92%), Minimum Size Step-Down DC-DC Converter Output: +5.0V (+3.0V to +5.0V) Input: +6V, +12V, +15V Models Input V Output V BSI-P Series BSI-5.0S4R0PA BSI-5.0S4R0FPA Vdc Vdc 5.0 (3.0-5.0) 6-16.5 Output I Line Reg Load Reg Ripple/Noise Efficiency A %(typ.) 0-4 0.3 %(typ.) mVpp(typ.) %(typ.) 0.2 50 92 Note 1: When operating at output current 3A-6A, air flow (1m/sec) is required. Note 2: The output voltage inside the ( ) indicates the adjustable range. Note 3: External capacitors are required. Note 4: Suffix "A" stands for version. BSI-5.0S4R0FPA (h=9.3typ) 0.8 2.5typ (Temp Derating Required) Bellnix 5 18 14 0.64 22.86 P2.54×4=10.16 3.0typ 15.24 5.5typ P2.54×4=10.16 Units: mm Weight: 12g typ. Load current: 3A or more Air flow (1m/sec) required. pin Function 1 +Vin 2 2.25+Vin 3 -Vin 4 -Vin 5 ON/OFF 14 V.ADJ 15 -Vout 16 -Vout 17 +Vout 18 +Vout Bellnix 5 1 14 50(+1/-0.5) 18 10.3max C/L 1 t0.8 9.8 max 50(+1/-0.5) - RoHS Compliance 5.5typ 19 C/L 36 0.64 22.86 2.54×4=10.16 20.5(+1/-0.5) (t=8.8typ) BSI-5.0S4R0PA 20.5(+1/-0.5) - Efficiency 92% - Latest Technology, Synchronous Rectification Circuit - Adjustable Output Voltage - Non-Isolated Type Converter - Short Circuit, Over-Current Protection - No Electrolytic Capacitor used No Tantalum Capacitor used - Heat Sink Not Required - Minimum Size - Remote ON/OFF Control - Low Standby Current 100µA - MTBF 1,000,000Hrs - High Reliability, High Performance - Operating Temp Range -10°C to +70°C 2.54×4=10.16 Units: mm Weight: 12g typ. Load current: 3A or more Air flow (1m/sec) required. pin Function 1 +Vin 2 +Vin 3 -Vin 4 -Vin 5 ON/OFF 14 V.ADJ 15 -Vout 16 -Vout 17 +Vout 18 +Vout NC 19 36 NC +Vin 1 FET1 18 +Vout 2 C1 -Vin C3 17 3 PWM.OCP.CONT 16 ON/OFF CONT 4 Load C2 FET2 15 ON/OFF 5 ON = Open OFF= Short (0 to 0.5V) -Vout 14 V.adj Open =5V - External Capacitors C1=100µF20WV× 2 pcs or more (Recommended OS-CON SH, FA type) C2=220µF10WV× 2 pcs or more (Recommended OS-CON SH, FA type) - ON/OFF Control The ON/OFF control is controlled by opening and shortening between 5pin(ON/OFF) and 3, 4pin (-Vin). - Adjustable Output Voltage The output voltage is adjustable by connecting a resistor between 14pin (V.ADJ) and 17, 18pin (+Vout). - Note! This catalogue is an outline of the products. When designing, be sure to refer to the data sheets. When 14pin is open, the rated output voltage is as follows   BSI-5.0S = +5.0V±5%
BSI-5.0S4R0FPA 价格&库存
很抱歉,暂时无法提供与“BSI-5.0S4R0FPA”相匹配的价格&库存,您可以联系我们找货
