BY05-12W06H
BY05-12W06H
    BELLNIX
    DIP6 模块
    隔离模块 直流转换器 2 输出 12V -12V 65mA,65mA 4.75V - 6V 输入
BY05-12W06H 数据手册
1.5 Watt BY-H Series RoHS High Isolated Compliance 1500 V AC1500V High Isolated Type DC-DC Converter Input: 5V    Output: 5V, ±12V - Additional capacitors are the same as those of BY-SL, BY-WL series. Input V Output V Output I Vdc Vdc 5 ±12 mA 0-200 ±0-65 4.75-6 % (typ.) 0.3 BY-SH 2.54 1 2.54 10 24 15 22.86 12 Φ0.6 Isolated space Units: mm Weight: 17g typ. 13 5.08 5typ. 1.4 9.8 N.P 2.33 2.33 32.6 - Note! Line Reg Load Reg Ripple/Noise Efficiency % (typ.) mVpp(typ.) % (typ.) 0.3 100 60 Note 1: Derating required for input voltage 5.25V or higher. 15.24 (Derating required for 50°C or higher) Models BY-H Series BY05-05S20H BY05-12W06H 11.2 - Isolation Voltage AC1500V - Long-Life with TCT Patent Circuit - 24pin-DIP IC Size - Over-Heat Protection - No Electrolytic Capacitor, No Tantalum Capacitor - Floating Type between Input and Output - 5-Side Metallic shield structure - EMI Line Filter - Over-Current Protection - RoHS Compliance - Operating Temp Range: -20°C to +70°C 20.42 C e -I l u d d C C I I Mo Mo - M M p p i i C C M C h M ti l l Mu C C D D - C C D C -D C D D 型 型 a te d a te d l l 縁 縁 s o s o I I 絶 絶 e s e s i i l l p p p p C C Su Su D D - - e r e r C C w w D D Po Po 圧 圧 e e 高 高 ta g ta g l l 中 中 Vo Vo h h g g H i H i C C D D - A C D C A C D C C C A A ズ ズ N o i s e N o i s e イ イ L o w L o w ノ ノ 低 低 U l t r a U l t r a A C D C A C D C C C D D O u t p u t O u t p u t - C C A A 力 力 M u l t i p l e M u l t i p l e 出 出 多 多 S e m i C u s t o m S e m i C u s t o m e r e r 器 器 fi fi 流 流 R e c ti R e c ti 整 整 D C -D C N o n -I s o l a te d D C -D C Mu ti C h u l e -I C Bellnix High Isolated Type, Small Size DC-DC Converter This catalogue is an outline of the product. When designing, be sure to refer to the datasheet. Pin 1 10 12 13 15 24 Function -Vin -Vout +Vin -Vout +Vout +Vout +Vin BY-WH Pin 1 10 12 13 15 24 Function -Vin -Vout Common +Vin Common +Vout +Vin +Vin C1 -Vin +Vin 24 15 13 BY-SH Series 1 12 10 24 15 +Vout C2 Load -Vout +Vout Load C2 C1 -Vin BY-WH Series 13 12 1 10 Com C3 -Vout Load
BY05-12W06H 价格&库存
很抱歉,暂时无法提供与“BY05-12W06H”相匹配的价格&库存,您可以联系我们找货
