BSI-5.0S3R0FA
BSI-5.0S3R0FA
    BELLNIX
    DIP36_12Pin
    非隔离 PoL 模块 直流转换器 1 输出 5V 3A 6V - 16.5V 输入
BSI-5.0S3R0FA 数据手册
Bellnix High Efficiency, Ultra Small Size, Non-Isolated Type POL DC-DC Converter 3A/4A BSI Series RoHS Compliance Ultra High Efficiency (90-95%), Minimum Size Step-Down DC-DC Converter Input: +5V, +12V Input: +6V, +12V, +15V Output: +3.3V (+1.8V to +3.3V) Output: +5.0V (+3.0V to +5.0V) 15.24 21.5max (Temp Derating required) - High Reliability, High Performance - RoHS Compliance Bellnix 1 5 14 18 51max Bellnix 1 5 14 18 0.64 2.25 pin Function P2.54×4=10.16 P2.54×4=10.16 1 +Vin 2 +Vin 3 -Vin Weight: 10g typ. 4 -Vin Units: mm 5 on/off 14 V.ADJ - Externally coated by resinous - Note! 15 -Vout This catalogue is an outline of the products. - Tolerances unless otherwise specified: ±0.5 16 -Vout 17 +Vout When designing, be sure to refer to the 18 +Vout 22.86 FET1 18 2 C1 -Vin 17 3 PWM.OCP.CONT ON/OFF CONT 4 16 C2 FET2 15 ON/OFF 5 ON = Open OFF= Short (0 to 0.5V) 2.54×4=10.16 Weight: 10g typ. Units: mm - Externally coated by resinous - Tolerances unless otherwise specified: ±0.5 pin Function 1 +Vin 2 +Vin 3 -Vin 4 -Vin 5 on/off 14 V.ADJ 15 -Vout 16 -Vout 17 +Vout 18 +Vout NC 19 36 NC - External Capacitors (SH, FA type OS-CON Recommended) 3.3V, 5V Output Product C1=100µF20WV×2pcs or more C2=220µF10WV×1pcs or more - ON/OFF Control 1 0.64 22.86 2.54×4=10.16 data sheets. +Vin 21.5max - Input Voltage Range 4.75V-16.5V Models Input V Output V Output I Line Reg Load Reg Ripple/Noise Efficiency - Output Voltage Range 1.8V-5V BSI Series Vdc Vdc A %(typ.) %(typ.) mVpp(typ.) %(typ.) - Latest Technology,Synchronous BSI-3.3S3R0A 3.3 4.75-13.6 0.2 0.3 91 Rectification Circuit (1.8-3.3) BSI-3.3S3R0FA 0-3 50 - Efficiency 90% to 95% 5.0 BSI-5.0S3R0A 6.0-16.5 0.2 0.2 95 - Adjustable Output Voltage (3.0-5.0) BSI-5.0S3R0FA - Non-Isolated Type Converter Note 1: The output voltage inside the ( ) indicates the adjustable range. - Short Circuit, Over-Current Note 2: External capacitors are required. Protection Note 3: Suffix "A" stands for version. - No Electrolytic Capacitor used No Tantalum Capacitor used (SIP type) (DIP type) - Heat Sink Not Required (h=9.3typ.) BSI-3.3S3R0A (t=8.8typ.) BSI-3.3S3R0FA - Minimum Size (h=9.3typ.) BSI-5.0S3R0A (t=8.8typ.) BSI-5.0S3R0FA - Remote ON/OFF Control - Low Standby Current 100μA 11.3max C/L  (3A output type product) 36 19 10.8 max - MTBF 1,000,000Hrs 51max 0.8 2.5typ - Operating Temp Range C/L 6.5typ -10°C to +70°C ON/OFF control is controlled by opening and shortening between +Vout 5pin(ON/OFF) and 3, 4pin (-Vin). Adjustable Output Voltage C3 Load The output voltage is adjusted by connecting a resistor between 14pin (V.ADJ) and 17, 18pin (+Vout). When 14pin is open, the rated output voltage is as follows: -Vout 14 V.adj Open = 2.5V,3.3V,5V BSI-3.3S = +3.3V±5% BSI-5.0S = +5.0V±5% - A voltage difference of 0.6V or more between the Input/ Output is required for output current 4A type.
BSI-5.0S3R0FA 价格&库存
很抱歉,暂时无法提供与“BSI-5.0S3R0FA”相匹配的价格&库存,您可以联系我们找货
