BTI48-15S100D
BTI48-15S100D
    BELLNIX
    DIP6 模块
    隔离模块 直流转换器 1 输出 15V 1A 18V - 76V 输入
BTI48-15S100D 数据手册
BELLNiX Ultra Small Size, Isolated DC-DC Converter 15 Watt BTI Series RoHS Isolated Compliance Low Isolation Capacitance Wide input voltage range, High efficinecy, Low input / Load regulation Input: 24V, 48V Output: 3.3V, 5V, 12V, 15V, ±12V, ±15V - Industry standard 1 x 1(in) Model BTI Series BTI24-03S400D BTI24-05S300D BTI24-12S130D BTI24-15S100D BTI24-12W65D BTI24-15W50D BTI48-03S400D BTI48-05S300D BTI48-12S130D BTI48-15S100D BTI48-12W65D BTI48-15W50D - Wide input voltage range 4:1 - High efficiency 85% to 90% - 6 sided metal shield cover - Remote ON/OFF control - Isolation voltage DC1500V - Over current protection - Low input voltage protection - Dual power supply usable as single power supply - Operating temp. -40℃ to +85℃ (Temp. derating required) - RoHS compliance - UL/c-UL approved Input V Output V Output P Output I Line Reg. Load Reg. Ripple Noise Efficiency Vdc Vdc 3.3 5 12 15 ±12 ±15 3.3 5 12 15 ±12 ±15 W 13.2 15 15.6 15 15.6 15 13.2 15 15.6 15 15.6 15 A 0 to 4 0 to 3 0 to 1.3 0 to 1 0 to 0.65 0 to 0.5 0 to 4 0 to 3 0 to 1.3 0 to 1 0 to 0.65 0 to 0.5 %(max.) %(max.) mVpp(max.) 0.4 0.4 0.5 1.0 0.4 0.4 0.5 1.0 %(typ.) 85 87 88 88 89 90 85 87 88 88 89 90 9 to 36 18 to 76 70 95 70 95 Note 1: If not indicated, Input V rating, Output V rating, Output I rating, ambient temp. are measured at 25℃±5℃ Note 2: Ripple noise is measured at BW=20MHz. NOTE!! Note 3: Temp. derating and forced air cooling required depending on the ambient temp. conditions. This catalog is an outline of the product. Note 4: Adjustable output voltage range is 2.97 to 3.63V(3.3V products), 4.5 to 5.5V(5V products), 10.8 to 13.2V(12V products) and 13.5 to 16.5V(15V products). When designing, be sure to refer to the Note 5 : The maximum output power of each product is specified as shown in Table above. If the output voltage is raised with the variable output voltage data sheet.     function, reduce the output current to the value specified by the maximum output power. CL 9.9 1 3.5 BTI-S Series Pin Function 1 RC 2 -Vin +Vin 3 4 -Vout 5 TRIM 6 +Vout 20.32 6-φ1.0±0.1 10.16 5.08 4 5 2 (2.54) 1 10.16 25.4 3 7.62 CL Weight : 20g typ. Unit : mm 6 20.32  BTI-S Series (3.3V, 5V, 12V, 15V) Fuse +Vin +Vin 3 4 BTI-W Series (±12V, ±15V) Fuse +Vout +Vin Ra Cin -Vin 2 BTI-S Series 5 TRIM +Vin 3 4 +Vout Load Cin -Vin Load 2 BTI-W Series 5 COM Rb SW1 RC SW1 Open = Output OFF Short = Output ON 1 6 Load SW1 -Vout RC 1 6 -Vout SW1 Open = Output OFF Short = Output ON        - This product has limit to the capacity of external capacitor. Please refer to the data sheet.        - BTI-S Series is rated output voltage with 5pin (TRIM) open. To change the output voltage, connect a resistor to Ra or Rb. BTI-W Series Pin Function 1 RC 2 -Vin +Vin 3 4 -Vout 5 COM 6 +Vout
BTI48-15S100D 价格&库存
很抱歉,暂时无法提供与“BTI48-15S100D”相匹配的价格&库存,您可以联系我们找货
