BELLNiX Ultra Small Size, Isolated DC-DC Converter
15 Watt BTI Series
RoHS
Isolated
Compliance
Low Isolation
Capacitance
Wide input voltage range, High efficinecy, Low input / Load regulation
Input: 24V, 48V
Output: 3.3V, 5V, 12V, 15V, ±12V, ±15V
- Industry standard 1 x 1(in)
Model
BTI Series
BTI24-03S400D
BTI24-05S300D
BTI24-12S130D
BTI24-15S100D
BTI24-12W65D
BTI24-15W50D
BTI48-03S400D
BTI48-05S300D
BTI48-12S130D
BTI48-15S100D
BTI48-12W65D
BTI48-15W50D
- Wide input voltage range 4:1
- High efficiency 85% to 90%
- 6 sided metal shield cover
- Remote ON/OFF control
- Isolation voltage DC1500V
- Over current protection
- Low input voltage protection
- Dual power supply usable as
single power supply
- Operating temp. -40℃ to +85℃
(Temp. derating required)
- RoHS compliance
- UL/c-UL approved
Input V
Output V
Output P
Output I
Line Reg.
Load Reg.
Ripple Noise
Efficiency
Vdc
Vdc
3.3
5
12
15
±12
±15
3.3
5
12
15
±12
±15
W
13.2
15
15.6
15
15.6
15
13.2
15
15.6
15
15.6
15
A
0 to 4
0 to 3
0 to 1.3
0 to 1
0 to 0.65
0 to 0.5
0 to 4
0 to 3
0 to 1.3
0 to 1
0 to 0.65
0 to 0.5
%(max.)
%(max.)
mVpp(max.)
0.4
0.4
0.5
1.0
0.4
0.4
0.5
1.0
%(typ.)
85
87
88
88
89
90
85
87
88
88
89
90
9 to 36
18 to 76
70
95
70
95
Note 1: If not indicated, Input V rating, Output V rating, Output I rating, ambient temp. are measured at 25℃±5℃
Note 2: Ripple noise is measured at BW=20MHz.
NOTE!!
Note 3: Temp. derating and forced air cooling required depending on the ambient temp. conditions.
This catalog is an outline of the product.
Note 4: Adjustable output voltage range is 2.97 to 3.63V(3.3V products), 4.5 to 5.5V(5V products), 10.8 to 13.2V(12V products) and 13.5 to
16.5V(15V products).
When designing, be sure to refer to the
Note 5 : The maximum output power of each product is specified as shown in Table above. If the output voltage is raised with the variable output voltage
data sheet.
function, reduce the output current to the value specified by the maximum output power.
CL
9.9
1
3.5
BTI-S Series
Pin Function
1
RC
2
-Vin
+Vin
3
4
-Vout
5
TRIM
6
+Vout
20.32
6-φ1.0±0.1
10.16
5.08
4
5
2
(2.54)
1
10.16
25.4
3
7.62
CL
Weight : 20g typ.
Unit : mm
6
20.32
BTI-S Series (3.3V, 5V, 12V, 15V)
Fuse
+Vin
+Vin
3
4
BTI-W Series (±12V, ±15V)
Fuse
+Vout
+Vin
Ra
Cin
-Vin
2
BTI-S
Series
5
TRIM
+Vin
3
4
+Vout
Load
Cin
-Vin
Load
2
BTI-W
Series
5
COM
Rb
SW1
RC
SW1
Open = Output OFF
Short = Output ON
1
6
Load
SW1
-Vout
RC
1
6
-Vout
SW1
Open = Output OFF
Short = Output ON
- This product has limit to the capacity of external capacitor. Please refer to the data sheet.
- BTI-S Series is rated output voltage with 5pin (TRIM) open. To change the output voltage, connect a resistor to Ra or Rb.
BTI-W Series
Pin Function
1
RC
2
-Vin
+Vin
3
4
-Vout
5
COM
6
+Vout
很抱歉,暂时无法提供与“BTI24-15W50D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+296.575651+35.88564
- 10+266.9731610+32.30374
- 50+226.7688450+27.43902
- 100+194.96338100+23.59056
